Test Adapter Garmin
@bommel_030 probier nochmal die GitHub version
adapter stoppen
GitHub drüber installieren
token und fgp eingebe
adapter starten -
@tombox
Leider das gleiche Ergebnis.
Er macht alle 13 Minuten einen "Refresh Token". Das versucht er auch nach dem "Absturz" weiter.
10:29 das letzte Mal aktuelle Daten abgerufen, nächster Durchlauf 10:59 mit Fehler (siehe unten).garmin.0 2025-02-25 11:04:19.305 debug HTTPError: Response code 500 (Internal Server Error) garmin.0 2025-02-25 11:04:19.305 error FGP missmatch. Please logout and login in garmin and update FGP in the settings garmin.0 2025-02-25 11:04:19.305 debug [object Object] garmin.0 2025-02-25 11:04:18.473 debug Refresh token garmin.0 2025-02-25 10:59:46.707 error undefined garmin.0 2025-02-25 10:59:46.707 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:46.706 error https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-19&endDate=2025-02-25 garmin.0 2025-02-25 10:59:46.561 error undefined garmin.0 2025-02-25 10:59:46.561 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:46.561 error https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10 garmin.0 2025-02-25 10:59:46.418 error undefined garmin.0 2025-02-25 10:59:46.418 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:46.418 error https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-25 garmin.0 2025-02-25 10:59:46.250 error undefined garmin.0 2025-02-25 10:59:46.250 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:46.250 error https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-19 garmin.0 2025-02-25 10:59:46.051 error undefined garmin.0 2025-02-25 10:59:46.051 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:46.051 error https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-25 garmin.0 2025-02-25 10:59:45.897 error undefined garmin.0 2025-02-25 10:59:45.896 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:45.896 error https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-25&nonSleepBufferMinutes=60 garmin.0 2025-02-25 10:59:45.751 error undefined garmin.0 2025-02-25 10:59:45.751 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:45.750 error https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical garmin.0 2025-02-25 10:59:45.582 error undefined garmin.0 2025-02-25 10:59:45.582 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:45.581 error https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030 garmin.0 2025-02-25 10:59:45.435 error undefined garmin.0 2025-02-25 10:59:45.435 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:45.435 error https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-25 garmin.0 2025-02-25 10:59:45.013 error undefined garmin.0 2025-02-25 10:59:45.013 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:45.013 error https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-25/2025-02-25 garmin.0 2025-02-25 10:59:44.848 error undefined garmin.0 2025-02-25 10:59:44.847 error HTTPError: Response code 401 (Unauthorized) garmin.0 2025-02-25 10:59:44.847 error https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-25 garmin.0 2025-02-25 10:51:24.308 debug HTTPError: Response code 500 (Internal Server Error) garmin.0 2025-02-25 10:51:24.308 error FGP missmatch. Please logout and login in garmin and update FGP in the settings garmin.0 2025-02-25 10:51:24.307 debug [object Object] garmin.0 2025-02-25 10:51:23.706 debug Refresh token
@bommel_030 sollte mit der GitHub version gefixt werden
@tombox
Leider nein. Nach 2h ist mit 401 wieder Ende.
Hab mir noch die Zugangsdaten für einen weiteren Account besorgt, da ist das gleiche Fehlerbild. -
@bommel_030 Mit version 1c2f1c714442701166c9aa2304b4fe6b87de6d83 ?
@tombox
Die neueste Version eigentlich...
Kann ich die Nummer über den Admin auslesen?
Hab gerade noch mal die GitHub Version installiert und starte noch Mal einen Durchlauf. -
@bommel_030 steht im log wenn der adapter gestartet wird
@tombox
Also...
Adapter noch mal installeirt...
Erster Abruf 12:43, Aktualisierung alle 30 min, Refresh token alle 13min.
14:39 ein erfolgreicher "Refresh Token", 14:43 Fehler 401.
Da ich im Meeting war konnte ich nicht nachsehen bzw. den Adapter stoppen.
14:52 dann wieder ein erfolgreicher "Refresh Token" und 15:13 wieder ein erfolgreicher Abruf...
Ich schau mal was in 2h passiert... -
@tombox
Der Adapter ruft jetzt seit gestern durchgehend Daten ab. Alle 2h haut er aber das LOG voll.
