    3. Einsteigerfragen
    4. Zigbee kabelgebundene Geräte reagieren nicht
      maxpd @Asgothian last edited by
      @asgothian
      Was mir aufgefallen ist, die PAN ID meiner initialen Instanz ist 6755.
      Von allen anderen Instanzen in die ich ein Backup einspiele ist sie 6754.
      Die initiale Instanz startet aber nur mit der 6755, nicht mit einer 6754.
      Wie kommts? Hab nicht daran rumgespielt.
      Hier, was beim starten kommt:
      zigbee.0
      2025-02-21 10:34:33.100	info	Currently 60 devices are joined:
      zigbee.0
      2025-02-21 10:34:33.064	info	--> transmitPower : high+
      zigbee.0
      2025-02-21 10:34:33.043	info	Unable to disable LED, unsupported function.
      zigbee.0
      2025-02-21 10:34:33.041	info	Disable LED
      zigbee.0
      2025-02-21 10:34:33.041	info	Zigbee network parameters: panID=6755 channel=11 extendedPanID=dddddddddddddddd
      zigbee.0
      2025-02-21 10:34:33.040	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0
      2025-02-21 10:34:32.523	info	Installed Version: asgothian/ioBroker.zigbee#9bb500b9b8d7e8926e31a894b572dc52bf0a6729
      zigbee.0
      2025-02-21 10:34:31.697	info	Starting Zigbee npm ...
      zigbee.0
      2025-02-21 10:34:31.695	warn	devices are
      zigbee.0
      2025-02-21 10:34:31.693	warn	legacy models are []
      zigbee.0
      2025-02-21 10:34:31.692	warn	devices are
      zigbee.0
      2025-02-21 10:34:31.690	info	delete old Backup files. keep only last 10
      zigbee.0
      2025-02-21 10:34:31.605	warn	localConfig:loaded data {"by_id":{},"by_model":{}}
      zigbee.0
      2025-02-21 10:34:31.602	info	init localConfig
      zigbee.0
      2025-02-21 10:34:31.570	info	starting. Version 1.10.15 (non-npm: asgothian/ioBroker.zigbee#9bb500b9b8d7e8926e31a894b572dc52bf0a6729) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6```
      • Asgothian
        Asgothian Developer @Homoran last edited by
        @homoran sagte in Zigbee kabelgebundene Geräte reagieren nicht:
        ist halt "KI"
        mehtr KD 🙂 (Künstlicher Dummpfug)
        • Asgothian
          Asgothian Developer @maxpd last edited by
          @maxpd das ist nicht der Branch sondern der Master. Was genau hast du als Link eingetragen ?
          A.
            maxpd @Asgothian last edited by maxpd
            @asgothian https://github.com/asgothian/ioBroker.zigbee.git
            Der zeigt mir in dem Branch auch nur den Hauptlink an:
            Asgothian 2 Replies Last reply Reply Quote 0
            • Asgothian
              @maxpd in dem post ist der korrekte Link drin. Damit bekommst du dann auch den aktuellen 1.11 (von heute), sowie die Informationen was gehen und nicht gehen sollte.
              A.
              • Asgothian
                @maxpd Hast du inzwischen vom korrekten Link installiert ? Wenn ja, dann bitte nochmal drüber installieren - dann hast du die Version 2.0.1. So soll der (mit @arteck s Hilfe ins Latest geschoben werden.
                A.
                  @asgothian Hi, ja hatte ich. Ich installiere auch gleich darüber. Er hat tatsächlich auch wieder die Hälfte der kabelgebundenen Geräte ansprechen können. Dafür fehlen jetzt ein paar Batteriegeräte. Irgendwie ist nun die Netzwerkroute hin.
                  Bei allen Geräten fehlt jetzt der sprechende Name, als würde er sich die neue Datei dev_names.json nicht ziehen.
                  Und es fehlt bei allen Geräten das default Bild.
                  • Asgothian
                    Asgothian Developer @maxpd last edited by Asgothian
                    @maxpd sagte in Zigbee kabelgebundene Geräte reagieren nicht:
                    Unwahrscheinlich. Gib denen etwas Zeit
                    Das sollte wenn du heute nochmal über-installierst gefixed sein. Dazu musst du aber die Datei LocalOverrides.json löschen - wenn die nicht da ist zieht er sich einmalig nochmal die dev_names.json
                    bitte ein Adapter Upload machen - dann sind alle Bilder da
                    hast du den verlinkten Thread gelesen - da gibt es eine Liste mit den Änderungen.
                    A.
                      @asgothian Ok, Namen klappen wieder.
                      Zeit hatten sie seit der 1.11.3 ca 24h.
                      Hab den Thread gelesen ja. Da stand drin, dass man sich nun auch selber Icons ablegen kann. Dass die normalen Bilder verschwinden, habe ich nicht gesehen.
                      • Asgothian
                        @maxpd Die verschwinden nicht - es werden die Bilder nur beim ersten auftreten eines Devices aus dem Netz geladen. Danach muss ein Upload des Adapters gemacht werden (nach dem 1. Start). Kommt auch noch in die offizielle Doku.
