    4. Node-Red
    5. Hilfe bei NodeRed wegen Status Fenster/Türen - GELÖST
    • mickym
      Im Prinzip habe ich halt keine Lust - immer alles aus den Screenshots abzuschreiben.
      mac89muc 1 Reply Last reply Reply Quote 0
      • mac89muc
        mac89muc @mickym last edited by
        @mickym Kein Thema - vielen lieben Dank für die superschnelle Hilfestellung 👍
        {"0x54ef44100025b758":{"item":{"definition":{"description":"Door and window sensor E1","exposes":[{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"category":"diagnostic","description":"Indicates if the battery of this device is almost empty","label":"Battery low","name":"battery_low","property":"battery_low","type":"binary","value_off":false,"value_on":true},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...","model":"MCCGQ14LM","options":[],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genPowerCfg","genIdentify","ssIasZone","manuSpecificLumi"],"output":["genIdentify","genOta"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Küche FensterR Contact","ieee_address":"0x54ef44100025b758","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.magnet.acn001","network_address":1783,"power_source":"Battery","supported":true,"type":"EndDevice","current_values":{"battery":89,"battery_low":false,"contact":true,"last_seen":"2025-02-18T16:46:47+01:00","linkquality":98,"power_outage_count":0,"tamper":false,"voltage":2983},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":89,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Küche FensterR Contact","selector":"zigbee2mqtt_KcheFensterRContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":89,"StatusLowBattery":0}},"payload":{"battery":89,"battery_low":false,"contact":true,"last_seen":"2025-02-18T16:46:47+01:00","linkquality":98,"power_outage_count":0,"tamper":false,"voltage":2983},"format":{}},"0x54ef44100025b3ff":{"item":{"definition":{"description":"Door and window sensor E1","exposes":[{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"category":"diagnostic","description":"Indicates if the battery of this device is almost empty","label":"Battery low","name":"battery_low","property":"battery_low","type":"binary","value_off":false,"value_on":true},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,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...","model":"MCCGQ14LM","options":[],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genPowerCfg","genIdentify","ssIasZone","manuSpecificLumi"],"output":["genIdentify","genOta"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Küche FensterL Contact","ieee_address":"0x54ef44100025b3ff","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.magnet.acn001","network_address":30725,"power_source":"Battery","supported":true,"type":"EndDevice","current_values":{"battery":78,"battery_low":false,"contact":true,"last_seen":"2025-02-18T16:53:33+01:00","linkquality":76,"power_outage_count":1,"tamper":false,"voltage":2967},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":78,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Küche FensterL Contact","selector":"zigbee2mqtt_KcheFensterLContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":78,"StatusLowBattery":0}},"payload":{"battery":78,"battery_low":false,"contact":true,"last_seen":"2025-02-18T16:53:33+01:00","linkquality":76,"power_outage_count":1,"tamper":false,"voltage":2967},"format":{}},"0x00158d0006bd1963":{"item":{"definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...","model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Studio FensterR Contact","ieee_address":"0x00158d0006bd1963","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":39306,"power_source":"Battery","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":16,"last_seen":"2025-02-18T16:47:16+01:00","linkquality":105,"power_outage_count":73,"trigger_count":0,"voltage":3005},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Studio FensterR Contact","selector":"zigbee2mqtt_StudioFensterRContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":16,"last_seen":"2025-02-18T16:47:16+01:00","linkquality":105,"power_outage_count":73,"trigger_count":0,"voltage":3005},"format":{}},"0x00158d00019f3819":{"item":{"definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,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...","model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Bad Fenster Contact","ieee_address":"0x00158d00019f3819","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":30025,"power_source":"Battery","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":18,"last_seen":"2025-02-18T17:08:11+01:00","linkquality":160,"power_outage_count":241,"trigger_count":0,"voltage":3005},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Bad Fenster Contact","selector":"zigbee2mqtt_BadFensterContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":18,"last_seen":"2025-02-18T17:08:11+01:00","linkquality":160,"power_outage_count":241,"trigger_count":0,"voltage":3005},"format":{}},"0x00158d0006b7d36c":{"item":{"definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,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...","model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","65535","genOnOff"],"output":["genBasic","genGroups","65535"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Schlafzimmer Fenster Contact","ieee_address":"0x00158d0006b7d36c","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":61288,"power_source":"Battery","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":18,"last_seen":"2025-02-18T17:23:11+01:00","linkquality":109,"power_outage_count":103,"trigger_count":0,"voltage":3025},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Schlafzimmer