ioBroker in Proxmox gesperrt, wer kann helfen
@altersrentner sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
@homoran sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
zu wenig Platz
Ja, habe ich verstanden,
Aber wie ändern?
MfG Michaelhab leider schon länger kein Proxmox mehr, Sorry
Sicher das nicht dein Backuplaufwerk voll ist?
@ticaki sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
Ja, aber wie erweitern?
INFO: starting new backup job: vzdump 100 --remove 0 --notification-mode auto --notes-template 'Backup nach Sperrung 150225' --compress zstd --mode snapshot --node pve --storage local INFO: Starting Backup of VM 100 (lxc) INFO: Backup started at 2025-02-15 11:17:38 INFO: status = running INFO: CT Name: iobroker INFO: including mount point rootfs ('/') in backup INFO: found old vzdump snapshot (force removal) Logical volume "snap_vm-100-disk-1_vzdump" successfully removed. INFO: backup mode: snapshot INFO: ionice priority: 7 INFO: create storage snapshot 'vzdump' WARNING: You have not turned on protection against thin pools running out of space. WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full. Logical volume "snap_vm-100-disk-1_vzdump" created. WARNING: Sum of all thin volume sizes (192.00 GiB) exceeds the size of thin pool pve/data and the amount of free space in volume group (16.00 GiB). INFO: creating vzdump archive '/var/lib/vz/dump/vzdump-lxc-100-2025_02_15-11_17_38.tar.zst' INFO: cleanup temporary 'vzdump' snapshot Logical volume "snap_vm-100-disk-1_vzdump" successfully removed. ERROR: Backup of VM 100 failed - command 'set -o pipefail && lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar cpf - --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.*' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' --one-file-system '--warning=no-file-ignored' '--directory=/var/lib/vz/dump/vzdump-lxc-100-2025_02_15-11_17_38.tmp' ./etc/vzdump/pct.conf ./etc/vzdump/pct.fw '--directory=/mnt/vzsnap0' --no-anchored '--exclude=lost+found' --anchored '--exclude=./tmp/?*' '--exclude=./var/tmp/?*' '--exclude=./var/run/?*.pid' ./ | zstd '--threads=1' >/var/lib/vz/dump/vzdump-lxc-100-2025_02_15-11_17_38.tar.dat' failed: interrupted by signal INFO: Failed at 2025-02-15 11:18:59 INFO: Backup job finished with errors INFO: notified via target `mail-to-root` TASK ERROR: job errors -
Erstmal müsste man sehen wo die automatsichen Backups hingehen, dann wieviele da sind. Anschließend entscheiden ob den Speicherplatz vergrößern will oder die Vorrätig gehaltenen Backups reduzieren.
Vielleicht hab ich es ja übersehen, wenn ja bitte gib mir links auf die Postings.
Wie oder wo kann ich die Situation bereinigen?
ich nehme an, das trifft zu
https://forum.proxmox.com/threads/backup-of-ct-fails-vm-works.135900/
übersetztKurz gesagt: Um unprivilegierte LXC zu sichern, benötigen sowohl UID 0 als auch UID 100000 Schreibberechtigungen für den temporären Speicher (der standardmäßig ein Unterverzeichnis Ihres Ziel-Backup-Speichers ist). Stellen Sie also entweder sicher, dass UID 100000 auf Ihrem NAS auch die Rechte hat, in das Share zu schreiben, oder bearbeiten Sie Ihre /etc/vzdump.conf und weisen Sie das tmpdir auf einen Ordner mit ausreichenden Rechten wie "/tmp" zu, der 777 hat. -
Danke für deine Nachricht
Hier gehen sie hin:
Hilft das weiter?
MfG Michael -
@crunchip sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
Ist sehr kompliziert für mich,
Ich glaube mich zu erinnern, das der Speicher auch nachträglich vergrößert werden kann.
Aber wie, das ist die Frage.
MfG Michael -
damit ist klar, warum das nicht mehr geht. Lokal speichert man am besten garkeine Backups, oder nur zum testen mal eins.
Binde ein anderes Laufwerk in den Proxmox-Host ein, oder haeng per usb ne externe Festplatte dran, oder per SMB/NFS n Drive einbinden oder oder oder..
Vergroessern bringt da nix, du sicherst ja deine Daten nicht weg, sondern nur im System, wenn das die Kraetsche macht, haste auch kein Backup mehr.
@altersrentner
Aber zu dem kompliziert - dort steht das du das temporäre Verzeichnis in einer Datei ändern sollst. Wenn du den Inhalt der Datei hier postet ist bestimmt einer so nett und ändert es für dich.
@ilovegym sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
OK, Habe ich verstanden.
Reicht es dann wie schon beschrieben meine täglichen Sicherungen
über BackitUp in Google Drive zur Wiederherstellung zu verwenden?
Dann wäre alles geklärt.
MfG Michael -
über BackitUp in Google Drive zur Wiederherstellung zu verwenden?Hallo Michael,
wenn du sonst keine "extras" ( wie Redis oder sonstige besondere Einstellungen ) auf dem iobroker VM laufen hast, reicht das Backup mit dem Backitup-Adapter.Schoen ist ein Backup von der VM natuerlich immer.
macht ja keinen Sinn, hier nochmal in deutsch
https://forum.proxmox.com/threads/proxmox-backup-ct-auf-nas.158704/ -
OK, danke für den Hinweis
Werde ich mich damit beschäftigen wie ich eine Festplatte einbinden kann oder muss.@crunchip sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
Danke auch dir nochmal. Ist zwar in unserer Landessprache aber für mich fast unerklärlich.
MfG Michael -
@altersrentner da hatte @haus-automatisierung ein super video zu gemacht.
@altersrentner also mit eigenen Worten
- backups machen nur Sinn, wenn extern gesichert wird
- bedingt wäre auch ok, wenn wenigsten ein Stick oder Festplatte daran hängt und darauf die backups laufen
- LXC gibt es privilegiert und unprivilegiert, hängt mit den Rechten (Sicherheit) zusammen
- diesbezüglich muss man dann eben für unprivilegiert LXC die
/etc/vzdump.confbearbeiten und auftmpstellen, damit das backup zwischengespeichert werden kann
@siggi0904 sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
Danke, habe ich mir gerade angesehen und glaube das kann ich realisieren.
Mal sehen ob ich noch eine Festplatte finde.@crunchip sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
Nochmals danke,
wie gesagt werde versuchen über eine externe FP zu sichern
MfG Michael -
@altersrentner
Wenn ein NAS vorhanden ist, kann man eine Freigabe als Backupverzeichnis vom PVE einrichten.Tschau
Uwe -
@uweklatt sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
Hallo Uwe,
Leider nicht, heißt nur eine alte die ich schon lange nicht mehr nutze,
aber gestern habe ich eine 2TB externe Festplatte eingebunden und
eine VM installiert. Die Festplatte wurde auf ext4 konfiguriert und nun muss ich sehen,
wie ich sie in die VM Test(102) eingebunden bekomme,
Mir haben ganz schön die Socken gequalmt
MfG Michael -
da fehlt noch das einbinden unter Storage im Datencenter, dann ist die Festplatte auch fuer alle und das Backup zu nutzen.
Hier mal eine Anleitung in Deutsch, die ich zufaellig gefunden habe, die ersten Schritte hast du ja schon...https://www.server-verstehen.de/festplatte-proxmox-einbinden/
Danke für die Anleitung
MfG Michael
