    4. Test Adapter rpi2 2.x
      Thomas Braun Most Active @Smallfeuer last edited by Thomas Braun
      @smallfeuer @Garfonso
      Und die Meldungen im Log sehen so aus. Zumindest bei mir...
      2025-02-23 11:53:08.571  - info: rpi2.0 (279931) starting. Version 2.3.2 (non-npm: iobroker-community-adapters/ioBroker.rpi2) in /opt/iobroker/node_modules/iobroker.rpi2, node: v23.7.0, js-controller: 7.0.6
      2025-02-23 11:53:08.981  - error: rpi2.0 (279931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-02-23 11:53:08.981  - error: rpi2.0 (279931) unhandled promise rejection: value.toFixed is not a function
      2025-02-23 11:53:08.983  - error: rpi2.0 (279931) TypeError: value.toFixed is not a function
          at parser (/opt/iobroker/node_modules/iobroker.rpi2/main.js:454:58)
          at async main (/opt/iobroker/node_modules/iobroker.rpi2/main.js:327:9)
          at async Rpi2.onReady (/opt/iobroker/node_modules/iobroker.rpi2/main.js:58:9)
      2025-02-23 11:53:08.984  - error: rpi2.0 (279931) value.toFixed is not a function
      2025-02-23 11:53:08.990  - info: rpi2.0 (279931) terminating
      2025-02-23 11:53:08.992  - warn: rpi2.0 (279931) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-02-23 11:53:09.490  - info: rpi2.0 (279931) terminating
      2025-02-23 11:53:09.603  - error: host.chet instance system.adapter.rpi2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-02-23 11:53:43.092  - info: rpi2.0 (279987) starting. Version 2.3.2 (non-npm: iobroker-community-adapters/ioBroker.rpi2) in /opt/iobroker/node_modules/iobroker.rpi2, node: v23.7.0, js-controller: 7.0.6
      2025-02-23 11:53:43.532  - error: rpi2.0 (279987) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-02-23 11:53:43.533  - error: rpi2.0 (279987) unhandled promise rejection: value.toFixed is not a function
      2025-02-23 11:53:43.535  - error: rpi2.0 (279987) TypeError: value.toFixed is not a function
      2025-02-23 11:53:43.535  - error: rpi2.0 (279987) value.toFixed is not a function
      2025-02-23 11:53:43.543  - info: rpi2.0 (279987) terminating
      2025-02-23 11:53:43.545  - warn: rpi2.0 (279987) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-02-23 11:53:44.043  - info: rpi2.0 (279987) terminating
      2025-02-23 11:53:44.160  - error: host.chet instance system.adapter.rpi2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-02-23 11:53:44.161  - warn: host.chet Do not restart adapter system.adapter.rpi2.0 because restart loop detected
      Version: iobroker.rpi2@2.3.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.rpi2.git#c75795660b15fec21ffda74db9263f94f3e341a1)
        @smallfeuer
        Allerdings läuft die iobroker.rpi2@2.3.2 aus dem Repo.
        Lass halt die Finger von GitHub-Installationen, wenn du nicht dazu aufgefordert wurdest das zu tun.
        Da kann halt jeder Code-Stand angespült werden.
          Smallfeuer @Thomas Braun last edited by
          @thomas-braun sagte in Test Adapter rpi2 2.x:
          Na eigentlich wird nur der letzte Stand der in Github hochgeladen wurde installiert.
          Hatte mir die Comparing changes vorher angeschaut - bin schon groß 😉
            @smallfeuer sagte in Test Adapter rpi2 2.x:
            Richtig. Das kann aber was komplett anderes sein, als das was (mit gleicher Versionsnummer!) in den Repos landet.
              Smallfeuer @Thomas Braun last edited by Smallfeuer
              Dieser Hinweis ist wichtig an der Stelle, daher hatte ich die Version und aus Github geschrieben. Aber korrekt und wichtig für alle da zu unterscheiden.
              Ich such jetzt im Programm mal nach dem Fehler der mir beim Neustart des Adapters meinen Eingang auf false setzt, obwohl dieser definitiv true ist.
              @Garfonso
              Problem gefunden und hätte hier eine Lösung. Die Initialisierung geht nicht schnell genug.