                        Es kommt auch noch ein Hinweis in das Adapter-UI wenn ein upload notwendig ist. Leider können wir den so nicht einfach anstossen
                        Inzwischen solltest Du im Objektbaum auch 'orange' eingefärbte Datenpunkte finden - diese sind veraltet und werden vom Adapter nicht mehr unterstützt. Du musst also deine Skripte / Alias entsprechend anpassen. Wenn das geschehen ist kannst du diese alle per 'state cleanup' (roter Knopf im Admin) löschen lassen
                        A.
                          @asgothian da heute immer noch viele Devices nicht im Netzwerk angekommen sind, lerne ich wohl alles einmal neu an.
                          Aber puh, ich glaube das Anpassen der Scripte ist noch mehr Aufwand. Alle Datenpunkte die ich vorher genutzt hatte, gibt es nun nicht mehr oder wurden umbenannt. No Motion der Aqara Sensoren wurde zu jeder Steuerung benutzt und illumination (jetzt: illumination_raw) auch
                          Number of power outages kann ich noch nicht so recht deuten.
                          W Asgothian 2 Replies Last reply Reply Quote 0
                            Wildbill @maxpd last edited by
                            @maxpd Da kann man Dir nur empfehlen, einmal ALIASe für die relevanten Datenpunkte anzulegen und dann in Skripten und Visualisierungen nur noch auf die ALIASe zu verweisen. Dann musst Du bei derartigen Änderungen oder auch mal dem Austausch eines Geräts bei Defekt nur den jeweiligen ALIAS einmal anpassen und der Rest passt automatisch.
                            Gruss, Jürgen
                            • Asgothian
                              @maxpd Siehe Hier.
                              https://forum.iobroker.net/topic/79504/alpha-tester-für-zigbee-adapter-v2-0/18?_=1740304985790
                              Das Problem ist bekannt, lässt sich aber leider nicht wirklich ändern. Ich hab versucht weitgehend dabei zu unterstützen das man sehen kann
                              • was unterschiedlich ist
                              • ob es unterschiede gibt
                              Mehr kann ich kaum tun. Bei ca. 120 betroffenen Gerätetypen, von denen ich genau 2 selber zum Testen habe und vernachlässigbarer Unterstützung bei Test und Umsetzung von Gegenmassnahmen hab ich das Thema beerdigt.
                              A.
                              Nachtrag: Was @Wildbill geschrieben hat. Dann bist Du für die Zukunft gewappnet.
                                maxpd @Wildbill last edited by
                                @wildbill das Alias System in seinem Grundgedanken verstehe ich. Aber für mich hat sich nie Aufwand/Nutzen gerechnet. Auch jetzt nicht, wenn ich 60 Scripte anfassen muss. Das Erstellen der Datenpunkte ist aufgrund fehlender Automatismen wie Multiselect oder durch Auslesung von Scripten auf notwendige Aliases, einfach zu schwerfällig und aufwendig. Da bin ich auch bei 3x Scripte ändern schneller.
                                • Asgothian
                                  So hab ich auch mal gedacht. Bis mir klar wurde das ich dann bei so einer grossen Änderung wie die des Zigbee-Adapters alle skripte, History, upnp, etc. durchgehen muss um die Anpassungen zu machen.
                                  Seit ich die Alias benutze kann ich direkt im Objektbaum sehen wo ich den besagten State nutze, und dementsprechend die Umstellung vornehmen. Ich werde also getriggert wo etwas ist, und bin sicher das ich nichts vergesse. Seit dem ist bei mir alles was ich in Skripten, anderen Adaptern, DP-Spezifischen Einstellungen habe nur am Alias.
                                  Ja, es ist viel Aufwand das alles umzubauen. Es hat sich für mich aber bereits mehrfach rentiert. (ausgefallene Geräte, breaking changes in Adaptern, etc.)
                                  A.
                                    Mäcki_MD last edited by
                                    ich habe seit heute Nacht das selbe Problem.
                                    Habe nichts am Abend davor verändert.
                                    Neustarts usw habe ich bereits alles ausprobiert.
                                    Hatte auch noch einen älteren Stick (CC2531) da aber auch da ist das selbe Problem.
                                    Als Zigbee Adapter habe ich die 1.10.14 installiert.
                                    Es funktionieren wie beim Themenersteller alle Batteriebetriebenen Geräte wie Fensterkontakte oder einen an/aus schalter.
                                    Alle Lampen und andere Aktoren lassen sich nicht ansprechen.
                                    NodeJS 20.28.3
                                    JS Controller 7.0.6
                                    Habe jetzt schon den Sonoff CC2652P bestellt.
                                      maxpd @Mäcki_MD last edited by
                                      @mäcki_md entweder die 1.10.3 mit entsprechendem backup von vor der 1.10.14 installieren oder die 2.0
                                      Klappt es damit nicht, dann wie ich, neu anlernen.
                                      1.3k
                                      74
                                      6024
