    4. [geklärt] History Adapter viele Fehlermeldungen
      Peter c @David G. last edited by
      @david-g said in History Adapter viele Fehlermeldungen:
      hilft evtl
      Hab ich versucht. Dann kommt folgendes:
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
        Thomas Braun Most Active @Peter c last edited by
        @peter-c sagte in History Adapter viele Fehlermeldungen:
        Dann ist dein System nicht auf Stand.
          Peter c @Thomas Braun last edited by
          @thomas-braun said in History Adapter viele Fehlermeldungen:
          Hier die Diagnose
          ========== Start marking the full check here ===========
          ```bash
          Script v.2025-02-02
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          OS is similar to: debian
          Model		: Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 32 bit
          Systemuptime and Load:
           12:59:07 up  1:14,  2 users,  load average: 0.65, 0.68, 8.43
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          *** TIME AND TIMEZONES ***
                         Local time: Sat 2025-02-22 12:59:07 CET
                     Universal time: Sat 2025-02-22 11:59:07 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pt
          HOME=/home/pt
          GROUPS=pt adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Mem:            3.8G        942M        2.5G        0.0K        374M        2.8G
          Swap:            99M         28M         71M
          Total:          3.9G        970M        2.5G
          Active iob-Instances: 	20
                   3794 M total memory
                    942 M used memory
                    980 M active memory
                    208 M inactive memory
                   2477 M free memory
                     48 M buffer memory
                    326 M swap cache
                     99 M total swap
                     28 M used swap
                     71 M free swap
          top - 12:59:08 up  1:14,  2 users,  load average: 0.65, 0.68, 8.43
          Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  4.2 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3794.3 total,   2476.6 free,    942.6 used,    375.1 buff/cache
          MiB Swap:    100.0 total,     71.5 free,     28.5 used.   2776.5 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          /dev/root      ext4       29G   13G   16G  45% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
          [Sat Feb 22 11:45:01 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.7G	/var/
          969M	/var/log
          961M	/var/log/journal/061ea1674ff8454f9e4d5c7dfa8e6e06
          458M	/var/cache
          Archived and active journals take up 960.2M in the file system.
          /opt/iobroker/backups:
          83M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          3.8G	/opt/iobroker/iobroker-data/
          2.9G	/opt/iobroker/iobroker-data/history
          927M	/opt/iobroker/iobroker-data/files
          617M	/opt/iobroker/iobroker-data/files/javascript.admin
          560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
          19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
          13M	/opt/iobroker/iobroker-data/objects.jsonl
          9.3M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v20.18.3
          /usr/bin/node 		v20.18.3
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          /usr/bin/corepack 	0.30.0
          nodejs:
            Installed: 20.18.3-1nodesource1
            Candidate: 20.18.3-1nodesource1
            Version table:
           *** 20.18.3-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u5 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1610)
          Core adapters versions
          js-controller: 	7.0.6
          admin: 		7.4.10
          javascript: 	8.8.3
          nodejs modules from github: 	1
          `-- tibber-api@5.1.9 (git+ssh://git@github.com/bisand/tibber-api.git#c288a93c2f4d4989dc8214f9e3549477fd1b5acd)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
            system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
            system.adapter.history.0                : history               : iobroker                                 - disabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.94
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
          + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tibberlink"   : 4.2.3    , installed 4.2.3
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects: 	4957
          States: 	4074
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1909       561/sshd: /usr/sbin
          tcp        0      0 192.168.178.94:1883     0.0.0.0:*               LISTEN      1001       89012      32415/io.mqtt.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       86010      32217/node-red
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       89868      32385/io.shelly.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87431      32050/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       85718      32050/iobroker.js-c
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15383      532/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15079      561/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       87566      32168/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       92298      32644/io.web.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15382      532/cupsd
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       92237      32571/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       92238      32571/io.tuya.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1823       398/avahi-daemon: r
