    4. Puppeteer: Screenshots PhantomJS Alternative
      Freak @Codierknecht last edited by
      @codierknecht
      Ja, das habe ich schon gesehen, danke für den Hinweis.
      Leider bekomme ich mein Problem nicht selbst in den Griff und wollte kein neues Thema eröffnen.
      Mein iobroker läuft auf einer Ds1522+ mit einem AMD Ryzen R1600
      Wenn ich den Puppeteer adapter installiere bekomme ich folgende Fehler im Log.
      puppeteer.0
      2024-02-19 08:08:23.154	error	Failed to launch the browser process![24624:24624:0219/080822.240775:FATAL:zygote_host_impl_linux.cc(127)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.TROUBLESHOOTING: https://pptr.dev/troubleshooting
      puppeteer.0
      2024-02-19 08:08:23.154	error	Error: Failed to launch the browser process![24624:24624:0219/080822.240775:FATAL:zygote_host_impl_linux.cc(127)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.TROUBLESHOOTING: https://pptr.dev/troubleshooting at ChildProcess.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:267:24) at ChildProcess.emit (node:events:525:35) at ChildProcess._handle.onexit (node:internal/child_process:291:12)
      puppeteer.0
      2024-02-19 08:08:23.153	error	unhandled promise rejection: Failed to launch the browser process![24624:24624:0219/080822.240775:FATAL:zygote_host_impl_linux.cc(127)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.TROUBLESHOOTING: https://pptr.dev/troubleshooting
      puppeteer.0
      2024-02-19 08:08:23.152	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      puppeteer.0
      2024-02-19 08:08:22.187	info	starting. Version 0.2.8 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v18.15.0, js-controller: 5.0.17
      Danke für die Unterstützung.
      • Codierknecht
        Codierknecht Developer Most Active @Freak last edited by
        @freak sagte in Puppeteer: Screenshots PhantomJS Alternative:
        Da bist Du offenbar nicht der Einzige.
        @ilovegym sagte in Puppeteer: Screenshots PhantomJS Alternative:
        Denke, das geht nicht im Docker.
        @ilovegym @foxriver76 @andre
        Oder hat sich an dem Umstand etwas geändert?
        F Neuschwansteini 2 Replies Last reply Reply Quote 0
          @codierknecht
          das habe ich auch gefunden. Hab halt gehofft, dass es doch jemanden gibt, der eine Lösung hat.
          Danke für deine Mühe.
          • Neuschwansteini
            Neuschwansteini @Codierknecht last edited by
            @codierknecht sagte in Puppeteer: Screenshots PhantomJS Alternative:
            nee, leider nicht, ich habe mir eine VM als Multihost-Slave in Proxmox als Workaround angelegt.
            Ist auch in den Issues zu Puppeteer auf git und npm zu sehen, sandbox in the sandbox geht nicht.
            @Freak
            wenn du Synology hast, kannst du dir auch eine VM anlegen (Paket Virtual Machine Manager installieren). Bei mir hat das zuviel Ressourcen gefressen, daher bin ich dann auf Docker umgestiegen.
              Freak @Neuschwansteini last edited by
              @ilovegym
              Das habe ich mir auch schon überlegt.
              Ich habe gesehen, es gibt auch Puppeteer Docker container.
              Wenn dieser Container einen Screenshot einer Website erstellen kann und ihn an einem bestimmten Ort ablegt, sollte das ja nutzbar sein.
              Kann das zufällig jemand bestätigen?
              danke
                bimmi last edited by bimmi
                Sorry. Falscher Beitrag 😁
                  liv-in-sky @foxriver76 last edited by
                  @foxriver76
                  bräuchte kurz deine hilfe - gibt es einen trick, wie man über sowas drüber kommt:
                  ist eine google maps seite, die ich "phtographieren" möchte
                  • foxriver76
                    foxriver76 Developer last edited by foxriver76
                    Ich habe gestern eine 0.4.0 veröffentlicht, mit der kann man nun einen externen Browser Pfad in den Einstellungen konfigurieren, somit sollte es nun auch in Docker sowie auf dem Pi möglich sein den Adapter laufen zu lassen in dem man einen externen Browser installiert, z. B. sudo apt install chromium und dann in dem Pfad den Chromium Browser angibt z. B. /usr/bin/chromium-browser.
                    O B 2 Replies Last reply Reply Quote 2
                    • O
                      oxident @foxriver76 last edited by
                      @foxriver76 Super, danke!
                      Auf meinem OrangePi (RK3588) war es /usr/bin/chromium
                        BobmortonTX @foxriver76 last edited by
                        @foxriver76
                        das funktioniert leider bei mir nicht.
                        muss ich noch weitere Einstellungen vornehmen als den Pfad in der Instanz zu setzen (/usr/bin/chromium) ?
                        ARM Rock5 - iobrocker als Docker
                        browser local installiert.
                        keine Desktopumgebung installiert
                        puppeteer.0
                        	2025-02-13 11:58:45.432	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        puppeteer.0
                        	2025-02-13 11:58:45.432	info	terminating
                        puppeteer.0
                        	2025-02-13 11:58:45.423	error	Browser was not found at the configured executablePath (/usr/bin/chromium)
                        puppeteer.0
                        	2025-02-13 11:58:45.422	error	Error: Browser was not found at the configured executablePath (/usr/bin/chromium) at ChromeLauncher.launch (/opt/iobroker/node_modules/puppeteer-core/lib/cjs/puppeteer/node/BrowserLauncher.js:86:19) at async PuppeteerAdapter.onReady (/opt/iobroker/node_modules/iobroker.puppeteer/build/main.js:45:20)
                        puppeteer.0
                        	2025-02-13 11:58:45.422	error	unhandled promise rejection: Browser was not found at the configured executablePath (/usr/bin/chromium)
                        puppeteer.0
                        	2025-02-13 11:58:45.421	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        puppeteer.0
                        	2025-02-13 11:58:45.406	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v18.20.4, js-controller: 7.0.3
                        local browser installiert:
                        rock-5b:/bin$ ls chromiu*
                        chromium
                        rock-5b:/usr/bin$ ls chro*
                        chromium
                        • foxriver76
                          @bobmortontx passen die rechte? Ansonsten keine Ahnung gerade
                          31.7k
                          79.8k
                          browser headless phantomjs puppeteer screenshot screenshots website
                          23
                          245
                          25541
