    4. Test Adapter e3oncan - Viessmann E3 Serie einbinden
      Flatlander @jrbwh last edited by
      @jrbwh Vielen Dank für Deinen Post, habe Deinen e3oncan gleich mal zu installieren versucht, bin aber leider an dieser Fehlermeldung gescheitert:
      Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 8, in <module> import gyp.common File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/common.py", line 435 if CC := os.environ.get("CC_target") or os.environ.get("CC"): ^SyntaxError: invalid syntax
      gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/configure.js:317:18)gyp ERR! stack at ChildProcess.emit (node:events:514:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)gyp ERR! System Linux 4.19.0-27-amd64gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/socketcangyp ERR! node -v v18.17.1gyp ERR! node-gyp -v v11.0.0gyp ERR! not ok
      npm error code 1npm error path /opt/iobroker/node_modules/socketcannpm error command failed
      npm error command sh -c node-gyp rebuild
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-02-06T17_04_50_686Z-debug-0.log
      host.DellE6400 Cannot install MyHomeMyData/ioBroker.e3oncan: 1
      ERROR: Process exited with code 25
      Ich bereibe einen IoB v7.1.5 mit NPM 10.8.2 und Node.js 18.17.1; sollte also aktuell sein.
      Hast Du eine Idee, was da schief lief ?
      Gruß Flatlander.
      jrbwh Thomas Braun 2 Replies Last reply Reply Quote 0
      • jrbwh
        jrbwh @Flatlander last edited by
        @flatlander Das sagt mir grade gar nichts, sorry. Über welchen Weg hast Du denn installiert? Welches Betriebssystem?
        Sieht mir eher nach einem ioBroker-Thema aus als nach einem Problem des Adapters.
        Die aktuelle Version 0.10.4 von e3oncan ist seit 15.01.25 verfügbar, mehr als 40 Mal installiert und mir sind keine Probleme bekannt.
          @jrbwh Ich fahre Ubuntu 24/04 und den Adapter habe ich aus dem ioB- Repository installiert. Habe dann nochmal die Adapter Javascript Ausführung und MQTT-Broker aktualisiert und dann nochmal den ViessmannApi-Adapter installiert - jetzt hat's problemlos geklappt :-)))
          Jetzt muss nur noch der CAN2USB- Adapter kommen...
            Thomas Braun Most Active @Flatlander last edited by
            @flatlander sagte in Test Adapter e3oncan - Viessmann E3 Serie einbinden:
            Die Kombination sieht für mich nach krummer Installation aus.
            Installier die empfohlene Version 20 von nodejs:
            iob nodejs-update
            nodejs@18 läuft ohnehin in wenigen Wochen aus.
              RaspiCan @jrbwh last edited by
              @jrbwh
              Guten Abend,
              habe einen Raspi 4 mit iobroker aufgesetzt, den CANBUS USB Adapter, allerdings wird ein Fehler ausgegeben External CAN Bus was stopped.
              Was könnte die Ursache sein?
              Verkabelung habe ich geprüft, Cat Kabel ist rund 2m lang.
              Vielen Dank für Unterstützung.
              Thomas Braun jrbwh 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @RaspiCan last edited by
                @raspican sagte in Test Adapter e3oncan - Viessmann E3 Serie einbinden:
                Mit dem Einzeiler kan wohl niemand was anfangen.
                Logfile sagt?
                • jrbwh
                  jrbwh @RaspiCan last edited by
                  @raspican Hallo, diese Meldung bedeutet, eine bestehende Verbindung des Raspi zum CAN-Adapter wurde unterbrochen. Eine typische Ursache sind Probleme mit der USB-Verbindung zwischen Raspi und Adapter. Das kann am Kabel liefen oder an den Buchsen. Ich hatte einen Adapter mit schlechter Lötverbindung der USB-Buchse. Da hat bereits eine ungeschickte Berührung des Kabels gereicht und die Verbindung war unterbrochen.
                  Aber auch andere Ursachen sind möglich, z.B. SW-seitig.
