    4. Upgrade wird nicht ausgeführt
      Thomas Braun Most Active @JB1985 last edited by
      @jb1985
      Hmmmmm.
      Gib uns mal eine Übersicht darüber, wie du da insgesamt unterwegs bist.
      iob diag
      am besten gleich die Langfassung.
      JB1985 1 Reply Last reply Reply Quote 0
      • JB1985
        JB1985 @Thomas Braun last edited by
        @thomas-braun den Befehl kennt mein iobroker nicht ...
        root@ioBroker:~# iob diag
        iobroker [command]
          A Former User @JB1985 last edited by
          @jb1985
          Ruth schlägt Benutzer tot!
          • JB1985
                                    v.2025-02-02
               Static hostname: ioBroker
                     Icon name: computer-vm
                       Chassis: vm
                Virtualization: microsoft
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 5.10.0-33-amd64
                  Architecture: x86-64
            Installation:           microsoft
            Kernel:                 x86_64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            Display-Server:         false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
            Pending iob updates:    6
            Nodejs-Installation:
            /usr/bin/nodejs         v22.14.0
            /usr/bin/node           v22.14.0
            /usr/bin/npm            11.1.0
            /usr/bin/npx            11.1.0
            /usr/bin/corepack       0.31.0
            Recommended versions are nodejs 20.18.3 and npm 10.8.2
            nodeJS installation is correct
            MEMORY:
            Mem:            7.9G        3.0G        2.0G        0.0K        2.9G        4.6G
            Swap:           974M          0B        974M
            Total:          8.9G        3.0G        3.0G
            Active iob-Instances:   17
            Upgrade policy: none
            ioBroker Core:          js-controller           7.0.6
                                    admin                   7.4.14
            At least one iobroker host is running.
            Objects type: redis
            States  type: redis
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              system.adapter.admin.1                  : admin                 : ioBroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                13714
            States:                 10222
            Size of iob-Database:
            16M     /opt/iobroker/iobroker-data/objects.jsonl
            5.1M    /opt/iobroker/iobroker-data/objects.json.migrated
            5.1M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
            2.2M    /opt/iobroker/iobroker-data/states.jsonl
            36K     /opt/iobroker/iobroker-data/states.json.migrated
            36K     /opt/iobroker/iobroker-data/states.json.bak.migrated
            Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
            mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
            • mcm1957
              mcm1957 @JB1985 last edited by mcm1957
              @jb1985
              Bitte um die LANGfassung des Outputs von 'iob diag'
              Und was meinst du mit
              Und wieder werden die Adapter für ein Update aufgelistet.
              genau ? WO werden die Adapter aufgelistet? In adminUI, auf der commandline oder als Notification?
                @jb1985 sagte in Upgrade wird nicht ausgeführt:
                (bullseye)
                Ist abgekündigt. Bring das auf Debian 12 'Bookworm'.
                Nodejs@20 ist die derzeitige Empfehlung für den ioBroker.
                Dann hampelt man grundsätzlich nicht als root über die Kiste.
                Und das ist auch nicht die Langfassung, sondern nur die Zusammenfassung.
                iob stop
                iob fix
                iob nodejs-update 20
                Danach nochmal
                iob diag
                in der Langversion.
                JB1985 1 Reply Last reply Reply Quote 1
                • JB1985
                  JB1985 @Thomas Braun last edited by JB1985
                  @thomas-braun sagte in Upgrade wird nicht ausgeführt:
                  Script v.2025-02-02
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                            Kernel: Linux 6.1.0-31-amd64
                   Hardware Vendor: QEMU
                    Hardware Model: Standard PC _i440FX + PIIX, 1996_
                  Firmware Version: Virtualization-2.5.1-11303-200428-0-gfff70e7
                  OS is similar to:
                  model name      : AMD Ryzen Embedded V1500B
                  Docker          : false
                  Virtualization  : microsoft
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   18:56:53 up 10 min,  2 users,  load average: 0.53, 0.83, 0.56
                  CPU threads: 8
                  *** LIFE CYCLE STATUS ***
                  Operating System is the current Debian stable version codenamed 'bookworm'!
