    4. vis-2-widgets-collection
    • carsten04
      carsten04 Developer @Merlin123 last edited by carsten04
      @merlin123 {ts1:evcc.0.loadpoint.1.status.mode; ts1=="pv" ? #00ff00 : #ff0000}
      Das ist ein ternärer Operater, also:
      condition ? exprIfTrue : exprIfFalse
      Für den Vergleich brauchst Du == und nicht =, sonst ist es eine Zuweisung.
      • Merlin123
        Merlin123 @carsten04 last edited by
        @carsten04 ah.. ich erinnere mich... Da war was...
        Geht aber trotzdem nicht.
        Hab bei Hintergrundfarbe
        eingetragen aber der Hintergrund bleibt weiß.....
        Im Editor sieht das so aus:
        Das Widget:
            "tpl": "tplStateCollectionWidget",
            "data": {
              "bindings": [],
              "iconXOffset": "15px",
              "g_common": true,
              "iconYOffset": "0px",
              "header": "PV Laden",
              "footer": "",
              "basePadding": 1,
              "baseElevation": 4,
              "oid": "evcc.0.loadpoint.1.control.pv",
              "unit": "",
              "g_button": true,
              "values_count": 1,
              "onlyStates": false,
              "onlyDisplay": false,
              "name": "Button PV Laden",
              "comment": null,
              "class": null,
              "filterkey": null,
              "multi-views": null,
              "locked": null,
              "g_fixed": true,
              "oidType": "boolean",
              "write": true,
              "minValue": 0,
              "maxValue": 100,
              "icon": null,
              "value1": true,
              "alias1": "",
              "iconSmall": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0yMCAxMkg0TDIgMjJoMjBsLTItMTB6bS0xLjY0IDJsLjQgMkgxM3YtMmg1LjM2ek0xMSAxNHYySDUuMjRsLjQtMkgxMXptLTYuMTYgNEgxMXYySDQuNDRsLjQtMnpNMTMgMjB2LTJoNi4xNmwuNCAySDEzek0xMSA4aDJ2M2gtMnptNC43NjQtLjc5NWwxLjQxNS0xLjQxNEwxOS4zIDcuOTEybC0xLjQxNCAxLjQxNHptLTExLjA1OS43MDhMNi44MjYgNS43OUw4LjI0IDcuMjA2TDYuMTIgOS4zMjd6TTMgMmgzdjJIM3ptMTUgMGgzdjJoLTN6bS02IDVjMi43NiAwIDUtMi4yNCA1LTVoLTJjMCAxLjY1LTEuMzUgMy0zIDNTOSAzLjY1IDkgMkg3YzAgMi43NiAyLjI0IDUgNSA1eiIvPjwvc3ZnPg==",
              "noFooter": true,
              "valueSize1": 0,
              "iconSize": 150,
              "g_css_font_text": true,
              "iconColor1": "",
              "iconColor": "",
              "valueSize": 0,
              "backgroundColor": "{ts1:evcc.0.loadpoint.1.status.mode; ts1==\"pv\" ? #00ff00 : #ff0000}",
              "backgroundColor1": "{ts1:evcc.0.loadpoint.1.status.mode; ts1==\"pv\" ? #00ff00 : #ff0000}"
            "style": {
              "bindings": [],
              "left": 986,
              "top": "24px",
              "width": "100px",
              "height": "100px",
              "position": "",
              "color": null,
              "text-align": "center",
              "text-shadow": null,
              "font-family": null,
              "font-style": null,
              "font-variant": null,
              "font-weight": null,
              "font-size": null,
              "line-height": null,
              "letter-spacing": null,
              "word-spacing": null
            "widgetSet": "vis-2-widgets-collection",
            "_id": "i000001"
        carsten04 1 Reply Last reply Reply Quote 0
        • carsten04
          @merlin123 Setz die Farben mal in "". Wenn das nicht klappt, schaue ich mir das heute Abend noch einmal am Rechner an.
          • Merlin123
            @carsten04 Die " waren's 🙂 Danke!
            • carsten04
              carsten04 Developer @micklafisch last edited by carsten04
              @micklafisch Was soll das Widget denn sonst noch können? Nur View anzeigen und Dialogfenster skalieren?
                micklafisch @carsten04 last edited by
                @carsten04
                Kennst du zufällig das MDW von Scrounger? Das konnte eigentlich fast alles.
