    4. [Frage] Realisierung Adapter UDP Keba Wallbox
      gto @Sneak-L8 last edited by gto
      @sneak-l8
      Habe mein Script noch etwas gekürzt
      Blockly
        <variables>
          <variable id="MU8;yslk(B7(Tv%sqWM=">Phasenlimit in A</variable>
        </variables>
        <block type="variables_set" id="E*Vu$_+fuxrGm/d:dGi#" x="23" y="-354">
          <field name="VAR" id="MU8;yslk(B7(Tv%sqWM=">Phasenlimit in A</field>
            <block type="math_number" id="gqLBcLSd@@Snb8KlaVTx">
              <field name="NUM">32</field>
            <block type="on_ext" id="2s[RmVP})1RW}8|l/6pN">
              <value name="OID0">
                <shadow type="field_oid" id="$s?)jmdJ!-uBN2*Q%ez]">
                  <field name="oid">fronius.1.meter.0.Current_AC_Sum</field>
                <block type="control" id="T~q1?/]SMOxLPmZ?_S7T">
                  <field name="OID">kecontact.0.automatic.limitCurrent</field>
                    <block type="math_arithmetic" id="J6Nk{J9=+uJ%]s.koila">
                        <shadow type="math_number" id="Z{Vk|*~/(O0zyg;T@0-q">
                          <field name="NUM">1</field>
                        <block type="math_arithmetic" id="xlV)uzos74*Z54_`_vpH">
                            <shadow type="math_number" id="F4``i@tO{@ZsVDVEkX^s">
                            <block type="variables_get" id="?,G]_}j/2XK.{I/:SV(x">
                            <shadow type="math_number" id=",l%4P_9nAUjj2mNGH[h2">
                            <block type="math_round" id="~[yGWn[1a|N5Vd]OFBYo">
                              <field name="OP">ROUND</field>
                              <value name="NUM">
                                <shadow type="math_number" id="{wV8`R=q|7O=$|[gI6_t">
                                  <field name="NUM">3.1</field>
                                <block type="math_on_list" id="IE:o.]A^D[N|P{Bno.IL">
                                  <mutation op="MAX"></mutation>
                                  <field name="OP">MAX</field>
                                  <value name="LIST">
                                    <block type="lists_create_with" id="O162NtYNZ~wUA9s=P=]W">
                                      <value name="ADD0">
                                        <block type="get_value" id="ow$Xn02]:Vt{wT;tLX%$">
                                          <field name="OID">fronius.1.meter.0.Current_AC_Phase_1</field>
                                      <value name="ADD1">
                                        <block type="get_value" id="=bdn8.dOaSZs.tZ]bWRk">
                                          <field name="OID">fronius.1.meter.0.Current_AC_Phase_2</field>
                                      <value name="ADD2">
                                        <block type="get_value" id="p5he[kz$J=zaKte5tC}:">
                                          <field name="OID">fronius.1.meter.0.Current_AC_Phase_3</field>
                        <shadow type="math_number" id=".0n_l9PyIGr}lG[(RN7+">
                          <field name="NUM">1000</field>
      und Javascript
      var Phasenlimit_in_A;
      Phasenlimit_in_A = 32;
      on({ id: [].concat(['fronius.1.meter.0.Current_AC_Sum']), change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        setState('kecontact.0.automatic.limitCurrent' /* limit dynamic charging to this value of amperage (0 = no limitation) */, ((Phasenlimit_in_A - Math.round(Math.max.apply(null, [getState('fronius.1.meter.0.Current_AC_Phase_1').val, getState('fronius.1.meter.0.Current_AC_Phase_2').val, getState('fronius.1.meter.0.Current_AC_Phase_3').val]))) * 1000));
        Sneak-L8 @gto last edited by
        @gto Danke für die Skripte, ich hatte aber schon das Meiste programmiert. Jetzt steht eine guthub-Version bereit, die auch eine Limitierung auf einen bestimmten wert je Phase zulässt.
        Bitte einfach mal testen, mein energyMeter liefert keine Ampere-Werte und wollte die jetzt auch nicht berechnen lassen.
          @sneak-l8 Hallo Sneak, danke für die Arbeit. Es hat sich noch ein Fehler eingeschlichen. LimitCurrent bleibt immer auf auf einem konstanten Wert, egal was die Phasen für Werte haben.
