    4. Problem mit nodejs. Fehlermeldung (Node-red)
      gerrit1 @Homoran last edited by gerrit1
      @homoran habe nun schon ne Neuinstallation versucht.
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      sagt:
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
          at Module._load (node:internal/modules/cjs/loader:981:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.20.6
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v18.20.6
      node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
      /home/pi/.nvm/versions/node/v20.18.3/bin/node
      /home/pi/.nvm/versions/node/v20.18.3/bin/npm
      /home/pi/.nvm/versions/node/v20.18.3/bin/npx
      /home/pi/.nvm/versions/node/v20.18.3/bin/corepack
      Recommended versions are nodejs  and npm
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please execute
      iob nodejs-update
      to fix these errors.
      MEMORY:
      Mem:           3.8G         69M        3.0G         24M        762M        3.6G
      Swap:           99M          0B         99M
      Total:         3.9G         69M        3.1G
      Active iob-Instances: 	0
      node:internal/modules/cjs/loader:1143
        throw err;
        requireStack: []
      Node.js v18.20.6
        throw err;
        requireStack: []
      Node.js v18.20.6
      ioBroker Core: 		js-controller
        throw err;
        requireStack: []
      Node.js v18.20.6
      			admin
        throw err;
        requireStack: []
      Node.js v18.20.6
      ioBroker Status:
      Objects: 		0
      States: 		0
      Size of iob-Database:
      find: '/opt/iobroker/iobroker-data': No such file or directory
      Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
      für mich wäre es mittlerweile wohl am besten, node red neuzuinstallieren, allerdings gerne übers Terminal und nicht hart über die sd karte. So müsste ich nicht alles neu machen
        Homoran Global Moderator Administrators @gerrit1 last edited by
        @gerrit1 sagte in Problem mit nodejs. Fehlermeldung (Node-red):
        buster
        ist so was von tot!
        Dafür gibt es keinerlei updates mehr, auch nicht für node.
          was genau ist tot?
          ich vermute ich habe mir irgendwas "altes" raufgezogen. Habe aktuell keinen Zugang mehr zu Node-red.
            was genau ist tot?
            Buster!
            das Betriebssystem
            • OliverIO
              OliverIO @gerrit1 last edited by OliverIO
              @gerrit1
              Du hast Node aktualisiert was durch dein altes Betriebssystem nicht mehr supportet wird
              Entweder du aktualisierst dein Betriebssystem (bevorzugt) oder
              Machst wieder ein downgrade von node um das andere in Ruhe vorzubereiten (Backup vom IoBroker und so)
              Glib ist eine der zentralen Bibliotheken die benötigt wird für alle Programme
              Die mit dem gnu c compiler kompiliert worden sind.
              Bei raspberry, dank den preiswerten sd Karten machst du am besten auf einer neuen sd Karte eine komplett neuinstallation
                Homoran Global Moderator Administrators @OliverIO last edited by
                @oliverio sagte in Problem mit nodejs. Fehlermeldung (Node-red):
                klingt nach RasPi.
                Da geht nur Neuinstallation mit Restore des ketzten Backups.
                Voraussetzung ist, dass nicht auch der js-controller zu alt ist.
                  Thomas Braun Most Active @gerrit1 last edited by Thomas Braun
                  @gerrit1
                  Versuch es mal mit
                  iob stop
                  iob fix
                  iob nodejs-update 18
                  Und lass die Finger von so einem Kram wie nvm!!!
                  Das zerschießt dir die Installation. Wenn der ioBroker wieder laufen sollte ziehst du ein Backup und ziehst damit auf ein von Grund auf NEUINSTALLIERTES Raspberry OS 12 'Bookworm' um.
                    gerrit1 @Thomas Braun last edited by
                    Danke für eure Hilfe,
                    habe es irgendwie geschafft, Node-red neuzinstallieren. Musste hierfür aber keine komplette Neuinstallation vom Raspberry machen.
                      @gerrit1
                      Doch, musst du. Dein buster ist nämlich tot.
                      Und ein 'in-line-Upgrade' auf ein aktuelles Release ist nicht möglich.
                      Zeig mal die Langfassung von
                      iob diag
                      nun
                        Da steht tatsächlich:
                        *** LIFE CYCLE STATUS ***
                        Wobei jetzt das neueste Node-Red läuft
                        Kann ich denn ein Backup von Node-Red machen und anschließend auf das neue Betriebssystem wieder schieben? Oder wie sollte ich da am sinnvollsten vorgehen?
                          @gerrit1
                          Wenn es 'da steht' wird es wohl auch wahr sein.
                          Warum sollte ich dich anlügen?
                          Mittels
                          distro-info --unsupported -yeol -c
                          steht da sogar, wie lange (in Tagen) das schon tot ist.
                          Klar, jetzt ist ja auch nodejs senkrecht installiert.
                          Kiste inkl. ioBroker auf den letzen Stand bringen, Backup mittels Backitup-Adapter ziehen, neues Betriebssystem komplett neuinstallieren, ioBroker 'leer' installieren, Backup einspielen.
                          Ob für node-red da noch weitere Dinge zu berücksichtigen sind weiß ich allerdings nicht, ich verwende kein node-red.
                          380
