    4. Warnmeldungen MQTT Adapter
      Emilleopold last edited by Homoran
      ich bekomme seit ein paar Tagen in den Protokollen viele Warnung nach dem Schema :
      2025-02-14 15:15:05.507 warn Client [nodered_b23a406443e22c7e] Message 77 deleted after 11 retries
      Weiss aber nicht, wie ich die Ursache finden soll.
      Danke für eure Hinweise und Unterstützung.
      Adapter ist : MQTT Broker/Client
      Linux User bitte hier den Output von iob diag einfügen.
      			v.2024-12-09 Raspbian+zigbee diag+masking
         Static hostname: iobroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		32 bit
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      Display-Server: 	false
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v20.18.3
      /usr/bin/node 		v20.18.3
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.30.0
      Recommended versions are nodejs 20.18.3 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            7.8G         96M        6.9G        0.0K        828M        7.6G
      Swap:            99M          0B         99M
      Total:          7.9G         96M        7.0G
      Active iob-Instances: 	1
      Upgrade policy: none
      ioBroker Core: 		js-controller 		7.0.6
      			admin 			7.4.10
      ioBroker Status: 	iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      Objects: 		18192
      States: 		31605
      Size of iob-Database:
      21M	/opt/iobroker/iobroker-data/objects.jsonl
      12M	/opt/iobroker/iobroker-data/objects.json.migrated
      12M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      6.4M	/opt/iobroker/iobroker-data/states.jsonl
      5.8M	/opt/iobroker/iobroker-data/states.json.migrated
      5.8M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      === Mark text until here for copying ===
        Wildbill last edited by
        @emilleopold Die Nachricht kommt, wenn ein MQTT-Gerät, welches eben noch erreichbar war, eben nicht mehr erreichbar ist.
        Gruss, Jürgen
          @wildbill Und wie finde ich heraus, welches MQTT-Gerät das ist ?
            Wildbill @Emilleopold last edited by
            @emilleopold Keine Ahnung, bei mir haben die Geräte da eigentlich immer Klarnamen. Da da bei Dir in der Meldung was von nodered steht, würde ich mal in der Richtung suchen.
            Gruss, Jürgen
              Emilleopold @Wildbill last edited by
              @wildbill In Node-Red habe ich auch schon gesucht, bin aber mit der ID nicht weitergekommen. Hat hier sonst noch jemand eine Idee, wie man die Ursache finden könnte ?
              mqtt.0 protokoll warnung
