    3. Einsteigerfragen
    4. Installation
    5. Adapter
    Adapter
    • Codierknecht
      Codierknecht Developer Most Active @arnold last edited by
      @arnold
      Im Stable sollte das eigentlich so aussehen:
      Zeig' bitte mal Deine Repo-Einstellungen.
        arnold @Codierknecht last edited by arnold
        @codierknecht
        • Codierknecht
          @arnold
          Die Repos sind OK.
          Aber Dein System scheint etwas veraltet.
          Bitte mal die Langfassung von
          iob diag
          hier in Code-Tags</> posten.
          A 2 Replies Last reply Reply Quote 0
            @codierknecht said in Adapter:
            iob diag
            ```bash
                                    v.2025-02-02
               Static hostname: raspberrypi4-iob
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               32 bit
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            Display-Server:         false
            Boot Target:            multi-user.target
            Pending OS-Updates:     0
            Error: Object "system.repositories" not found
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/nodejs         v18.20.6
            /usr/bin/node           v18.20.6
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.4
            Recommended versions are nodejs 18.20.6 and npm 10.8.2
            nodeJS installation is correct
            MEMORY:
            Mem:            3.8G        2.0G        830M        0.0K        969M        1.8G
            Swap:            99M          0B         99M
            Total:          3.9G        2.0G        930M
            Active iob-Instances:   30
            List is empty
            ioBroker Core:          js-controller           6.0.9
                                    admin                   6.17.14
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 6030, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 6032, bind: 0.0.0.0 (SSL), run as: admin
            Objects:                12001
            States:                 10862
            Size of iob-Database:
            13M     /opt/iobroker/iobroker-data/objects.jsonl
            12M     /opt/iobroker/iobroker-data/objects.json.migrated
            12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            0       /opt/iobroker/iobroker-data/objects.json.broken
            22M     /opt/iobroker/iobroker-data/states.jsonl
            1.6M    /opt/iobroker/iobroker-data/states.json.migrated
            1.6M    /opt/iobroker/iobroker-data/states.json.bak.migrated
            0       /opt/iobroker/iobroker-data/states.json.broken
            Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
              @codierknecht
              bei start bekomme ich Meldung
              Ausgeführt
              sudo apt-get update
              sudo apt-get upgrade
              iobroker stop
              iobroker fix
              iobroker start
              eventuell
              sudo reboot
              • Codierknecht
                @arnold
                Das ist nur die Summary.
                "bullseye" hat bereits sein EOL erreicht.
                Wie in der Ausgabe schon angemerkt, solltest Du das beizeiten auf "bookworm" heben.
                Du könntest aber zwischenzeitlich zumindest mal Node aktualisieren:
                iob nodejs-update 20
                  Thomas Braun Most Active @Codierknecht last edited by
                  @codierknecht sagte in Adapter:
                  Korrekt, allerdings würde ich da nix 'heben', bei RaspberryOS ist da eine komplette NEUinstallation angesagt. Noch dazu, wenn die Geschichte momentan mit 32Bit läuft.
                    also neu installieren ,Habe schon lange nicht gemacht
                    Erst Bakitup sichern
                    dann installieren ;
                    _Raspberry Pi OS (64-bit)bookworm
                    _Iobroker
                    _Grafana/InfluxDB
                    _Backitup
                    Und gespeicherte backitup von NAS wiederherstellen
                      Thomas Braun Most Active @arnold last edited by
                      @arnold
                      Ja.
                        und wieder 17 updates
                        Nach node 20 Aktualisierung
                        Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Codierknecht
                          @arnold sagte in Adapter:
                          Soll heißen?
                          Sieht doch jetzt korrekt aus.
                            Wo? Im OS? Im ioBroker?
                            iob diag
                            schaut nun wie aus?
                            Gerne auch die Langfassung.
                              @codierknecht mit der nodejs Updates auf 20 habe ich das System "aufgeweckt "
                              ich hatte seit neu Installation auf bullseye vor 8 Monaten seit 7 Monate keine Adapter Updates und jetzt 17
                              • mcm1957
                                mcm1957 last edited by
                                Möglicherweise liegt es auch darn, dass immer mehr Adapter node.js20 als minimum verlangen
                                  arnold @Thomas Braun last edited by
                                  nur die summary die lange Version weiß nicht wie ?
