      Max_yeah @ticaki last edited by Max_yeah
      @ticaki
      ok wenn es das im Hintergrund macht das ging da jedenfalls etwas schief.
      -Hab es auch eine zeit lang machen lassen jedoch ohne Erfolg.
      Hab jetzt wieder eine alte Version die ich noch von der ersten Inbetriebnahme auf der platte rumliegen hatte geflasht.
      Jetzt geht wieder alles.
      Vielleicht probiere ich gleich nochmal das update und berichte ob es jetzt klappt.
      EDIT:
      Gleicher fehler:
      2025-02-19 23:09:54.241 - info: mqtt.0 (934) Client [NSPanel_Buero] connection closed: closed
      2025-02-19 23:09:58.663 - info: mqtt.0 (934) Client [NSPanel_Buero] connected with secret 1740002998661_1569
      2025-02-19 23:09:58.720 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/NSPanel_Buero/cmnd/#" with regex /^SmartHome\.NSPanel_Buero\.cmnd\..*/
      2025-02-19 23:09:58.721 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/NSPanel_Buero/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_Buero\.cmnd\..*/
      2025-02-19 23:09:58.723 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
      2025-02-19 23:09:58.723 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
      2025-02-19 23:09:58.724 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "cmnd/NSPanel_Buero_fb/#" with regex /^cmnd\.NSPanel_Buero_fb\..*/
      2025-02-19 23:09:58.724 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "cmnd/NSPanel_Buero_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_Buero_fb\..*/
      2025-02-19 23:09:58.781 - warn: javascript.0 (767) script.js.NSPanels.Buero.Panel_Buero: Tasmota in Safeboot - Please wait while upgrading
      2025-02-19 23:09:58.922 - info: mqtt.0 (934) Client [NSPanel_Buero] publishOnSubscribe send all known states
      2025-02-19 23:09:58.924 - info: mqtt.0 (934) Client [NSPanel_Buero] publishOnSubscribe send all known states
      2025-02-19 23:09:58.925 - info: mqtt.0 (934) Client [NSPanel_Buero] publishOnSubscribe send all known states
      2025-02-19 23:10:38.437 - info: mqtt.0 (934) Client [NSPanel_Buero] connection closed: closed
      2025-02-19 23:10:44.043 - info: mqtt.0 (934) Client [NSPanel_Buero] connected with secret 1740003044042_4319
      2025-02-19 23:10:44.099 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/NSPanel_Buero/cmnd/#" with regex /^SmartHome\.NSPanel_Buero\.cmnd\..*/
      2025-02-19 23:10:44.100 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/NSPanel_Buero/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_Buero\.cmnd\..*/
      2025-02-19 23:10:44.102 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
      2025-02-19 23:10:44.103 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
      2025-02-19 23:10:44.104 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "cmnd/NSPanel_Buero_fb/#" with regex /^cmnd\.NSPanel_Buero_fb\..*/
      2025-02-19 23:10:44.105 - info: mqtt.0 (934) Client [NSPanel_Buero] subscribes on "cmnd/NSPanel_Buero_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_Buero_fb\..*/
      2025-02-19 23:10:44.191 - info: javascript.0 (767) script.js.NSPanels.Buero.Panel_Buero: Tasmota upgrade complete. New Version: 14.5.0(release-tasmota32)
      2025-02-19 23:10:44.301 - info: mqtt.0 (934) Client [NSPanel_Buero] publishOnSubscribe send all known states
      2025-02-19 23:10:44.303 - info: mqtt.0 (934) Client [NSPanel_Buero] publishOnSubscribe send all known states
      2025-02-19 23:10:44.306 - info: mqtt.0 (934) Client [NSPanel_Buero] publishOnSubscribe send all known states
      2025-02-19 23:11:26.603 - info: admin.0 (756) ==> Connected system.user.admin from ::ffff:192.168.178.21
      2025-02-19 23:12:31.158 - info: admin.0 (756) ==> Connected system.user.admin from ::ffff:192.168.178.21
      2025-02-19 23:12:34.232 - info: web.0 (1020) ==> Connected system.user.admin from ::ffff:192.168.178.160
      2025-02-19 23:12:40.763 - info: web.0 (1020) <== Disconnect system.user.admin from ::ffff:192.168.178.160
      2025-02-19 23:12:42.156 - info: admin.0 (756) <== Disconnect system.user.admin from ::ffff:192.168.178.21 javascript
      2025-02-19 23:12:42.310 - info: smartmeter.0 (893) Received 5 values, 2 updated
      2025-02-19 23:12:42.634 - info: admin.0 (756) ==> Connected system.user.admin from ::ffff:192.168.178.21
      2025-02-19 23:12:44.220 - info: admin.0 (756) <== Disconnect system.user.admin from ::ffff:192.168.178.21 devices
      2025-02-19 23:13:48.403 - error: mqtt.0 (934) Client [NSPanel_Buero] Cannot parse "SmartHome/NSPanel_Buero/tele/RESULT": {"CustomRecv":"""�"� 6*"2�,*S6*"}
      2025-02-19 23:13:48.413 - warn: javascript.0 (767) script.js.NSPanels.Buero.Panel_Buero: error at trigger rceiving CustomRecv: Unexpected token  in JSON at position 16
      EDIT2:
      ok weis nicht was das problem ist, hab noch mal die binary direkt runtergeladen und über das web interface geflasht
      https://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin
      aber auch dann die gleichen fehler.