          Habe im debug-log gesehen, dass ein Eintrag "wallbox set to charging maximum of 7000 mA" kommt. Dieser Wert wäre richtig, er wird aber nicht in "limitCurrent" geschrieben. Regelst du über einen anderen Datenpunkt?
          Habe gerade gesehen, dass du über CurrentUser regelst. Hier scheint es korrekt zu laufen. Ich muss aber noch warten bis ein KFZ lädt.
            @gto Ah, ok. Ich hatte gerade danach geschaut und dachte, dass es eigentlich passen muss. Hab das Debug-Log nun auch um die Einzelwerte für die Ampere-Berechnung ergänzt.
            Aber ja, limitCurrent ist für Dich. Dort kannst dem Adapter dynamisch eine (zusätzliche) Begrenzung mitteilen.
            Wenn Du den wert brauchst, könnte ich ihn höchstens als weiteren State (wie maxPower) unter statistics ausgeben.
              @sneak-l8 Noch eine Verständnisfrage für die Testung.
              Regelst du immer oder nur wenn an der Wallbox ein Auto lädt?
              Die Hardwarelimitierung über die DIP-Schalter ist die Obergrenze für currentUser?
              LimitCurrent benötige ich nicht.
                @gto Siehe Post #1133 - ich regle immer, da ich nicht weiß, wann ein Fahrzeug angesteckt wird und dann die Wallbox bereits runtergeregelt sein sollte.
                Ja, das "Standardlimit" ist currentHardware, ein anderes Limit kenne ich nicht.
                G 2 Replies Last reply Reply Quote 0
                  @sneak-l8 Danke, ich teste wenn der Hybrid zuhause ist und gebe dann Bescheid
                    Leider ist ein Fehler im Adapter. Es erfolgt keine Regelung.
                    Ich habe "maximaler Strom/Phase" auf 32000mA, hier die Phasenwerte und der "currentUser". Die Werte sind um 17:49 registriert.
                    Debug-Log:
                    LOG.txt
                      @gto Kannst Du noch mal die neuste Version ziehen? Hatte heute Morgen noch ergänzt, dass im Debug log auch die Einzel-Werte aus der Berechnung ausgegeben werden. Jetzt hab ich noch einen State statistics.maxAmperage ergänzt, in dem Du immer die aktuelle Begrenzung siehst.
                      Und schicke bitte auch mal ein Screenshot der Konfig (gerne aus dem Log).
                      Evtl. hast Du die Einheit für das EnergyMeter noch auf mA stehen?
                        @sneak-l8 neueste Version installiert
                        Debug-LOG
                        LOG.txt
                        Info-Log
                        Info-Log.txt
                        Einstellungen zur Leistungsbegrenzung
                        Config.zip
                        Ich denke deine Umrechnung A in mA stimmt nicht, ich habe gerade einen Fixwert von 25A an einer Phase eingegeben und der Wert statistics.maxAmperage ist 31975.
                        kecontact.0
                        2025-02-24 20:51:55.301 debug Available max amperage: 31975
                        kecontact.0
                        2025-02-24 20:51:55.301 debug amperage of mains: 25/-3.39/-4.15, amperage of charging station: 0/0/0 => available: 31975/32003.39/32004.15
                          @gto Ah, hab die Einheit falsch abfragt, bin aber schon auf der Couch... Muss ich morgen machen, wird evtl. auch übermorgen.
                            @sneak-l8 kein Problem, ich teste gerne wenn du fertig bist, morgen habe ich ohnehin kein Auto zum laden daheim
                              @gto So, jetzt bitte nochmal probieren. Jetzt wird im Log auch der neue Wert für die Einheit mitprotokolliert.
                                @sneak-l8 Sieht mit manuell eingegebenen Werten in Datenpunkten gut aus. Nächste Woche kommt mein Auto, dann kann ich mit 2 Autos im Echtbetrieb weitertesten.
                                Ein herzliches Dankeschön für deine Bemühungen .
                                  ich habe jetzt einmal ein Testergebnis mit dem einphasig ladenden Hybrid, ich habe den Heizstab der zufällig auf der selben Phase liegt eingeschaltet.
                                  maxAmperage ist korrekt berechnet, regelt die Box mit diesem Wert oder sollte auch der current User reduziert sein?