                                  ```bash
                                                          v.2025-02-02
                                           Icon name: computer
                                        Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               32 bit
                                  User-ID:                1000
                                  Pending iob updates:    2
                                  /usr/bin/nodejs         v20.18.3
                                  /usr/bin/node           v20.18.3
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  /usr/bin/corepack       0.30.0
                                  Recommended versions are nodejs 20.18.3 and npm 10.8.2
                                  MEMORY:
                                  Mem:            3.8G        2.0G        971M        0.0K        843M        1.9G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        2.0G        1.1G
                                  Active iob-Instances:   29
                                  Upgrade policy: none
                                  ioBroker Core:          js-controller           7.0.6
                                                          admin                   7.4.10
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                12013
                                  States:                 10860
                                  22M     /opt/iobroker/iobroker-data/objects.jsonl
                                  15M     /opt/iobroker/iobroker-data/states.jsonl
                                    Homoran Global Moderator Administrators @arnold last edited by
                                    nur die summary
                                    da stehen die Informationen nicht drin.
                                    die kommt davor.
                                    Du darfst nicht den anykey drücken 😁
                                      arnold @Homoran last edited by
                                      ```bash
                                      Script v.2025-02-02
                                      *** BASE SYSTEM ***
                                              Icon name: computer
                                           Architecture: arm64
                                      OS is similar to: debian
                                      Model           : Raspberry Pi 4 Model B Rev 1.1
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 32 bit
                                      Systemuptime and Load:
                                      12:13:04 up 21:19,  2 users,  load average: 1.00, 0.59, 0.68
                                      CPU threads: 4
                                      *** LIFE CYCLE STATUS ***
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** TIME AND TIMEZONES ***
                                                    Local time: Tue 2025-02-18 12:13:04 CET
                                                Universal time: Tue 2025-02-18 11:13:04 UTC
                                                      RTC time: n/a
                                                   NTP service: active
                                               RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                      *** DISPLAY-SERVER SETUP ***
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        2.0G        925M        0.0K        889M        1.9G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        2.0G        1.0G
                                              3794 M total memory
                                              1979 M used memory
                                              2162 M active memory
                                               356 M inactive memory
                                               925 M free memory
                                                59 M buffer memory
                                               830 M swap cache
                                                99 M total swap
                                                 0 M used swap
                                                99 M free swap
                                      top - 12:13:05 up 21:19,  2 users,  load average: 1.00, 0.59, 0.68
                                      Tasks: 200 total,   1 running, 199 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  2.8 us,  2.8 sy,  0.0 ni, 94.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3794.3 total,    925.5 free,   1979.4 used,    889.4 buff/cache
                                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1853.0 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       29G   18G   11G  63% /
                                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                      tmpfs          tmpfs     759M  896K  758M   1% /run
                                      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                      [Mon Feb 17 14:54:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:40:6D:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c2ae5e61-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      [Mon Feb 17 14:54:03 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Mon Feb 17 14:54:03 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Mon Feb 17 14:54:06 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET  SOURCE         FSTYPE OPTIONS
                                      /       /dev/mmcblk0p2 ext4   rw,noatime
                                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                      /var:
                                      6.5G    /var/
                                      3.2G    /var/cache/apt/archives
                                      3.2G    /var/cache/apt
                                      3.2G    /var/cache
                                      3.1G    /var/log
                                      Archived and active journals take up 2.9G in the file system.
