    4. Mehrere Objekte mit deren Datenpunkten in VIS Tabelle
      Snopy_16 @Oli last edited by
      @Codierknecht
      Ich hab nun die Zeile 12 hinzugefügt (mac-Adresse)
      const persons = $('unifi.0.default.clients.*.is_online').toArray();
      const jsonId = '0_userdata.0.Unifi.Clients';
      function checkOnline() {
          let list = [];
          persons.forEach(function (id) {
              let obj = {
                  online: getState(id).val,
                  Name: getState(id.replace('.is_online', '.name')).val,
                  IP: getState(id.replace('.is_online', '.ip')).val,
      		    zuletzt: getState(id.replace('.is_online', '.last_seen_by_uap')).val,
                  Mac: getState(id.replace('.is_online','.mac')).val
              list.push(obj);
          setState(jsonId, JSON.stringify(list), true);
      on({id: persons, change: "ne"}, function(obj) {
          checkOnline();
      checkOnline();
      beim Scriptaufruf kommen aber immer Fehlermedungen, obwohl die Mac-Adresse aber dann im JSON steht, also doch gefunden wird🙄
      javascript.0
      2025-02-02 20:11:34.594	info	script.js.Mein_Ordner.Unifi.Unifi_Geräte: registered 54 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0
      2025-02-02 20:11:34.594	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
      javascript.0
      2025-02-02 20:11:34.594	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
      javascript.0
      2025-02-02 20:11:34.594	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
      javascript.0
      2025-02-02 20:11:34.594	warn	at Array.forEach (<anonymous>)
      javascript.0
      2025-02-02 20:11:34.593	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:13:18
      javascript.0
      2025-02-02 20:11:34.593	warn	getState "unifi.0.default.clients.b8:76:3f:b4:62:75.mac" not found (3)
      javascript.0
      2025-02-02 20:11:34.593	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
      javascript.0
      2025-02-02 20:11:34.593	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
      javascript.0
      2025-02-02 20:11:34.593	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
      javascript.0
      2025-02-02 20:11:34.593	warn	at Array.forEach (<anonymous>)
      javascript.0
      javascript.0
      2025-02-02 20:11:34.592	warn	getState "unifi.0.default.clients.94:53:30:4e:39:ea.mac" not found (3)
      javascript.0
      2025-02-02 20:11:34.592	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
      javascript.0
      2025-02-02 20:11:34.592	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
      javascript.0
      2025-02-02 20:11:34.592	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
      javascript.0
      2025-02-02 20:11:34.592	warn	at Array.forEach (<anonymous>)
      javascript.0
      2025-02-02 20:11:34.592	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:13:18
      javascript.0
      2025-02-02 20:11:34.592	warn	getState "unifi.0.default.clients.54:32:04:55:16:c4.mac" not found (3)
      javascript.0
      2025-02-02 20:11:34.591	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:28:3
      javascript.0
      2025-02-02 20:11:34.591	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:23:1
      javascript.0
      2025-02-02 20:11:34.591	warn	at checkOnline (script.js.Mein_Ordner.Unifi.Unifi_Geräte:7:13)
      javascript.0
      2025-02-02 20:11:34.591	warn	at Array.forEach (<anonymous>)
      javascript.0
      2025-02-02 20:11:34.591	warn	at script.js.Mein_Ordner.Unifi.Unifi_Geräte:13:18
      javascript.0
      2025-02-02 20:11:34.591	warn	getState "unifi.0.default.clients.4c:0f:6e:f5:53:84.mac" not found (3)
      javascript.0
      2025-02-02 20:11:34.574	info	Start JavaScript script.js.Mein_Ordner.Unifi.Unifi_Geräte (Javascript/js)
      javascript.0
      2025-02-02 20:11:34.486	info	Stopping script script.js.Mein_Ordner.Unifi.Unifi_Geräte
      • Codierknecht
        Codierknecht Developer Most Active @Snopy_16 last edited by
        @snopy_16
        Es gibt bei Dir Geräte ohne MAC?
        Mac: existsState(id.replace('.is_online','.mac')) ? getState(id.replace('.is_online','.mac')).val : '<ohne>'
        S 2 Replies Last reply Reply Quote 1
          Snopy_16 @Codierknecht last edited by
          @codierknecht
          es gibt tatsächlich Geräte, bei denen im unifi adapter keine MAC Adresse übernommen wird.
          Sonderbar, im Unifi-Controller stehen alle MAC Adressen drin.
            Snopy_16 @Codierknecht last edited by Snopy_16
            @codierknecht
            const jsonId = '0_userdata.0.Unifi.geraete';
                let list = [];
                    let obj = {
                        name: getState(id.replace('.is_online', '.name')).val,
                        ip: getState(id.replace('.is_online', '.ip')).val,
                        last_seen: getState(id.replace('.is_online', '.last_seen_by_uap')).val
                    list.push(obj);
                checkOnline();
            Wie kann man das umbauen damit die Liste nach IP oder Name sortiert wird?