                  *** TIME AND TIMEZONES ***
                                 Local time: Wed 2025-02-12 18:56:53 CET
                             Universal time: Wed 2025-02-12 17:56:53 UTC
                                   RTC time: Wed 2025-02-12 17:56:53
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  user
                  HOME=/home/user
                  GROUPS=user cdrom floppy sudo audio dip video plugdev netdev iobroker
                  js-controller is not running
                  *** DISPLAY-SERVER SETUP ***
                  Desktop:
                  Terminal:       tty
                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                  *** MEMORY ***
                  Mem:            8.3G        1.4G        5.0G        540K        2.2G        6.9G
                  Swap:           1.0G          0B        1.0G
                  Total:          9.3G        1.4G        6.0G
                           7939 M total memory
                           1352 M used memory
                            501 M active memory
                           2358 M inactive memory
                           4787 M free memory
                            209 M buffer memory
                           1888 M swap cache
                            974 M total swap
                              0 M used swap
                            974 M free swap
                  top - 18:56:53 up 10 min,  2 users,  load average: 0.53, 0.83, 0.56
                  Tasks: 140 total,   1 running, 139 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  7.1 sy,  0.0 ni, 85.7 id,  7.1 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7939.8 total,   4785.9 free,   1354.6 used,   2097.8 buff/cache
                  MiB Swap:    975.0 total,    975.0 free,      0.0 used.   6585.2 avail Mem
                  *** FAILED SERVICES ***
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  udev           devtmpfs  3.9G     0  3.9G   0% /dev
                  tmpfs          tmpfs     794M  528K  794M   1% /run
                  /dev/sda1      ext4       62G   22G   37G  38% /
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs          tmpfs     794M     0  794M   0% /run/user/0
                  [Wed Feb 12 18:46:43 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                  [Wed Feb 12 18:46:45 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET SOURCE    FSTYPE OPTIONS
                  /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                  /var:
                  1.8G    /var/
                  878M    /var/log
                  857M    /var/log/journal/2ef03e74e8a7484b80516c17bf8095ba
                  538M    /var/lib
                  Archived and active journals take up 16.0M in the file system.
                  /opt/iobroker/backups:
                  1.5G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  9.1G    /opt/iobroker/iobroker-data/history
                  29M     /opt/iobroker/iobroker-data/history/20240913
                  29M     /opt/iobroker/iobroker-data/history/20240912
                  29M     /opt/iobroker/iobroker-data/history/20240902
                  12M     /opt/iobroker/iobroker-data/history/20240710/history.Datenpunkte.0.PV-Anlage.PV-Power.json
                  12M     /opt/iobroker/iobroker-data/history/20240707/history.Datenpunkte.0.PV-Anlage.PV-Power.json
                  12M     /opt/iobroker/iobroker-data/history/20240706/history.Datenpunkte.0.PV-Anlage.PV-Power.json
                  12M     /opt/iobroker/iobroker-data/history/20240624/history.Datenpunkte.0.PV-Anlage.PV-Power.json
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.3
                  /usr/bin/node           v20.18.3
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.30.0
                  nodejs:
                    Installed: 20.18.3-1nodesource1
                    Candidate: 20.18.3-1nodesource1
                    Version table:
                   *** 20.18.3-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                          100 /var/lib/dpkg/status
                       20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                          500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  iobroker is not running on this host.
