    4. Mehrere Objekte mit deren Datenpunkten in VIS Tabelle
      Snopy_16 @senior1418 last edited by Snopy_16
      @senior1418 sagte in Mehrere Objekte mit deren Datenpunkten in VIS Tabelle:
      hatte mir eine HTLM Tabelle aus DP's von Sourceanalytics gebastelt.
      <!DOCTYPE html><html lang="de"><table style="width:95%;"><thead><tr style="font-size:1em; text-align:right"><th style="text-align:left";>Bezeichg.</th><th>Status</th><th>Heute</th><th>Gestern</th><th>Monat akt.</th><th>Vormonat</th><th>Jahr akt.</th><th>Vorjahr</th></tr></thead><body><tr style="font-size:1em; text-align:right"><td style="text-align:left";> EDV </td><td>🟢</td><td class="mdui-lightblue-bg"> 1087 Wh</td><td class="mdui-lightblue-bg"> 1288 Wh</td><td class="mdui-darkgrey-bg">  -15 Kwh</td><td class="mdui-darkgrey-bg">  38 Kwh</td><td class="mdui-amber-bg">  	-15 Kwh</td><td class="mdui-amber-bg">     130 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> Heizung </td><td>🟢</td><td class="mdui-lightblue-bg"> 5271 Wh</td><td class="mdui-lightblue-bg"> 6037 Wh</td><td class="mdui-darkgrey-bg">  9973 Kwh</td><td class="mdui-darkgrey-bg">  194 Kwh</td><td class="mdui-amber-bg">  	9973 Kwh</td><td class="mdui-amber-bg">     3142 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> WW </td><td>🟢</td><td class="mdui-lightblue-bg"> 2040 Wh</td><td class="mdui-lightblue-bg"> 2 Wh</td><td class="mdui-darkgrey-bg">  -5 Kwh</td><td class="mdui-darkgrey-bg">  15 Kwh</td><td class="mdui-amber-bg">  	-5 Kwh</td><td class="mdui-amber-bg">     234 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> Backrohr </td><td>🟢</td><td class="mdui-lightblue-bg"> 1241 Wh</td><td class="mdui-lightblue-bg"> 601 Wh</td><td class="mdui-darkgrey-bg">  -2 Kwh</td><td class="mdui-darkgrey-bg">  17 Kwh</td><td class="mdui-amber-bg">  	-2 Kwh</td><td class="mdui-amber-bg">     66 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> Geschirrspüler </td><td>🟢</td><td class="mdui-lightblue-bg"> 999 Wh</td><td class="mdui-lightblue-bg"> 0 Wh</td><td class="mdui-darkgrey-bg">  -6 Kwh</td><td class="mdui-darkgrey-bg">  14 Kwh</td><td class="mdui-amber-bg">  	-6 Kwh</td><td class="mdui-amber-bg">     50 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> Kühl_Gefrierkombi </td><td>🟢</td><td class="mdui-lightblue-bg"> 534 Wh</td><td class="mdui-lightblue-bg"> 615 Wh</td><td class="mdui-darkgrey-bg">  19 Kwh</td><td class="mdui-darkgrey-bg">  19 Kwh</td><td class="mdui-amber-bg">  	19 Kwh</td><td class="mdui-amber-bg">     435 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> Gefriertruhe </td><td>🟢</td><td class="mdui-lightblue-bg"> 828 Wh</td><td class="mdui-lightblue-bg"> 1004 Wh</td><td class="mdui-darkgrey-bg">  1088 Kwh</td><td class="mdui-darkgrey-bg">  563 Kwh</td><td class="mdui-amber-bg">  	1088 Kwh</td><td class="mdui-amber-bg">     1084 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> Kühlschrank </td><td>🟢</td><td class="mdui-lightblue-bg"> 412 Wh</td><td class="mdui-lightblue-bg"> 494 Wh</td><td class="mdui-darkgrey-bg">  332 Kwh</td><td class="mdui-darkgrey-bg">  16 Kwh</td><td class="mdui-amber-bg">  	332 Kwh</td><td class="mdui-amber-bg">     336 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> 3D-Druck </td><td>🔴</td><td class="mdui-lightblue-bg"> 0 Wh</td><td class="mdui-lightblue-bg"> 0 Wh</td><td class="mdui-darkgrey-bg">  0 Kwh</td><td class="mdui-darkgrey-bg">  2 Kwh</td><td class="mdui-amber-bg">  	0 Kwh</td><td class="mdui-amber-bg">     6 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> E-Bike </td><td>🔴</td><td class="mdui-lightblue-bg"> 0 Wh</td><td class="mdui-lightblue-bg"> 0 Wh</td><td class="mdui-darkgrey-bg">  0 Kwh</td><td class="mdui-darkgrey-bg">  0 Kwh</td><td class="mdui-amber-bg">  	0 Kwh</td><td class="mdui-amber-bg">     9 Kwh</td></tr><tr style="font-size:1em; text-align:right"><td style="text-align:left";> TV-WZ </td><td>🟢</td><td class="mdui-lightblue-bg"> 130 Wh</td><td class="mdui-lightblue-bg"> 180 Wh</td><td class="mdui-darkgrey-bg">  12 Kwh</td><td class="mdui-darkgrey-bg">  9 Kwh</td><td class="mdui-amber-bg">  	12 Kwh</td><td class="mdui-amber-bg">     105 Kwh</td></tr></body></table></html>
