    4. Parser Adapter Werte Zeilenweise auslesen (Guntamatic)
      glitzi @AlCalzone last edited by glitzi
      @alcalzone
      in meinem Skript nutze ich noch "request" viele sprechen jetzt von einer Umstellung auf "axios"
      Daher hier die Version mit "axios"
      Das habe ich leider nicht selber hinbekommen, aber das Forum hat mich hier prächtig unterstützt!
      createState('Guntamatic_Betrieb_0');
      createState('Guntamatic_Aussentemperatur_1');
      createState('Guntamatic_Kesseltemperatur_3');
      createState('Guntamatic_Leistung_5');
      createState('Guntamatic_Rücklauf_6');
      createState('Guntamatic_CO2_Gehalt_8');
      createState('Guntamatic_Puffer_oben_17');
      createState('Guntamatic_Puffer_unten_19');
      createState('Guntamatic_Pumpe_HP0_20');
      createState('Guntamatic_Warmwasser_21');
      createState('Guntamatic_Vorlauf_31');
      createState('Guntamatic_Füllstand_65');
      createState('Guntamatic_Kesselfreigabe_68');
      createState('Guntamatic_Programm_69');
      createState('Guntamatic_Programm_HK1_71');
      createState('Guntamatic_Stoer0_79');
      createState('Guntamatic_Stoer1_80');
      createState('Guntamatic_Asche_entleeren_85');
      createState('Guntamatic_Brennstoffzähler_89');
      createState('Guntamatic_Pufferladung_90');
      createState('Guntamatic_CO2_Gehalt_korrigiert');
      const axios=require('axios');
      schedule("*/5 * * * * *", function(){
      	axios.post('http://xx.xx.xx.xx/daqdata.cgi?key=xxxx', {
      		responseEncoding: 'latin1'
      	.then(function(response) {
      			if (response.data) {
      				var parts = response.data.split('\n');
      				var parts_Guntamatic = parts[0];
      				setState('Guntamatic_Betrieb_0', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[1];
      				setState('Guntamatic_Aussentemperatur_1', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[3];
      				setState('Guntamatic_Kesseltemperatur_3', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[5];
      				setState('Guntamatic_Leistung_5', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[6];
      				setState('Guntamatic_Rücklauf_6', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[8];
      				setState('Guntamatic_CO2_Gehalt_8', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[17];
      				setState('Guntamatic_Puffer_oben_17', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[19];
      				setState('Guntamatic_Puffer_unten_19', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[20];
      				setState('Guntamatic_Pumpe_HP0_20', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[21];
      				setState('Guntamatic_Warmwasser_21', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[31];
      				setState('Guntamatic_Vorlauf_31', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[65];
      				setState('Guntamatic_Füllstand_65', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[68];
      				setState('Guntamatic_Kesselfreigabe_68', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[69];
      				setState('Guntamatic_Programm_69', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[71];
      				setState('Guntamatic_Programm_HK1_71', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[79];
      				setState('Guntamatic_Stoer0_79', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[80];
      				setState('Guntamatic_Stoer1_80', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[85];
      				setState('Guntamatic_Asche_entleeren_85', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[89];
      				setState('Guntamatic_Brennstoffzähler_89', parts_Guntamatic, true);
      				var parts_Guntamatic = parts[90];
      				setState('Guntamatic_Pufferladung_90', parts_Guntamatic, true);
      				CO2 Korrigieren da der Wert im Leerlauf teils 18.00 annimmt.
      				parts[5] = Leistung parts[8] = CO2 Gehalt
      				if (parts[5] == 0) {
      					setState("Guntamatic_CO2_Gehalt_korrigiert", 0, true);
      				} else {
      					setState("Guntamatic_CO2_Gehalt_korrigiert", parts[8], true);
      • Seiler1983
        Seiler1983 @glitzi last edited by Seiler1983
        ich bin erst jetzt durch Google Recherche auf dieses Forum aufmerksam geworden. Ich nutze bisher nur die App von Guntamatic, da funktioniert alles super (also was die App halt hergibt).
        Bei dem HTTP Request via Browser scheitere ich auch an "Keine Berechtigung".
