    3. Einsteigerfragen
    4. Installation
    5. Adapter
    Adapter
      arnold @Codierknecht last edited by arnold
      @codierknecht said in Adapter:
      iob diag
      ```bash
                              v.2025-02-02
         Static hostname: raspberrypi4-iob
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               32 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Error: Object "system.repositories" not found
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.6
      /usr/bin/node           v18.20.6
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      Recommended versions are nodejs 18.20.6 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            3.8G        2.0G        830M        0.0K        969M        1.8G
      Swap:            99M          0B         99M
      Total:          3.9G        2.0G        930M
      Active iob-Instances:   30
      List is empty
      ioBroker Core:          js-controller           6.0.9
                              admin                   6.17.14
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 6030, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 6032, bind: 0.0.0.0 (SSL), run as: admin
      Objects:                12001
      States:                 10862
      Size of iob-Database:
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      22M     /opt/iobroker/iobroker-data/states.jsonl
      1.6M    /opt/iobroker/iobroker-data/states.json.migrated
      1.6M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        @codierknecht
        bei start bekomme ich Meldung
        Ausgeführt
        sudo apt-get update
        sudo apt-get upgrade
        iobroker stop
        iobroker fix
        iobroker start
        eventuell
        sudo reboot
        • Codierknecht
          Codierknecht Developer Most Active @arnold last edited by
          @arnold
          Das ist nur die Summary.
          "bullseye" hat bereits sein EOL erreicht.
          Wie in der Ausgabe schon angemerkt, solltest Du das beizeiten auf "bookworm" heben.
          Du könntest aber zwischenzeitlich zumindest mal Node aktualisieren:
          iob nodejs-update 20
            Thomas Braun Most Active @Codierknecht last edited by
            @codierknecht sagte in Adapter:
            Korrekt, allerdings würde ich da nix 'heben', bei RaspberryOS ist da eine komplette NEUinstallation angesagt. Noch dazu, wenn die Geschichte momentan mit 32Bit läuft.
              also neu installieren ,Habe schon lange nicht gemacht
              Erst Bakitup sichern
              dann installieren ;
              _Raspberry Pi OS (64-bit)bookworm
              _Iobroker
              _Grafana/InfluxDB
              _Backitup
              Und gespeicherte backitup von NAS wiederherstellen
                Thomas Braun Most Active @arnold last edited by
                @arnold
                Ja.
                  und wieder 17 updates
                  Nach node 20 Aktualisierung
                  Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Codierknecht
                    @arnold sagte in Adapter:
                    Soll heißen?
                    Sieht doch jetzt korrekt aus.
                      Wo? Im OS? Im ioBroker?
                      iob diag
                      schaut nun wie aus?
                      Gerne auch die Langfassung.
                        @codierknecht mit der nodejs Updates auf 20 habe ich das System "aufgeweckt "
                        ich hatte seit neu Installation auf bullseye vor 8 Monaten seit 7 Monate keine Adapter Updates und jetzt 17
                        • mcm1957
                          mcm1957 last edited by
                          Möglicherweise liegt es auch darn, dass immer mehr Adapter node.js20 als minimum verlangen
                            arnold @Thomas Braun last edited by
                            nur die summary die lange Version weiß nicht wie ?
                            ```bash
                                                    v.2025-02-02
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               32 bit
                            User-ID:                1000
                            Pending iob updates:    2
                            /usr/bin/nodejs         v20.18.3
                            /usr/bin/node           v20.18.3
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.30.0
                            Recommended versions are nodejs 20.18.3 and npm 10.8.2
                            MEMORY:
                            Mem:            3.8G        2.0G        971M        0.0K        843M        1.9G
                            Swap:            99M          0B         99M
                            Total:          3.9G        2.0G        1.1G
                            Active iob-Instances:   29
                            Upgrade policy: none
                            ioBroker Core:          js-controller           7.0.6
                                                    admin                   7.4.10
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                12013
                            States:                 10860
                            22M     /opt/iobroker/iobroker-data/objects.jsonl
                            15M     /opt/iobroker/iobroker-data/states.jsonl
                              Homoran Global Moderator Administrators @arnold last edited by
                              nur die summary
                              da stehen die Informationen nicht drin.