Fenster Contact","selector":"zigbee2mqtt_SchlafzimmerFensterContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":18,"last_seen":"2025-02-18T17:23:11+01:00","linkquality":109,"power_outage_count":103,"trigger_count":0,"voltage":3025},"format":{}},"0x00158d0006b7ccb9":{"item":{"date_code":"20161128","definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,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...","model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","65535","genOnOff"],"output":["genBasic","genGroups","65535"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Lina Fenster Contact","ieee_address":"0x00158d0006b7ccb9","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":30017,"power_source":"Battery","software_build_id":"3000-0001","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":23,"last_seen":"2025-02-18T17:00:27+01:00","linkquality":160,"power_outage_count":24,"trigger_count":0,"voltage":3005},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Lina Fenster Contact","selector":"zigbee2mqtt_LinaFensterContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":23,"last_seen":"2025-02-18T17:00:27+01:00","linkquality":160,"power_outage_count":24,"trigger_count":0,"voltage":3005},"format":{}},"0x00158d0001dd431f":{"item":{"date_code":"20161128","definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,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...","model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","65535","genOnOff"],"output":["genBasic","genGroups","65535"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"WC Fenster Contact","ieee_address":"0x00158d0001dd431f","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":50753,"power_source":"Battery","software_build_id":"3000-0001","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":12,"last_seen":"2025-02-18T16:47:38+01:00","linkquality":160,"power_outage_count":55,"trigger_count":0,"voltage":3045},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/WC Fenster Contact","selector":"zigbee2mqtt_WCFensterContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":12,"last_seen":"2025-02-18T16:47:38+01:00","linkquality":160,"power_outage_count":55,"trigger_count":0,"voltage":3045},"format":{}},"0x00158d0001ddef66":{"item":{"definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"icon":"data:image/png;base64,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...","model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Dachbodenfenster Contact","ieee_address":"0x00158d0001ddef66","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":42946,"power_source":"Battery","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":13,"last_seen":"2025-02-18T17:26:36+01:00","linkquality":109,"power_outage_count":450,"trigger_count":0,"voltage":3005},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Dachbodenfenster Contact","selector":"zigbee2mqtt_DachbodenfensterContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":13,"last_seen":"2025-02-18T17:26:36+01:00","linkquality":109,"power_outage_count":450,"trigger_count":0,"voltage":3005},"format":{}},"0x00158d0001ddc8e5":{"item":{"date_code":"20161128","definition":{"description":"Door and window sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Indicates if the contact is closed (= true) or open (= false)","label":"Contact","name":"contact","property":"contact","type":"binary","value_off":true,"value_on":false},{"access":1,"category":"diagnostic","description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Number of power outages","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Indicates how many times the sensor was triggered (since last scheduled report)","label":"Trigger count","name":"trigger_count","property":"trigger_count","type":"numeric"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"MCCGQ11LM","options":[{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Aqara"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","65535","genOnOff"],"output":["genBasic","genGroups","65535"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Studio FensterL Contact","ieee_address":"0x00158d0001ddc8e5","interview_completed":true,"interviewing":false,"manufacturer":"LUMI","model_id":"lumi.sensor_magnet.aq2","network_address":16276,"power_source":"Battery","software_build_id":"3000-0001","supported":true,"type":"EndDevice","current_values":{"battery":100,"contact":true,"device_temperature":12,"last_seen":"2025-02-18T16:32:29+01:00","linkquality":76,"power_outage_count":160,"trigger_count":0,"voltage":3125},"homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"format":{}},"topic":"zigbee2mqtt/Studio FensterL Contact","selector":"zigbee2mqtt_StudioFensterLContact","homekit":{"ContactSensor":{"ContactSensorState":0},"ContactSensor_Inverse":{"ContactSensorState":1},"Battery":{"BatteryLevel":100,"StatusLowBattery":0}},"payload":{"battery":100,"contact":true,"device_temperature":12,"last_seen":"2025-02-18T16:32:29+01:00","linkquality":76,"power_outage_count":160,"trigger_count":0,"voltage":3125},"format":{}}}
        Hoffe das passt so.
        VG
        • mickym
          mickym Most Active last edited by mickym
          So ich habe Dir mit Deinen Daten folgendes gebastelt:
          Du siehst in der 1. Node werden alle geschlossenen Fenster selektiert. In der 2. Node alle offenen Fenster.
