    4. Zigbee Helligkeitssensor gibt keine Werte aus
    • surfer09
      surfer09 @FredF last edited by surfer09
      @fredf Die Batterie ist eigentlich noch recht neu. Die würde ich ausschließen.
      Ich habe mal das LOG angehangen vom Anlernen.
      2025-02-26 18:57:10.714 - debug: zigbee.0 (1620) handleMessage. {"type":"commandIdentifyQuery","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":39,"_applicationVersion":27,"_dateCode":"20200312","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":262,"inputClusters":[0,1024,3,1],"outputClusters":[3],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.sen_ill.mgl01","manufacturerName":"XIAOMI","powerSource":3,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"20200312","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":6021}}},"deviceIeeeAddress":"0x04cf8cdf3c81a421","deviceNetworkAddress":6365,"_binds":[{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":1024,"attrId":0,"minRepIntval":15,"maxRepIntval":3600,"repChange":500}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x04cf8cdf3c81a421"}}],"_hardwareVersion":1,"_ieeeAddr":"0x04cf8cdf3c81a421","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1740592630714,"_manufacturerID":4718,"_manufacturerName":"XIAOMI","_modelID":"lumi.sen_ill.mgl01","_networkAddress":6365,"_powerSource":"Battery","_softwareBuildID":"2019\u0000www.","_stackVersion":2,"_type":"EndDevice","_zclVersion":3,"_linkquality":168,"_skipDefaultResponse":false,"_checkinInterval":3600,"_pendingRequestTimeout":3600000,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{},"linkquality":168,"groupID":0,"cluster":"genIdentify","meta":{"zclTransactionSequenceNumber":7,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-02-26 18:57:10.715 - debug: zigbee.0 (1620) Received Zigbee message from '0x04cf8cdf3c81a421', type 'commandIdentifyQuery', cluster 'genIdentify', data '{}' from endpoint 1 with groupID 0
      2025-02-26 18:57:10.715 - debug: zigbee.0 (1620) Type commandIdentifyQuery device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":39,"_applicationVersion":27,"_dateCode":"20200312","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":262,"inputClusters":[0,1024,3,1],"outputClusters":[3],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.sen_ill.mgl01","manufacturerName":"XIAOMI","powerSource":3,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"20200312","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":6021}}},"deviceIeeeAddress":"0x04cf8cdf3c81a421","deviceNetworkAddress":6365,"_binds":[{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":1024,"attrId":0,"minRepIntval":15,"maxRepIntval":3600,"repChange":500}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x04cf8cdf3c81a421"}}],"_hardwareVersion":1,"_ieeeAddr":"0x04cf8cdf3c81a421","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1740592630714,"_manufacturerID":4718,"_manufacturerName":"XIAOMI","_modelID":"lumi.sen_ill.mgl01","_networkAddress":6365,"_powerSource":"Battery","_softwareBuildID":"2019\u0000www.","_stackVersion":2,"_type":"EndDevice","_zclVersion":3,"_linkquality":168,"_skipDefaultResponse":false,"_checkinInterval":3600,"_pendingRequestTimeout":3600000,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["illuminance","illuminance_lux"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"manuSpecificLumi","type":["attributeReport","readResponse"]}],"exposes":[{"name":"battery","label":"Battery","access":1,"type":"numeric","property":"battery","description":"Remaining battery in %, can take up to 24 hours before reported","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Voltage of the battery in millivolts","category":"diagnostic","unit":"mV"},{"name":"illuminance","label":"Illuminance","access":5,"type":"numeric","property":"illuminance","description":"Raw measured illuminance"},{"name":"illuminance_lux","label":"Illuminance (lux)","access":5,"type":"numeric","property":"illuminance_lux","description":"Measured illuminance in lux","unit":"lx"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"meta":{"battery":{"voltageToPercentage":{"min":2850,"max":3000}}},"onEvent":null,"zigbeeModel":["lumi.sen_ill.mgl01"],"model":"GZCGQ01LM","vendor":"Xiaomi","whiteLabel":[{"vendor":"Xiaomi","model":"YTC4043GL"}],"description":"Mi light sensor","options":[{"name":"illuminance_calibration","label":"Illuminance calibration","access":2,"type":"numeric","property":"illuminance_calibration","description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device."