2025-02-28 10:33:05.017 error undefined 2025-02-28 10:33:05.017 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:05.017 error https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-22&endDate=2025-02-28 2025-02-28 10:33:04.870 error undefined 2025-02-28 10:33:04.870 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:04.870 error https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10 2025-02-28 10:33:04.717 error undefined 2025-02-28 10:33:04.717 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:04.717 error https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-28 2025-02-28 10:33:04.199 error undefined 2025-02-28 10:33:04.198 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:04.198 error https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-22 2025-02-28 10:33:04.032 error undefined 2025-02-28 10:33:04.032 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:04.032 error https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-28 2025-02-28 10:33:03.883 error undefined 2025-02-28 10:33:03.883 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:03.883 error https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-28&nonSleepBufferMinutes=60 2025-02-28 10:33:03.730 error undefined 2025-02-28 10:33:03.730 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:03.730 error https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical 2025-02-28 10:33:03.568 error undefined 2025-02-28 10:33:03.568 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:03.568 error https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030 2025-02-28 10:33:03.380 error undefined 2025-02-28 10:33:03.380 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:03.380 error https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-28 2025-02-28 10:33:03.224 error undefined 2025-02-28 10:33:03.224 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:03.224 error https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-28/2025-02-28 2025-02-28 10:33:03.072 error undefined 2025-02-28 10:33:03.072 error HTTPError: Response code 401 (Unauthorized) 2025-02-28 10:33:03.072 error https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-28
Kann man das noch irgendwie abfangen? Wenn nicht, die Logstufe evtl. auf "Warn" setzen?
@bommel_030 Wenn das kommt sollten aber keine Daten reinkommen oder
@tombox
Nein, bei dem Abruf der den Fehler 401 erzeugt kommen keine Daten. Bei dem darauffolgenden kommen dann wieder Daten. -
@bommel_030 hast du ein größeren log ausschnitt mit refresh token
@tombox
Mit refresh vor und nach 401. Reicht das?
2025-02-28 00:20:30.918 - debug: garmin.0 (2133783) Refresh token 2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:13:16.024Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:13:16.024Z","sameSite":"none"},{"key":"JWT_FGP","value":"a90b9183-b21b-4477-a473-6b4346295d77","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T21:24:18.016Z","lastAccessed":"2025-02-27T23:20:30.918Z"},{"key":"ADRUM_BTa","value":"R:0|g:e5a90d46-5b0e-4249-be6a-ebe67936c980|n:garmin_869629ee-d273-481d-b5a4-f4b0a8c4d5a3","expires":"2025-02-27T23:13:45.000Z","maxAge":30,"domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":true,"creation":"2025-02-27T23:13:14.122Z","lastAccessed":"2025-02-27T23:13:16.024Z"},{"key":"ADRUM_BT1","value":"R:0|i:137465|e:23|t:1740697995888","expires":"2025-02-27T23:13:45.000Z","maxAge":30,"domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":true,"creation":"2025-02-27T23:13:14.122Z","lastAccessed":"2025-02-27T23:13:16.024Z"}]} 2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.ZVboYSNZS-o7BgcCmfggSwzN_8_odrsX97qdCrhEwWTcVjsVjjxhrbKnbMbvGZ2Iu2-JdY4v2YWpxe1ghApY2ag4t84UQcIUmMewqkTnmTeBM_ggSEK6ix3NyiVjpDkbLnoXeOuyYI8mSCEX0jpmHZx76w0yNESfIhh_wTJySjz-mKR7CFdFtVnw97jck4mqU9nRZTvKCka2UhjkuJp_MXPSgQofOdPm0lk9HwacALZVEwxnT2q4HtWq8MZM2NkcV3AMirow8p8Cwx8LPdWJhWXr_cF90Y8zoI_zloCxmFRFhUwZrCGb9FE7WKUAN363-kDEt-63NLYQ8lt7YAFU8w 2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImRlNmRhOTdlLWViNTUtNDgzZi1hMTY1LWIzOTlmY2NjNmUxZSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD== 2025-02-28 00:20:31.518 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.g92Uywmjq_hgvI9ZHINo6wtzQz7P_NUW1LkVFL-MbxGk4X0T9wvLm5PmCELi_KCwcaVHoRO3ntyZBlMqXG0sFLB9k_NHgmBtKNuvdoUyl1gj79SIXmN6F0pOBOKbj3kpYVKe_ksNzkLgcC0NilHbOnNi35jJwKw-zfScV1bxePf4ba1U-leVXCl7EOl3cQ2n4kjxqHfAd8js1oFNgA79loGPu1aYD4R-RJwnAs-PtaVdmIpAk2X8u2qXnfWZXSGiMuPZbuQhik1P2Ypkq1X3oO8rpx4craAuupzk97xDOMfOcIggYfWKE9G-qXprp16aBpNYVnyP6oex2JCVJhrC3g\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImZjYThjMDNkLTUwMWQtNGViMS04N2JjLTJhYTI5ZTJmYTRlZCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"d4eee4a1-3da5-4ab8-a7b3-62c5356b5d74\",\"refresh_token_expires_in\":7199}" 