                                      /opt/iobroker/backups:
                                      4.0K    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      1.3G    /opt/iobroker/iobroker-data/
                                      1.1G    /opt/iobroker/iobroker-data/files
                                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                      23M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_96afdeed50c8eb118ac2c4c3de5b81b4-if00-port0
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyUSB0
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                       Installed: 20.18.3-1nodesource1
                                       Candidate: 20.18.3-1nodesource1
                                       Version table:
                                      *** 20.18.3-1nodesource1 1001
                                             500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                             100 /var/lib/dpkg/status
                                          20.18.2-1nodesource1 1001
                                          20.18.1-1nodesource1 1001
                                          20.18.0-1nodesource1 1001
                                          20.17.0-1nodesource1 1001
                                          20.16.0-1nodesource1 1001
                                          20.15.1-1nodesource1 1001
                                          20.15.0-1nodesource1 1001
                                          20.14.0-1nodesource1 1001
                                          20.13.1-1nodesource1 1001
                                          20.13.0-1nodesource1 1001
                                          20.12.2-1nodesource1 1001
                                          20.12.1-1nodesource1 1001
                                          20.12.0-1nodesource1 1001
                                          20.11.1-1nodesource1 1001
                                          20.11.0-1nodesource1 1001
                                          20.10.0-1nodesource1 1001
                                          20.9.0-1nodesource1 1001
                                          20.8.1-1nodesource1 1001
                                          20.8.0-1nodesource1 1001
                                          20.7.0-1nodesource1 1001
                                          20.6.1-1nodesource1 1001
                                          20.6.0-1nodesource1 1001
                                          20.5.1-1nodesource1 1001
                                          20.5.0-1nodesource1 1001
                                          20.4.0-1nodesource1 1001
                                          20.3.1-1nodesource1 1001
                                          20.3.0-1nodesource1 1001
                                          20.2.0-1nodesource1 1001
                                          20.1.0-1nodesource1 1001
                                          20.0.0-1nodesource1 1001
                                          12.22.12~dfsg-1~deb11u5 500
                                             500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      raspberrypi4-iob    raspberrypi4-iob (version: 7.0.6, hostname: raspberrypi4-iob, alive, uptime: 75426)
                                      Core adapters versions
                                      js-controller:  7.0.6
                                      admin:          7.4.10
                                      javascript:     8.8.3
                                      nodejs modules from github:     0
                                      Adapter State
                                      + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iob                         -  enabled
                                      + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
                                      + system.adapter.ble.0                    : ble                   : raspberrypi4-iob                         -  enabled
                                       system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         - disabled
                                       system.adapter.daswetter.0              : daswetter             : raspberrypi4-iob                         -  enabled
                                      + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
                                       system.adapter.dwd.0                    : dwd                   : raspberrypi4-iob                         -  enabled
                                       system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
                                       system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
                                       system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4-iob                         - disabled
                                      + system.adapter.influxdb.0               : influxdb              : raspberrypi4-iob                         -  enabled, port: 8086
                                      + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
                                      + system.adapter.iot.0                    : iot                   : raspberrypi4-iob                         -  enabled
                                      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4-iob                         -  enabled
                                      + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4-iob                         -  enabled, port: 54321
                                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iob                         -  enabled, port: 1885, bind: 0.0.0.0
                                       system.adapter.openweathermap.0         : openweathermap        : raspberrypi4-iob                         -  enabled
                                      + system.adapter.parcel.0                 : parcel                : raspberrypi4-iob                         -  enabled
                                      + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
                                      + system.adapter.scenes.0                 : scenes                : raspberrypi4-iob                         -  enabled
                                      + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.1                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1884, bind: 0.0.0.0
                                      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4-iob                         -  enabled
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iob                         -  enabled
                                      + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.text2command.0           : text2command          : raspberrypi4-iob                         -  enabled
                                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-iob                         -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
                                       system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         - disabled
                                      + system.adapter.volumio.0                : volumio               : raspberrypi4-iob                         -  enabled
                                      + system.adapter.wled.0                   : wled                  : raspberrypi4-iob                         -  enabled
                                       system.adapter.worx.0                   : worx                  : raspberrypi4-iob                         - disabled
                                      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/ttyUSB0
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 7.4.10   , installed 7.4.10
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                      Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                      Adapter    "daswetter"    : 3.2.2    , installed 3.1.15 [Updatable]
                                      Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                      Controller "js-controller": 7.0.6    , installed 7.0.6
                                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                      Adapter    "rpi2"         : 2.3.1    , installed 1.3.2  [Updatable]
                                      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                      Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Adapter    "volumio"      : 0.2.0    , installed 0.2.0
