    4. Test Adapter flexcharts - Stapeldiagramme und mehr
    • M-A Hueb
      M-A Hueb @jrbwh last edited by
      @jrbwh habs dort auch reingestellt
      • icebear
        icebear @M-A Hueb last edited by
        @m-a-hueb said in Test Adapter flexcharts - Stapeldiagramme und mehr:
        hab hier mal 2 Charts gebaut. Dank geht an
        Kann man die Farben der Balken auch verändern?
        jrbwh 1 Reply Last reply Reply Quote 0
        • jrbwh
          jrbwh @icebear last edited by
          @icebear Die Farben der Balken ändert man bei der Definition der Datenreihen (series), z.B. so:
                              series: [{ name: "Consumption", type: "bar", color: "#ff0000", yAxisIndex: 0, data: []},
                                       { name: "Cost",        type: "bar", color: "#00ff00", yAxisIndex: 1, data: []}]
          Die Referenz zu Chart-Definitionen findest Du hier. Wenn Du da die Option "series" aufklappst, findest Du den Parameter "color".
          • Merlin123
            Merlin123 @M-A Hueb last edited by
            @m-a-hueb sagte in Test Adapter flexcharts - Stapeldiagramme und mehr:
            @merlin123 von dem hier:
            // Create chart for Tibber data. To be used with flexcharts.
            // Sample http request for hourly data chart:
            // http://localhost:8082/flexcharts/echarts.html?source=script&message=tibber&chart=hourly
            // Replace 'MY-TOKEN' with your own token:
            const ID_TIBBER = 'tibberLink.0.Homes.MY-TOKEN.Consumption';
            const IDS = { hourly:  '.jsonHourly',  // hourly data
                          daily:   '.jsonDaily',   // daily data
                          weekly:  '.jsonWeekly',  // weekly data
                          monthly: '.jsonMonthly'  // monthly data
            onMessage('tibber', (httpParams, callback) => {
                // Use hourly data in case of invalid chart type
                const id = (httpParams.chart && httpParams.chart in IDS ? ID_TIBBER+IDS[httpParams.chart] : ID_TIBBER+IDS['hourly']);
                if (existsState(id)) {
                    evalTibberData(httpParams.chart, id, result => callback(result));
                } else {
                    console.log('Requested state is not available >>'+id+'<<');
                    callback({title: { left: "center", textStyle: { color: "#ff0000" }, text: "REQUESTED STATE IS NOT AVAILABLE: >>" + id +"<<" }});
            function evalTibberData(myChart, id, callback) {
                const tibber = JSON.parse(getState(id).val);  // Read tibber data
                const chart = {
                                tooltip: { trigger: "axis", axisPointer: { type: "cross" }},
                                legend: { show: true, orient: "horizontal", left: "center", top: 25 },
                                title: { left: "center", text: "Tibber " },
                                grid: { right: "20%" },
                                toolbox: { feature: { dataView: { show: true, readOnly: false }, restore: { show: true }, saveAsImage: { show: true }}},
                                xAxis: [{ type: "category", axisTick: { alignWithLabel: true }, data: []}],
                                yAxis: [{ type: "value", position: "left",  alignTicks: true, axisLine: { show: true, lineStyle: { color: "#5470C6" }}, axisLabel: { formatter: "{value} kWh" }},
                                        { type: "value", position: "right", alignTicks: true, axisLine: { show: true, lineStyle: { color: "#91CC75" }}, axisLabel: { formatter: "{value} €" }}],
                                series: [{ name: "Consumption", type: "bar", yAxisIndex: 0, data: []},
                                         { name: "Cost",        type: "bar", yAxisIndex: 1, data: []}]
                const xAxis  = [];
                const yAxis0 = [];
                const yAxis1 = [];
                for (const data of Object.values(tibber)) {
                    const isHourly = (myChart == 'hourly');  // Hourly data?
                    const xValue = (isHourly ? new Date(data.from).toLocaleTimeString() : new Date(data.from).toLocaleDateString());
                    xAxis.push(xValue);
                    yAxis0.push((data.consumption ? data.consumption.toFixed(2) : 0));  // push 0 on null values
                    yAxis1.push((data.cost ? data.cost.toFixed(2) : 0));                // push 0 on null values
                chart.xAxis[0].data  = xAxis;       // Set chart x-axis data
                chart.series[0].data = yAxis0;      // Set chart y-values consumption
                chart.series[1].data = yAxis1;      // Set chart y-values cost
                chart.title.text += myChart;             // Add type of chart to title
                console.log('Evaluation of tibber '+myChart+' data done.');
                callback(chart);
            Das ist nicht von mir 😉
              legro @jrbwh last edited by legro
              @jrbwh
              Nachdem ich mir nunmehr viele Wünsche mit deinem flexcharts-Adapter erfüllt habe - vielen Dank für diesen hervorragenden Adapter - habe ich gestern das neueste Update 3.2 installiert. Da wurde mir etwas à al echart-gl angezeigt. Ist diese Library mittlerweile in deinem Adapter integriert?
