    4. Backitup fehler bei Grafana
      arnold last edited by
      ERRORgrafanaError on Grafana Dashboard Request: AxiosError: Request failed with status code 500
      ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      Telegram Error Meldung
      Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
      grafana: {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n    at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\n    at IncomingMessage.emit (node:events:530:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n    at processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.7.9","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.80:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_RESPONSE","status":500}
      da ich Debian Version: 12 (bookworm) neu Installation machen will ,will mit Backitup grafana auch komplett mitnehmen .
      • haus-automatisierung
        haus-automatisierung Developer Most Active @arnold last edited by
        @arnold Welche Grafana-Version ist das denn? Token / Service Account so wie in der Doku beschrieben erstellt?
        https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#grafana-backup
        A 2 Replies Last reply Reply Quote 0
          arnold @haus-automatisierung last edited by arnold
          Grafana-Version
          pi@raspberrypi4-iob:~ $ grafana-server -v
          Version 9.2.3 (commit: ec9c2ed029, branch: HEAD)
          erledigt
          Ab Version 9.0 wird zunächst ein Service Account unter "Configuration → Administration Users and access → Service accounts" erstellt. Ist der Account erstellt, kann mit "Add service account token" ein Token hinzugefügt werden.
          • simatec
            simatec Developer Most Active @arnold last edited by
            @arnold Das ist aber keine Antwort auf die Frage von @haus-automatisierung
              Grafana-Version
              erledigt
              Manuelle sicherung schon geklaptt
              DANKE Matthias
                Thomas Braun Most Active @arnold last edited by Thomas Braun
                @arnold
                Grafana solltest du mal in die Gegenwart holen.
                  Version table:
                     11.5.2 500
                        500 https://apt.grafana.com stable/main arm64 Packages
                Den Rest vom Fest dann auch. Der hat's mit Sicherheit dann auch nötig.