      Kann es sein das ich zu dem tasmota update auch eine neue nextion firmware flaschen muss?
      Von der Version wie sie aber nach dem Flaschen mit der binary angezeigt wird, wirkt es so als ob die tasmota Version nicht die wäre, die speziel fürs nspanel angeboten wird.
      Was schlecht wäre, weil das dann alle Geräte die per autoupdate diese Version erhalten Bricken würde.
        ticaki @Max_yeah last edited by ticaki
        @max_yeah
        Das ist die richtige Version für das panel - das andere ist eigentlich die "falsche".
        Dein Problem scheint zu sein, das er die aktuelle Version nicht will, das hat nix mit dem iobroker zu tun.
        Um es nochmal klar zu sagen. Die tasmota32 ist die richtige.
        also die hier; https://ota.tasmota.com/tasmota32/release/tasmota32.bin
        In der Version ist aber nix drin, was man braucht. kann man auch auf 14.4 bleiben.
          @ticaki
          Ja ok, wenn aber das "richtige" nicht geht und das "falsche" es tut, dann ist irgendwas im Busch.
          Kann mir jemand erklären, warum ein anderes besser wäre?
          Tritt der Fehler möglicherweise nur bei mir auf, weil ich von dieser Version update?
          Mir ist klar das, dass Flashen nicht direkt was mit iobroker zu tun hat, jedoch kann mein Script scheinbar mit iwas an der neuen Firmware nicht umgehen.
          Das Panel zeigt die ganze Zeit, dass es auf content wartet.
          T T 2 Replies Last reply Reply Quote 0
            TT-Tom @Max_yeah last edited by TT-Tom
            @max_yeah
            was wird dir in der Console von Tasmota angezeigt?
            EDIT:
            trage diesen link mal in Tasmota ein für das Update auf 14.4
            http://ota.tasmota.com/tasmota32/release-14.4.1/tasmota32.bin
            M 3 Replies Last reply Reply Quote 0
              @max_yeah sagte in SONOFF NSPanel mit Lovelace UI:
              @ticaki
              Soweit ich das lese tut weder die richtige noch die falsche es - nur ne alte tut es.
              Mit richtig und falsch ist da gemeint - das beide gehen die nspanel version aber code dabei hat, den man nicht braucht.
              Nö auch das nicht 🙂 Der mqtt adapter kann mit dem eingehenden Zeichenmüll nix anfangen. Die Logs helfen nicht weiter - das problem sitzt im Tasmota und ich hab keine ahnung was es sein könnte - aber TT-Tom vielleicht.
              T M 2 Replies Last reply Reply Quote 1
                TT-Tom @ticaki last edited by
                @ticaki
                @Max_yeah
                also bei mir läuft die 14.5 habe Garde mein Testsystem umgestellt.
                  ticaki @TT-Tom last edited by
                  @tt-tom
                  Bei mir ebenfalls, ich hab alle bis auf das adapter testpanel umgestellt - da fehlt noch die funktionen zu aktualisieren 😄
                    Max_yeah @TT-Tom last edited by
                    @tt-tom
                    ok ich kann das heute Abend mal testen.
                    Die Version, die aktuell installiert ist, kommt aus dem Webinstaller. Glaube seit dem habe ich noch kein Tasmota update gemacht.
                      @ticaki ah danke für die Erklärung.
                        @max_yeah
                        ich mache die Updates direkt in der Tasmota Oberfläche.
                        Bei OTA-URL den Link einsetzen den ich dir geschrieben habe.
                        du kannst hier auch nochmal die 14.5 versuchen.
                          @tt-tom danke, aber genau das hab ich gestern schon gemacht. Sowohl über den Webserver, als auch dass ich die Binary der 14.5 von GitHub manuell hochgeladen hab. Immer kam ich bei dem gleichen Ergebnis raus.
                          Nur das Laden der alten Version, die ich noch herumliegen hatte, hat dann alles wieder zurückgesetzt.
                            @max_yeah
                            Dann versuche doch mal die tasmota32 Version 14.4.1 die TT-Tom verlinkt hat und anschließend die 14.5
                              @ticaki Ja werde ich heute Abend testen und berichten.
                                A Former User last edited by
                                wenns nach dem update probleme gibt, mal stromlos machen, nicht vergessen...