          Hier der Flow zum Import:
                 "id": "3da931fb6f59da6d",
                 "type": "inject",
                 "z": "7e6af0015415146d",
                 "name": "Daten von zigbee2mqtt",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "{\"0x54ef44100025b758\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor E1\",\"exposes\":[{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates if the battery of this device is almost empty\",\"label\":\"Battery low\",\"name\":\"battery_low\",\"property\":\"battery_low\",\"type\":\"binary\",\"value_off\":false,\"value_on\":true},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ14LM\",\"options\":[],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genPowerCfg\",\"genIdentify\",\"ssIasZone\",\"manuSpecificLumi\"],\"output\":[\"genIdentify\",\"genOta\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Küche FensterR Contact\",\"ieee_address\":\"0x54ef44100025b758\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.magnet.acn001\",\"network_address\":1783,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":89,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:46:47+01:00\",\"linkquality\":98,\"power_outage_count\":0,\"tamper\":false,\"voltage\":2983},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":89,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Küche FensterR Contact\",\"selector\":\"zigbee2mqtt_KcheFensterRContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":89,\"StatusLowBattery\":0}},\"payload\":{\"battery\":89,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:46:47+01:00\",\"linkquality\":98,\"power_outage_count\":0,\"tamper\":false,\"voltage\":2983},\"format\":{}},\"0x54ef44100025b3ff\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor E1\",\"exposes\":[{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates if the battery of this device is almost empty\",\"label\":\"Battery low\",\"name\":\"battery_low\",\"property\":\"battery_low\",\"type\":\"binary\",\"value_off\":false,\"value_on\":true},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ14LM\",\"options\":[],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genPowerCfg\",\"genIdentify\",\"ssIasZone\",\"manuSpecificLumi\"],\"output\":[\"genIdentify\",\"genOta\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Küche FensterL Contact\",\"ieee_address\":\"0x54ef44100025b3ff\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.magnet.acn001\",\"network_address\":30725,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":78,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:53:33+01:00\",\"linkquality\":76,\"power_outage_count\":1,\"tamper\":false,\"voltage\":2967},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":78,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Küche FensterL Contact\",\"selector\":\"zigbee2mqtt_KcheFensterLContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":78,\"StatusLowBattery\":0}},\"payload\":{\"battery\":78,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:53:33+01:00\",\"linkquality\":76,\"power_outage_count\":1,\"tamper\":false,\"voltage\":2967},\"format\":{}},\"0x00158d0006bd1963\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[],\"output\":[]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Studio FensterR Contact\",\"ieee_address\":\"0x00158d0006bd1963\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":39306,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":16,\"last_seen\":\"2025-02-18T16:47:16+01:00\",\"linkquality\":105,\"power_outage_count\":73,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Studio FensterR Contact\",\"selector\":\"zigbee2mqtt_StudioFensterRContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":16,\"last_seen\":\"2025-02-18T16:47:16+01:00\",\"linkquality\":105,\"power_outage_count\":73,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d00019f3819\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[],\"output\":[]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Bad Fenster Contact\",\"ieee_address\":\"0x00158d00019f3819\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":30025,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:08:11+01:00\",\"linkquality\":160,\"power_outage_count\":241,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Bad Fenster Contact\",\"selector\":\"zigbee2mqtt_BadFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:08:11+01:00\",\"linkquality\":160,\"power_outage_count\":241,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d0006b7d36c\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Schlafzimmer Fenster Contact\",\"ieee_address\":\"0x00158d0006b7d36c\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":61288,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:23:11+01:00\",\"linkquality\":109,\"power_outage_count\":103,\"trigger_count\":0,\"voltage\":3025},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Schlafzimmer Fenster Contact\",\"selector\":\"zigbee2mqtt_SchlafzimmerFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:23:11+01:00\",\"linkquality\":109,\"power_outage_count\":103,\"trigger_count\":0,\"voltage\":3025},\"format\":{}},\"0x00158d0006b7ccb9\":{\"item\":{\"date_code\":\"20161128\",\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Lina Fenster Contact\",\"ieee_address\":\"0x00158d0006b7ccb9\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":30017,\"power_source\":\"Battery\",\"software_build_id\":\"3000-0001\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":23,\"last_seen\":\"2025-02-18T17:00:27+01:00\",\"linkquality\":160,\"power_outage_count\":24,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Lina