},{"name":"illuminance_lux_calibration","label":"Illuminance lux calibration","access":2,"type":"numeric","property":"illuminance_lux_calibration","description":"Calibrates the illuminance_lux value (percentual offset), takes into effect on next report of device."}]},"name":"0x04cf8cdf3c81a421"} incoming event: {"type":"commandIdentifyQuery","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":39,"_applicationVersion":27,"_dateCode":"20200312","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":262,"inputClusters":[0,1024,3,1],"outputClusters":[3],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.sen_ill.mgl01","manufacturerName":"XIAOMI","powerSource":3,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"20200312","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":6021}}},"deviceIeeeAddress":"0x04cf8cdf3c81a421","deviceNetworkAddress":6365,"_binds":[{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":1024,"attrId":0,"minRepIntval":15,"maxRepIntval":3600,"repChange":500}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x04cf8cdf3c81a421"}}],"_hardwareVersion":1,"_ieeeAddr":"0x04cf8cdf3c81a421","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1740592630714,"_manufacturerID":4718,"_manufacturerName":"XIAOMI","_modelID":"lumi.sen_ill.mgl01","_networkAddress":6365,"_powerSource":"Battery","_softwareBuildID":"2019\u0000www.","_stackVersion":2,"_type":"EndDevice","_zclVersion":3,"_linkquality":168,"_skipDefaultResponse":false,"_checkinInterval":3600,"_pendingRequestTimeout":3600000,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{},"linkquality":168,"groupID":0,"cluster":"genIdentify","meta":{"zclTransactionSequenceNumber":7,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-02-26 18:57:10.719 - debug: zigbee.0 (1620) No converter available for 'GZCGQ01LM' '04cf8cdf3c81a421' with cluster 'genIdentify' and type 'commandIdentifyQuery'
      Vielleicht hat noch jemand eine andere Empfehlung für einen Lichtsensor über Zigbee.
        crunchip Forum Testing Most Active @surfer09 last edited by
        @surfer09 sagte in Zigbee Helligkeitssensor gibt keine Werte aus:
        Hat jemand vielleicht eine Idee,
        vllt ein Hinweis zur Firmware deines Sticks
        https://www.zigbee2mqtt.io/devices/GZCGQ01LM.html
        • Asgothian
          Asgothian Developer @surfer09 last edited by
          @surfer09 Bitte testen:
          • Update auf die 2.0.1 aus dem Latest Zweig.
          • Debug für den Sensor aktivieren (siehe Hier)
          • Prüfen mit welchem Payload Nachrichten vom Gerät am Adapter ankommen.
          • Prüfen ob das Gerät neu 'Konfiguriert' werden kann. (Button auf der Rückseite der Gerätekachel). Dabei das Gerät wach halten.
          A.
          crunchip surfer09 2 Replies Last reply Reply Quote 1
            crunchip Forum Testing Most Active @Asgothian last edited by
            @asgothian sagte in Zigbee Helligkeitssensor gibt keine Werte aus:
            sollte dieser Sensor denn nicht auch mit seiner jetzigen installierten Version funktionieren?
            • Asgothian
              Asgothian Developer @crunchip last edited by
              @crunchip sagte in Zigbee Helligkeitssensor gibt keine Werte aus:
              Tut er bei mir. Aber es gibt so viele Effekte das ich keine Lust habe in altem Code zu graben. Also auf die aktuelle Version, dann weiter testen.
              nebenbei ist in dieser Version das aktivieren der Debug-Nachrichten deutlich komfortabler als es das in der alten Version war. Und auch entsprechend gut dokumentiert (link)
              A.
                hab ich mir gerade schon angesehen
                • Asgothian
                  Und.. Meinung dazu ?
                    @asgothian klingt vielversprechend und sauber aufgebaut. Habe jedoch davon keinen nutzen da ich z2m nutze.
                    setzt jeoch immer noch voraus, das
                    eine Rolle spielt, jedoch noch keine Info kam, was genutzt wird
                    • surfer09
                      surfer09 @Asgothian last edited by
                      @asgothian: Also.. ich bräuchte da mal Hilfe zu, weil ich noch nie Firmware Updates auf die Sensoren gepackt habe. Wie muss ich dazu vorgehen?
