    4. Test Adapter rpi2 2.x
    • Hasont
      Hasont @Hasont last edited by Hasont
      @Garfonso
      Hallo Garfonso,
      ich habe gerade das Update mit der Katze auf 2.3.2 aufgespielt.
      Es kam eine Meldung, dass ich
      sudo apt --fix-broken install
      auführen soll was ich auch gemacht habe. Beim zweiten Update kam dann eine Ellenlange liste
      $ iobroker url iobroker-community-adapters/ioBroker.rpi2 --host raspberrypi --debug
      install iobroker-community-adapters/ioBroker.rpi2
      NPM version: 10.8.2
      Installing iobroker-community-adapters/ioBroker.rpi2... (System call)
      > iobroker.rpi2@2.3.2 preinstall> sudo apt-get install -y libgpiod-dev || exit 0
      Reading package lists...
      Building dependency tree...
      Reading state information...
      libgpiod-dev is already the newest version (1.6.3-1+b3).The following package was automatically installed and is no longer required:
      libcamera0.3Use 'sudo apt autoremove' to remove it.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      > node-dht-sensor@0.4.4 install> node-gyp configure
      gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.18.2 | linux | arm64
      gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      gyp info spawn /usr/bin/python3
      gyp info spawn args [
      gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.2/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.2',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.2/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
      gyp info ok
      > opengpio@1.0.17 install> node-gyp rebuild
      gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.2/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.2',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.2/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
      gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
      SOLINK_MODULE(target) Release/obj.target/opengpio.node
      COPY Release/opengpio.node
      make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'
      gyp info ok
      > node-dht-sensor@0.4.4 postinstall> node-gyp build
      gyp info spawn make
      CC(target) Release/obj.target/nothing/node_modules/node-addon-api/src/nothing.o
      rm -f Release/obj.target/node_modules/node-addon-api/src/nothing.a Release/obj.target/node_modules/node-addon-api/src/nothing.a.ar-file-list; mkdir -p `dirname Release/obj.target/node_modules/node-addon-api/src/nothing.a`
      ar crs Release/obj.target/node_modules/node-addon-api/src/nothing.a @Release/obj.target/node_modules/node-addon-api/src/nothing.a.ar-file-list
      CC(target) Release/obj.target/node_dht_sensor/src/bcm2835/bcm2835.o
      ../src/bcm2835/bcm2835.c: In function ‘bcm2835_init’:
      ../src/bcm2835/bcm2835.c:1818:84: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] 1818 | bcm2835_peripherals = mapmem("gpio", bcm2835_peripherals_size, memfd, (off_t)(uint32_t)bcm2835_peripherals_base); | ^../src/bcm2835/bcm2835.c:1851:84: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] 1851 | bcm2835_peripherals = mapmem("gpio", bcm2835_peripherals_size, memfd, (off_t)(uint32_t)bcm2835_peripherals_base); | ^
      CXX(target) Release/obj.target/node_dht_sensor/src/node-dht-sensor.o
      CXX(target) Release/obj.target/node_dht_sensor/src/dht-sensor.o
      CXX(target) Release/obj.target/node_dht_sensor/src/util.o
      SOLINK_MODULE(target) Release/obj.target/node_dht_sensor.node
      COPY Release/node_dht_sensor.node
      make: Leaving directory '/opt/iobroker/node_modules/node-dht-sensor/build'
      gyp info ok
      added 7 packages in 1m155 packages are looking for funding run `npm fund` for details
      upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
      upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
      Updating objects from io-package.json for adapter "rpi2" with version "2.3.2"
      Process exited with code 0
      Die Ausgänge hab ich auf Ausgangsstellung 0 eingestellt.
      Der Adapter schaltet jetzt ganz kurz alle Relais was auch wahrscheinlich früher so war und zeigt den Zustand dann auch richtig an. Ich wäre aus jetzigen Stand damit zufrieden. Werde morgen mal testen wie er sich bei Ausgangsstellung 1 oder nur Ausgang verhält und es dir melden.
      Vielen, vielen Dank schon mal.
      LG Horst
      PS: Mit meinem Update auf Bookworm wäre ich dann nach 4 Tagen (40Stunden) bis auf den SPI durch.
      SPI brauch ich für meine Feuchtigkeitsfühler. Am leichtesten war das IoBroker Update. Am längsten hat der eBus gedauert.
      Hab jetzt alles Dokumentiert;-). Ist jetzt nur noch SPI offen dann hab ichs geschafft.
      Edit9.02.2025 > Bin leider noch nicht zum Testen von Input, Anfang1 und Ausgang gekommen mach das aber noch!!!