                  Wie lange läuft denn die Verbindung stabil? Gibt es typische Begleitumstände, wenn der Verbindung abbricht?
                    RaspiCan @jrbwh last edited by RaspiCan
                    @jrbwh
                    Bisher konnte ich noch keine Verbindung aufbauen, bricht immer mit Fehlermeldung ab.
                    Habe gerade noch einen USB2CAN bestellt, vielleicht hat dieser tatsächlich einen Defekt.
                    Bin absoluter Neuling, seht es mir nach, aber ich bemühe mich.
                    Die LED des Adapters leuchtet rot.
                    Anschluss genau nach Vorgabe CAN L CAN H verdrillt.
                    Muss der Jumper gesetzt oder nicht gesetzt sein?
                    jrbwh 1 Reply Last reply Reply Quote 0
                    • jrbwh
                      @raspican Dann sollten wir zuerst klären, ob der CAN-Bus überhaupt richtig aufgesetzt ist. Bist Du nach dieser Anleitung vorgegangen? Was liefert folgender Befehl im Terminal?
                      ip -details link show can0
                        @jrbwh
                        Habe die einzelnen Schritte in die Kommandozeile kopiert und auf enter gedrückt, gemäß Anleitung.
                        jrbwh R 2 Replies Last reply Reply Quote 0
                        • jrbwh
                          @raspican Ok, der CAN läuft nicht. Da steht state DOWN und can state STOPPED
                          Ein funktionierender CAN liefert z.B. so was:
                          3: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
                              link/can  promiscuity 0  allmulti 0 minmtu 0 maxmtu 0
                              can state ERROR-ACTIVE restart-ms 0
                                    bitrate 250000 sample-point 0.875
                                    tq 250 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1 brp 12
                                    gs_usb: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..1024 brp_inc 1
                                    clock 48000000 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 tso_max_size 65536 tso_max_segs 65535 gro_max_size 65536 parentbus usb parentdev
                          Versuch mal ein sudo ip link set can0 up type can bitrate 250000 und dann nochmal ip -details link show can0
                            RaspiCan @RaspiCan last edited by
                            @raspican
                            Hab nochmal alles auseinander und zusammen gesteckt und jetzt scheint es zu gehen.
                              @raspican
                              • jrbwh
                                @raspican Ja, das sieht gut aus. Dann sollte jetzt auch e3oncan funktionieren.
                                Noch einen schönen Abend!
                                Jürgen
                                  @jrbwh
                                  Vielen Dank für den super Support
                                  Wünsche Dir ebenfalls einen schönen Abend
                                    @jrbwh Der CAN-Bus Adapter ist jetzt eingebaut und funzt auch. Die Instanz wird im IoB auch als verbunden mit Host und Gerät angezeigt aber in den Instanz- Einstellungen kann ich nur die Viessmann ID, pwd, etc. eingeben aber keine Geräteeinstellungen - es gibt keinen Reiter in dm Fenster. Was habe ich falsch gemacht ?
                                    • jrbwh
                                      jrbwh @Flatlander last edited by jrbwh
                                      @flatlander Ich kann nicht ganz folgen. Wo gibst Du Viessmann ID und pwd ein??? Du musst im Tab "CAN Adapter" bei "UDS CAN Adapter" can0 eintragen und den Haken setzen. Dann auf "Speichern" drücken. Die Instanz startet neu und Du bekommst weitere Tabs angezeigt.
                                      Die Vorgehensweise ist im Readme beschrieben.
                                        @jrbwh Ganz am Anfang der Instanz-Einstellungen. Ich sehe gar keine Tabs, siehe Bild
                                        • jrbwh
                                          @flatlander Wenn Du mit e3oncan arbeiten möchtest, solltest Du auch die Instanz e3oncan konfigurieren. Mit dem Adapter viessmannapi hat das genau gar nichts zu tun.
                                            @jrbwh Das war eine peinliche Verwechslung, sorry. Habe wohl nicht genau genug hingesehen, das andere Icon ist halt auch rot und steht Viessman drauf.
                                            5709