                  No iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 106)
                  Core adapters versions
                  js-controller:  7.0.6
                  admin:          7.4.14
                  javascript:     8.8.3
                  nodejs modules from github:     1
                  +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                  Adapter State
                    system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                    system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                    system.adapter.bshb.0                   : bshb                  : ioBroker                                 -  enabled
                    system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                    system.adapter.govee-app.0              : govee-app             : ioBroker                                 -  enabled
                    system.adapter.history.0                : history               : ioBroker                                 -  enabled
                    system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                    system.adapter.lovelace.0               : lovelace              : ioBroker                                 -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.midea.0                  : midea                 : ioBroker                                 - disabled
                    system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                    system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
                    system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 192.168.2.229
                    system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                    system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │ name               │ url                                                     │ auto upgrade │
                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  Active repo(s): Beta (latest)
                  Installed ioBroker-Instances
                  Used repository: Beta (latest)
                  Adapter    "admin"        : 7.4.21   , installed 7.4.14 [Updatable]
                  Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                  Adapter    "bshb"         : 0.5.0    , installed 0.3.0  [Updatable]
                  Adapter    "javascript"   : 8.9.1    , installed 8.8.3  [Updatable]
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "lovelace"     : 4.1.11   , installed 4.1.11
                  Adapter    "midea"        : 0.0.7    , installed 0.0.7
                  Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "shelly"       : 9.0.0    , installed 8.5.1  [Updatable]
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 7.0.1    , installed 6.7.1  [Updatable]
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "web"          : 6.3.1    , installed 6.3.1
                  Adapter    "ws"           : 3.0.5    , installed 2.6.2  [Updatable]
                  Adapter    "yahka"        : 1.0.9    , installed 1.0.9
                  Objects and States
                  Objects:        13714
                  States:         10098
                  Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                  Hit:2 http://ftp.de.debian.org/debian bookworm InRelease
                  Hit:3 http://ftp.de.debian.org/debian bookworm-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16406      1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15594      571/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        16638      554/redis-server 12
                  tcp6       0      0 ::1:6379                :::*                    LISTEN      108        16639      554/redis-server 12
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          17836      1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15596      571/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16589      504/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15389      1/init
                  udp6       0      0 :::111                  :::*                                0          14387      1/init
                  2025-02-12 18:51:20.054  - info: lovelace.0 (1487) terminating
                  2025-02-12 18:51:20.055  - info: web.0 (1518) terminating
                  2025-02-12 18:51:20.056  - info: govee-app.0 (1470) terminating
                  2025-02-12 18:51:20.057  - info: alexa2.0 (1455) terminating
                  2025-02-12 18:51:20.056  - info: web.0 (1518) Terminated (NO_ERROR): Without reason
                  2025-02-12 18:51:20.156  - info: host.ioBroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.174  - info: host.ioBroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.246  - info: host.ioBroker instance system.adapter.shelly.1 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.269  - info: history.0 (1295) terminating
                  2025-02-12 18:51:20.270  - info: history.0 (1295) Terminated (NO_ERROR): Without reason
                  2025-02-12 18:51:20.246  - info: host.ioBroker instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.247  - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.247  - info: host.ioBroker instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.304  - info: host.ioBroker instance system.adapter.bshb.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.304  - info: host.ioBroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.305  - info: host.ioBroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.305  - info: host.ioBroker instance system.adapter.govee-app.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.334  - info: host.ioBroker instance system.adapter.lovelace.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.335  - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.344  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.569  - info: host.ioBroker instance system.adapter.pushover.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.581  - info: host.ioBroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.798  - info: host.ioBroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                  2025-02-12 18:51:20.799  - info: host.ioBroker All instances are stopped.
                  2025-02-12 18:51:20.989  - info: host.ioBroker terminated
                    Homoran Global Moderator Administrators @JB1985 last edited by
                    @jb1985 da fehlte noch ein iob start
                      @jb1985
                      Und ein
                      iob upgrade all -y
                      liefert?
                      • JB1985
                        iob upgrade all -y
                        Strange ... jetzt funktioniert es wieder.
                        Lag wohl an der Node Version. Obwohl ich die eigentlich schon länger habe.
                        468