                                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                      Adapter    "worx"         : 3.1.1    , installed 3.1.1
                                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                                      Objects and States
                                      Objects:        12083
                                      States:         10918
                                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                      W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Get:3 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
                                      Get:4 https://packages.grafana.com/oss/deb stable InRelease [7661 B]
                                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Err:3 https://repos.influxdata.com/debian stretch InRelease
                                      Err:4 https://packages.grafana.com/oss/deb stable InRelease
                                      Fetched 12.9 kB in 2s (8527 B/s)
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3446135    31835/cupsd
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       125115     32448/iobroker.js-c
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       125110     32448/iobroker.js-c
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       741193     2813/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       698309     21776/io.sonoff.1
                                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       741192     2813/io.mqtt.0
                                      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15767      580/vncserver-x11-c
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15744      590/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11814      566/influxd
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16638      566/influxd
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       124790     513/io.simple-api.0
                                      tcp6       0      0 :::6032                 :::*                    LISTEN      1001       965306     9664/io.web.0
                                      tcp6       0      0 :::6030                 :::*                    LISTEN      1001       790240     18553/io.admin.0
                                      tcp6       0      0 :::5900                 :::*                    LISTEN      0          15766      580/vncserver-x11-c
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15746      590/sshd: /usr/sbin
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3446134    31835/cupsd
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      115        16561      547/grafana-server
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13290      499/dhcpcd
                                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       126162     32601/io.mihome-vac
                                      udp        0      0 0.0.0.0:56186           0.0.0.0:*                           108        11686      425/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       128197     782/io.wled.0
                                      udp        0      0 192.168.178.80:5353     0.0.0.0:*                           1001       126562     32718/io.tr-064.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11684      425/avahi-daemon: r
                                      udp6       0      0 :::36846                :::*                                108        11687      425/avahi-daemon: r
                                      udp6       0      0 :::546                  :::*                                0          16434      499/dhcpcd
                                      udp6       0      0 :::5353                 :::*                                108        11685      425/avahi-daemon: r
                                      2025-02-18 12:12:44.623  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:12:45.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
                                      2025-02-18 12:12:45.538  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                      2025-02-18 12:12:47.720  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:12:48.888  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:02.402  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:04.448  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:05.713  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                      2025-02-18 12:13:07.632  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:08.730  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:15.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
                                      2025-02-18 12:13:22.227  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:24.286  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:25.907  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                      2025-02-18 12:13:27.392  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:28.487  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:41.848  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:43.927  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:45.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
                                      2025-02-18 12:13:46.107  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                      2025-02-18 12:13:46.558  - info: javascript.0 (16002) Stopping script script.js.common.Heizung_Winter_-10-0_Grad_24h_Probe
                                      2025-02-18 12:13:47.005  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:13:48.209  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:14:01.674  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2025-02-18 12:14:03.717  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                        A Former User @arnold last edited by
                                        @arnold
                                        Ich schlage vor, bevor du an dem toten System (Debian Bullseye, wird nicht mehr supported) weiter arbeitest, nimm ne neue SD Karte, installier Debian Bookworm in der Lite-Version 64bit, dann installierst du die BS-Updates, Curl, dann eine Zeile fuer iobroker zum installieren, reboot, dann ein restore vom aktuellen Backup und du bist erstmal wieder save.
                                        Dann kann man auch nach weiteren Fehlern suchen, die vielleicht mitgeschleppt wurden, meistens sind die mit dem Update schon behoben.
                                        Iobroker haste ja relativ aktuell.
                                          arnold @Guest last edited by
                                          @ilovegym said in Adapter:
                                          Bookworm
                                          werde demnächst auf Bookworm umstellen (neu Installation )aber da ict noch Grafana und Influxdb
                                          da bekomme ich Fehler bei Telegram
                                          Backitup:
                                          Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
                                          grafana: {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n    at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\n    at IncomingMessage.emit (node:events:530:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n    at processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.7.9","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.80:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_RESPONSE","status":500}
                                            A Former User @arnold last edited by A Former User
                                            @arnold
                                            ist Grafana und Influx etwa auch auf dem iobroker-Host installiert?
                                            Falls ja, dann mach davon auch ein backup und installier das auch neu. Wuerde ich aber aufm anderen Host installieren, alles auf einen, hat viele Nachteile..
                                            Edit:
                                            Grafana und Influx kannste auch ohne Backitup Adapter sichern, da musste du halt mal schauen, wo es klemmt.. oder nimm dafuer halt ein aelteres Backup, wo es noch funktioniert hat..
                                            81.1k
                                            37
                                            3406