            Oder ist das ein erheblicher Aufwand?
            • OliverIO
              OliverIO @Snopy_16 last edited by OliverIO
              @snopy_16 sagte in Mehrere Objekte mit deren Datenpunkten in VIS Tabelle:
              Du kannst dir beiden Sortier-Hilffunktionen hinzufügen und dann im sort-Befehl diese mitgeben.
              https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort
              function sortIP(a,b) {
                  return a.ip<b.ip
              function sortName(a,b) {
                  return a.name<b.name
              setState(jsonId, JSON.stringify(list.sort(sortName), true);
                Snopy_16 @OliverIO last edited by
                @oliverio
                Danke, werd ich dann gleich mal probieren
                  @oliverio
                      let list = [];
                          let obj = {
                              //Mac: getState(id.replace('.is_online','.mac')).val
                          list.push(obj);
                      checkOnline();
                  checkOnline();
                  Leider funktioniert diese sort-function bei mir nicht
                  Da steht irgendwas von list not defined
                  Sorry, aber bin in Javascript ein ziemliches Greenhorn.
                  • OliverIO
                    @snopy_16
                    Genaue Fehlermeldung bitte kopieren.
                    Wo sind jetzt die sortierfunktionen?
                    Und du hast die Schreibweise von ip und Name verändert. Das muss in den sortierfunktionen angepasst werden
                      @oliverio
                      Ich checks nicht
                          let list = [];
                              let obj = {
                              list.push(obj);
                          checkOnline();
                          return a.IP<b.IP
                          return a.Name<b.Name
                      checkOnline();
                      Fehlermeldung:
                      javascript.0
                      2025-02-15 13:18:32.659	error	at processImmediate (node:internal/timers:485:21)
                      javascript.0
                      2025-02-15 13:18:32.659	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
                      javascript.0
                      2025-02-15 13:18:32.659	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2322:17
                      javascript.0
                      2025-02-15 13:18:32.659	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2224:37)
                      javascript.0
                      2025-02-15 13:18:32.659	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1956:21)
                      javascript.0
                      2025-02-15 13:18:32.659	error	at new Script (node:vm:117:7)
                      javascript.0
                      2025-02-15 13:18:32.659	error	SyntaxError: missing ) after argument list
                      javascript.0
                      2025-02-15 13:18:32.659	error	^
                      javascript.0
                      2025-02-15 13:18:32.659	error	setState(jsonId, JSON.stringify(list.sort(sortName), true);
                      javascript.0
                      2025-02-15 13:18:32.659	error	script.js.Mein_Ordner.Unifi.Unifi_Geräte compile failed: at script.js.Mein_Ordner.Unifi.Unifi_Geräte:31
                      javascript.0
                      2025-02-15 13:18:32.658	info	Start JavaScript script.js.Mein_Ordner.Unifi.Unifi_Geräte (Javascript/js)
                      javascript.0
                      2025-02-15 13:18:32.568	info	Stopping script script.js.Mein_Ordner.Unifi.Unifi_Geräte
                      • OliverIO
                        @snopy_16
                        Jetzt ist es klar. Du sollst deine bisherige Zeile
                        setState durch die von mir geposteten Zeilen ersetzen.
                        an der Stelle, wo du es hin kopiert hast, gibt es in der Tat kein List
                        Warum steht hier
                        https://javascript.info/closure
                          @OliverIO
                          Sorry, kein Fehler aber auch keine Sortierung im json
                              let list = [];
                                  let obj = {
                                  list.push(obj);
                          //setState(jsonId, JSON.stringify(list), true);
                          return a.ip<b.ip
                          setState(jsonId, JSON.stringify(list.sort(sortName)), true);
                              checkOnline();
                          checkOnline();
                          • Codierknecht
                            Versuch mal diese Sortierfunktionen:
                                if (a.ip < b.ip) {
                                    return -1;
                                } else if (a.ip > b.ip) {
                                    return 1;
                                } else {
                                    return 0;
                                if (a.name < b.name) {
                                    return -1;
                                } else if (a.name > b.name) {
                                    return 1;
                                } else {
                                    return 0;
                            Dabei ist aber zu beachten, dass Groß- und Kleinschreibung beachtet wird.
                            Wenn das keine Rolle spielen soll, müsste das etwas umformuliert werden.
                            if (a.name.toLowerCase() < b.name.toLowerCase())
                            Und bevor die Frage kommt: Die IP ist ein String und wird auch als solcher sortiert (und nicht Zahlenweise).
                              @codierknecht
                              Super, das war es
                              DANKE
                              • OliverIO
                                @snopy_16
                                seltsam, hab das aus dem gedächtnis aufgeschrieben, ich dachte das funktioniert so.
                                aber tatsächlich.
                                Eine universelle Methode wäre auch noch so.
                                ["ccc","bbb","aaa].sort(new Intl.Collator("de").compare)
                                  @oliverio
                                  Ok, trotzdem auch danke. Freue mich über jede Hilfe
                                  3010