                                  Max_yeah @TT-Tom last edited by Max_yeah
                                  @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                                  mit dem link updated sich Tasmota trotzdem auf die version 14.5
                                  gleiches fehlerbild im iobroker
                                  javascript.0
                                  2025-02-20 19:17:14.112	warn	script.js.NSPanels.Buero.Panel_Buero: error at trigger rceiving CustomRecv: Unexpected token  in JSON at position 17
                                  mqtt.0
                                  2025-02-20 19:17:14.104	error	Client [NSPanel_Buero] Cannot parse "SmartHome/NSPanel_Buero/tele/RESULT": {"CustomRecv":"�|�X���%��y8$�
                                  javascript.0
                                  2025-02-20 19:17:04.985	warn	script.js.NSPanels.Buero.Panel_Buero: Please report to developer: Unknown NSPanel.EventMethod: undefined
                                  19:13:33.470 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('8CFDFCD8537BFC1F2CD31B807F69BEEA322BAC2A53362A2A0C0AAB95AB2C6213...')"}
                                  19:13:33.571 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3CBCB8FCDEFBF1E80DA74BA17FAD3859362A2A228B152A0C221332AB2C226295...')"}
                                  19:13:33.670 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E8B152A0C0AAB95AB0C0AAB95AB2C22B00936AA0B2A2A952BAC2A5336AA0C2A...')"}
                                  19:13:33.693 QPC: Reset
                                  19:13:33.773 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3EF66FF5E511AC222B952BAC2A53362A0C0AAB95C02AAB95AB2C22C00936AACC...')"}
                                  19:13:33.881 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('56228B09362A0C0AAB252BAC2A53362A0C2AAB952B2A2A952BAC2A53362A0C0A...')"}
                                  19:13:33.980 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('564E2A13362A2A0C0AAB95AB2C2200A82A0C0AAB95ABAC228B0954AC2A53362A...')"}
                                  19:13:34.075 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1E40EF15050202B1EF20F202D0B1EF20450202B1EB300202B1AD151515151515...')"}
                                  19:13:34.175 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('562A2C2AAB952B2C228B09362AC82A5336AA0C0AAB952BAC221336AB2C2AAA95...')"}
                                  19:13:34.276 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('16E532CB2AAB5532AA0C2AAB95AB0C2A5336AA0C0AAB952BAC22AB95AB2C2A2A...')"}
                                  19:13:34.375 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('167D4311222BAC2A5332AB2C2AAA952BAC2A5336AA2AAB95AB2C228B09362A0C...')"}
                                  19:13:34.476 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('16891322AB2C22C00936AA0C221322AB2C22C0C9362A0C368B09362A0C0AAB95...')"}
                                  19:13:34.575 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3692AA952BAC2A5336C22A2A952B2B2BAA2C2AAB202B2B2A2A0C0AAB95AB2C2A...')"}
                                  19:13:34.677 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('16AB04118B1322AB2C22C00922C10AAB352A0C221336AB2C2A2A95CB0AAB95AB...')"}
                                  19:13:34.777 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3C222A0C0AAB95AB2C2266A82A0C0AAB95ABAC228B81540C0AAB95AB2C228B09...')"}
                                  19:13:34.888 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('36C42AAA952BAC228B0936ABCC2A2A952B2B2BAA2C2AAB202B2B2A2A0C0AAB95...')"}
                                  19:13:34.983 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E221336AB2C2A6A952BAB2AAA952BAC228B0936AA0C541322AB2C22C00936AA...')"}
                                  19:13:35.083 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('A72140CD1DA109B1EB308302822174CF154000502040EF1515200502D0B1EF20...')"}
                                  19:13:35.182 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E2EAA952BAC2A5336C22A2A952B2B2BAA2C2AAB202BAB3843362B2A0C0AAB32...')"}
                                  19:13:35.282 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5CB3AB952B2A2A0C0AAB95AB2C220032AA0C0AAB95AB2C22C00922AB6CA9322B...')"}
                                  19:13:35.381 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('362AAC2A2A95462A2AFF4109222B2B2A0C22C009362A8A0C2AAA952B0AAB95AB...')"}
                                  19:13:35.482 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E0F8B95512C2A11226B3B81AB952BAC2223202B2B2A0C221322AB2C2CAA952B...')"}
                                  19:13:35.582 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FFB777722A0332AB2C22C0093636318B95AB2C226A952B2B2A0C0A2B952BAC22...')"}
                                  19:13:35.681 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('EE9CFC79D6F1391FBCF88B211F3FFEC44A512C2A5336AA0C2AAB952BAC228BA9...')"}
                                  19:13:35.710 MQT: SmartHome/NSPanel_Buero/tele/STATE = {"Time":"2025-02-20T19:13:35","Uptime":"0T00:00:09","UptimeSec":9,"Heap":157,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":57,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":213},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SchauAmEiskasten","BSSId":"98:9B:CB:A3:60:8B","Channel":11,"Mode":"HT40","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                  19:13:35.756 MQT: SmartHome/NSPanel_Buero/tele/SENSOR = {"Time":"2025-02-20T19:13:35","ANALOG":{"Temperature1":18.6},"TempUnit":"C"}