              Mutig begab ich mich ans Testen und probierte das nachfolgende, einfache Chart aus ..
                "series": [{
                  "type": "pie3D",
                  "data": [
                    45,20,56,80
                  "depth": 45,
                  "angle": 40
              Leider erscheint keine Anzeige. Mache ich etwas falsch oder fehlt noch echart-gl?
              • jrbwh
                jrbwh @legro last edited by
                @legro Ja, ab 0.3.1 werden 3D-Charts unterstützt. Probier mal diese Chart-Definition, die sollte funktionieren:
                {"tooltip":{},"visualMap":{"min":1,"max":6,"dimension":2,"inRange":{"color":["#313695","#4575b4","#74add1","#abd9e9","#e0f3f8","#ffffbf","#fee090","#fdae61","#f46d43","#d73027"]}},"xAxis3D":{"type":"category","name":"AT (°C)"},"yAxis3D":{"type":"category","name":"VL (°C)"},"zAxis3D":{"type":"value","name":"COP"},"grid3D":{"boxWidth":100,"boxDepth":100,"viewControl":{"projection":"perspective"}},"series":[{"type":"scatter3D","symbolSize":10,"data":[[-10,35,3.43],[-10,40,3.18],[-10,45,2.92],[-10,50,2.65],[-10,55,2.37],[-10,60,2.08],[-10,65,1.78],[-8,35,3.67],[-8,40,3.42],[-8,45,3.15],[-8,50,2.88],[-8,55,2.6],[-8,60,2.31],[-8,65,2.01],[-6,35,3.92],[-6,40,3.67],[-6,45,3.4],[-6,50,3.13],[-6,55,2.85],[-6,60,2.56],[-6,65,2.26],[-4,35,4.18],[-4,40,3.93],[-4,45,3.67],[-4,50,3.4],[-4,55,3.12],[-4,60,2.83],[-4,65,2.53],[-2,35,4.44],[-2,40,4.19],[-2,45,3.92],[-2,50,3.65],[-2,55,3.37],[-2,60,3.08],[-2,65,2.78],[0,35,4.69],[0,40,4.44],[0,45,4.18],[0,50,3.91],[0,55,3.63],[0,60,3.34],[0,65,3.04],[2,35,4.95],[2,40,4.7],[2,45,4.43],[2,50,4.16],[2,55,3.88],[2,60,3.59],[2,65,3.29],[4,35,5.2],[4,40,4.95],[4,45,4.69],[4,50,4.42],[4,55,4.14],[4,60,3.85],[4,65,3.55],[6,35,5.44],[6,40,5.19],[6,45,4.93],[6,50,4.66],[6,55,4.38],[6,60,4.09],[6,65,3.79],[8,35,5.67],[8,40,5.42],[8,45,5.16],[8,50,4.89],[8,55,4.61],[8,60,4.32],[8,65,4.02],[10,35,5.89],[10,40,5.64],[10,45,5.38],[10,50,5.11],[10,55,4.83],[10,60,4.54],[10,65,4.24],[12,35,6.1],[12,40,5.85],[12,45,5.59],[12,50,5.32],[12,55,5.04],[12,60,4.75],[12,65,4.45],[14,35,6.29],[14,40,6.04],[14,45,5.78],[14,50,5.51],[14,55,5.23],[14,60,4.94],[14,65,4.64],[16,35,6.47],[16,40,6.22],[16,45,5.96],[16,50,5.69],[16,55,5.41],[16,60,5.12],[16,65,4.82],[18,35,6.63],[18,40,6.38],[18,45,6.12],[18,50,5.85],[18,55,5.57],[18,60,5.28],[18,65,4.98],[20,35,6.78],[20,40,6.53],[20,45,6.27],[20,50,6],[20,55,5.72],[20,60,5.43],[20,65,5.13]]}]}
                  @jrbwh
                  Beeindruckend!👍
                  Meine bisher gepflegte Strategie: Ganz klein anfangen! Ich möchte Stück für Stück jeden Schritt verstehen. Nur so kann ich dann hoffentlich irgendwann einmal meine Wünsche in die Tat umsetzen.
