    4. Visualisierungen weg und "cannot call visUtils: Not exists"
    • Christof.Kac
      Christof.Kac last edited by
      hier der Inhalt von iob diag:
                              v.2025-02-02
         Static hostname: ioBrokerProductive
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-32-amd64
            Architecture: x86-64
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.3
      /usr/bin/node           v20.18.3
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.30.0
      Recommended versions are nodejs 20.18.3 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            7.9G        2.8G        3.3G        2.0M        1.8G        4.9G
      Swap:           974M          0B        974M
      Total:          8.9G        2.8G        4.3G
      Active iob-Instances:   37
      Upgrade policy: none
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.10
      Objects type: jsonl
      States  type: redis
      + system.adapter.admin.0                  : admin                 : ioBrokerProductive                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : ioBrokerProductive                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                27008
      States:                 23105
      Size of iob-Database:
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/objects.json.migrated
      21M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.0K    /opt/iobroker/iobroker-data/objects.json.old
      35M     /opt/iobroker/iobroker-data/states.jsonl
      4.1M    /opt/iobroker/iobroker-data/states.json.migrated
      4.1M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      3.6M    /opt/iobroker/iobroker-data/states.json.old
      0       /opt/iobroker/iobroker-data/states.json.broken
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      Danke!
      Christof.Kac 1 Reply Last reply Reply Quote 0
      • Christof.Kac
        Christof.Kac @Christof.Kac last edited by
        Und hier der Inhalt von "HeatingControl" (um die Vis geht es mir hauptsächlich) und "main"
        christof@ioBrokerProductive:/opt/iobroker/iobroker-data/files/vis.0 $ ls
        insgesamt 36
        drwxrwxr-x+ 3 iobroker iobroker  4096 13. Nov 2021  Hauptprojekt
        drwxrwxr-x+ 3 iobroker iobroker  4096 18. Nov 2021  HeatingControl
        drwxrwxr-x+ 2 iobroker iobroker  4096 13. Nov 2021  LogParser
        drwxrwxr-x+ 2 iobroker iobroker  4096 14. Nov 2021  main
        -rw-rw-r--+ 1 iobroker iobroker   671 13. Feb 18:15 _data.json
        -rw-rw-r--+ 1 iobroker iobroker 14404 13. Feb 18:15 htmlexample.html
        christof@ioBrokerProductive:/opt/iobroker/iobroker-data/files/vis.0 $ ls HeatingControl/
        insgesamt 20
        drwxrwxr-x+ 2 iobroker iobroker  4096 18. Nov 2021  images
        -rw-rw-r--+ 1 iobroker iobroker     0 13. Feb 17:18 vis-user.css
        -rw-rw-r--+ 1 iobroker iobroker 14972 13. Feb 18:15 vis-views.json
        christof@ioBrokerProductive:/opt/iobroker/iobroker-data/files/vis.0 $ ls main
        insgesamt 64
        -rw-rw-r--+ 1 iobroker iobroker     0  2. Jan 2024  vis-user.css
        -rw-rw-r--+ 1 iobroker iobroker 63863  2. Jan 2024  vis-views.json
          Homoran Global Moderator Administrators @Christof.Kac last edited by Homoran
          @christof-kac sagte in Visualisierungen weg und "cannot call visUtils: Not exists":
          die müsste da sein.
          wie rufst du sie auf?
          versuch es mal ohne die page
          • Christof.Kac
            Christof.Kac @Homoran last edited by
            @homoran Ich habe einen link auf die VIsualisierung, den ich bisher immer genutzt habe. Von einen Tag auf den anderen geht es nicht mehr:
            http://192.168.178.200:8082/vis/index.html?HeatingControl#pageHzng
            Komisch ist, dass keine View gefunden wird:
              @homoran sagte in Visualisierungen weg und "cannot call visUtils: Not exists":
              zeig mal die Projekte
              • Christof.Kac
                @homoran Das ist ja das komische: Alle Projekte sind weg:
                Und das HeatingControl hat Vis anscheinend angelegt, da dort nur die Default-Visualisierung ist.
                Falls es hilft: Ich habe automatische backups der letzten Monate, wenn Ihr mir sagt, wonach ich suchen muss, kann ich auch Daten wiederherstellen.
                Komisch ist halt, dass keiner der Projekte / Views gefunden wird.
                  bist du denn auf dem richtigen Rechner?
                  die views befinden sich immer in den vis-views.json des zugehörigen Projektes
                  kannst fir ja mal eins ansehen. ist ein "einfaches" json
                  • Christof.Kac
                    Christof.Kac @Homoran last edited by Christof.Kac
                    @homoran Ich habe nur eine Instanz von iobroker, also ja, es ist der richtige Rechner.