                                  19:13:35.801 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('968B2A2A95CB0AAB95AB2C2A2A952B2BAA0E8B95AB2C2A2A952B2B2A35AB95AB...')"}
                                  19:13:35.834 MQT: SmartHome/NSPanel_Buero/stat/RESULT = {"POWER1":"ON"}
                                  19:13:35.837 MQT: SmartHome/NSPanel_Buero/stat/POWER1 = ON
                                  19:13:35.870 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E06AB2C228B0936C00AAB95AB2C2A2A952B2B82228B152A0C0AAB952BAC2253...')"}
                                  19:13:35.962 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BE07ABC02A2A952BAC2A5336AA0C2A1332AB2C226A952A2A0C2A47362B2A2A0C...')"}
                                  19:13:36.063 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('161D41064201408F1D4106400042CF154000500142CF154000502040EF154106...')"}
                                  19:13:36.164 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5C0F8B95AB2C22C009362B2B2A2A0C0AAB95AB2C2A53361E59C132AB2C22C089...')"}
                                  19:13:36.261 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('DEB209322B25228B09362A0C0AAB95AB18221332AB2C2A2A952B2B82228B152A...')"}
                                  19:13:36.423 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FA6153362A8C2AAAF540B209362B0C2213282BAC228B0936A22C2AAAA02B2A2A...')"}
                                  19:13:36.473 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('162BAC2A1336AB2C2AAA952BAC228B09362A0C248B95512C2AAB952B2B2A0C2A...')"}
                                  19:13:36.633 MQT: SmartHome/NSPanel_Buero/stat/RESULT = {"CustomSend":"Done"}
                                  19:13:36.661 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('96AA0C0AAB95AB2C2260152A2A0C0AAB95AB2C2200A8AA0C2AAB95ABAC228B09...')"}
                                  19:13:36.727 MQT: SmartHome/NSPanel_Buero/stat/RESULT = {"CustomSend":"Done"}
                                  19:13:36.756 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E9BC10AAB95AB2C2262152BAA0E8B95AB2C2A2A952B2B2A35AB95AB2C226A95...')"}
                                  19:13:36.923 MQT: SmartHome/NSPanel_Buero/stat/RESULT = {"CustomSend":"Done"}
                                  19:13:36.959 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('56B03380CC826BB466000217B380DC41A341B4B380DC41836BB4F30400836B17...')"}
                                  19:13:37.111 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('362E17E084C8D2ABB0E084C8D26B17C384C8D28326E084C8D26B173380DCD249...')"}
                                  19:13:37.151 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5646AA11222B0C0AAB95AB2C22C009362ACC2A2A952BAC2A5336552C2A20202B...')"}
                                  19:13:37.254 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('56310B1332AB2C226A952B2A2A0C2A5336AA0C2AAB312BAC2A1336AB2C2AAA95...')"}
                                  19:13:37.354 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FE8B152A0C0AAB952B2A2A0C0AAB95AB2C220032AA0C0AAB95AB2C22C00922AB...')"}
                                  19:13:37.462 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5C081322AB2C2A2A952BAC2A5336AA0C368B093F2A2A0C0AAB95AB318B95512C...')"}
                                  19:13:37.557 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7692AA952BAC228B15CA2A6A952B2B2A2A0C0AABB52BAC1E2EAB2C228B152A8C...')"}
                                  19:13:37.658 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7C44226A952A2A4C3CC009362A2A0C0AAB95AB2A0C0AAB95AB2C928B152A8A22...')"}
                                  19:13:37.757 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('E784362A0C221332AB2C6253362A0C0AAB95AB2C228B09362B2A0C221336AB2C...')"}
                                  19:13:37.864 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('165336AA2AAA952BAC228B0936AA0C541322AB2C22C00936AA0C221322AB2C22...')"}
                                  19:13:37.957 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('56332BAB0C0AAB352A0C221336AB2C2A2A95CB0AAB95AB2C2A2A952B2BAA0E8B...')"}
                                  19:13:38.059 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1EDAAE48A8FF4550AD6D63C2EB30830642A2EB3003184142CF15400050000415...')"}
                                  19:13:38.158 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3C4E221336AB2C2A2A952B2B81AB95AB2C22C00936AA0C221322AB2C22C00936...')"}
                                  19:13:38.259 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E9A2B0B2A2A952BAC2A5336AA0C2A1332AB2C226A952A2A0C2A47362B2A2A0C...')"}
                                  19:13:38.365 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FE8B152A0C0A11222BAC2A5336AA0C2AAB982B2B2A0C22132EAB2C22AB95AB2C...')"}
                                  19:13:38.459 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E5336AA0C2A23A82A0C221332AB2C2A2A952B2A2A0C0AAB95AB2C220032C10A...')"}
                                  19:13:38.559 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3EAB2C2AC00936C32A2A952B2B2BAA2C2AAB202B2B2A2A0C0AAB95AB24248B95...')"}
                                  19:13:38.659 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7B777F6EAD2A09362A2A0C8AAB35AB2C2A20A02B2A0C221332AB2C226295AB2C...')"}