2025-02-28 00:33:25.684 - debug: garmin.0 (2133783) Refresh token 2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:20:30.921Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:20:30.921Z","sameSite":"none"},{"key":"JWT_FGP","value":"7fe4bd67-6230-4d20-b739-1f2abd78f1bc","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T21:24:18.016Z","lastAccessed":"2025-02-27T23:33:25.685Z"}]} 2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.g92Uywmjq_hgvI9ZHINo6wtzQz7P_NUW1LkVFL-MbxGk4X0T9wvLm5PmCELi_KCwcaVHoRO3ntyZBlMqXG0sFLB9k_NHgmBtKNuvdoUyl1gj79SIXmN6F0pOBOKbj3kpYVKe_ksNzkLgcC0NilHbOnNi35jJwKw-zfScV1bxePf4ba1U-leVXCl7EOl3cQ2n4kjxqHfAd8js1oFNgA79loGPu1aYD4R-RJwnAs-PtaVdmIpAk2X8u2qXnfWZXSGiMuPZbuQhik1P2Ypkq1X3oO8rpx4craAuupzk97xDOMfOcIggYfWKE9G-qXprp16aBpNYVnyP6oex2JCVJhrC3g 2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImZjYThjMDNkLTUwMWQtNGViMS04N2JjLTJhYTI5ZTJmYTRlZCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD== 2025-02-28 00:33:26.324 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInRASDsdfsdverzbezbdgvI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"d396d226-0b4a-4627-a1fa-3975e5f1a6ad\",\"refresh_token_expires_in\":7199}" 2025-02-28 00:43:13.708 - error: garmin.0 (2133783) https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-27 2025-02-28 00:43:13.708 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:13.708 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.088 - error: garmin.0 (2133783) https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-27/2025-02-27 2025-02-28 00:43:14.088 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.088 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.242 - error: garmin.0 (2133783) https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-27 2025-02-28 00:43:14.242 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.242 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.395 - error: garmin.0 (2133783) https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030 2025-02-28 00:43:14.396 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.396 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.543 - error: garmin.0 (2133783) https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical 2025-02-28 00:43:14.543 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.543 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.690 - error: garmin.0 (2133783) https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-27&nonSleepBufferMinutes=60 2025-02-28 00:43:14.690 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.690 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.837 - error: garmin.0 (2133783) https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-27 2025-02-28 00:43:14.838 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.838 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:14.986 - error: garmin.0 (2133783) https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-21 2025-02-28 00:43:14.986 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:14.986 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:15.159 - error: garmin.0 (2133783) https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-27 2025-02-28 00:43:15.160 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:15.160 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:15.307 - error: garmin.0 (2133783) https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10 2025-02-28 00:43:15.308 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:15.308 - error: garmin.0 (2133783) undefined 2025-02-28 00:43:15.451 - error: garmin.0 (2133783) https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-21&endDate=2025-02-27 2025-02-28 00:43:15.451 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized) 2025-02-28 00:43:15.451 - error: garmin.0 (2133783) undefined 2025-02-28 00:46:20.452 - debug: garmin.0 (2133783) Refresh token 2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"JWT_FGP","value":"983a4a62-9e24-40ea-89ef-c57b224611fa","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:46:20.452Z"}]} 2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA 2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD== 2025-02-28 00:46:21.181 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVdtzbudzbdbtZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"c08f4f2e-08bf-4022-afff-273700e389b7\",\"refresh_token_expires_in\":7199}" 2025-02-28 00:59:15.219 - debug: garmin.0 (2133783) Refresh token
@bommel_030 mmh und nach dem zweiten refresh geht es dann wieder?
