    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Modbus EasyCharge Einstellungen
      Mark @Homoran last edited by Mark
      @homoran said in Modbus EasyCharge Einstellungen:
      @mark sagte in Modbus EasyCharge Einstellungen:
      Error response for FCx3: Illegal Data Address
      hast du noch Leichen auf snderen Tabs des Adapters?
      Ich hab nur den einen modbus adapter und auch nur eine Instanz. Angeschlossen ist auch nur das Board.
      mit den Einstellungen 8,1,even kommt
      modbus.0
      	2025-02-09 21:31:35.192	debug	Cleaning up request fifo.
      modbus.0
      	2025-02-09 21:31:35.190	debug	Clearing timeout of the current request.
      modbus.0
      	2025-02-09 21:31:35.185	info	Disconnected from slave
      modbus.0
      	2025-02-09 21:31:34.178	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      	2025-02-09 21:31:34.173	error	Request timed out.
      modbus.0
      	2025-02-09 21:31:34.171	warn	Error: undefined
      modbus.0
      	2025-02-09 21:31:29.155	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
      modbus.0
      	2025-02-09 21:31:29.153	debug	Initialization of scale factors done!
      modbus.0
      	2025-02-09 21:31:29.148	debug	[DevID_2] Poll start ---------------------
      modbus.0
      	2025-02-09 21:31:29.145	info	Connected to slave
      modbus.0
      	2025-02-09 21:31:29.116	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      	2025-02-09 21:31:28.545	debug	Add holdingRegisters.40035_Temperatur: {"_id":"holdingRegisters.40035_Temperatur","type":"state","common":{"name":"Temperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
      modbus.0
      	2025-02-09 21:31:28.543	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temperatur","description":"Temperatur","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temperatur"}]
      modbus.0
      	2025-02-09 21:31:28.542	debug	Initialize Objects for inputRegs: []
      modbus.0
      	2025-02-09 21:31:28.539	debug	Initialize Objects for coils: []
      modbus.0
      	2025-02-09 21:31:28.537	debug	Initialize Objects for disInputs: []
      modbus.0
      	2025-02-09 21:31:28.216	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
      modbus.0
      	2025-02-09 21:31:27.245	debug	Plugin sentry Initialize Plugin (enabled=true)
      host.michi
      	2025-02-09 21:31:22.951	info	instance system.adapter.modbus.0 in version "6.3.2" started with pid 1209
      host.michi
      	2025-02-09 21:31:21.925	info	"system.adapter.modbus.0" enabled
      admin.0
      	2025-02-09 21:31:15.087	info	<== Disconnect system.user.admin from ::ffff:192.168.188.158 modbus
      admin.0
      	2025-02-09 21:30:59.851	info	==> Connected system.user.admin from ::ffff:192.168.188.158
      wendy2702 Homoran 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @Mark last edited by
        @mark steht das eine Register jetzt bei Holding?
        Wenn ja stelle es mal bei Eingangs Register ein
          Mark @wendy2702 last edited by
          @wendy2702 said in Modbus EasyCharge Einstellungen:
          kommt genau das selbe.
          Egal ob mit none oder even, egal ob als Eingang oder Holding
          • wendy2702
            @mark Probier mal ein anderes Register. Vielleicht geht das eine gerade nicht
              Homoran Global Moderator Administrators @Mark last edited by
              und da steht nur unter holding nur der eine Eintrag?
                Hab schon 40155 probiert. Da müsste eigentlich eine 5 zurückkommen. Geht aber auch nicht
                  Stop!
                  ihr hängt mich ab 😁
                  zuerst kam illegal address
                  in Verbindung mit function code 3.
                  Das ist read holding register
                  also "eigentlich" alles richtig
                  mit even statt none war das weg
                  richtig?
                  M Homoran 2 Replies Last reply Reply Quote 0
                    eben nicht!
                      Stop!
                      ihr hängt mich ab 😁
                      richtig?
                      Ja, richtig.
                      Mit dem egal meinte ich, dass bei even immer das selbe kommt (egal welches Register) und bei none kommt auch das selbe (egal welches Register). Aber even und none produzieren unterschiedliche Fehler
                      • wendy2702
                        wendy2702 @Mark last edited by wendy2702
                        @mark laut deiner Beschreibung ist „none“ richtig.
                        Also damit mal ein Register bei Holding eintragen und log zeigen oder mal a/b tauschen und testen
                          ja das passt!
                          even war laut Registertanelle fettgedruckt = Werkseinstellumg!?
                          Also bleiben wir erst mal dabei.
                          dieses dämliche
                          hatten wir in einem anderen Fall schon mal.
                          Ich kann mich nur nicht erinnern warum, und ob das gelöst wurde
                          • wendy2702
                            wendy2702 @Homoran last edited by
                            @homoran nö, nix Even.