                                  19:13:38.759 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FF9D0B2A53362A0C21AB95ABAC228B152A8C0AAB952BAC285336552C2AAB952B...')"}
                                  19:13:38.866 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7FEDFBF6BFFFFFFEFF95AB2CB28B95550C22603CF678D9FD3AF509F6932C2A2A...')"}
                                  19:13:38.960 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('162A952BAC2AB311270B952BACE2FFDEFDFF7D9FFEEAEF7AB5FB62BDFEB7F295...')"}
                                  19:13:39.061 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BFEF0841401F17050212E2EF20450202B1EB3083060C40EF17050202B1EF2045...')"}
                                  19:13:39.156 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1EAB2C2A2A95C3228B152A0C221322AB2C228B152A0C0AAB95AB2C226AA9C10A...')"}
                                  19:13:39.266 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('16C8228B21C10AAB95AB2C22C00936AA0AAB95AB2C22C009362A0C611322AB2C...')"}
                                  19:13:39.366 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('CD3335AB95AB2C228B09492B2A2A0C0AAB952BAC2253362A2A0C0AAB95AB2C22...')"}
                                  19:13:39.463 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('9E2B2A0C221332AB0C2A53560F8B15AA2C2A2A953581AB95AB2C22C009362A0C...')"}
                                  19:13:39.589 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('9E2BAC228B0936AA228B15072AAA952BAC2A5336C10AAB95AB2C2262152BAA0E...')"}
                                  19:13:39.682 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('96642A2A952B2A2A0C0AAB95AB2C220032AA0C0AAB95AB2C22C00922AB2C22C0...')"}
                                  19:13:39.783 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('161332892AAB952BAC228B362B2A2A0C0AAB952BAC2253362A2A0C0AAB95AB2C...')"}
                                  19:13:39.890 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E0FE31BF7FDFEFCFFDFF27E472A0CA28B0936C4228B09362A0C221322AB1022...')"}
                                  19:13:39.985 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5EE536AB2C228B09362A0C0AAB15AB2C226A95A29A97FEEFA7FFF7EAD72E8B49...')"}
                                  19:13:40.085 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('D6D40140CFBDDEFFFF3B9FFDAEDFFBFE1F20E2EFA00502D041EF151515151505...')"}
                                  19:13:40.191 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('8CF4F8990C0E5E2EEBFF9BF03FEFBEB10922CB228B09362A0C0AAB95AB2C226A...')"}
                                  19:13:40.288 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('142847362B2B2ACCF95FFFBE7D3FFA7BAE9F85362B2A2A0C0A6B95552C2CAA95...')"}
                                  19:13:40.390 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BE6BB4F38448D96BB4F3844841A26BB0E004DCD24BB4F384DC41836BB4C180DC...')"}
                                  19:13:40.487 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FE37012A952B2B2BAA2C2AAB202B2B2A2A0C0AAB95AB2C2AAB95AB2C228B0936...')"}
                                  19:13:40.588 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('DE8B2A2A952BAC5E5336AAC02A6A4AAA0C0A2B952BAC620936AB2C2AAA952BAC...')"}
                                  19:13:40.687 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('168B09362A0C0AAB95AB2C226A952B2B8A0AAB952A0C0AAB95AB2C2A2A952B48...')"}
                                  19:13:40.767 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1C0E8B95AB2E53362A0C0AAB95C3228B09362A0C0AAA952BAC0AAB95AB2C226A...')"}
                                  19:13:40.874 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3EC12A1336512C2AAB952B2B2A8A22C009362A2A0C0AAB9504118B09362A0C22...')"}
                                  19:13:40.974 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BCC9C1034BC009B62B2B2B2A0C223332AB2C6053362A0C0AAB95AB2C2260152A...')"}
                                  19:13:41.070 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3647AC05025020E20F1D40C0180140EF15400010C2EB3083024231CF22830212...')"}
                                  19:13:41.169 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E681322CB0AAB95AB2CAAEACBDD7E57FDFA4EC391FB98C009362A2A0C0AAB95...')"}
                                  19:13:41.268 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3EB9FFDEFC257EBF4EECCF8F703FBF76464936AB2C2847362B2B2A0C221332AB...')"}
                                  19:13:41.369 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('9E68215BFB36512A0C0AAB95AB2C2A2A952B2AAB95AB2C22C00936AA0C221322...')"}
                                  19:13:41.468 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('565A1336AB2C2AAA952BAC2A0B36512C2AAB95AB2B2A2A2C2A2A952BAC2AF336...')"}
                                  19:13:41.569 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7625228B15C40E8B95512C2AAB952BAC222A952BAC2A5336AA2C2AAB202B2B2A...')"}
                                  19:13:41.668 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5C362A0C221336AB2C2A2295AB2C226A952B0C221336AB2C2A2A952BAC2A5336...')"}
                                  19:13:41.768 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('362A0C221336AB2C2A2A950B0AAB95AB2C2A2A952B2BAA0E8B95AB2C2A2A952B...')"}