@tombox
Danach geht es wieder. Die nächsten Zeilen vom LOG direkt im Anschluss wenn das was hilft.
2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"JWT_FGP","value":"983a4a62-9e24-40ea-89ef-c57b224611fa","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:46:20.452Z"}]} 2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA 2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ== 2025-02-28 00:46:21.181 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"c08f4f2e-08bf-4022-afff-273700e389b7\",\"refresh_token_expires_in\":7199}" 2025-02-28 00:59:15.219 - debug: garmin.0 (2133783) Refresh token 2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:46:20.455Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:46:20.455Z","sameSite":"none"},{"key":"JWT_FGP","value":"af387cb9-d3a3-41b3-8c89-a668d7401461","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:59:15.219Z"}]} 2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg 2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ== 2025-02-28 00:59:16.148 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.CYPtRMD30ZXSlqlMAvw2Dj7z4yKqyUyuWOnbCLz3UYBj64QvREE9N3XXER3OjlZcBUNiKuc5xirbslTnnPS2P-DOX6UAxiE6Ads-Q-L_zgE59z-1GxWV23TUWl2mxwj-I257mwP-1q2ixj95E4C_ge1xQ5Q-JbLNpBIQZponcm2sx-Oirub4vwgGY9gQELLtCsJS1jslnfKgDs5YH53tm5xS8MXC2VP-J3ZIoFNTO3q1xC9No_YDN-98aAE2Ra-2o19oBFCwO7wcldLpf01ldqvWyzX1AFApC-FCrmrNXGTuge9XYVFKi83DWLcNUSgHpzJ5H07rYD2lCTJu5uv2Bw\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImFjNThjNmEyLWJiNjYtNDQ4Yy05ZGUzLTQ5MDEyZTAyODY3YyIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"4b3be690-0ef3-4ddd-b93e-8ea8d391c52d\",\"refresh_token_expires_in\":7199}" 2025-02-28 01:12:09.985 - debug: garmin.0 (2133783) Refresh token 2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:59:15.223Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:59:15.223Z","sameSite":"none"},{"key":"JWT_FGP","value":"05589760-e24e-46f8-a04f-b85cb72a10e6","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-28T00:12:09.985Z"}]} 2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.CYPtRMD30ZXSlqlMAvw2Dj7z4yKqyUyuWOnbCLz3UYBj64QvREE9N3XXER3OjlZcBUNiKuc5xirbslTnnPS2P-DOX6UAxiE6Ads-Q-L_zgE59z-1GxWV23TUWl2mxwj-I257mwP-1q2ixj95E4C_ge1xQ5Q-JbLNpBIQZponcm2sx-Oirub4vwgGY9gQELLtCsJS1jslnfKgDs5YH53tm5xS8MXC2VP-J3ZIoFNTO3q1xC9No_YDN-98aAE2Ra-2o19oBFCwO7wcldLpf01ldqvWyzX1AFApC-FCrmrNXGTuge9XYVFKi83DWLcNUSgHpzJ5H07rYD2lCTJu5uv2Bw 2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImFjNThjNmEyLWJiNjYtNDQ4Yy05ZGUzLTQ5MDEyZTAyODY3YyIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ== 2025-02-28 01:12:10.684 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.eyJzY29wZSI6WyJDT01NVU5JVFlfQ09VUlNFX1JFQUQiLCJHT0xGX0FQSV9SRUFEIiwiR0hTX0hJRCIsIkFUUF9SRUFEIiwiRElWRV9BUElfV1JJVEUiLCJHSFNfU0FNRCIsIklOU0lHSFRTX1JFQUQiLCJESVZFX0FQSV9SRUFEIiwiRElWRV9BUElfSU1BR0VfUFJFVklFVyIsIkNPTU1VTklUWV9DT1VSU0VfV1JJVEUiLCJDT05ORUNUX1dSSVRFIiwiRElWRV9TSEFSRURfUkVBRCIsIkdIU19SRUdJU1RSQVRJT04iLCJEVF9DTElFTlRfQU5BTFlUSUNTX1dSSVRFIiwiR09MRl9BUElfV1JJVEUiLCJJTlNJR0hUU19XUklURSIsIlBST0RVQ1RfU0VBUkNIX1JFQUQiLCJHT0xGX1NIQVJFRF9SRUFEIiwiT01UX0NBTVBBSUdOX1JFQUQiLCJPTVRfU1VCU0NSSVBUSU9OX1JFQUQiLCJDT05ORUNUX05PTl9TT0NJQUxfU0hBUkVEX1JFQUQiLCJDT05ORUNUX1JFQUQiLCJBVFBfV1JJVEUiXSwiaXNzIjoiaHR0cHM6Ly9kaWF1dGguZ2FybWluLmNvbSIsInJldm9jYXRpb25fZWxpZ2liaWxpdHkiOlsiR0xPQkFMX1NJR05PVVQiXSwiY2xpZW50X3R5cGUiOiJVTkRFRklORUQiLCJleHAiOjE3NDA3MDUxMzAsImlhdCI6MTc0MDcwMTUzMCwiZ2FybWluX2d1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUiLCJqdGkiOiJiZThhOWNkNC01YzljLTQ5YmEtOTNmZS1hOTFjOWJmMWI5ZmUiLCJjbGllbnRfaWQiOiJDT05ORUNUX1dFQiIsImZncCI6IjdhNGY0MDk1ODcwODgwMmUzYTFhNWU1OTE5YjE4NDdiZDg1OGYxMTdmYzEyZGJkYmUwY2Y2MTgzNzkyYTA3MTMifQ.TRYFENyJT0pBz4kqnkATNbG5EV-rb_2NJEsemuPlbOeWV89rOoVW0WJ5N1WXuvbCN3HYibS6Lnwg7nqvExbdBSBAH1MbtVNb8xSDlq2HdMjyYhwcC66W-wy0g9ciXCX6P1kyUcwdayD6LMSxJI_SQ9FE6KzUqOpxjX2JGq7myg38QGSXVDjFJpffcfb4Mvg2F4pMeK5uiPyj9K5lWlmMo4rinnWeKuRW7lx9tIaEJ7lqs6hSGNCSw4yXWXKEp3k4wZrX16WyvN6E9djYoYrlvjCxR6y3oQ3CTzUpsbUFc7o2Pp7Lz5j6F7k9Yx8He3gnUDtKQ1QsUiEZAIDqlHYXLw\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImRmOGRiOTg1LTVjMTktNDQ4Zi05ZGQ1LTEyMGViMzhmZGYzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"be8a9cd4-5c9c-49ba-93fe-a91c9bf1b9fe\",\"refresh_token_expires_in\":7199}" 2025-02-28 01:13:14.544 - debug: garmin.0 (2133783) {"userProfileId":2400759,"totalKilocalories":27,"activeKilocalories":0,"bmrKilocalories":27,"wellnessKilocalories":27,"burnedKilocalories":null,"consumedKilocalories":null,"remainingKilocalories":1500,"totalSteps":null,"netCalorieGoal":1500,"totalDistanceMeters":null,"wellnessDistanceMeters":null,"wellnessActiveKilocalories":0,"netRemainingKilocalories":1500,"userDailySummaryId":2400759,"calendarDate":"2025-02-28","rule":{"typeId":3,"typeKey":"subscribers"},"uuid":"3cc5c04cce824a92bf67d8616a334a6e","dailyStepGoal":14280,"wellnessStartTimeGmt":"2025-02-27T23:00:00.0","wellnessStartTimeLocal":"2025-02-28T00:00:00.0","wellnessEndTimeGmt":"2025-02-27T23:18:00.0","wellnessEndTimeLocal":"2025-02-28T00:18:00.0","durationInMilliseconds":1080000,"wellnessDescription":null,"highlyActiveSeconds":0,"activeSeconds":0,"sedentarySeconds":1080,"sleepingSeconds":0,"includesWellnessData":true,"includesActivityData":false,"includesCalorieConsumedData":false,"privacyProtected":false,"moderateIntensityMinutes":0,"vigorousIntensityMinutes":0,"floorsAscendedInMeters":0,"floorsDescendedInMeters":0,"floorsAscended":0,"floorsDescended":0,"intensityMinutesGoal":150,"userFloorsAscendedGoal":10,"minHeartRate":68,"maxHeartRate":70,"restingHeartRate":67,"lastSevenDaysAvgRestingHeartRate":63,"source":"GARMIN","averageStressLevel":26,"maxStressLevel":28,"stressDuration":720,"restStressDuration":360,"activityStressDuration":null,"uncategorizedStressDuration":null,"totalStressDuration":1080,"lowStressDuration":720,"mediumStressDuration":null,"highStressDuration":null,"stressPercentage":66.67,"restStressPercentage":33.33,"activityStressPercentage":0,"uncategorizedStressPercentage":0,"lowStressPercentage":66.67,"mediumStressPercentage":0,"highStressPercentage":0,"stressQualifier":"UNKNOWN","measurableAwakeDuration":1080,"measurableAsleepDuration":0,"lastSyncTimestampGMT":"2025-02-27T23:18:53.423","