                              die kommt davor.
                              Du darfst nicht den anykey drücken 😁
                                arnold @Homoran last edited by
                                ```bash
                                Script v.2025-02-02
                                *** BASE SYSTEM ***
                                        Icon name: computer
                                     Architecture: arm64
                                OS is similar to: debian
                                Model           : Raspberry Pi 4 Model B Rev 1.1
                                Docker          : false
                                Virtualization  : none
                                Kernel          : aarch64
                                Userland        : 32 bit
                                Systemuptime and Load:
                                12:13:04 up 21:19,  2 users,  load average: 1.00, 0.59, 0.68
                                CPU threads: 4
                                *** LIFE CYCLE STATUS ***
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                Previously detected issues:
                                *** TIME AND TIMEZONES ***
                                              Local time: Tue 2025-02-18 12:13:04 CET
                                          Universal time: Tue 2025-02-18 11:13:04 UTC
                                                RTC time: n/a
                                             NTP service: active
                                         RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                *** DISPLAY-SERVER SETUP ***
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        2.0G        925M        0.0K        889M        1.9G
                                Swap:            99M          0B         99M
                                Total:          3.9G        2.0G        1.0G
                                        3794 M total memory
                                        1979 M used memory
                                        2162 M active memory
                                         356 M inactive memory
                                         925 M free memory
                                          59 M buffer memory
                                         830 M swap cache
                                          99 M total swap
                                           0 M used swap
                                          99 M free swap
                                top - 12:13:05 up 21:19,  2 users,  load average: 1.00, 0.59, 0.68
                                Tasks: 200 total,   1 running, 199 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  2.8 us,  2.8 sy,  0.0 ni, 94.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3794.3 total,    925.5 free,   1979.4 used,    889.4 buff/cache
                                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1853.0 avail Mem
                                *** FAILED SERVICES ***
                                0 loaded units listed.
                                *** DMESG CRITICAL ERRORS ***
                                No critical errors detected
                                *** FILESYSTEM ***
                                /dev/root      ext4       29G   18G   11G  63% /
                                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                tmpfs          tmpfs     759M  896K  758M   1% /run
                                /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                [Mon Feb 17 14:54:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:40:6D:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c2ae5e61-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Mon Feb 17 14:54:03 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Mon Feb 17 14:54:03 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Mon Feb 17 14:54:06 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                Show mounted filesystems:
                                TARGET  SOURCE         FSTYPE OPTIONS
                                /       /dev/mmcblk0p2 ext4   rw,noatime
                                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                /var:
                                6.5G    /var/
                                3.2G    /var/cache/apt/archives
                                3.2G    /var/cache/apt
                                3.2G    /var/cache
                                3.1G    /var/log
                                Archived and active journals take up 2.9G in the file system.
                                /opt/iobroker/backups:
                                4.0K    /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                1.3G    /opt/iobroker/iobroker-data/
                                1.1G    /opt/iobroker/iobroker-data/files
                                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                23M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_96afdeed50c8eb118ac2c4c3de5b81b4-if00-port0
                                HINT:
                                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                /dev/ttyUSB0
                                *** NodeJS-Installation ***
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Installed: 20.18.3-1nodesource1
                                 Candidate: 20.18.3-1nodesource1
                                 Version table:
                                *** 20.18.3-1nodesource1 1001
                                       500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                       100 /var/lib/dpkg/status
                                    20.18.2-1nodesource1 1001
                                    20.18.1-1nodesource1 1001
                                    20.18.0-1nodesource1 1001
                                    20.17.0-1nodesource1 1001
                                    20.16.0-1nodesource1 1001
                                    20.15.1-1nodesource1 1001
                                    20.15.0-1nodesource1 1001
                                    20.14.0-1nodesource1 1001
                                    20.13.1-1nodesource1 1001
                                    20.13.0-1nodesource1 1001
                                    20.12.2-1nodesource1 1001
                                    20.12.1-1nodesource1 1001
                                    20.12.0-1nodesource1 1001
                                    20.11.1-1nodesource1 1001
                                    20.11.0-1nodesource1 1001
                                    20.10.0-1nodesource1 1001
                                    20.9.0-1nodesource1 1001
                                    20.8.1-1nodesource1 1001
                                    20.8.0-1nodesource1 1001
                                    20.7.0-1nodesource1 1001
                                    20.6.1-1nodesource1 1001
                                    20.6.0-1nodesource1 1001
                                    20.5.1-1nodesource1 1001
                                    20.5.0-1nodesource1 1001
                                    20.4.0-1nodesource1 1001
                                    20.3.1-1nodesource1 1001
                                    20.3.0-1nodesource1 1001
                                    20.2.0-1nodesource1 1001