                    Was mir aber aufgefallen ist: Die CSS war ohne Inhalt.
                    Ich habe nun mein Backup zurückgespielt, leider ohne Erfolg
                    christof@ioBrokerProductive:/opt/iobroker/iobroker-data/files/vis.0/HeatingControl $ ls
                    insgesamt 212
                    -rwxrwxr-x+ 1 iobroker iobroker 179491 13. Feb 19:15 vis-user.css
                    -rwxrwxr-x+ 1 iobroker iobroker  14972 13. Feb 19:16 vis-views.json
                    Immernoch "view not found".
                    Wo werden denn die Projekte registiert? Da scheint irgend was kaputt gegangen zu sein, da ja kein Projekt angezeigt wird.
                      welche?
                      du solltest dur das json ansehen
                      • Christof.Kac
                        @homoran So, wir kommen der Sache näher:
                        Nach dem Einspielen des Backups:
                        insgesamt 1724
                        -rwxrwxr-x+ 1 iobroker iobroker  179491 13. Feb 19:24 vis-user.css
                        -rwxrwxr-x+ 1 iobroker iobroker 1559827 13. Feb 19:24 vis-views.json
                        nach dem Aufruf von http://192.168.178.200:8082/vis/index.html?HeatingControl#pageHzng und Bestätigung der Fehlermeldung:
                        insgesamt 216
                        -rwxrwxr-x+ 1 iobroker iobroker  14972 13. Feb 19:25 vis-views.json
                        Die JSON ist überschrieben worden.
                        Und nu?
                        Christof.Kac Homoran 2 Replies Last reply Reply Quote 0
                        • Christof.Kac
                          Ich habe noch versucht, eine alte View zu öffnen: Hauptprojekt:
                          Hier wird gesagt, dass das json nicht da ist obwohl es klar vorhanden ist:
                          insgesamt 36
                          drwxrwxr-x+ 3 iobroker iobroker  4096 13. Feb 19:23 HeatingControl
                          drwxrwxr-x+ 2 iobroker iobroker  4096 13. Feb 19:44 main
                          -rw-rw-r--+ 1 iobroker iobroker   671 13. Feb 19:49 _data.json
                          -rw-rw-r--+ 1 iobroker iobroker 14404 13. Feb 19:49 htmlexample.html
                          christof@ioBrokerProductive:/opt/iobroker/iobroker-data/files/vis.0 $ ls Hauptprojekt/
                          insgesamt 7320
                          drwxrwxr-x+ 4 iobroker iobroker    4096 13. Nov 2021  img
                          -rw-rw-r--+ 1 iobroker iobroker   61686  2. Jan 2024  vis-user.css
                          -rw-rw-r--+ 1 iobroker iobroker 7423196  2. Jan 2024  vis-views.json
                            Und nu?
                            die letzte funktionierende vis-views.json dorthin schreiben
                            • Christof.Kac
                              @homoran Das habe ich ja gemacht und das Backup wird einfach überschrieben....Irgendwie alles komisch. Und warum werden die Projekte unter "Setup->Projekte" nicht angezeigt?
                              Gibt es da noch eine mini-datenbank oder wird einfach nur nach den Ordnern gesucht.
                              Sorry für die verzwickte lage
                                @christof-kac wie schiebst du die Dateuen in die Verzeichnisse?
                                über den Dateimanager von vis?
                                • Christof.Kac
                                  @homoran Ne, ich kopiere die über die shell in den Ordner
                                    @christof-kac nee, nee, nicht so!
                                    • Christof.Kac
                                      @homoran Ich habe nun versucht, die json und css Datei per VIS Dateimanager upzuloaden, dies ging aber nicht in den Ordner
                                      sondern nur in den Vorgeschlagenen folder
                                      /opt/iobroker/iobroker-data/files/vis.0/HeatingControl/img
                                      Was mache ich falsch?
                                      • Christof.Kac
                                        @christof-kac Für alle, die das gleich Problem haben:
                                        Ich habe nun den Ordner HeatingControl gelöscht, den Ordner HeatingControl aus dem Backup gezippt und den per Projekt->Import in Vis importiert.
                                        Danach funktionierte alles
                                        Schon schräg, wieso das alles passiert ist aber nun läuft es.
                                        Danke!
                                          klar!(??)
                                          über
                                          Projekt->Impor
                                          wird das in der vis registriert.
                                          ebenso über den file upload in der vis und auch über Dateien im Admin
                                          aber nicht per shell oder ftp
                                          • Christof.Kac
                                            @homoran Danke für die Tipps. Ich verstehe nur nicht, warum es überhaupt kaputt gegangen ist - aber egal, Hauptsache es läuft jetzt wieder.
                                            vis
                                            1713