              Habe eine Delay Funktion nach dem GPIO watch Befehl integriert - jetzt wird der Eingang korrekt auf True gesetzt.
              function delay(ms) {
                return new Promise(resolve => setTimeout(resolve, ms));
                // Füge eine kurze Verzögerung hinzu, um sicherzustellen, dass der Pin initialisiert ist
                 121              this.gpioInputPorts.push(gpioSetting.gpio); //
                 neu                 await delay(100); // Verzögerung von 100 Millisekunden
                 122                 await this.readValue(gpioSetting.gpio);
              im DEBUG Log zeigt er mir damit aber eine lange liste true. Das "false" am Anfang kommt leider immer noch durch. Er korrigiert es jetzt aber. Kannst du beim 1. lesen des Eingangs den Inhalt verwerfen? Das liegt sicher an der Debounce Abfrage - richtig?
              2025-02-23 17:43:25.161 - debug: rpi2.0 (34903) GPIO chip undefined initialized
              2025-02-23 17:43:25.161 - debug: rpi2.0 (34903) Port 17 direction: in
              2025-02-23 17:43:25.164 - debug: rpi2.0 (34903) Setting state for port 17 to false
              2025-02-23 17:43:25.221 - silly: rpi2.0 (34903) States user redis pmessage rpi2.0.*/rpi2.0.gpio.17.state:{"val":false,"ack":true,"ts":1740329005219,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1740329005219}
              2025-02-23 17:43:25.225 - debug: rpi2.0 (34903) Port 22 direction: outhigh
              2025-02-23 17:43:25.227 - debug: rpi2.0 (34903) Adding event listener for port 17
              2025-02-23 17:43:26.792 - debug: rpi2.0 (34903) GPIO change on port 17: true
              2025-02-23 17:43:26.793 - debug: rpi2.0 (34903) Setting state for port 17 to true
              2025-02-23 17:43:26.795 - debug: rpi2.0 (34903) GPIO change on port 17: true
              2025-02-23 17:43:26.797 - debug: rpi2.0 (34903) Setting state for port 17 to true
              2025-02-23 17:43:26.800 - debug: rpi2.0 (34903) GPIO change on port 17: true
              2025-02-23 17:43:26.801 - debug: rpi2.0 (34903) Setting state for port 17 to true
              2025-02-23 17:43:26.803 - debug: rpi2.0 (34903) GPIO change on port 17: true
              2025-02-23 17:43:26.804 - debug: rpi2.0 (34903) Setting state for port 17 to true
              2025-02-23 17:43:26.806 - debug: rpi2.0 (34903) GPIO change on port 17: true
              S Garfonso 2 Replies Last reply Reply Quote 0
                Smallfeuer @Smallfeuer last edited by
                Jetzt verstehe ich es nicht mehr. Nachdem ich alles gelöscht hatte ändert er aktuell den Status wieder automatisch von false auf true - bei 2.3.1 jedenfalls auch ohne mein Delay.
                Das 1. false müsste man aber abfangen. Kein Plan was sich jetzt wieder geändert hat zwischenzeitlich :(.
                • Garfonso
                  Garfonso Developer @Smallfeuer last edited by
                  @smallfeuer
                  ähm.. ja.. die github Version hab ich auch noch nicht getestet. Kann sein, dass da noch fehler drin sind. Die Tests laufen ja auch nicht durch. 😉
                  Bin am Freitag nur dazu gekommen neuen Code zu produzieren, ausprobieren und Fehler glatt bügeln, dafür hat die Zeit nicht mehr gereicht. Insofern, was @Thomas-Braun sagt: Bitte erstmal bei der Version aus dem repository bleiben. Ich bitte um tests, wenns soweit ist.
                  Und ja, eigentlich wollte ich das Freitag noch schaffen, aber ging halt nicht. Aber im Forum wollte ich halt auch noch kurz antworten. 😉
                  S 1 Reply Last reply Reply Quote 2
                    Smallfeuer @Garfonso last edited by
                    @garfonso Kein Stress. Sag bescheid wenn du soweit bist.
                    • Garfonso
                      @smallfeuer said in Test Adapter rpi2 2.x:
                      Hä? Welches Problem hat das denn jetzt gelöst?
                      In deinem log sehe ich, dass der Port initialisiert wurde, dann wurde false eingelesen, nach dem timeout, den du dort hinzugefügt hast und danach meldet die library von "außen" mehrere Veränderungen zu true. Wenn da nur einmal true rauskommen soll, könntest du das mit debounce timer lösen.
                      Was genau hat der delay jetzt bei dir behoben, wenn es nicht das initiale lesen war?