                            Laut seiner Beschreibung—> keine parität
                              Einstellung: none, Holding 40035 mit Abfrage:
                              modbus.0
                              	2025-02-09 21:55:26.201	debug	Cleaning up request fifo.
                              modbus.0
                              	2025-02-09 21:55:26.199	debug	Clearing timeout of the current request.
                              modbus.0
                              	2025-02-09 21:55:26.193	info	Disconnected from slave
                              modbus.0
                              	2025-02-09 21:55:25.193	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                              modbus.0
                              	2025-02-09 21:55:25.187	error	Request timed out.
                              modbus.0
                              	2025-02-09 21:55:25.184	warn	Error: undefined
                              modbus.0
                              	2025-02-09 21:55:20.219	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
                              modbus.0
                              	2025-02-09 21:55:20.217	error	Error response for FCx3: Illegal Data Address
                              modbus.0
                              	2025-02-09 21:55:20.169	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
                              modbus.0
                              	2025-02-09 21:55:20.166	debug	Initialization of scale factors done!
                              modbus.0
                              	2025-02-09 21:55:20.161	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              	2025-02-09 21:55:20.159	info	Connected to slave
                              modbus.0
                              	2025-02-09 21:55:20.141	debug	connect to serial /dev/ttyUSB0 with 9600
                              modbus.0
                              	2025-02-09 21:55:19.578	debug	Add holdingRegisters.40035_Temp: {"_id":"holdingRegisters.40035_Temp","type":"state","common":{"name":"Temp","role":"level","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                              modbus.0
                              	2025-02-09 21:55:19.576	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temp","description":"Temp","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temp"}]
                              modbus.0
                              	2025-02-09 21:55:19.575	debug	Initialize Objects for inputRegs: []
                              modbus.0
                              	2025-02-09 21:55:19.572	debug	Initialize Objects for coils: []
                              modbus.0
                              	2025-02-09 21:55:19.570	debug	Initialize Objects for disInputs: []
                              modbus.0
                              	2025-02-09 21:55:19.249	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
                              modbus.0
                              	2025-02-09 21:55:18.308	debug	Plugin sentry Initialize Plugin (enabled=true)
                              modbus.0
                              	2025-02-09 21:55:18.241	debug	States connected to redis: 127.0.0.1:9000
                              modbus.0
                              	2025-02-09 21:55:18.213	debug	States create User PubSub Client
                              modbus.0
                              	2025-02-09 21:55:18.211	debug	States create System PubSub Client
                              modbus.0
                              	2025-02-09 21:55:18.195	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                              modbus.0
                              	2025-02-09 21:55:18.158	debug	Objects connected to redis: 127.0.0.1:9001
                              modbus.0
                              	2025-02-09 21:55:18.139	debug	Objects client initialize lua scripts
                              modbus.0
                              	2025-02-09 21:55:18.095	debug	Objects create User PubSub Client
                              modbus.0
                              	2025-02-09 21:55:18.092	debug	Objects create System PubSub Client
                              modbus.0
                              	2025-02-09 21:55:18.086	debug	Objects client ready ... initialize now
                              modbus.0
                              	2025-02-09 21:55:18.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                              host.michi
                              	2025-02-09 21:55:14.149	info	instance system.adapter.modbus.0 in version "6.3.2" started with pid 1477
                              host.michi
                              	2025-02-09 21:55:13.101	info	"system.adapter.modbus.0" enabled
                              admin.0
                              	2025-02-09 21:55:05.799	info	<== Disconnect system.user.admin from ::ffff:192.168.188.158 modbus
                              admin.0
                              	2025-02-09 21:54:13.438	info	==> Connected system.user.admin from ::ffff:192.168.188.158
                                Homoran Global Moderator Administrators @wendy2702 last edited by Homoran
                                @wendy2702 sagte in Modbus EasyCharge Einstellungen:
                                aber in der Registerbeschreibung ist die Zeile mit even fettgedruckt = Werkseinstellung
                                und einen Fall mit undefined hatte ich gerade über die Suche gefunden.
                                Da war der Stick defekt 😞
                                • wendy2702
                                  @homoran tolle Dokumentation wenn mal none und mal even angegeben ist.
                                  Vielleicht ist der Stick auch gegrillt nachdem er falsch angeschlossen war.
                                    Man könnte noch
                                    • Leitungen A/B tauschen
                                    • Die Anzahl auf einmal gelesene Register begrenzen
                                      • einige Geräte brauchen das
                                      Würde ich ausschließen. Hab gerade einen 2. (selbe Marke) getestet. Gleiches Ergebnis.
                                        @mark ne Kontrollleuchte hat der nicht?
                                          nein.
                                            @mark Dann bleibt nur Kontakt zum Hersteller der Karte aufnehmrn und dediziert nach den Parametern fragen, und/oder due genannten Möglichkeiten in allen Variationen durchprobierrn.
                                            modbus-adapter
                                            5979