      Komme abar mit SPI grad leider überhaupt nicht weiter, unter bookworm und 64bit hat sich alles geändert. Wenn jemand weiß wie ich da weiter komme wäre ich für jede Hilfe dankbar. Auch wiringpi gibt es scheinbar nicht mehr.
      Hab neuen Thread "MCP3008 in IoBroker einbinden" angelegt.
      Hasont 1 Reply Last reply Reply Quote 1
      • Hasont
        @Garfonso
        Hallo Garfonso,
        die 2.3.2 habe ich nun an meinen 8 Ausgängen und 6 Eingängen getestet und bin für meine Anwendungen mit Ausgang, Ausgangswert 0 absolut zufrieden. Beim Hochfahren werden kurz alle Relais ein- und ausgeschaltet und damit kann ich leben. Die Anzeige in den Objekten ist danach korrekt.
        Dann habe ich alle Ausgang, Ausgangswert 1 eingestellt. Rpi2 startet neu und alle Relais sind eingeschaltet.
        Auch hier ist die Anzeige in den Objekten und der VIS korrekt.
        Ich habe dann alle auf Ausgang, Ausgang gestellt und 4 Relais ein und 4 ausgeschaltet.
        Nach Neustart von Rpi2 wurden diese in den Objekten und in VIS richtig angezeigt.
        Allerdings war es so, dass alle Relais angezogen haben. Die im Objekt eingeschalteten Relais konnte über VIS sofort ausgeschaltet werden. Die als "aus" angezeigten Ausgänge waren ein und mussten über die VIS erst ein- (nix passiert) und dann ausgeschaltet werden. Dann passt wieder alles.
        Die Eingänge habe ich mit 200ms entprellt. Ab und zu reagieren diese noch immer beim Einschalten von induktiven Lasten in unmittelbarer Nähe wie z.B. Trafo für die Gartenventile und Leuchtstoffröhre. Ist aber für meine Anwendung "3min Wasser vorm Haus nach Tastendruck" nicht problematisch.
        Gibt es für die Eingänge schon Werte die man als Standard annehmen kann. Ich konnte mit 100ms und 200ms noch keine Unterschiede feststellen. Habe auch in meinen Script noch entprellt.
        Vielen Dank nochmal für die schnelle Bereitstellung der 2.3.2.
        LG Horst
        L Hasont 2 Replies Last reply Reply Quote 1
          Laser @Hasont last edited by Laser
          @Garfonso
          Habe jetzt auf die 2.3.2 upgedatet (RPI 4). 4 Relaisausgänge. Bei meiner Relaisbaugruppe sind die Relais gezogen, wenn der Ausgang auf "false" steht. 2 Ausgänge "false", 2 Ausgange "true2. RPI reboot. Nach dem Reboot sind alle Relais abgefallen. Ist für mich wichtig.
          In den Objekten verbleiben die Statusanzeigen, wie Sie vor dem Reboot waren. Erst nach hin und herschalten passen die Statusanzeigen. Und die Relais schalten auch erst nach einmal hin und her schalten. Hin und her = Ein/Aus.
          Relais Aus: Objektanzeige "True". Wenn ich ein Relais Einschalten will, muß ich einen Doppelimpuls absenden. Da die Statusanzeige in den Objekten nicht passt, kann ich Die auch nicht vor dem Schaltvorgang sinnvoll abfragen. Browser aktualisieren bringt auch nichts.
          Hasont Garfonso 2 Replies Last reply Reply Quote 0
          • Hasont
            Hasont @Laser last edited by Hasont
            @laser
            Das ist aber komisch jetzt!
            Meine Relais sind nach einem Reboot bei Ausgang=0 immer aus (bis auf das ms kurze ein/aus beim Start)
            Bei Ausgang=1 werden nach dem Reboot alle Relais eingeschaltet.
            Wird bei den Instanzen nur Ausgang ohne 0 oder 1 eingestellt so bleibt es beim letzten Status der Objekte aber alle Relais sind nach Reboot eingeschaltet.
            Die im Objekt mit True gekennzeichneten kann ich sofort mit False ausschalen.
            Die im Objekt mit False gekennzeichneten muss ich erst auf True umschalten und dann wieder auf False.
            Erst dann werden die Relais ausgeschaltet.
            Aus meiner Sicht ist nur noch was falsch wenn er nach einem Reboot mit "Ausgang (ohne 0 oder 1)" den letzten Stand wieder herstellen soll.
            Wird ev. auf deiner Relaiskarte etwas invertiert?