                                    20.1.0-1nodesource1 1001
                                    20.0.0-1nodesource1 1001
                                    12.22.12~dfsg-1~deb11u5 500
                                       500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                No problems detected
                                Errors in npm tree: 0
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                raspberrypi4-iob    raspberrypi4-iob (version: 7.0.6, hostname: raspberrypi4-iob, alive, uptime: 75426)
                                Core adapters versions
                                js-controller:  7.0.6
                                admin:          7.4.10
                                javascript:     8.8.3
                                nodejs modules from github:     0
                                Adapter State
                                + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iob                         -  enabled
                                + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
                                + system.adapter.ble.0                    : ble                   : raspberrypi4-iob                         -  enabled
                                 system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         - disabled
                                 system.adapter.daswetter.0              : daswetter             : raspberrypi4-iob                         -  enabled
                                + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
                                 system.adapter.dwd.0                    : dwd                   : raspberrypi4-iob                         -  enabled
                                 system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
                                 system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
                                 system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4-iob                         - disabled
                                + system.adapter.influxdb.0               : influxdb              : raspberrypi4-iob                         -  enabled, port: 8086
                                + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
                                + system.adapter.iot.0                    : iot                   : raspberrypi4-iob                         -  enabled
                                + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4-iob                         -  enabled
                                + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
                                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4-iob                         -  enabled, port: 54321
                                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iob                         -  enabled, port: 1885, bind: 0.0.0.0
                                 system.adapter.openweathermap.0         : openweathermap        : raspberrypi4-iob                         -  enabled
                                + system.adapter.parcel.0                 : parcel                : raspberrypi4-iob                         -  enabled
                                + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
                                + system.adapter.scenes.0                 : scenes                : raspberrypi4-iob                         -  enabled
                                + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.sonoff.1                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1884, bind: 0.0.0.0
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4-iob                         -  enabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iob                         -  enabled
                                + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : raspberrypi4-iob                         -  enabled
                                + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-iob                         -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
                                 system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         - disabled
                                + system.adapter.volumio.0                : volumio               : raspberrypi4-iob                         -  enabled
                                + system.adapter.wled.0                   : wled                  : raspberrypi4-iob                         -  enabled
                                 system.adapter.worx.0                   : worx                  : raspberrypi4-iob                         - disabled
                                + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/ttyUSB0
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): stable
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "admin"        : 7.4.10   , installed 7.4.10
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                Adapter    "daswetter"    : 3.2.2    , installed 3.1.15 [Updatable]
                                Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Controller "js-controller": 7.0.6    , installed 7.0.6
                                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                Adapter    "rpi2"         : 2.3.1    , installed 1.3.2  [Updatable]
                                Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                Adapter    "volumio"      : 0.2.0    , installed 0.2.0
                                Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                Adapter    "worx"         : 3.1.1    , installed 3.1.1
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                                Objects and States
                                Objects:        12083
                                States:         10918
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                Get:3 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
                                Get:4 https://packages.grafana.com/oss/deb stable InRelease [7661 B]
                                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Err:3 https://repos.influxdata.com/debian stretch InRelease
                                Err:4 https://packages.grafana.com/oss/deb stable InRelease
                                Fetched 12.9 kB in 2s (8527 B/s)
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3446135    31835/cupsd
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       125115     32448/iobroker.js-c
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       125110     32448/iobroker.js-c
                                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       741193     2813/io.mqtt.0
                                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       698309     21776/io.sonoff.1
                                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       741192     2813/io.mqtt.0
                                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15767      580/vncserver-x11-c
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15744      590/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11814      566/influxd
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        16638      566/influxd