Fenster Contact\",\"selector\":\"zigbee2mqtt_LinaFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":23,\"last_seen\":\"2025-02-18T17:00:27+01:00\",\"linkquality\":160,\"power_outage_count\":24,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d0001dd431f\":{\"item\":{\"date_code\":\"20161128\",\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"WC Fenster Contact\",\"ieee_address\":\"0x00158d0001dd431f\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":50753,\"power_source\":\"Battery\",\"software_build_id\":\"3000-0001\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:47:38+01:00\",\"linkquality\":160,\"power_outage_count\":55,\"trigger_count\":0,\"voltage\":3045},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/WC Fenster Contact\",\"selector\":\"zigbee2mqtt_WCFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:47:38+01:00\",\"linkquality\":160,\"power_outage_count\":55,\"trigger_count\":0,\"voltage\":3045},\"format\":{}},\"0x00158d0001ddef66\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[],\"output\":[]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Dachbodenfenster Contact\",\"ieee_address\":\"0x00158d0001ddef66\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":42946,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":13,\"last_seen\":\"2025-02-18T17:26:36+01:00\",\"linkquality\":109,\"power_outage_count\":450,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Dachbodenfenster Contact\",\"selector\":\"zigbee2mqtt_DachbodenfensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":false,\"device_temperature\":13,\"last_seen\":\"2025-02-18T17:26:36+01:00\",\"linkquality\":109,\"power_outage_count\":450,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d0001ddc8e5\":{\"item\":{\"date_code\":\"20161128\",\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Studio FensterL Contact\",\"ieee_address\":\"0x00158d0001ddc8e5\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":16276,\"power_source\":\"Battery\",\"software_build_id\":\"3000-0001\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:32:29+01:00\",\"linkquality\":76,\"power_outage_count\":160,\"trigger_count\":0,\"voltage\":3125},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Studio FensterL Contact\",\"selector\":\"zigbee2mqtt_StudioFensterLContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:32:29+01:00\",\"linkquality\":76,\"power_outage_count\":160,\"trigger_count\":0,\"voltage\":3125},\"format\":{}}}",
                 "payloadType": "json",
                 "x": 300,
                 "y": 7060,
                 "wires": [
                         "e29d13e39355375d",
                         "6c6901822b24f320",
                         "3aa357dca689ad3f"
                 "id": "e29d13e39355375d",
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "complete": "payload",
                 "targetType": "msg",
                 "statusVal": "",
                 "statusType": "auto",
                 "x": 570,
                 "y": 7000,
                 "wires": []
                 "id": "6c6901822b24f320",
                 "type": "change",
                 "name": "Fenster zu",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload.*[payload.contact=true].topic",
                         "tot": "jsonata"
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload ? payload : \"Alle Fenster geöffnet\"",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 550,
                 "y": 7060,
                 "wires": [
                         "5960a47fef812439"
                 "id": "5960a47fef812439",
                 "type": "debug",
                 "name": "Fenster geschlossen",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 800,
                 "y": 7060,
                 "wires": []
                 "id": "3aa357dca689ad3f",
                 "type": "change",
                 "name": "Fenster offen",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload.*[payload.contact=false].topic",
                         "tot": "jsonata"
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload ? payload : \"Alle Fenster geschlossen\"",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 550,
                 "y": 7120,
                 "wires": [
                         "da1365a7f5a03cfc"
                 "id": "da1365a7f5a03cfc",
                 "type": "debug",
                 "name": "Fenster geöffnet",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 780,
                 "y": 7120,
                 "wires": []
          Ich habe mal ein Dachboden-Fenster virtuell geöffnet, damit ein Ergebnis rauskommt.
          Mit
          kannst Du also die Objekte leicht selektieren und somit auch gleich das topic ausgeben lassen.
          Um das für Dich selbst auszuprobieren und die verschiedenen Contact Sensoren auf true zu stellen, nutz am Besten auch einfach den JSONATA Exerciser:
          https://try.jsonata.org/uEEVBxn2i
          Links siehst Du Deine Quelldaten:
          rechts oben den Code - der gleich das Ergebnis im unteren Fenster rechts anzeigt.
          Ach so und wenn Du Dir statt des topics gleich die friendly_names in Deinem Array ausgeben lassen willst, dann brauchst Du es in dem Objekt nur selektieren.
          Also dann einfach:
          payload.*[payload.contact=false].item.friendly_name
          Und wenn Du auch bei einem Ergebnis ein Array und keinen skalaren Text haben willst, dann halt das ganze in eckige Klammer setzen. Diese einfach Anhängen funktioniert nicht.
          So erhälst Du also immer ein Array - auch mit nur EINEM Element.