                      • Garfonso
                        Jetzt kannst du von github mal ausprobieren und gucken, ob es einen Unterschied macht. Der initiale Zustand der Eingäge wird jetzt erst gelesen, nachdem der Eventlistener hinzugefügt wurde.
                        Wenn da immer noch das falsche bei rum kommt, weiß ich nicht mehr so richtig weiter.
                        In dem Fall, könntest du mir deine Konfiguration mal zukommen lassen? Weiß zwar nicht, ob ich da ohne Hardware hier weiter komme, aber vielleicht fällt mir was ein. 😉
                        Hasont S 2 Replies Last reply Reply Quote 0
                        • Hasont
                          Hasont @Garfonso last edited by Hasont
                          @garfonso
                          Ich hab ja auf Raspi 4 Bookworm die rpi2 v 2.3.2 und wenn du da Hilfe bei Tests brauchst sag Bescheid.
                          Habe 8 Ausgänge am Raspie mit High aktiv und 6 Eingänge (Pull down) die ich kurzfristig auch für Tests mit 3,3V beschalten könnte. Derzeit verwende ich GPIO 23 mit einem Taster.
                          Was mir im Thread auffällt ist, dass viele von Ihren Relaiszustand schreiben. Dieser kann aber je nach verwendeter Relaiskarte auch invertiert sein. Es wäre hier sinnvoll sich immer auf high oder low an den Pins am Raspie zu beziehen. Weiter sollte auch immer in der ersten Zeile benannt werden ob es schon die 2.3.2 ist.
                          Zum Thema GPIO mit Raspie 5 hab ich grad was im Netz gesehen. Ev. hilft euch das!
                          https://kofler.info/gpio-aerger-auf-dem-raspberry-pi-5/
                          https://kofler.info/gpio-reloaded-ii-bash/#more-7796
                          Dort ist auch eine Abfrage der GPIOs mit z.B. pinctrl get 23 für GPIO 23 beschrieben die bei mir prima funktioniert.
                          pinctrl get [gpionr] ermittelt den aktuellen Status aller GPIOs bzw. des angegebenen GPIOs.
                           pinctrl funcs [gpionr] ermittelt, welche alternativen Funktionen der angegebene GPIO bzw. alle GPIOs erfüllen können.
                           pinctrl set gpionr options verändert den Status des angegeben GPIOs. Mögliche Optionen sind:
                               ip = Input
                               op = Output
                               dl = Zustand Low (Drive Low)
                               dh = Zustand High (Drive High)
                               pu = Pull-up-Widerstand aktiv
                               pd = Pull-down-Widerstand aktiv
                               pn = keine Pull-up/down-Funktion
                               a0 bis a7 = alternative Funktion n aktivieren
                               no = Deaktivieren (no function)
                          Soweit sich sinnvolle Kombinationen ergeben, dürfen mehrere der obigen Optionen auf einmal übergeben werden, jeweils getrennt durch Leerzeichen. Welche alternative Funktionen ein GPIO unterstützt und wie sie nummeriert sind, geht aus pinctrl funcs hervor.code_text
                            @garfonso
                            Naja, ich dachte es hätte was geändert. Deshalb hatte ich ja drunter geschrieben gestern Abend - ich verstehe es nicht mehr 🙂
                            Vorher war es so, dass beim Rebooten "false" stehen geblieben ist und der Eingang gar nicht auf true ging. Nun hatte ich ja die Github Version installiert die nicht lief, dann meine komplette Instanz + Adapter gelöscht und neu auf 2.3.1 gespielt.
                            Danach blieb von meinem Problem nur noch über, das der 1. Befehl false war und es dann auf true wechselte obwohl ein Signal anliegt. Kurz gesagt - vergiss mein Delay - ich teste jetzt mal die Github Version.
                              Smallfeuer @Garfonso last edited by Smallfeuer
                              @garfonso Getestet - läuft, Fehler mit falschen "False" Befehl ist aber identisch. Hast du ne Idee wie wir den 1. Befehl der vom Ausgang gelesen wird verwerfen können?
                                @Garfonso
                                sogar die debounce funktion funktioniert im nachhinein. Was meintest du mit meiner Konfiguration? Ist ja einfach nur ein Eingang der spannung high hat und dauerhaft als true durchgereicht werden sollte.
                                @Hasont Kannst du das mal nachstellen? Einfach mal einen Eingang auf True bringen über die Pi Spannung und schauen was beim reboot passiert?