                                  19:13:41.882 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('762A0C0AAB95AB2C611322AB2C22C00936AA0C221322AB2C22C0C9362A0C368B...')"}
                                  19:13:42.049 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E5336AA0AAB95AB2C226A952B2A0C4811222BAC228B0936AA0C0A47322B2B2B...')"}
                                  19:13:42.146 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BC158306420142CF1540005020452C4000502040EF151515520202B1EB208302...')"}
                                  19:13:42.244 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('168B09362AC82A5336AA0C0AAB952BAC221336AB2C2AAA952BAC2A53492B2A2A...')"}
                                  19:13:42.344 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E620C2A6A952B2B2A2A0C0AAB95AB2AAB95AB2C228B09362A0C610936AA0C2A...')"}
                                  19:13:42.445 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FC9FBAACEF2EBEFEFFFE4E0932512C2A6A952B2B2B2A0C221322AB10228BBF51...')"}
                                  19:13:42.544 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FCF9FB0AC10AABA9AB2C226A952B2B0C0AABA5AB2C226A952B2B2A0C222336AA...')"}
                                  19:13:42.644 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1E512C22C009362AAC228B09362A0C2AAB5951CA2A5336AA0434AB952BAC22E0...')"}
                                  19:13:42.745 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('AE922A15C10AABAFAB2C22CB0936952B2B2A0C221332AB2C226295AB2C228B09...')"}
                                  19:13:42.859 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3EAB2C228B152A0C0AAB95AB2C226AA52A0C221332AB2C22C009962A0C0AAB95...')"}
                                  19:13:42.953 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('D60B2A53362A0C0AAB95AB2C151332AB2C226A952B2B2AAC2A53362A0C221322...')"}
                                  19:13:43.053 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7642EF17050202B1EB2045020281EF20F3F203502040EF177500500040EFCFD0...')"}
                                  19:13:43.150 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E4E2A1336511E2213CE0EAB95AB2C22C081512C2A2A952BAC2A1336AB2C2AAA...')"}
                                  19:13:43.255 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FCAB2C22B109362A0C221332AB2C226295AB7C4311222BAC228B35C10AAB95AB...')"}
                                  19:13:43.351 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('562B2B2AA22C2A2A952BAC2A53362A0C0AAB95C3228B152A0C221322AB2C2213...')"}
                                  19:13:43.452 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E0F47362B2B2A0C221332AB2C2A1336AB2C2AAA952BAC2A8836AB2C2A2A952B...')"}
                                  19:13:43.551 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5EA8AACB2A2A952B2B2BC22A2A952B2B2BAA0C2AABA92A0C0AAB95AB2C2A6A95...')"}
                                  19:13:43.657 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1E0F8B95AA14226A952B2B2A0C0AAB95C3228B152A0C2213222BAC2253362A0C...')"}
                                  19:13:43.752 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('B62A2C088B89362B4EB80936AA0C2AAB952A0C221336AB2C92C00936AB2C226A...')"}
                                  19:13:43.859 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('362A2A0C2AAB952B2B2A2A0C0AAB95AB2C621336AB2C2A2A952B8B2A0C228B15...')"}
                                  19:13:43.952 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E13602B2A2A0C0AAB952BAC22AB95AB2C2A2A952B2B2AAA2A6A952B2B2AAA0C...')"}
                                  19:13:44.053 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5EEE378EFF45685ADBF563C2CD1D4000D02040EF21450202B1EB30830202B1EB...')"}
                                  19:13:44.152 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('168B95AB2C2A64A82A0C0AAB95AB2C2A6A952A0CF23CAA0C0AAB95AB2C151332...')"}
                                  19:13:44.253 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E44226A952B2B2A0C0AAB952BACE294C00936C10AAB152BAC2A53362A0C0AAB...')"}
                                  19:13:44.351 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E0C2211322BAC2A5336512C2A8B362B2A2A0C0AAB95AB2C621336AB2C2A2A95...')"}
                                  19:13:44.527 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('9661362A01C132AB2C228B0954AC2A53362A0C0AAB95AB0C0AAB95AB2C226A95...')"}
                                  19:13:44.574 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('962A0C221322AB2C621336512C2AAB952BAC2A53222B2C228B0936AA2C2AAB20...')"}
                                  19:13:44.671 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7C13362B2B2B2A0C221332AB2C2A47362B2B2A0C221322AB10228B09362A0C0A...')"}
                                  19:13:44.771 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7C221332AB2C2A6A952BCB0AAB95AB2C2A2A952B2AAA2AAB95AB2C22C009362A...')"}
                                  19:13:44.878 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E084732CB0E8B95AB2C2AAA952BAC2A0C322B2B2A2A0C2AAB952B2A2A952BAC...')"}
                                  19:13:44.971 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('AEAB2C2AAB95AB2C2A2A95EBFBFA21AA952B6C348B15AA0C0AABA5C10AAB95AB...')"}
                                  19:13:45.072 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('DE83EF1515151505C20821C2EB3083064231CF158306420142CF154006500063...')"}