                      Hier werden mir keine Update angeboten...
                      crunchip arteck Asgothian 3 Replies Last reply Reply Quote 0
                      • surfer09
                        surfer09 @crunchip last edited by
                        @crunchip Also ich habe den SONOFF Zigbee 3.0 USB Dongle mit der Firmware 7.4.5 (GA) im Einsatz. Ich steige bei den ganzen Firmwares auch nicht wirklich durch, welche man davon nutzen sollte, oder auch nicht. Scheinbar gibt es dafür auch mehrere Möglichkeiten, wenn ich das richtig verstehe? 🤔
                          @surfer09 davon hat doch niemand etwas geschrieben
                            Soweit ich weiß, ist das davon abhängig welcher Chip auf dem Stick verbaut ist
                              arteck Developer Most Active @surfer09 last edited by
                              @surfer09 wie währe es wenn du erstmal GENAUER lesen würdest was man von dir braucht...
                              • Asgothian
                                Nochmal von vorne:
                                • Firmware auf dem Gerät ist wahrscheinlich nicht veraltet.
                                • Firmware auf dem Stick ist wahrscheinlich ok.
                                • Irgendeine Firmware aktualisieren bringt im Zweifelsfall erst einmal wenig
                                • Du musst schauen was das Gerät an Nachrichten Sendet. Das geht (auch) mit der Adapter Version die du nutzt, aber nicht so elegant. Bitte hier lesen, da steht was zu tun ist.
                                • Du musst schauen ob es Möglich ist dem Gerät eine Konfiguration zu senden. Dafür gibt es auf der Gerätekachel einen entsprechenden Button. Wichtig dabe ist das Du das Gerät vor dem Konfigurieren aufweckst, sonst geht das sowieso schief.
                                Ohne Informationen ob das Gerät überhaupt etwas relevantes Sendet ist alles nur stochern im Dunkeln und tauschen wir mal XYZ aus, vielleicht geht es dann, keine vernünftige Fehlerprüfung.
                                A.
                                • surfer09
                                  Also ich weiß nicht, was hier über Nacht passiert ist, aber plötzlich meldet er die Werte. Verstehen muss man das nicht?!
                                    Maddin77 last edited by
                                    Servus
                                    ich häng mich hier mal dran mit einem Helligkeits Sensor
                                    Diesen Hier Tuya ZG-204ZL
                                    leider bekomme ich Werte mit denen es sich nicht wirklich Steuern lässt in meinen Augen
                                    evtl. müsste ich was anders einstellen, weis nur nicht wie
                                    hier mal paar Daten und Bilder
                                    Der Gerät im Zigbee Adapter
                                    Hier die Objekte aus IOB
                                    ich nehme die Iluminance Raw
                                    und so schaut die Aufzeichnung dann aus 15sek
                                    evtl. jemand nenn Tipp für mich
                                    Danke schon mal
                                    haselchen arteck 2 Replies Last reply Reply Quote 0
                                      arteck Developer Most Active @surfer09 last edited by arteck
                                      @surfer09
                                      was bist du aber auch ungeduldig 🙂
                                      • haselchen
                                        haselchen Most Active @Maddin77 last edited by
                                        @maddin77
                                        Wo hakt es denn?
                                        Genau den Gleichen habe ich und viele andere hier auch.
                                          Maddin77 @haselchen last edited by Maddin77
                                          @haselchen
                                          Naja er spring von 2500 auf 1600 und dann auf 0
                                          Da bleibt nicht viel spiel zum schalten.
                                          Ich dachte es wäre ne schönere Rampe zum abfragen.
                                          Also damit ich besser und genauer auswerten könnte.
                                          Die Sonne geht ja auch langsam weg und nicht so ruck artik.
                                          • haselchen
                                            haselchen Most Active @Maddin77 last edited by haselchen
                                            @maddin77
                                            Also .
                                            Nimm den Datenpunkt wo null Minuten drin steht .
                                            Schreib da meinetwegen 5 rein ( Haken bei bestätigt nicht setzen).
                                            Vorher drückst Du am BWM den Pairingknopf.
                                            Dann blinkt er vorne rot.
                                            Dann drückst Du auf OK mit den 5minuten .
                                            Und in der Kachel sollte jetzt 5minutes stehen und im DP auch .
                                            Und nun beobachte nochmal das Verhalten mit der Helligkeit .
                                            5229