                                DeBUG auf alles - > Dann sollte es sich identisch verhalten.
                                rpi2.0
                                2025-02-24 20:12:27.178	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.177	debug	Ignoring change event due to debounce: 15ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.176	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.175	debug	Ignoring change event due to debounce: 13ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.174	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.174	debug	Ignoring change event due to debounce: 12ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.173	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.173	debug	Ignoring change event due to debounce: 11ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.172	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.172	debug	Ignoring change event due to debounce: 10ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.171	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.171	debug	Ignoring change event due to debounce: 9ms < 500.
                                rpi2.0
                                rpi2.0
                                2025-02-24 20:12:27.170	debug	Ignoring change event due to debounce: 8ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.170	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.169	debug	Ignoring change event due to debounce: 7ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.169	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.168	debug	Ignoring change event due to debounce: 6ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.168	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.167	debug	Ignoring change event due to debounce: 5ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.167	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.166	debug	Ignoring change event due to debounce: 4ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.166	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.165	debug	Ignoring change event due to debounce: 3ms < 500.
                                rpi2.0
                                2025-02-24 20:12:27.164	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:27.162	debug	Setting state for port 17 to true
                                rpi2.0
                                2025-02-24 20:12:27.162	debug	GPIO change on port 17: true
                                rpi2.0
                                2025-02-24 20:12:25.826	silly	States user redis pmessage rpi2.0.*/rpi2.0.gpio.27.state:{"val":true,"ack":true,"ts":1740424345823,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1740424345823}
                                rpi2.0
                                2025-02-24 20:12:25.770	debug	Written true into port 27
                                rpi2.0
                                2025-02-24 20:12:25.769	debug	Setting initial value for port 27 to true
                                rpi2.0
                                2025-02-24 20:12:25.767	silly	States user redis pmessage rpi2.0.*/rpi2.0.gpio.24.state:{"val":true,"ack":true,"ts":1740424345764,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1740424345764}
                                rpi2.0
                                2025-02-24 20:12:25.711	debug	Written true into port 24
                                rpi2.0
                                2025-02-24 20:12:25.710	debug	Setting initial value for port 24 to true
                                rpi2.0
                                2025-02-24 20:12:25.706	silly	States user redis pmessage rpi2.0.*/rpi2.0.gpio.23.state:{"val":true,"ack":true,"ts":1740424345703,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1740424345703}
                                rpi2.0
                                2025-02-24 20:12:25.650	debug	Written true into port 23
                                rpi2.0
                                2025-02-24 20:12:25.650	debug	Setting initial value for port 23 to true
                                rpi2.0
                                2025-02-24 20:12:25.646	silly	States user redis pmessage rpi2.0.*/rpi2.0.gpio.22.state:{"val":true,"ack":true,"ts":1740424345643,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1740424345643}
                                rpi2.0
                                2025-02-24 20:12:25.591	debug	Written true into port 22
                                rpi2.0
                                2025-02-24 20:12:25.590	debug	Setting initial value for port 22 to true
                                rpi2.0
                                2025-02-24 20:12:25.586	silly	States user redis pmessage rpi2.0.*/rpi2.0.gpio.17.state:{"val":false,"ack":true,"ts":1740424345583,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1740424345583}
                                rpi2.0
                                2025-02-24 20:12:25.528	debug	Setting state for port 17 to false
                                rpi2.0
                                2025-02-24 20:12:25.528	debug	Read false from port 17.
                                S Hasont 2 Replies Last reply Reply Quote 0
                                  @smallfeuer
                                                  if (value === undefined) {
                                                      value = this.gpioPorts[port].value;
                                  		    this.log.debug(`Read ${value} from port ${port}.`);
                                  Also ich habe es jetzt soweit analysiert, hier wird der Wert beim 1. Durchlauf false gesetzt, ein delay ändert das Ergebnis aber hier nicht.
                                  Liest der Befehl
                                  den Wert direkt aus? Dann muss der Fehler weiter vorn in dieser Funktion verankert liegen 😞
                                  • Garfonso
                                    @smallfeuer
                                    Ja, genau, das .value liest den Wert aus. Daher hab ich dort das debug log ergänzt, was man bei dir auch sieht:
                                    Die restlichen Änderungen kommen über den onChange listener beim "watch", also da wird der Adapter über Änderungen am Pin informiert, sieht dann leicht anders aus:
                                    Es könnte sein, dass da noch eine Initialisierung läuft, und daher das false am Anfang kommt. Dazu hab ich aber in der Bibliothek bisher nichts finden können. 😕
                                    Bei meinem Test-System kommen am Anfang auch keine Change-Events.
