    4. Test Adapter MercedesMe v0.0.x
    • sigma415
      sigma415 @sigma415 last edited by sigma415
      @sigma415 sagte in Test Adapter MercedesMe v0.0.x:
      @tombox
      OK. Wo finde ich die und wie installiere ich die ?
      @tombox : OK, ich glaube ich hab's hingekriegt ?!?!
      War das richtig so ?
      Die HTTPS-URL aus GitHub kopiert
      und in ioB eine "Benutzerdefinierte Installation" von diesem Link gemacht.
      Jedenfalls steht dann im Log was von "non-npm: TA2k/ioBroker.mercedesme#5b76638a09e5237cb72edf7e3cb84020805987e3"
      2025-02-15 17:48:55.647 - info: mercedesme.0 (3862272) terminating
      2025-02-15 17:48:55.742 - info: host.ubuntu-server instance system.adapter.mercedesme.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-15 17:48:59.485 - info: host.ubuntu-server instance system.adapter.mercedesme.0 in version "0.3.7" (non-npm: TA2k/ioBroker.mercedesme#5b76638a09e5237cb72edf7e3cb84020805987e3) started with pid 3862782
      2025-02-15 17:49:01.169 - info: mercedesme.0 (3862782) starting. Version 0.3.7 (non-npm: TA2k/ioBroker.mercedesme#5b76638a09e5237cb72edf7e3cb84020805987e3) in /opt/iobroker/node_modules/iobroker.mercedesme, node: v20.18.3, js-controller: 7.0.6
      2025-02-15 17:49:01.396 - info: mercedesme.0 (3862782) Found old session. Try to refresh token
      2025-02-15 17:49:01.623 - info: mercedesme.0 (3862782) Refresh token successfull
      2025-02-15 17:49:01.919 - info: mercedesme.0 (3862782) Found 1 vehicles
      2025-02-15 17:49:01.919 - info: mercedesme.0 (3862782) Creating vehicle WWWWWWWWWW with XXXXXX
      2025-02-15 17:49:01.971 - info: mercedesme.0 (3862782) Start Websocket Connection
      2025-02-15 17:51:59.810 - info: admin.0 (1145676) <== Disconnect system.user.admin from ::ffff:192.168.xxx.yyy
      Passt das erstmal so ?
        tombox @sigma415 last edited by
        @sigma415 Ja das passt
          tombox @Duffy last edited by
          @duffy Email und Passwort in den Einstellungen eingeben
          • Duffy
            Duffy @tombox last edited by
            @tombox
            Danke, läuft 👍
            Gruß Duffy
            • sigma415
              sigma415 @tombox last edited by
              @tombox sagte in Test Adapter MercedesMe v0.0.x:
              @sigma415 bitte das mit der GitHub version wiederholen
              @tombox Hier ein 24h-Tages-Log aus GitHub-Version TA2k/ioBroker.mercedesme#5b76638a09e5237cb72edf7e3cb84020805987e3 mit Delay = 240 Sekunden.
              Ich wiederhole das jetzt mit Delay = 60 Sekunden. Neues Log folgt dann übermorgen.
              iobroker.2025-02-16_anonym.log
              sigma415 1 Reply Last reply Reply Quote 0
              • sigma415
                @tombox
                Hier jetzt 2 Stück 24h-Logs mit Delay = 60 Sekunden:
                iobroker.2025-02-18_anonym.log
                iobroker.2025-02-19_anonym.log
                  @sigma415 Ein test mit 70 wäre noch interessant
                  sigma415 2 Replies Last reply Reply Quote 0
                  • sigma415
                    @tombox
                    OK, mach ich mit 70 Sekunden.
                    Ich habe jetzt die dea884b drauf.
                    • sigma415
                      Hier jetzt (fast) 24h Log aus dea884b mit Delay = 70 Sek
                      iobroker.2025-02-20_anonym.log
                        @sigma415 ok also um die 120-150 sollte der richtige Wert sein
                        • sigma415
                          sigma415 @tombox last edited by sigma415
                          @tombox
                          150 sec reicht nicht. Da kriege ich auch:
                          2025-02-27 00:55:31.097 - info: mercedesme.0 (9792) 429 Too many requests. The account is blocked until 0:00. Reconnects Today: 11
                          Ich gehe jetzt auf 180, dann wieder auf 240
                          • sigma415
                            @tombox :
                            Mit Delay = 210 sec bekomme ich KEINE "429 Too many requests. The account is blocked until 0:00" mehr und ziemlich genau 82 Reconnects pro Tag.
                            • mbosch
                              mbosch last edited by
                              vielen Dank für den Adapter.
                              Ich habe diesen vor etwa 2 Wochen eingerichtet und soweit funktioniert auch alles prima.
                              Jetzt habe ich in der mercedes me App 2 Geo Fence Zonen (Gebiete) eingerichtet.
                              Ich hatte so latent die Erwartung, dass ich die Zonen dann auch im ioBroker unter ".../geofencing" wiederfinde. Leider ist der Knoten weiterhin leer.
                              Ist meine Erwartung falsch?
                                bishop9191 last edited by
                                Hat noch jemand die letzte Zeit wieder öfter mal Probleme, dass die Instanz auf Gelb ist?
                                sigma415 Duffy S 3 Replies Last reply Reply Quote 0
                                • sigma415
                                  sigma415 @bishop9191 last edited by
                                  @bishop9191
                                  Ja, schon seit mehreren Tagen auf: https://github.com/TA2k/ioBroker.mercedesme/issues/238
                                  T-S-Garp created this issue in TA2k/ioBroker.mercedesme
                                  open mercedes.me instance not connecting to car anymore #238
                                  • Duffy
                                    Duffy @bishop9191 last edited by
                                    @bishop9191
                                    Ja, bei mir auch.
                                      klassisch Most Active @sigma415 last edited by
                                      @sigma415 Dieser Tage zufällig in der Instanzenansicht als gelb erwischt. Nach restart wieder grün. Die Daten, die ich in der vis Ansicht habe, scheinen aber immer aktuell gewesen zu sein.
                                      Hatte aber ein Problem mit der App. Die wollte immer einen Code haben, der angeblich per Mail geschickt worden sei. Wurde er aber nicht. Mußte App deinstallieren und dann wieder neu installieren.
                                        shadow_cb @bishop9191 last edited by shadow_cb
                                        @bishop9191
                                        ja bei mir auch. Jeden früh auf gelb. Restart geht, ist dann auf grün. Dann wird aber trotzdem lange nicht der %-Satz der Batterieladung aktualisiert. Fehlermeldungen immer mal:
                                        AxiosError: Request failed with status code 404
                                        Error getting GeoFence
                                        Nach jedem Adapterneustart kommen die Meldungen. Habt Ihr das auch?
                                        Die Neuinstallation des Adapters brachte nun mal eine Aktualisierung der Werte.
                                        M S 2 Replies Last reply Reply Quote 1
                                          MB11 @shadow_cb last edited by
                                          @shadow_cb
                                          das gleiche Problem habe ich auch seit paar Tagen !
                                          vielleicht liegt das an der ME Aktualisierung Einwilligung .... Datenschutz da war doch mal was.?
                                          Gruß Markus
                                            MB11 last edited by
                                            @shadow_cb
                                            Gruß Markus
                                            mercedes
                                            120
                                            929
                                            224821