        Muss ich bei <KEY> den Schlüssel verwenden, den auch die App verwendet (einstellbar im Heizungsmenü), oder ist das wieder ein anderer bzw. wo krieg ich den her?
          glitzi @Seiler1983 last edited by
          @seiler1983
          Weiter oben ist das Formular für den Key, dieser wird von Guntamatic erstellt und ist von der Kesselnummer abhängig.
          https://forum.iobroker.net/topic/38469/parser-adapter-werte-zeilenweise-auslesen-guntamatic/42
            Esmax666 last edited by
            @glitzi said in Parser Adapter Werte Zeilenweise auslesen (Guntamatic):
            axios
            was sind die vorteile von axios?
            Dein skript geht auch für ein Biostar 15 ?
            ich werde bald ein Biostar haben und checke gerade die lösungen 😄
              glitzi @Esmax666 last edited by glitzi
              @esmax666
              Moin,
              Sollte eigentlich funktionieren, die Werte werden ja nur zeilenweise von der Webseite gelesen.
              Ob die Zuordnung passt siehst du leicht selber über folgende URL‘s und kannst ggf. das Skript anpassen.
              Werte:
              http://IP.IP.IP.IP/daqdata.cgi
              Beschreibung:
              http://IP.IP.IP.IP/daqdesc.cgi
                Esmax666 @glitzi last edited by
                @glitzi
                ok danke ich werde mal probieren
                Guntamatic adapter ist noch nicht vorgesehen oder?
                  @esmax666
                  Von einem Adapter bin ich leider mit meinen Programmierkenntnissen meilenweit entfernt,
                  Aber das Skript tut seinen Dienst…
                    devhoh @glitzi last edited by devhoh
                    @glitzi, @orfix,
                    durch eine Websuche bin ich auf diesen Thread gestoßen. Ich habe kürzlich meinen Biostar 17 Kessel in Home Assistant integriert und kann nun alle Werte auslesen und protokollieren sowie diverse Heizstatus setzen – soweit so gut.
                    In deiner schönen Grafik sehe ich, dass die Störmeldungen angezeigt werden. Wenn ich es richtig verstehe, gibt es auch einen Quittier-Button? Genau daran habe ich großes Interesse. Gibt es dafür ein spezifisches Kommando?
                    Der Guntamatic-Support hält sich dazu leider bedeckt, aber es muss ja irgendwie machbar sein – die offizielle App kann es schließlich auch.
                    Ich wäre dir für jede Info dankbar!
                    Liebe Grüße!
                    O G E 3 Replies Last reply Reply Quote 0
                    • O
                      orfix @devhoh last edited by orfix
                      @devhoh
                      servus,
                      quittieren muss ich nur nach Asche leeren, mach ich am Display.
                      Sonst zeig ich nur die Störungen an und Pushmeldung ans Handy.
                      mfg
                      orfix
                        glitzi @devhoh last edited by
                        @devhoh
                        quittieren sollte man auch nur vor Ort, meist liegt dann auch eine Störung vor die begutachtet werden sollte.
                        Und so wie ich die Dokumentation lese, ist dies auch nicht vorgesehen, man könnte ggf. den Traffic der Guntamatic-App mal mitschneiden und schauen was die so sendet.
                        Aber für diese seltene Fälle nutze ich dann einfach die APP oder den Finger vor Ort.
                        mfg
                          Esmax666 @devhoh last edited by
                          @devhoh Hast du dann Home Assistant und ioBroker für Guntamatic integriert?
                          Gab es fertige Templates und Skripte auch für Home Assistant?
                          Weißt du, ob es möglich ist, über ein Skript in ioBroker oder Home Assistant eine Anforderung zum Befüllen der Pellets zu senden?
                          Ich habe den Eindruck, dass Guntamatic keine Funktion für die Pelletbefüllung per Smartphone vorgesehen hat.
                          Gleiches gilt für das Zurücksetzen nach dem Entleeren der Aschebehälter – schade, dass man das nicht direkt über die App machen kann.
                            @glitzi
                            Hallo, ich verstehe das nicht ganz, sorry. Den Key bekommt man doch auch direkt am Heizungsdisplay, oder?
                            (Kundenebene / App / Schlüssel)
                            Und dann kann man im Browser einfach
                            http://IPADRESSE/daqdata.cgi?key=Schlüsselnummer
                            eingeben und bekommt die Infos.
                            Ich verstehe nicht, warum man zusätzlich „/ext“ verwenden muss (http://xx.xx.xx.xx/ext/parset.cgi...).
                            Kannst du das bitte erklären?
                            Sorry hab das nicht verstanden, danke
                            parser guntamatic regex
                            11319