                                      @garfonso Kannst du mir sagen wo ich die aktuell genutzte GPIO - Bibliothek vom Bookworm finde? Kann mich gern mal durch den Code suchen - etwas C- Verständnis hab ich mittlerweile.
                                      Alternativ würde ich jetzt folgendes Tun. Ich werde den GPIO INPUT einfach als Trigger nutzen und prüfen wie lange die Instanz "True" ist -> dementsprechend dann das Script starten über einen eigenen Datenpunkt. Ist zwar ein wenig aufwand, aber so werde ich die Falschmeldung bei Updates/Stromausfall los.
                                        @smallfeuer
                                        Es ist opengpio:
                                        https://github.com/ExplorationSystems/opengpio/
                                        • Hasont
                                          Hasont @Smallfeuer last edited by Hasont
                                          @smallfeuer
                                          Hallo, ich hab den Raspie auf GPIO 17 fest auf 3,3V gesetzt.
                                          Wurde sofort mit True angezeigt.
                                          Dann hab ich neu gebootet und GPIO 17 war false.
                                          rpi2.0
                                          	2025-02-26 18:45:42.625	debug	GPIO change on port 23: false
                                          rpi2.0
                                          	2025-02-26 18:45:42.625	debug	Ignoring change event due to debounce: 4ms < 200.
                                          rpi2.0
                                          	2025-02-26 18:45:42.624	debug	GPIO change on port 23: false
                                          rpi2.0
                                          	2025-02-26 18:45:42.624	debug	Ignoring change event due to debounce: 3ms < 200.
                                          rpi2.0
                                          rpi2.0
                                          	2025-02-26 18:45:42.623	debug	Ignoring change event due to debounce: 2ms < 200.
                                          rpi2.0
                                          	2025-02-26 18:45:42.623	debug	GPIO change on port 23: false
                                          rpi2.0
                                          	2025-02-26 18:45:42.622	debug	Ignoring change event due to debounce: 1ms < 200.
                                          rpi2.0
                                          	2025-02-26 18:45:42.622	debug	GPIO change on port 23: false
                                          rpi2.0
                                          	2025-02-26 18:45:42.621	debug	Setting state for port 23 to false
                                          rpi2.0
                                          	2025-02-26 18:45:42.620	debug	GPIO change on port 23: false
                                          rpi2.0
                                          	2025-02-26 18:42:45.609	debug	Port 23 direction: in
                                          rpi2.0
                                          	2025-02-26 18:42:45.601	debug	Setting state for port 22 to false
                                          rpi2.0
                                          	2025-02-26 18:42:45.599	debug	Port 22 direction: in
                                          rpi2.0
                                          	2025-02-26 18:42:45.598	debug	Port 21 direction: outlow
                                          rpi2.0
                                          	2025-02-26 18:42:45.597	debug	Port 20 direction: outlow
                                          rpi2.0
                                          	2025-02-26 18:42:45.595	debug	Port 19 direction: outlow
                                          rpi2.0
                                          	2025-02-26 18:42:45.587	debug	Setting state for port 18 to false
                                          rpi2.0
                                          	2025-02-26 18:42:45.586	debug	Port 18 direction: in
                                          rpi2.0
                                          	2025-02-26 18:42:45.564	debug	Setting state for port 17 to false
                                          rpi2.0
                                          	2025-02-26 18:42:45.557	debug	Port 17 direction: in
                                          rpi2.0
                                          	2025-02-26 18:42:45.556	debug	Port 16 direction: outlow
                                          rpi2.0
                                          	2025-02-26 18:42:45.554	debug	Port 13 direction: outlow
                                          rpi2.0
                                          	2025-02-26 18:42:45.550	debug	Port 12 direction: outlow
                                          rpi2.0
                                          	2025-02-26 18:42:45.550	debug	Got chip: class Default extends classes_1.Device {}
                                          rpi2.0
                                          	2025-02-26 18:42:45.549	debug	Got 4 from Raspberry Pi 4 Model B Rev 1.2code_text
                                          Bin dann mal in den Keller und hab meine Frau gebeten in den Objekten GPIO17 zu beachten und True mitzuteilen. Ich hab dann alle 5 sec ein/aus geschaltet. Vom zugerufenen her war das eher ein Flip/Flop als ein Schalter.