                                  19:13:45.170 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('16AB2B2A0C0AAB95AB2C22420911AC2A53362A0C221322AB10228B70A6226A95...')"}
                                  19:13:45.271 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BE6E2A2B2B2B2A0C0AAB59512C228B09362A0C0AAB95AB2CC4C132AB2C2A2A95...')"}
                                  19:13:45.372 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('162A0C2A1332AB2C226A952B0431AB202BAC4F09362AAA0C0A2B202B2B2A0C22...')"}
                                  19:13:45.476 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7C322B2C228B152A0C0AAB95AB2C2A2A952B2A0A0AAB95AB2C226A952B2AAA2A...')"}
                                  19:13:45.571 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E5336AA0C2AAB952BAC2A0322AB2C228B09362A0C0A8B362A2A0C0AAB95AB2C...')"}
                                  19:13:45.671 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('D6B4FBCF0A00826B17E0C4C8D26B173380DCD249B4F3CC00836BB0E084C8D26B...')"}
                                  19:13:45.772 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('DE022B2BAB2C2AAB9AAB2C2A2A952BAC2A5336CA2A2A952BAC2A53362A0C0A20...')"}
                                  19:13:45.880 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('962A2A0C2AAB952B2A2A952E2A53362A0C0AAB212BAC2A53362A0C0AAB95AB0A...')"}
                                  19:13:45.973 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('564F2AAB952B0B2A53362B2B2A2A0C0AAB95AB2C621336AB2C2A2A952B2B2A44...')"}
                                  19:13:46.073 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('4F8FCF19180142CF157806500004154000500040CF1D4000B0E2EF2083020231...')"}
                                  19:13:46.173 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('36E522CB0AAB95AB2C2A2A952B2BCA0AAB95AB2C088B09362B2A2AAB95AB2C22...')"}
                                  19:13:46.279 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('D64E221332AB2A0C221336AB2C228B09362B2B2A2A0C0AF311222B108B09322B...')"}
                                  19:13:46.376 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('74502B2A0C2213329B016A952B35AB95AB2C226A952B2AAA2A6A952B2B2AAA0C...')"}
                                  19:13:46.475 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E2B2B0C221332AB2C2AAA952BAC2A5336AA2A6A952B2B2AAA0C0AABA52A0C22...')"}
                                  19:13:46.576 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('D62EAB95AB2C228B09962BAC8A32512C2AAA952B0C980936AB2C2AAA952B2B2B...')"}
                                  19:13:46.675 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3C36AB2C2A2A982A0C221336AB2C22C009AAAB2C2AAA952BAC2A5336AA2A6A95...')"}
                                  19:13:46.775 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('DE621332AB2C2AABF5BE47362B2B2A0C0A11222BAC228B0936AB2C2A475C622A...')"}
                                  19:13:46.882 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('361142C10AAB95AB2C2262152BAA0E8B95AB2C2A2A952B2B2A35AB95AB2C226A...')"}
                                  19:13:47.002 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E332BAC2A09362A0C0AAB952B2C228BCA550C2AAB95AB2C228B15AA088B0932...')"}
                                  19:13:47.045 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FCEBDE782A46D5A13CFE4570FFBF4663E2EB3083020220E2EF600202B1EB3083...')"}
                                  19:13:47.155 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('D62C2AAA992B2A0C221336AB2C2A6AA5C10AAB95AB2C22C009362A318B95512C...')"}
                                  19:13:47.249 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1EB213222BAC2009362A0C0AAB95AB2C226015AA0C0AAB95AB2C22C009512C2A...')"}
                                  19:13:47.348 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('9EB22395AB2C226A952B0C221336AB2CBA8BE2AC2A53362A0CB109322B2B2A2A...')"}
                                  19:13:47.447 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('5E512C2A2A952BAC2A13226B9909362A0C0AAB95C00AAB95AB2C2A2A952B2B82...')"}
                                  19:13:47.547 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BEBC6ADB70BFFD08B9512C2A22A02BAB3211222B2B2A2A22C009362A2A0C0AAB...')"}
                                  19:13:47.647 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7E4E221336AB2C229632AB2C2A6A952B2B2A2AAC2A53362A0C221322AB2C2CD4...')"}
                                  19:13:47.747 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('FE5A5336AA0C0A63A82A0C221332AB0B228B8922AB2C228B09362A0C0A0B95AB...')"}
                                  19:13:47.854 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3E2A952BAC2A53362A0C0AAB952BAC201332AB2C226A952B2A2A1E2AAA952BAC...')"}
                                  19:13:47.947 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('1E4736AA0C2AAB95ABAC228B09492B2A2A0C0AAB952BAC2253362A2A0C0AAB95...')"}
                                  19:13:48.054 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('9E8320458236CF15400042014205154000502040EF1515157206420042CF1540...')"}
                                  19:13:48.149 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3C922A952B83228B152A0C0AAB952BAC2253362A2A0C0AAB31AB2C22AB95AB2C...')"}
                                  19:13:48.249 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('38B0DC956CB4F81EEE8FEFDFFFFEEDFFFCEC50E8A1A6CD134D0B2CB9926E2CB4...')"}