      Ich habe nun über das Script einen HTML-Code im vorgesehenen Datenpunkt in userdata.0.xxx stehen.
      Wie kann ich nun damit eine Tabelle in VIS1 darstellen?
      • O
        Oli @Snopy_16 last edited by
        @snopy_16
        Verwende ein ganz normales HTML Widget und schreibe in Allgemein deinen Datenpunkt in geschweiften Klammern
        {0_userdata.xxx}
        Du solltest aber noch den HTML Tag entfernen, dieser ist im Widget bereits hinterlegt.
          Snopy_16 @Oli last edited by
          @Codierknecht
          Ich hab nun die Zeile 12 hinzugefügt (mac-Adresse)
          const persons = $('unifi.0.default.clients.*.is_online').toArray();
          const jsonId = '0_userdata.0.Unifi.Clients';
          function checkOnline() {
              let list = [];
              persons.forEach(function (id) {
                  let obj = {
                      online: getState(id).val,
                      Name: getState(id.replace('.is_online', '.name')).val,
                      IP: getState(id.replace('.is_online', '.ip')).val,
          		    zuletzt: getState(id.replace('.is_online', '.last_seen_by_uap')).val,
                      Mac: getState(id.replace('.is_online','.mac')).val
                  list.push(obj);
              setState(jsonId, JSON.stringify(list), true);
          on({id: persons, change: "ne"}, function(obj) {
              checkOnline();
          checkOnline();
          beim Scriptaufruf kommen aber immer Fehlermedungen, obwohl die Mac-Adresse aber dann im JSON steht, also doch gefunden wird🙄
          javascript.0
          2025-02-02 20:11:34.594	info	script.js.Mein_Ordner.Unifi.Unifi_Geräte: registered 54 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2025-02-02 20:11:34.594	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
          javascript.0
          2025-02-02 20:11:34.594	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
          javascript.0
          2025-02-02 20:11:34.594	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
          javascript.0
          2025-02-02 20:11:34.594	warn	at Array.forEach (<anonymous>)
          javascript.0
          2025-02-02 20:11:34.593	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:13:18
          javascript.0
          2025-02-02 20:11:34.593	warn	getState "unifi.0.default.clients.b8:76:3f:b4:62:75.mac" not found (3)
          javascript.0
          2025-02-02 20:11:34.593	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
          javascript.0
          2025-02-02 20:11:34.593	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
          javascript.0
          2025-02-02 20:11:34.593	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
          javascript.0
          2025-02-02 20:11:34.593	warn	at Array.forEach (<anonymous>)
          javascript.0
          javascript.0
          2025-02-02 20:11:34.592	warn	getState "unifi.0.default.clients.94:53:30:4e:39:ea.mac" not found (3)
          javascript.0
          2025-02-02 20:11:34.592	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
          javascript.0
          2025-02-02 20:11:34.592	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
          javascript.0
          2025-02-02 20:11:34.592	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
          javascript.0
          2025-02-02 20:11:34.592	warn	at Array.forEach (<anonymous>)
