    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Parser Adapter
    Parser Adapter
      smoker_vvo last edited by
      И по чему вот такое работает:
      https://darksky.net/forecast/43.3969,132.1887/si24/de temp swip">(-?\d+)˚<
        parser.0 2017-02-01 23:23:53.900 error parser.0 Cannot read link "http://192.168.0.89/state": Error: Parse Error
        parser.0 2017-02-01 23:23:48.861 error parser.0 Cannot read link "http://192.168.0.89/state": Error: Parse Error
        parser.0 2017-02-01 23:23:43.776 error parser.0 Cannot read link "http://192.168.0.89/state": Error: Parse Error
        parser.0 2017-02-01 23:23:38.737 error parser.0 Cannot read link "http://192.168.0.89/state": Error: Parse Error
        parser.0 2017-02-01 23:23:33.667 error parser.0 Cannot read link "http://192.168.0.89/state": Error: Parse Error
        fа если в парсере вбить http://192.168.0.89/state/ - тогда этой ошибки не будет но и значения нет
          и еще вот такое есть:
          parser.0 2017-02-01 23:29:58.630 error at IncomingMessage.g (events.js:180:16)
          parser.0 2017-02-01 23:29:58.630 error at IncomingMessage. (C:\ioBroker\node_modules\iobroker.parser\node_modules\request\request.js:1001:12)
          parser.0 2017-02-01 23:29:58.630 error at Request.EventEmitter.emit (events.js:95:17)
          parser.0 2017-02-01 23:29:58.630 error at Request. (C:\ioBroker\node_modules\iobroker.parser\node_modules\request\request.js:1081:10)
          parser.0 2017-02-01 23:29:58.630 error at Request.EventEmitter.emit (events.js:98:17)
          parser.0 2017-02-01 23:29:58.630 error at Request.self.callback (C:\ioBroker\node_modules\iobroker.parser\node_modules\request\request.js:186:22)
          parser.0 2017-02-01 23:29:58.630 error at Request._callback (C:\ioBroker\node_modules\iobroker.parser\main.js:214:29)
          parser.0 2017-02-01 23:29:58.630 error at analyseDataForStates (C:\ioBroker\node_modules\iobroker.parser\main.js:122:5)
          parser.0 2017-02-01 23:29:58.630 error at _analyseDataForStates (C:\ioBroker\node_modules\iobroker.parser\main.js:104:9)
          parser.0 2017-02-01 23:29:58.630 error at analyseData (C:\ioBroker\node_modules\iobroker.parser\main.js:138:27)
          parser.0 2017-02-01 23:29:58.630 error TypeError: Cannot call method 'exec' of undefined
          parser.0 2017-02-01 23:29:58.630 error uncaught exception: Cannot call method 'exec' of undefined
          parser.0 2017-02-01 23:27:10.091 info starting. Version 0.1.1 in C:/ioBroker/node_modules/iobroker.parser, node: v0.10.25
          тока не могу понять с чем это связано
          • I
            instalator last edited by
            @smoker_vvo:
            тока не могу понять с чем это связано `
            node: v0.10.25 ….. так и не обновил node js?
              Ну похоже что обновил, но не то. Как НОДУ обновить….
              С моими хотелками парсера похоже проблемы в коде страницы. Не могу понять.... вот скрины... Может сможешь подсказать куда рыть...
                и второй
                  Haus last edited by
                  @smoker_vvo:
                  Ну похоже что обновил, но не то. Как НОДУ обновить…. `
                  Если Debian
                  apt-get --purge remove node
                  apt-get --purge remove nodejs
                  apt-get autoremove
                  reboot
                  apt-get update
                  apt-get upgrade
                  apt-get install curl build-essential
                  curl -sL https://deb.nodesource.com/setup_4.x | bash -
                  apt-get install -y nodejs
                  reboot
                    А если это Windows??
                    • I
                      ivan.cc last edited by
                      Подниму тему. Имею аналогичную проблему при попытке получить статичный файл через веб-морду OpenWrt (веб-сервер uhttpd).
                      На роутере есть текстовый файлик со значениями, ссылка вида http://192.168.0.1/tmp/lastvolt.txt
                      curl'ом все прекрасно читается, а вот parser adapter ругается, говорит:
                      Cannot read link "http://192.168.0.1/tmp/lastvolt.txt": Error: Parse Error
                      Закидываю этот файлик на сервер в интернете - все прекрасно читается и значения получаются.
                      Запрашиваю веб-морду роутера и пытаюсь её пропарсить:
                      Regex: Powered by LuCI ([\d.]+)
                      Все прекрасно запрашивается и парсится. WGET'ом скачиваю эту страницу в файл и кладу в роутер, parser adapter опять ругается той же ошибкой.
                      Посмотрел заголовки, которые приходят от серверов:
                      Запрос веб-морды роутера, удачный парсинг.
                      curl --head http://192.168.0.1/cgi-bin/luci
                      HTTP/1.1 200 OK
                      Connection: close
                      Transfer-Encoding: chunked
                      Content-Type: text/html
                      Cache-Control: no-cache
                      Expires: 0
                      Запрос нужного файлика с сайта в интернете, удачный парсинг.
                       curl --head http://site.ru/lastvolt.txt
                      HTTP/1.1 200 OK
                      Server: nginx
                      Date: Mon, 22 Jan 2018 15:30:54 GMT
                      Content-Type: text/plain
                      Content-Length: 66
                      Last-Modified: Mon, 22 Jan 2018 14:54:48 GMT
                      Connection: keep-alive
                      ETag: "5a65fb38-42"
                      Expires: Mon, 22 Jan 2018 21:01:00 GMT
                      Cache-Control: max-age=19806
                      Accept-Ranges: bytes
                      Запрос нужного файлика с роутера, парсинг не получился.
                      curl --head http://192.168.0.1/tmp/lastvolt.txt
                      HTTP/1.1 200 OK
                      Connection: close
                      ETag: "6ea9-42-5a6601c5"
                      Last-Modified: Mon, 22 Jan 2018 15:22:45 GMT
                      Date: Mon, 22 Jan 2018 15:22:49 GMT
                      Content-Length: 66
                      Похоже, проблема при получении страницы нодой. К сожалению в ноде не силен и не могу проверить что происходит на уровне кода.
                      • I
                        Нашел, похоже, в чём проблема https://github.com/request/request/issues/2091
                        Видать сервер отдает немного кривые заголовки и NODE.request их не пропускает.
                        Что же делать-то? В сфере умных домов куча всяких роутеров, ардуин и пр. с кривыми заголовками.
                        • I
                          А может можно сделать, в качестве затычки, чтобы в parser adapter можно было указывать не только файл или URL, но и команду, а парсить уже её результат?
                          Ну или хотя бы сделать возможность использовать CURL/WGET для запроса URL'ов.
                          6068