                Spontan fällt mir dazu ein:
                • definierte View anzeigen
                • variable Breite und gegebenenfalls Höhe
                • abgedunkelter Hintergrund
                • Option zum Schließen der View bei klicken außerhalb des Dialogs
                • Möglichkeit zur Anzeige/Aktivierung des Dialogs über State
                • optional Titel des Dialogs
                • optional schließen Button oben rechts oder unten
                  Matu @carsten04 last edited by
                  @carsten04
                  vielen Dank für deine tolle Sammlung. Ich habe versucht einen Button zu konfigurieren der wie die Schreibtischlampe den State true/false mit einem klick ändert (toggle). Leider will dies nicht gelingen. Habe alle 4 Widgets mal ausprobiert und verschiedene Einstellungen vorgenommen.
                  Mit der Checkbox klappe es und das Widget ändert Farbe/Symbol usw. jedoch nur wenn ich das State im Objektbaum ändere. Die Checkbox lässt sich nicht auswählen. Das Mouse-Icon ändert sich auch nicht wenn es darüber ist.
                    Matu last edited by
                    This post is deleted!
                    • carsten04
                      carsten04 Developer last edited by carsten04
                      @matu Woran scheitert es denn genau? Eigentlich kannst Du bei der Grundeinstellung nicht viel falsch machen, schau mal hier:
                      Achte auch darauf, dass die vis-2 die v2.9.64 (Stable-Version) hat.
                        @carsten04
                        danke für die schnelle Rückmeldung. Die Vis-2 hat die Version 2.9.64.
                        Das Problem ist das ich das Widget nicht anklicken kann.
                        Widget.mp4
                        • carsten04
                          carsten04 Developer @Matu last edited by
                          @matu Zeig mal bitte was unter common im Objekt steht.
                            @carsten04
                            das ist der ganz normale Beispiel DP.
                            Am DP liegt es auch nicht weil, weil wenn ich dein Schalter Widget verwende funktioniert es ja.
                            Auch die Button-Gruppe und der Schieberegler funktionieren.
                            Nur Checkbox und Zustand lassen sich nicht anklicken
                            carsten04 2 Replies Last reply Reply Quote 0
                            • carsten04
                              • carsten04
                                @matu Geh mal auf Objektdaten und mache dann bitte einen Screenshot.
                                  @carsten04
                                  • carsten04
                                    @matu Ergänze mal bitte in common:
                                    "read": true,
                                    "write": true
                                      @carsten04
                                      Keine Veränderung. Hier noch ein Video mit den 3 Widgets die alle auf den DP zugreifen.
                                      20250225172110.mp4
                                      • carsten04
                                        carsten04 Developer @Matu last edited by carsten04
                                        @matu Das schaue ich mir morgen am Rechner mal in Ruhe an.
                                        Wenn Du kurz noch Zeit hast mach mal bitte folgendes: lösche alle views in der vis-2 und lege eine neue leere view an und nutze nur das State-Widget. Ist der Effekt dann immer noch da?
                                          @carsten04
                                          Jetzt funktioniert es, aber trotzdem komisch, dass es bei einigen geht und bei anderen nicht.
                                          Vielen Dank für die schnellen Rückmeldungen, spiele jetzt mal etwas mit deinen Widgets 😉
                                          • carsten04
                                            @matu Kurz zur Erklärung. Bei dem State-Widget kannst Du "Nur Anzeige" setzen.
                                            Die Anzeigeoption ist nur dann sichtbar, wenn der State writeable ist, ansonsten kann sowieso nur angezeigt werden. Das war bei Dir der Fall, da weder write noch read in common gesetzt war (bei Real Life States eines Adapter sind die beiden Attribute in common eigentlich immer vorhanden).
                                            Nach setzen der beiden Attribute in common, wie von Dir gemacht (insbesondere "write": true), hättest Du eigetlich nur den State (oid) im State-Widget noch einmal neu auswählen müssen, denn erst dann bekommt das Widget die Änderung mit (das ist vis-2 immanent und läßt sich nicht ändern). Die Info von mir die view zu löschen war überflüssig und das Widget macht dann eigentlich auch genau das was es soll.
                                            293
                                            60465