          javascript.0
          2025-02-02 20:11:34.592	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:13:18
          javascript.0
          2025-02-02 20:11:34.592	warn	getState "unifi.0.default.clients.54:32:04:55:16:c4.mac" not found (3)
          javascript.0
          2025-02-02 20:11:34.591	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
          javascript.0
          2025-02-02 20:11:34.591	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
          javascript.0
          2025-02-02 20:11:34.591	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
          javascript.0
          2025-02-02 20:11:34.591	warn	at Array.forEach (<anonymous>)
          javascript.0
          2025-02-02 20:11:34.591	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:13:18
          javascript.0
          2025-02-02 20:11:34.591	warn	getState "unifi.0.default.clients.4c:0f:6e:f5:53:84.mac" not found (3)
          javascript.0
          2025-02-02 20:11:34.574	info	Start JavaScript script.js.Mein_Ordner.Unifi.Unifi_Geräte (Javascript/js)
          javascript.0
          2025-02-02 20:11:34.486	info	Stopping script script.js.Mein_Ordner.Unifi.Unifi_Geräte
          • Codierknecht
            Codierknecht Developer Most Active @Snopy_16 last edited by
            @snopy_16
            Es gibt bei Dir Geräte ohne MAC?
            Mac: existsState(id.replace('.is_online','.mac')) ? getState(id.replace('.is_online','.mac')).val : '<ohne>'
            S 2 Replies Last reply Reply Quote 1
              Snopy_16 @Codierknecht last edited by
              @codierknecht
              es gibt tatsächlich Geräte, bei denen im unifi adapter keine MAC Adresse übernommen wird.
              Sonderbar, im Unifi-Controller stehen alle MAC Adressen drin.
                Snopy_16 @Codierknecht last edited by Snopy_16
                @codierknecht
                const jsonId = '0_userdata.0.Unifi.geraete';
                    let list = [];
                        let obj = {
                            name: getState(id.replace('.is_online', '.name')).val,
                            ip: getState(id.replace('.is_online', '.ip')).val,
                            last_seen: getState(id.replace('.is_online', '.last_seen_by_uap')).val
                        list.push(obj);
                    checkOnline();
                Wie kann man das umbauen damit die Liste nach IP oder Name sortiert wird?
                Oder ist das ein erheblicher Aufwand?
                • OliverIO
                  OliverIO @Snopy_16 last edited by OliverIO
                  @snopy_16 sagte in Mehrere Objekte mit deren Datenpunkten in VIS Tabelle:
                  Du kannst dir beiden Sortier-Hilffunktionen hinzufügen und dann im sort-Befehl diese mitgeben.
                  https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort
                  function sortIP(a,b) {
                      return a.ip<b.ip
                  function sortName(a,b) {
                      return a.name<b.name
                  setState(jsonId, JSON.stringify(list.sort(sortName), true);
                    Snopy_16 @OliverIO last edited by
                    @oliverio
                    Danke, werd ich dann gleich mal probieren
                      @oliverio
                          let list = [];
                              let obj = {
                                  //Mac: getState(id.replace('.is_online','.mac')).val
                              list.push(obj);
                          checkOnline();
                      checkOnline();
                      Leider funktioniert diese sort-function bei mir nicht
                      Da steht irgendwas von list not defined
                      Sorry, aber bin in Javascript ein ziemliches Greenhorn.