                                  Wäre es nicht sinnvoll bei unterschreiten von 6A bei maxAmperage die Box auf Pause zu setzen?
                                    @gto der state "currenUser" sollte nicht höher als maxAperage sein. Kannst Du mal das debug-Log dazu bereitstellen? Habe im Code jetzt auch nichts Verdächtiges gefunden.
                                      Log.txt
                                      Heute regelt der Adapter beim Laden den currentUser mit, allerdings um einen Abfragezyklus zeitversetzt (das bedeutet, dass der Strombezug für 30 Sekunden oder mehr überschritten wird).
                                      Die Regelung erfolgt aber nur wenn der maxAmperage einen höheren Wert hat (Bild Heizstab aus). Schalte ich den Heizstab ein, so ist maxAmperage zwischen 2000 und 3000mA und es erfolgt keine Regelung des currentUser.
                                      Hängt das mit dem Unterschreiten der 6000mA-Grenze zusammen? In diesem Fall muss das Ladelimit aber auch runter oder die Box deaktiviert werden. Mit pauseWallbox wäre das aber schlecht realisierbar, weil dann ja bei genug Energie die Pause aufgehoben wird. Es könnte aber die Pause auch bewusst vom Nutzer eingeschaltet gewesen sein und nicht von der Ladelimitbegrenzung, dann dürfte sie nicht aufgehoben werden.
                                      Ich möchte auch zur Diskussion stellen, ob nicht eine Abrundung auf 500mA oder 1000mA (könnte durchaus die eingestellte Schrittweite für die PV-Regulierung sein) sinnvoll wäre. Derzeit werden viele currentUser-Werte im zweistelligen Bereich geregelt. Könnte dies nicht bei manchen KFZ.Ladereglern zu Problemen führen?
                                      Für dieses LOG ist zuerst der Heizstab an (19:49), danach ausgeschaltet.
                                        @sneak-l8 Ich muss mich korrigieren, heute regelt der currentUser nicht.
                                        Log.txt
                                          @gto Also die Regelung der Wallbox erfolgt immer nur alle 30 Sekunden (es werden aber alle 15 Sekunden die Werte aktualisiert).
                                          Um 19:49:05 ist erstmal der Heizstab ab (maxAmperage bei 2,8A). Das ist aber die Zwischenberechnung, bei der keine Regelung erfolgt. 19:49:20 ist die nächste Messung und da wird dann auch geregelt.
                                          Wenn die verfügbare Stromstärke unter das untere Limit (in der Regel 6A), dann wird der Ladevorgang unterbrochen. Dazu wird zwar currUser 0 gesendet, aber die Wallbox zeigt weiterhin bei Currnet den letzten Wert an. Aber enabled ist dann 0. Das mag verwirrend sein, aber ist halt so das Vorgehen der Wallbox. Daher evtl. Deine Anzeige ändern auf enabled == 1, dann zeige currUser sonst 0.
                                          Aber ich habe nun die Ampere-Begrenzung nach vorne verschoben, so dass sie alle 15 Sekunden greift, also auch bei der Zwischenmessung. Hier wird immer nur begrenzt (ggf. Ladung unterbricht), nicht erhöht.
                                          Auch den Hinweis auf die Rundung ist super. Bei der Leistungsbegrenzung ist sie drin, bei den Ampere hatte ich sie vergessen. Das trage ich nach, so dass auch gemäß dem in den Einstellungen hinterlegten Delta geregelt wird.
                                          Diese Version steht jetzt bereit.
                                            @gto sagte in [Frage] Realisierung Adapter UDP Keba Wallbox:
                                            Log.txt
                                            So, hat sich gerade überschnitten.
                                            Da Auto lädt im Protokoll nicht, weil vermutlich die PV-Automatik an ist. Wie oben beschrieben, wird dann currUser = 0 gesendet und stoppt jede Ladung (enableUser ist 0, currUser bleibt beim letzten Wert). Da nun also die Ladung auf 0A begrenzt wird, gibt es auch nichts weiter zu regeln ...
                                            (im Log muss man gut aufpassen, die Broadcasts der beiden Kebas auseinander zu halten (leider kann immer nur einer Instanz alle Rückmeldungen aller Boxen empfangen).
                                            81.1k
                                            1266
                                            425395