                  Aber meine Wünsche sind noch viel bescheidener. Was ist an meinem Beispiel wohlmöglich falsch?
                  • jrbwh
                    @legro Ich finde in der Doku zu echart-gl keinen Typ "pie3D":
                    Wo hast Du das gefunden?
                      @jrbwh
                      Das Beispiel hatte noch weitere Optionen, aber diese betrafen nicht die 3D-Darstellung. Daher hatte ich diese im obigen Beitrag weggelassen.
                      Leider finde ich die Stelle (auch) nicht mehr. 😕 Weiß der Teufel, wo das war. Das einzige, was ich derzeit finde, ist die Aussage, dass derzeit ECharts wohl doch noch keine 3D Pie Charts beherrscht. Schade.
                      • icebear
                        @jrbwh
                        Ich hab auch noch eine Frage und zwar wollte ich diese Chart anzeigen lassen, aber egal was ich mache die Seite bleibt einfach weiß.
                        Ich habs mal so hier gepostet wie ich es bei den Examples zusammengebaut hab.
                        Alle anderen Chart's bei mir funktionieren
                        option = {
                          tooltip: {
                            trigger: 'axis',
                            axisPointer: {
                              type: 'cross',
                              crossStyle: {
                                color: '#999'
                          toolbox: {
                            feature: {
                              magicType: { show: true, type: ['line', 'bar'] },
                          legend: {
                            data: ['Strom', 'Umweltertrag', 'Erzeugte Waerme']
                          xAxis: [
                              type: 'category',
                              axisTick: {
                              // prettier-ignore
                              data: ['Jan', 'Feb', 'Mar', 'Apr', 'May', 'Jun', 'Jul', 'Aug', 'Sep', 'Oct', 'Nov', 'Dec']
                          yAxis: [
                              type: 'value',
                              min: 0,
                              max: 1000,
                              interval: 100,
                              axisLabel: {
                                formatter: '{value} KWh'
                              type: 'value',
                              min: 0,
                              max: 6,
                              interval: 1,
                              axisLabel: {
                                formatter: '{value}'
                          series: [
                              type: 'bar',
                              color: '#999999',
                              data: [
                                323.4,
                                260,
                                207,
                                164,
                                92,
                                46.5,
                                41,
                                44,
                                61,
                                151.4,
                                308.6,
                                444
                              type: 'bar',
                              color: '#ea8109',
                              data: [
                                908.3,
                                698.6,
                                594.7,
                                452.1,
                                254.3,
                                115.1,
                                84.1,
                                82.2,
                                141.9,
                                458.8,
                                764.5,
                                950
                              type: 'bar',
                              color: '#028F7E',
                              data: [
                                746.7,
                                849.7,
                                660.5,
                                463.6,
                                206.8,
                                31.9,
                                3.4,
                                2.2,
                                78.5,
                                474.8,
                                920,
                                1201
                              type: 'line',
                              color: '#ff2c0a',
                              yAxisIndex: 1,
                              data: [
                                3.8,
                                3.6,
                                3.9,
                                3.8,
                                3.8,
                                3.5,
                                3.0,
                                3.0,
                                3.3,
                                4.0,
                                3.5,
                                3.1
                        was mach ich falsch?
                        • jrbwh
                          @icebear Schwer zu sagen, bei mir funktioniert es:
                          Vielleicht hilft es, wenn Du im Browser F12 drückst, dann "Konsole" auswählst und die Seite neu lädst. Da werden Log-Einträge und Fehlermeldungen des Browser angezeigt.
                          icebear 1 Reply Last reply Reply Quote 0
                          • icebear
                            icebear @jrbwh last edited by
                            @jrbwh
                            Ich hab den Fehler gefunden, da hat sich eine '{' dazwischen gemogelt, die hatte ich übersehen.
                            Trotzdem Danke für deinen Hinweis.
                            • jrbwh
                              @icebear Tja, sind meistens die einfachen Dinge. Noch ein Hinweis: Mit "alignTicks: true" kann man dafür sorgen, dass die beiden Achsen-Ticks aufeinander ausgerichtet werden. Der Max.-Wert der linken Achse sollte dann aber durch 6 teilbar sein. Z.B. so:
                                yAxis: [
                                    type: 'value',
                                    alignTicks: true,
                                    min: 0,
                                    max: 1500,
                                    axisLabel: {
                                    type: 'value',
                                    min: 0,
                                    max: 6,
                                    axisLabel: {
                              • icebear
                                @jrbwh
                                Super Tipp, Danke☺
                                • Merlin123
                                  Merlin123 last edited by
                                  Kann man eigentlich irgendwie die Einheiten an die Achsen schreiben, und zwar nicht hinter jeden Wert sondern am Ende der Achse?