                                          Hab dann Protokoll gemacht. Soll eigentlich alle ca. 5sec True/False wechseln. Komm damit nicht klar.
                                          Habs mal angehängt!
                                          rpi2.0
                                          	2025-02-26 20:09:52.044	debug	Ignoring change event due to debounce: 5ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:52.044	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:52.043	debug	Ignoring change event due to debounce: 4ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:52.043	debug	GPIO change on port 17: false
                                          rpi2.0
                                          rpi2.0
                                          	2025-02-26 20:09:52.042	debug	GPIO change on port 17: false
                                          rpi2.0
                                          	2025-02-26 20:09:52.042	debug	Ignoring change event due to debounce: 3ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:52.041	debug	GPIO change on port 17: false
                                          rpi2.0
                                          	2025-02-26 20:09:52.041	debug	Ignoring change event due to debounce: 2ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:52.040	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:52.039	debug	Setting state for port 17 to true
                                          rpi2.0
                                          	2025-02-26 20:09:52.038	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:47.685	debug	Ignoring change event due to debounce: 36ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:47.685	debug	GPIO change on port 17: false
                                          rpi2.0
                                          	2025-02-26 20:09:47.677	debug	Ignoring change event due to debounce: 28ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:47.676	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:47.676	debug	Ignoring change event due to debounce: 27ms < 200.
                                          rpi2.0
                                          rpi2.0
                                          	2025-02-26 20:09:47.649	debug	Setting state for port 17 to false
                                          rpi2.0
                                          	2025-02-26 20:09:47.649	debug	GPIO change on port 17: false
                                          rpi2.0
                                          	2025-02-26 20:09:43.757	debug	Setting state for port 17 to true
                                          rpi2.0
                                          	2025-02-26 20:09:43.757	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:43.705	debug	Ignoring change event due to debounce: 151ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:43.704	debug	GPIO change on port 17: false
                                          rpi2.0
                                          	2025-02-26 20:09:43.704	debug	Ignoring change event due to debounce: 150ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:43.704	debug	GPIO change on port 17: true
                                          rpi2.0
                                          rpi2.0
                                          	2025-02-26 20:09:43.703	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:43.555	debug	Setting state for port 23 to false
                                          rpi2.0
                                          	2025-02-26 20:09:43.555	debug	GPIO change on port 23: false
                                          rpi2.0
                                          	2025-02-26 20:09:43.554	debug	Ignoring change event due to debounce: 0ms < 200.
                                          rpi2.0
                                          	2025-02-26 20:09:43.554	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:43.554	debug	Setting state for port 17 to true
                                          rpi2.0
                                          	2025-02-26 20:09:43.553	debug	GPIO change on port 17: true
                                          rpi2.0
                                          	2025-02-26 20:09:38.391	debug	Setting state for port 17 to false
                                          rpi2.0
                                          	2025-02-26 20:09:38.391	debug	GPIO change on port 17: false
                                          rpi2.0
                                          	2025-02-26 20:09:33.705	debug	Setting state for port 17 to true
                                          rpi2.0
                                          	2025-02-26 20:09:33.705	debug	GPIO change on port 17: true
                                            Smallfeuer @Hasont last edited by Smallfeuer
                                            @hasont Also das hin und her ist verständlich, du hast kein Pull down Widerstand eingebaut nehme ich an - wenn du also die 3,3V am Ausgang ausschaltest ist das Signal undefiniert. Siehe auch einen meiner letzten Kommentare zum Thema PullUP/Pulldown.
                                            oder hier: https://www.electronics-tutorials.ws/de/logische/pullup-widerstaende.html
                                            Was meinst du mit neu gebootet? Den Adapter, oder den Pi?
                                            Beim Pi Neustart könnte es natürlich sein, das wirklich keine 3,3V ankommen. Insbesondere wenn du die 3,3V vom Ausgang holst.
                                            Interessant ist also im wesentlichen nur ob beim Start oder Neustart des Adapters der Wert mal auf False geht.
                                            bitte als Ausgang aber die 3,3V Spannungsversorgung nehmen, und keinen Ausgang der auf True sitzt. Sicherheitshalber sollte man hier glaube ich einen kleinen Widerstand zwischen packen, falls vorhanden. Für einen kurzen Test sollte es aber auch ohne gehen.
                                            Hasont 1 Reply Last reply Reply Quote 0
                                            519
                                            146555