                                  19:13:48.347 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3CFBF879EEA43D350FBFFEF7EB47DEDDB123C30E8BFD2511222BAC2A5336AB2C...')"}
                                  19:13:48.447 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('F6BCFB00B1318B152A0C0AAB952B44118B95AA0C2AAB952BAC228B89322B2B2A...')"}
                                  19:13:48.547 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3EC4FD4DEA0B3B318B95612C2A2F92318B152A0C0A2B36512C2AAB952BAC2A53...')"}
                                  19:13:48.649 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('BEE5222B2B2AC00AAB95AB2C2A2A952B2B82228B152A0C0AAB952BAC2253362A...')"}
                                  19:13:48.747 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('6ECBEAAFF3C0FB36AA0C2A1322EBAE95AB2C226A952B462A2A952B2B2B2A0C0A...')"}
                                  19:13:48.860 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('F67B77FBFDA276F72F191E0A11222BAC2A5336AA2C2AAB202B2B2A2A0C0AAB95...')"}
                                  19:13:48.953 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('F62BAC2A5336CA22C009362A2A0C0AAB95EB22C009362A2A0C2AAB952B2A8A11...')"}
                                  19:13:49.054 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('3F38FF3990B46E1B5C7B8F70FF2F8AFA0C20E2EF204D02D0B18B150502D0B1EF...')"}
                                  19:13:49.153 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('7DD9B8FA58DD79251EEFFF1B519F1291AB2C2A2495AB2C2AAA952B2B2A2A2AAB...')"}
                                  19:13:49.254 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('6900FE3DADB4F8274AF8FF4E013F5BEDC4C1322BAC2A0936AB2C2AAA952BAC2A...')"}
                                  19:13:49.352 MQT: SmartHome/NSPanel_Buero/tele/RESULT = {"nextion":"bytes('366495AB2C2A2A952B2B2B2AAC2A53362A0C221322AB2C2CAA952BAC228B152A...')"}
                                  das kam in der console
                                    und wieso machst du dann nicht ein update über upload? Damit bin ich bei 14.4.1 auf dem panel gelandet
                                      @ticaki naja weil ich erstmal das gemacht hab, muss jetzt erstmal wieder downgraden. Wenn ich vorher gewusst hätte das es über den Webserver nicht funktioniert hätte ich es natürlich gleich per upload gemacht.
                                      Mit der Binary vom Januar funktioniert es ja auch, auch wenn das ja scheinbar nicht die richtige Version ist.
                                        @max_yeah
                                        Wenn wir die tasmota32.bin verison 14.4.1 drauf bekommen und die läuft gehts vielleicht von da aus auf 14.5 - vielleicht stimmt aber auch was nicht auf dem nspanel in den einstellungen oder 14.5 interpretiert eine Einstellung anders als 14.4 mal schauen. Wenn das auch nicht gehe zeig mal einstellungsseiten vom nspanel dann verlgeich ich die mit meinen.
                                          Takahara last edited by
                                          ich versuche die Gäste WLAN Card mit dem QR-Code zum Laufen zu bekommen.
                                          nspanel-lovelace-ui ioBroker FAQ & Anleitungen Kapitel 5.) QR-Code Page
                                          Unter 0 userdata 0 NSPanel GuestWiFi Daten habe ich den Wert entsprechend meiner Test WLAN Konfiguration angepasst.
                                          Mit meinem IPhone habe ich versucht den QR-Code zu lesen. Allerdings ohne Erfolg. "Keine nutzbaren Daten gefunden" erscheint auf dem IPhone.
                                          Hat jemand eine Idee was ich ändern muss? Vielen Dank
                                          T Armilar 2 Replies Last reply Reply Quote 0
                                            TimoWald @Takahara last edited by
                                            @takahara Wenn ich CardsQR anlege und am NSPanel auf die Seite wechseln will kommt diese Meldung aber die Seite wird nicht angezeigt und dann übersprungen.
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at GenerateQRPage (script.js.NSPanels.NSPanel_1:9291:67)
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at GeneratePage (script.js.NSPanels.NSPanel_1:5785:29)
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at HandleButtonEvent (script.js.NSPanels.NSPanel_1:9851:21)
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at HandleMessage (script.js.NSPanels.NSPanel_1:5688:21)
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at script.js.NSPanels.NSPanel_1:5340:21
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at step (script.js.NSPanels.NSPanel_1:33:23)
                                            20.2.2025, 21:12:58.019	[warn ]: javascript.0 (479330)     at Object.next (script.js.NSPanels.NSPanel_1:14:53)
                                            20.2.2025, 21:12:58.020	[warn ]: javascript.0 (479330)     at script.js.NSPanels.NSPanel_1:8:71
                                            20.2.2025, 21:12:58.020	[warn ]: javascript.0 (479330) script.js.NSPanels.NSPanel_1: error at function GenerateQRPage: Cannot read properties of null (reading 'split')
                                            lovelace ui nspanel sonoff
                                            271
                                            7747
                                            6661333