                                  Also wo in der Art wie in dem Bild (nur als zufälliges Beispiel)
                                  • icebear
                                    icebear @Merlin123 last edited by
                                    @merlin123
                                    meinst du da wo bei dir "Preis in €" und " Anzahl in Tafeln" steht ?
                                    dann probier es mal damit:
                                      "yAxis": [
                                          "name": "Energien",
                                          "nameLocation": "end",
                                          "nameTextStyle": {
                                            "color": "#ffffff",
                                            "fontSize": 15
                                    und das gleiche dann halt auch bei der xAchse eintragen.
                                      legro last edited by legro
                                      @merlin123 sagte in Test Adapter flexcharts - Stapeldiagramme und mehr:
                                      Kann man eigentlich irgendwie ..
                                      Ideen zu dem, was man so alles machen und wie man sich in deren Erstellung einfinden kann, findest du u.a. hier. Eines dieser Diagramme wird in diesem Beitrag näher beschrieben.
                                      Merlin123 1 Reply Last reply Reply Quote 1
                                      • Merlin123
                                        Merlin123 @legro last edited by
                                        @legro Ah Dank Dir! Da hab ich den relevanten Teil gefunden 🙂
                                        • icebear
                                          Ich hätte jetzt auch nochmal eine Frage, für nicht so versierte Programmierer.
                                          Folgende Ausgangslage in drei DP's liegen das eChart (welches ich aus den Apache Examples) zusamengebaut hab und die json mit den Werten für die series.data (yAxis)
                                          Hier die DP's:
                                          Hier das eChart:
                                            title: {
                                              text: '2024 vs 2025',
                                                  textStyle:{
                                                 color:'white'
                                              subtext: 'WP Energieverbrauch'
                                            "backgroundColor": "rgba(26,26,26,1)",
                                            "darkMode": true,
                                            "dataZoom": [
                                                "show": false,
                                                "start": 0,
                                                "end": 100,
                                                "height": "7%",
                                                "bottom": "3%"
                                            tooltip: {
                                              trigger: 'axis'
                                            legend: {
                                              data: ['2024', '2025'],
                                              textStyle:{
                                                 color:'white'
                                            toolbox: {
                                              show: true,
                                              feature: {
                                            calculable: true,
                                            xAxis: [
                                                type: 'category',
                                                        textStyle:{
                                                 color:'white'
                                              axisLabel: {
                                                textStyle: {
                                                  color: 'white'
                                                // prettier-ignore
                                            yAxis: [
                                                type: 'value',
                                                axisLine: {
                                                  show: false,
                                                  lineStyle: {
                                                    color: 'white'
                                            series: [
                                                type: 'bar',
                                                data: [
                                            527,
                                            260,
                                            207,
                                            164,
                                            92,
                                            46.5,
                                            41,
                                            44,
                                            61,
                                            151.4,
                                            308.6,
                                            444
                                                markPoint: {
                                                  data: [
                                                    { type: 'max', name: 'Max' },
                                                    { type: 'min', name: 'Min' }
                                                markLine: {
                                                  data: [{ type: 'average', name: 'Avg' }]
                                                type: 'bar',
                                                data: [
                                            537.5,
                                            391.6
                                                markPoint: {
                                                  data: [
                                                markLine: {
                                          Im eChart yAxis series gibt es einmal name:'2024' (wo sich die Werte ja nicht mehr ändern) und einmal name:'2025' wo ich die Werte aus dem oben genannten DP fortschreiben möchte.
                                          Jetzt kann ich natürlich jeden Tag von Hand den aktuellen Wert eintragen, aber das wäre ja ein bischen albern.
                                          Kann mir vielleicht mal jemand einen einfachen Weg, z.B. ein Script zeigen wie ich die Daten für 2025 täglich für den aktuellen Monat und dann Monat aktualisieren kann.
                                          Ein bischen von JavaScript versteh ich ja, aber bis jetzt ist es mir anhand der Beispiele nicht gelungen das hinzubekommen.
                                          L jrbwh 3 Replies Last reply Reply Quote 0
                                            legro @icebear last edited by legro
                                            Gelöscht
                                            chart charts diagramme echarts visualisierung visualization
                                            19
                                            265
                                            46340