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       124790     513/io.simple-api.0
                                tcp6       0      0 :::6032                 :::*                    LISTEN      1001       965306     9664/io.web.0
                                tcp6       0      0 :::6030                 :::*                    LISTEN      1001       790240     18553/io.admin.0
                                tcp6       0      0 :::5900                 :::*                    LISTEN      0          15766      580/vncserver-x11-c
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          15746      590/sshd: /usr/sbin
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3446134    31835/cupsd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      115        16561      547/grafana-server
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13290      499/dhcpcd
                                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       126162     32601/io.mihome-vac
                                udp        0      0 0.0.0.0:56186           0.0.0.0:*                           108        11686      425/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       128197     782/io.wled.0
                                udp        0      0 192.168.178.80:5353     0.0.0.0:*                           1001       126562     32718/io.tr-064.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11684      425/avahi-daemon: r
                                udp6       0      0 :::36846                :::*                                108        11687      425/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          16434      499/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        11685      425/avahi-daemon: r
                                2025-02-18 12:12:44.623  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:12:45.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
                                2025-02-18 12:12:45.538  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                2025-02-18 12:12:47.720  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:12:48.888  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:02.402  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:04.448  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:05.713  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                2025-02-18 12:13:07.632  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:08.730  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:15.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
                                2025-02-18 12:13:22.227  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:24.286  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:25.907  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                2025-02-18 12:13:27.392  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:28.487  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:41.848  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:43.927  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:45.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
                                2025-02-18 12:13:46.107  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
                                2025-02-18 12:13:46.558  - info: javascript.0 (16002) Stopping script script.js.common.Heizung_Winter_-10-0_Grad_24h_Probe
                                2025-02-18 12:13:47.005  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:13:48.209  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:14:01.674  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2025-02-18 12:14:03.717  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                  A Former User @arnold last edited by
                                  @arnold
                                  Ich schlage vor, bevor du an dem toten System (Debian Bullseye, wird nicht mehr supported) weiter arbeitest, nimm ne neue SD Karte, installier Debian Bookworm in der Lite-Version 64bit, dann installierst du die BS-Updates, Curl, dann eine Zeile fuer iobroker zum installieren, reboot, dann ein restore vom aktuellen Backup und du bist erstmal wieder save.
                                  Dann kann man auch nach weiteren Fehlern suchen, die vielleicht mitgeschleppt wurden, meistens sind die mit dem Update schon behoben.
                                  Iobroker haste ja relativ aktuell.
                                    arnold @Guest last edited by
                                    @ilovegym said in Adapter:
                                    Bookworm
                                    werde demnächst auf Bookworm umstellen (neu Installation )aber da ict noch Grafana und Influxdb
                                    da bekomme ich Fehler bei Telegram
                                    Backitup:
                                    Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
                                    grafana: {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n    at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\n    at IncomingMessage.emit (node:events:530:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n    at processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.7.9","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.80:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_RESPONSE","status":500}
                                      A Former User @arnold last edited by A Former User
                                      @arnold
                                      ist Grafana und Influx etwa auch auf dem iobroker-Host installiert?
                                      Falls ja, dann mach davon auch ein backup und installier das auch neu. Wuerde ich aber aufm anderen Host installieren, alles auf einen, hat viele Nachteile..
                                      Edit:
                                      Grafana und Influx kannste auch ohne Backitup Adapter sichern, da musste du halt mal schauen, wo es klemmt.. oder nimm dafuer halt ein aelteres Backup, wo es noch funktioniert hat..
                                      • SMS
                                        SMS last edited by
                                        Hi
                                        bei mir werden die nichtinstallierten Adapter nicht angezeigt. Woran kann das liegen?
                                        Filter sind keine gesetzt.
                                        Danke!
                                          Thomas Braun Most Active @SMS last edited by
                                          @sms sagte in Adapter:
                                          Daran vermutlich:
                                          Filtern Sie die Adapter, um andere zu sehen. Es gibt 612 mehr
                                          Im Admin werden nicht mehr alle 600 angezeigt, ist zu viel Last.
                                          SMS 1 Reply Last reply Reply Quote 0
                                          • SMS
                                            SMS @Thomas Braun last edited by
                                            @thomas-braun Es werden aber nur meine 60 installierten Adapter angezeigt.
                                            81.1k
                                            37
                                            3406