          udp        0      0 0.0.0.0:52477           0.0.0.0:*                           108        1825       398/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      476/dhcpcd
          udp6       0      0 :::47601                :::*                                108        1826       398/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14060      476/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        1824       398/avahi-daemon: r
          2025-02-22 12:54:58.082  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:54:58.088  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:54:58.095  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:54:58.105  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:55:11.466  - warn: mqtt.0 (32415) Client [SOYO_3b2107] Message 519 deleted after 11 retries
          2025-02-22 12:55:12.580  - info: mqtt.0 (32415) Client [SOYO_3b2107] reconnected. Old secret 1740225297871_6311. New secret 1740225312579_2546
          2025-02-22 12:55:12.596  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.L1L2L3"
          2025-02-22 12:55:12.609  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.NotAus"
          2025-02-22 12:55:12.620  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.WaitSekunden"
          2025-02-22 12:55:12.637  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.MaxPower"
          2025-02-22 12:55:12.796  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:55:12.810  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:55:12.820  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:55:12.838  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:59:57.435  - info: mqtt.0 (32415) Client [SOYO_3b2107] connection closed: Error: read ECONNRESET
          2025-02-22 12:59:57.908  - info: mqtt.0 (32415) Client [SOYO_3b2107] connected with secret 1740225597907_7518
          2025-02-22 12:59:57.918  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.L1L2L3"
          2025-02-22 12:59:57.927  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.NotAus"
          2025-02-22 12:59:57.933  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.WaitSekunden"
          2025-02-22 12:59:57.941  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.MaxPower"
          2025-02-22 12:59:58.118  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:59:58.128  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:59:58.133  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 12:59:58.142  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
          2025-02-22 13:00:00.096  - info: javascript.0 (32228) script.js.Skript_Shelly_Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 6
            bullseye
            Aktuell ist Bookworm.
            Installier es neu, diesmal in der 64Bit-Lite-Version.
            ioBroker-Backup einspielen, fertig.
              wie installiere ich bookworm?
                @peter-c
                So:
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                P 2 Replies Last reply Reply Quote 0
                  Das ganze System neu aufsetzen?
                    @peter-c
                    Ja natürlich. Komplett von Grund auf NEU.
                      Ohne nach der Ursache zu suchen?
                        @peter-c
                        Was willst du auf dem toten Pferd denn noch suchen?
                        Du musst die Kiste eh neuaufsetzen, Fehler hin oder her.
                          toten Pferd
                          Sorry das ich das nachfrage. Warum ist meine Installation auf einmal ein totes Pferd?
                            @peter-c
                            Weil Debian 11 'Bullseye' im Upstream das EndOfLife erreicht hat.
                            Weil du da im Userland 32Bit fährst.
                            Weil du da so einen Quark wie CUPS aktiv hast.
                            Weil du da komische Fehlerbilder hast.
                            David G. P 2 Replies Last reply Reply Quote 0
                            • David G.
                              David G. @Thomas Braun last edited by
                              @thomas-braun sagte in History Adapter viele Fehlermeldungen:
                              Warum Quark.
                              Hab es auch auf einem anderen iobroker System und finde ess sehr praktisch.
                                Ich nutze keine Printfunktion über den IOB
                                  Homoran Global Moderator Administrators @Peter c last edited by
                                  da reicht wohl das Netzteil nicht.
                                  wo liegen deine History Daten?
                                    Peter c last edited by Peter c
                                    @homoran said in History Adapter viele Fehlermeldungen:
                                    so weit ich weiß auf der SD Karte.
                                    Das Netzteil hatte ich nicht geändert.
                                      dann ist es wohl von Anfang an zu schwach gewesen
                                        Peter c @Homoran last edited by Peter c
                                        Kann es sein, dass eine Netzunterbrechnung den Eintrag auslöst?
                                        Das ist vorgekommen.
                                        Soll ich den History adapter neu aufsetzen oder wirklich das System komplett neu aufsetzen?
                                          alles andere ergibt keinen Sinn!
                                          Nimm eine neue Karte, darauf bookworm lite 64bit, dann iob installieren und neuestes Backup zurückspielen.
                                          fertig!
                                            Ja.
                                            1093