                      • OliverIO
                        @snopy_16
                        Genaue Fehlermeldung bitte kopieren.
                        Wo sind jetzt die sortierfunktionen?
                        Und du hast die Schreibweise von ip und Name verändert. Das muss in den sortierfunktionen angepasst werden
                          @oliverio
                          Ich checks nicht
                              let list = [];
                                  let obj = {
                                  list.push(obj);
                              checkOnline();
                              return a.IP<b.IP
                              return a.Name<b.Name
                          checkOnline();
                          Fehlermeldung:
                          javascript.0
                          2025-02-15 13:18:32.659	error	at processImmediate (node:internal/timers:485:21)
                          javascript.0
                          2025-02-15 13:18:32.659	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
                          javascript.0
                          2025-02-15 13:18:32.659	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2322:17
                          javascript.0
                          2025-02-15 13:18:32.659	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2224:37)
                          javascript.0
                          2025-02-15 13:18:32.659	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1956:21)
                          javascript.0
                          2025-02-15 13:18:32.659	error	at new Script (node:vm:117:7)
                          javascript.0
                          2025-02-15 13:18:32.659	error	SyntaxError: missing ) after argument list
                          javascript.0
                          2025-02-15 13:18:32.659	error	^
                          javascript.0
                          2025-02-15 13:18:32.659	error	setState(jsonId, JSON.stringify(list.sort(sortName), true);
                          javascript.0
                          2025-02-15 13:18:32.659	error	script.js.Mein_Ordner.Unifi.Unifi_Geräte compile failed: at script.js.Mein_Ordner.Unifi.Unifi_Geräte:31
                          javascript.0
                          2025-02-15 13:18:32.658	info	Start JavaScript script.js.Mein_Ordner.Unifi.Unifi_Geräte (Javascript/js)
                          javascript.0
                          2025-02-15 13:18:32.568	info	Stopping script script.js.Mein_Ordner.Unifi.Unifi_Geräte
                          • OliverIO
                            @snopy_16
                            Jetzt ist es klar. Du sollst deine bisherige Zeile
                            setState durch die von mir geposteten Zeilen ersetzen.
                            an der Stelle, wo du es hin kopiert hast, gibt es in der Tat kein List
                            Warum steht hier
                            https://javascript.info/closure
                              @OliverIO
                              Sorry, kein Fehler aber auch keine Sortierung im json
                                  let list = [];
                                      let obj = {
                                      list.push(obj);
                              //setState(jsonId, JSON.stringify(list), true);
                              return a.ip<b.ip
                              setState(jsonId, JSON.stringify(list.sort(sortName)), true);
                                  checkOnline();
                              checkOnline();
                              • Codierknecht
                                Versuch mal diese Sortierfunktionen:
                                    if (a.ip < b.ip) {
                                        return -1;
                                    } else if (a.ip > b.ip) {
                                        return 1;
                                    } else {
                                        return 0;
                                    if (a.name < b.name) {
                                        return -1;
                                    } else if (a.name > b.name) {
                                        return 1;
                                    } else {
                                        return 0;
                                Dabei ist aber zu beachten, dass Groß- und Kleinschreibung beachtet wird.
                                Wenn das keine Rolle spielen soll, müsste das etwas umformuliert werden.
                                if (a.name.toLowerCase() < b.name.toLowerCase())
                                Und bevor die Frage kommt: Die IP ist ein String und wird auch als solcher sortiert (und nicht Zahlenweise).
                                  @codierknecht
                                  Super, das war es
                                  DANKE
                                  • OliverIO
                                    @snopy_16
                                    seltsam, hab das aus dem gedächtnis aufgeschrieben, ich dachte das funktioniert so.
                                    aber tatsächlich.
                                    Eine universelle Methode wäre auch noch so.
                                    ["ccc","bbb","aaa].sort(new Intl.Collator("de").compare)
                                      @oliverio
                                      Ok, trotzdem auch danke. Freue mich über jede Hilfe
                                      2991