            Wenn der Raspie aus ist oder im Bootmodus sind dann deine Relais ein?
              @hasont Ja, nur nach dem Reboot des Raspi ist das noch nicht optimal gelöst. Meine Relaiskarte läßt das Relais ziehen - Low-aktiv.
              Ist halt so gewesen, bei dieser Karte.
              Hasont 1 Reply Last reply Reply Quote 0
              • Hasont
                @laser
                Das Problem kenn ich weil da Rasperry und Arduino/DSP anders ist und die meisten Relaiskarten eben für Arduino gebaut werden. Du bist also bis auf den letzten Status vor einem Reboot der nicht stimmt mit der 2.3.2 auch zufrieden!
                  @hasont Ja. Die Statusanzeige wäre schon wichtig.
                  • Garfonso
                    Garfonso Developer @Laser last edited by
                    @laser
                    Bei Ausgängen hat der state das read flag auf false stehen, das heißt, der Wert, der da drin steht, ist unbedeutend. So ist der Adapter bisher auch implementiert, wenn ein GPIO als "Ausgang" definiert ist, wird dessen Status nicht gelesen und auch nicht im ioBroker aktualisiert.
                    Ob es dafür einen tieferen Grund gibt, oder nicht, weiß ich nicht. Ich kann mal versuchen einzubauen, dass der Wert beim starten gelesen wird und die state-Datenbank entsprechend aktualisiert.
                    @laser said in Test Adapter rpi2 2.x:
                    Bist du da sicher? Soweit ich den Code im Kopf habe, würde auch ein "true" setzen, obwohl der state schon auf true ist, trotzdem den GPIO versuchen einzuschalten. (wie das jetzt mit einer Visualisierung ist, ist nochmal ein anderes Thema... eigentlich ist das für den Ausgang halt nur ein Taster ohne Zustand).
                    Ich habe selber auch überlegt, ob das nicht sinnvoll wäre nach einem adapter neustart die states aus iobroker auszulesen und die GPIOs entsprechend zu setzen. Vielleicht erweitere ich dafür einfach die tabelle und mach einen "restore" Wert dazu.
                      Laser @Garfonso last edited by Laser
                      @garfonso Ja, wenn ich ohne den Satus zu beachten den Befehl absende, wird er ausgeführt. Werde ich nach dem nächsten Reboot erneut prüfen.
                      Ich habe mich da vom Status in den Objekten verwirren lassen.
                        Smallfeuer @Garfonso last edited by
                        @garfonso sagte in Test Adapter rpi2 2.x:
                        Der Adapter reicht das true/false, was du ins state Objekt setzt (nach einigen Überprüfungen), unverändert an die Bibliothek für die GPIOs weiter
                        Das bedeutet das es wohl Grundlegend geändert wurde. Vor Bookworm war es definitiv andersrum und für mich logischer. Belassen wir es dabei. Wenn du True/False im Hintergrund drehen kannst ohne Auswirkungen (InverseFunction), dann wäre das natürlich auch super. Für alle die mit Ihren alten Scripten/Blockly kommen und jetzt alles umschreiben müssen - definitiv eine ersparnis.
                        Ich setze nun erstmal um sicher zu gehen das die Relais beim Einschalten/Stromausfall / Restart etc. inaktiv sind den GPIO auf "Ausgang mit Ausgangswert 1".
                        Jetzt aber noch ein Problem - bitte mal nachstellen.
                        Wenn ich einen Eingang Abfrage und dieser true ist (Spannung anliegt) und nun einen Adapter Restart mache -> Spannung liegt noch immer an -> geht der Wert auf False.
                        Der Wert wird also nicht korrekt eingelesen, bis er das erst mal geändert wird. Der Wert darf erst aktualisiert werden, wenn er richtig eingelesen wurde.
                          Laser @Smallfeuer last edited by Laser
                          @smallfeuer Ich hatte 2 Ausgänge auf true und 2 auf false. Die beiden mit false haben das Relais anziehen lassen. Raspi reboot. Alle Relais waren abgefallen. Die Beiden, welche angezogen hatten, habe ich noch mal auf Ein (bei mir false) gesetzt. Es passiert nichts. Erst beim erneuten Aus und Einschalten haben die Relais gezogen. Es muß 100% sicher sein, daß nach einem Reboot die Relais in einem bestimmten Status stehen. Auch beim Reboot selber (oder Raspi ohne Spannung) müssen die Relais so stehen (aus).
                          Der Status in den Objekten blieb wie vor dem Reboot.
                          Mit welchen Konsolenbefehlen kann ich den Status der GPIO direkt abfragen?