          [payload.*[payload.contact=false].item.friendly_name]
          • mickym
            mickym Most Active @mac89muc last edited by
            @mac89muc sagte in Hilfe bei NodeRed wegen Status Fenster/Türen:
            Ich würde es auch Platzgründen gerne über eine function Node abwickeln.
            Verstehe ich zwar nicht - ein function Node - ist meines Erachtens viel umständlicher und braucht auch nicht mehr oder weniger Platz als eine Change Node???
            Und ehrlich gesagt, habe ich wenig Lust wieder x-Zeilen Code zu schreiben, weil in dem Fall das Javascript einfach viel umständlicher ist und JSONATA einfach für diese Art abfragen gemacht wurde und JSONATA in NodeRed sehr gut unterstützt ist.
            Wird auch in Blockly viel zuwenig genutzt.
            • mickym
              Hier die relevanten Nodes nochmal zum Import (letzter Stand mit immer Array):
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "[payload.*[payload.contact=true].item.friendly_name]",
                             "tot": "jsonata"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 550,
                     "y": 7060,
                     "wires": [
                             "5960a47fef812439"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 800,
                     "y": 7060,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "[payload.*[payload.contact=false].item.friendly_name]",
                             "tot": "jsonata"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 550,
                     "y": 7120,
                     "wires": [
                             "da1365a7f5a03cfc"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 780,
                     "y": 7120,
                     "wires": []
              mac89muc 1 Reply Last reply Reply Quote 0
              • mac89muc
                mac89muc @mickym last edited by
                @mickym Wow - vielen Dank. Probiere ich die nächsten Tage aus und melde mich wieder. So, oder so schon mal vielen Dank
                • mickym
                  Falls Du doch lieber mit Javascript programmieren willst, habe ich Dir noch eine function Node gebastelt mit 2 Ausgängen, für Fenster offen und geschlossen.
                  Hier zum Import:
                         "type": "inject",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 260,
                         "y": 7160,
                         "wires": [
                                 "e29d13e39355375d",
                                 "6c6901822b24f320",
                                 "3aa357dca689ad3f",
                                 "c7b9a3945149aaa6"
                         "type": "debug",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 550,
                         "y": 7080,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "Fenster geschlossen",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 510,
                         "y": 7260,
                         "wires": [
                                 "5960a47fef812439"
                         "type": "debug",
                         "name": "Fenster geschlossen (JSONATA)",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 780,
                         "y": 7260,
                         "wires": []
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "Fenster geöffnet",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 510,
                         "y": 7300,
                         "wires": [
                                 "da1365a7f5a03cfc"
                         "type": "debug",
                         "name": "Fenster geöffnet (JSONATA)",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 760,
                         "y": 7300,
                         "wires": []
                         "id": "c7b9a3945149aaa6",
                         "type": "function",
                         "func": "var arrOpened=[];\nvar arrClosed=[];\nfor (var key in msg.payload){\n    var obj;\n    obj = msg.payload[key];\n    obj.payload.contact ? arrClosed.push(obj.item.friendly_name) : arrOpened.push(obj.item.friendly_name)\n}\n \nreturn [{ topic: \"Fenster geschlossen\", payload: arrClosed.length > 0 ? arrClosed : \"Alle Fenster geöffnet\"  },\n    {topic: \"Fenster geöffnet\", payload: arrOpened.length > 0 ? arrOpened : \"Alle Fenster geschlossen !\" }];",
                         "outputs": 2,
                         "timeout": 0,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 510,
                         "y": 7160,
                         "wires": [
                                 "2f4bbe40257a37f3"
                                 "041a44ac252bbd51"
                         "id": "2f4bbe40257a37f3",
                         "type": "debug",
                         "name": "Fenster geschlossen (Javascript)",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 780,
                         "y": 7140,
                         "wires": []
                         "id": "041a44ac252bbd51",
                         "type": "debug",
                         "name": "Fenster geöffnet (Javascript)",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 760,
                         "y": 7180,
                         "wires": []
                  Der Code mit Javascript ist natürlich länger:
                  var arrOpened=[];
                  var arrClosed=[];
                      var obj;
                  return [{ topic: "Fenster geschlossen", payload: arrClosed.length > 0 ? arrClosed : "Alle Fenster geöffnet"  },
                      {topic: "Fenster geöffnet", payload: arrOpened.length > 0 ? arrOpened : "Alle Fenster geschlossen !" }];
                  Aber ich habe die function Node gleich mit 2 Ausgängen gebastelt, so dass oben die geschlossenen Fenster und unten die offenen Fenster ausgegeben werden.
                  Ich würde Dir aber trotzdem raten auf function Nodes so lange wie möglich zu verzichten - da Du sonst leicht wieder in Versuchung kommst, herkömmlichen Code zu schreiben - mit Schleifen etc.
                  • mac89muc
                    @mickym vielen lieben Dank für Deine Mühe!!! - hab ich importiert und funktioniert wie gewünscht. 👍 ☺
                    In dem Fall bin ich komplett deiner Meinung mit dem Verzicht auf die Function node, ich dachte das wird etwas umfangreicher was die Anzahl der nodes angeht und da ist mir dann normalerweise eine Function node immer lieber. Aber in dem Beispiel sehe ich das genauso wie Du.
                    Beim Thema JSONATA muss ich mich mal einarbeiten, ich glaube das ist genau das was ich für ein paar Themen brauchen kann als Ansatz - Danke dafür.
                    Hast Du ggf. noch einen kurzen Tipp für mich, wenn ich die geöffneten Fenster nicht in einem Array ausgegeben haben möchte, sondern in einem einzigen getrennt durch Kommas? Muss ich das Array danach nochmal anfassen und zusammenfassen? Das müsste dann doch bestimmt mit JSONATA auch schon in einem Aufwasch direkt funktionieren, oder??
                    Viele Grüße
                    • mickym
                      mickym Most Active @mac89muc last edited by mickym
                      Viele Grüße
                      Einfach das Array in eine Join Funktion geben.
                      https://docs.jsonata.org/string-functions#join
                      1. Du kannst entweder die letzte Regel nehmen - wenn sonst ausgegeben wird, dass Alle Fenster geschlossen sind
                      1. oder falls Du keine Ausgabe und die letzte Regel nicht brauchst(falls alle Fenster geschlossen sind) wünschst kannst Du auch einfach das Ergebnis weitergeben
                      Dann brauchst natürlich auch die eckige Klammer nicht, wenn nur ein Element vorhanden ist.
                      • mac89muc
                        @mickym perfekt - eine letzte minimale Optimierung ist mir gerade noch aufgefallen...
                        Ich habe zwecks Organisation und Übersicht bei meinen Zigbee Kontaktsensoren im Namen immer Contact mit am Schluss stehen. Das hätte ich in der Aufzählung gerne entfernt - wie bekomme ich das noch integriert also ->
                        friendly_name.slice(0, -8)
                        Wenn ich das direkt dranhänge
                        payload.*[payload.contact=false].item.friendly_name.slice(0, -8)~>$join(", ")
                        bekomme ich einen Fehler
                        Invalid JSONata expression: Attempted to invoke a non-function
                        Kann ich mich für Deine Hilfe irgendwo mit einer Kaffeespende revanchieren?
                        Danke & Gruß
                        • mickym
                          slice ist keine JSONATA Funktion sondern eine Javascript Funktion
                          Danke & Gruß
                          Nein - brauchst Du nicht, mache ich gerne
                          In JSONATA machst Du das so:
                          payload.*[payload.contact=false].$substringBefore(item.friendly_name," Contact")~>$join(", ")
                          • mickym
                            Falls Du zigbee2mqtt verwendest, was Du auch tust - soweit ich mich erinnere, kannst Du als friendly Name auch Hierarchien bilden und dann brauchst Du diese Konstrukte mit den Namen nicht.
                            Also einfach die Gerätenamen entsprechend mqtt topics in der Hierarchie benennen:
                            Im friendlyName wird das mqtt topic dann entsprechend eingetragen:
                            • mickym
                              mickym Most Active @mickym last edited by mickym
                              @mickym Vorteil für Dich ist, dass Du diese Nodes eigentlich dann nicht brauchst, sondern über die mqtt Hierachien selektieren kannst.
                              In meinem Fall selektiere (subscribe) ich alle Kontakte mit
                              zigbee2mqtt/kontakt/#
                              • mac89muc
                                @mickym
                                Vielen Dank ich probiere jetzt mal ein bisschen rum und passe meine Flows an. Ich habe noch 2-3 andere Themen bzgl. Node-Red und würde mich dann mit einem separaten Thread nochmal melden, vielleicht hast Du dann ja nochmal Zeit & Lust mir weiterzuhelfen. Vielen Dank nochmals für die schnelle und ausführliche Hilfe.
                                81.1k
                                1089