                            Smallfeuer @Laser last edited by
                            @laser sagte in Test Adapter rpi2 2.x:
                            e
                            gpioinfo -> damit siehst du aber nur Eingang/Ausgang / LOW HIGH
                            für Pin 17:
                            pi3:~ $ gpioget gpiochip0 17
                            gpioget: error reading GPIO values: Device or resource busy
                            jetzt also den Adapter Stoppen:
                            bei mir folgender Zustand:
                            IOB:
                            22 = true
                            17 = false
                            GPIOGET nach deaktivieren des Adapters:
                            pi3:~ $ gpioget gpiochip0 22
                            Was ich nicht verstehen kann, warum ist es bei dir anders? Hast du einen Pi5?
                            L S 2 Replies Last reply Reply Quote 0
                              @smallfeuer Ich habe einen PI4. Aber eine low-aktive Relaiskarte. Low= Relais gezogen.
                                Glaub ich hab deinen Text beim ersten mal falsch gelesen. Scheint ja doch identisch.
                                NA ganz so ist es nicht .
                                Wenn der Strom ausfällt -> muss das Relais Spannungslos sein. Also bei:
                                Ausgangssituation Status: "false" im IOB
                                -> wird true (beim Stromausfall - Relais wird losgelassen)
                                -> sobald Strom/Reboot -> sollte Ausgang wieder "false" werden
                                (Wenn dieser ohne Anfangswert konfiguriert ist - wenn du natürlich den Anfangswert 1 konfigurierst dann bleibt das Relais aus - so ist es auch bei mir aktuell.)
                                  @laser Na du kannst ja das Relais bei diesen "Standard Relasis aus dem PI Baukasten Sortiment" anklemmen wie du magst. LOW oder HIGH
                                  Wichtig ist -> erregt ist das Relais wenn Strom da ist - also der Eingang am Relais beschalten ist -> die LED leuchtet. Darum geht es.
                                  Was die Steuerung dahinter macht ist erstmal egal. Wenn dein Relais Stromausfall hat -> muss es in den sicheren Zustand wechseln. Wenn der sichere Zustand bei dir ein geschlossener Stromkreis am Relais ist, dann ist das für die Sache hier aber nebensächlich.
                                    @smallfeuer Raspi (4) ausgeschaltet- LED an der Relaiskarte glimmen, Relais aber noch nicht gezogen. Wieder hochfahren- Relais ist abgefallen. Statusabfrage = 1. (Adapter gestoppt). Relais abgefallen (LED aus). Auch wenn der Adapter wieder gestartet wird.
                                    Wo kann ich denn einen Anfangswert konfigurieren? Adapter V.2.3.2
                                    Ärgerlich, daß der Status des GPIO nur bei gestopptem Adapter abgefragt werden kann.
                                    EDIT: ich habe jetzt nur Ausgänge betrachtet. Noch keine Eingänge.
                                      Smallfeuer @Smallfeuer last edited by
                                      @smallfeuer sagte in Test Adapter rpi2 2.x:
                                      e
                                      für Pin 17:
                                      IOB:
                                      22 = true
                                      17 = false
                                      @Garfonso Dieses Problem tritt auf wenn ich den Adapter, oder PI Neustarte - > er schreibt den Eingang 17 auf false und prüft ihn nicht vorher. Meiner Meinung nach müsste der State vom Eingang "schreibgeschützt" sein und müsste sich - selbst wenn er manuell geändert in kürzester Zeit zurück ändern. Normalerweise sind doch alle aktiven GPIO überwacht und wenn der Datenpunkt nicht dem GPIO entspricht muss er sofort umgeschrieben werden.
                                        Du musst in den Einstellungen der Instanz wo du Eingang und Ausgang definierst, Ausgang mit Anfangswert 0 /1 auswählen.
                                          JA, stellt sich mir daraus eine Frage:
                                          Wenn der Ausgang 0 ist -> Relais erregt - LED AN
                                          -> dann der Adapter beendet wird
                                          -> wird dann der Wert auf 1 gesetzt und das Relais deaktiviert - LED AUS?
                                            @smallfeuer Den Anfangswert kann ich nur beim Neuanlegen festlegen. Das war mir nicht klar. Gab es möglicherweise in älteren Versionen noch nicht. Zur Zeit geht, ohne daß ich das konfiguriert habe, der Ausgang auf 1, nach dem Neustart.
                                            Das Relais ist deaktiviert.
                                            EDIT: habe jetzt auf "Ausgangswert 1" konfiguriert. Nach dem Neustart des RPI steht auch eine 1 an.
                                            519
                                            146444