minAvgHeartRate":69,"maxAvgHeartRate":70,"bodyBatteryChargedValue":0,"bodyBatteryDrainedValue":0,"bodyBatteryHighestValue":5,"bodyBatteryLowestValue":5,"bodyBatteryMostRecentValue":5,"bodyBatteryDuringSleep":null,"bodyBatteryAtWakeTime":null,"bodyBatteryVersion":2,"abnormalHeartRateAlertsCount":null,"averageSpo2":90,"lowestSpo2":87,"latestSpo2":91,"latestSpo2ReadingTimeGmt":"2025-02-27T23:18:00.0","latestSpo2ReadingTimeLocal":"2025-02-28T00:18:00.0","averageMonitoringEnvironmentAltitude":-4,"restingCaloriesFromActivity":null,"avgWakingRespirationValue":14,"highestRespirationValue":16,"lowestRespirationValue":12,"latestRespirationValue":16,"latestRespirationTimeGMT":"2025-02-27T23:18:00.0","respirationAlgorithmVersion":100} 2025-02-28 01:13:14.555 - debug: garmin.0 (2133783) Type changed for usersummary.totalSteps from number to mixed 2025-02-28 01:13:14.561 - debug: garmin.0 (2133783) Type changed for usersummary.totalDistanceMeters from number to mixed 2025-02-28 01:13:14.566 - debug: garmin.0 (2133783) Type changed for usersummary.wellnessDistanceMeters from number to mixed 2025-02-28 01:13:14.618 - debug: garmin.0 (2133783) Type changed for usersummary.activityStressDuration from number to mixed 2025-02-28 01:13:14.622 - debug: garmin.0 (2133783) Type changed for usersummary.uncategorizedStressDuration from mixed to mixed 2025-02-28 01:13:14.629 - debug: garmin.0 (2133783) Type changed for usersummary.mediumStressDuration from mixed to mixed 2025-02-28 01:13:14.653 - debug: garmin.0 (2133783) Type changed for usersummary.bodyBatteryDuringSleep from mixed to mixed 2025-02-28 01:13:14.657 - debug: garmin.0 (2133783) Type changed for usersummary.bodyBatteryAtWakeTime from mixed to mixed 2025-02-28 01:13:14.671 - debug: garmin.0 (2133783) Type changed for usersummary.restingCaloriesFromActivity from mixed to mixed 2025-02-28 01:13:14.712 - debug: garmin.0 (2133783) [] 2025-02-28 01:13:14.893 - debug: garmin.0 (2133783) {"userId":2400759,"calendarDate":"2025-02-28","valueInML":null,"goalInML":2800,"dailyAverageinML":null,"lastEntryTimestampLocal":null,"sweatLossInML":null,"activityIntakeInML":null} 2025-02-28 01:13:14.899 - debug: garmin.0 (2133783) Type changed for hydration.valueInML from mixed to mixed 2025-02-28 01:13:14.907 - debug: garmin.0 (2133783) Type changed for hydration.sweatLossInML from mixed to mixed 2025-02-28 01:13:14.911 - debug: garmin.0 (2133783) Type changed for hydration.activityIntakeInML from mixed to mixed
@bommel_030 siehst du ein Muster wan es auftritt
@bommel_030 nein leider immer nur wenige Stunden.
@tombox
Naja, exakt alle 2,5 h kommen die Meldungen.
Ob das jetzt zufällig mit dem 30min Abrufintervall zusammenfällt, oder die Anzahl der Abrufe ist kann ich nicht sagen.
Sobald ich wieder an nem PC sitze schraube ich das Abrufintervall Mal runter.
Es ist auch kein zeitlicher Zusammenhang zu refresh Token und 401 zu sehen. Das was er an Daten abruft scheint damit nichts zu tun zu haben. -
@bommel_030 Ja refresh Token funktioniert immer ohne Probleme Vielleicht tmla das interval 15 oder so setzen
@tombox
Intervall ist jetzt auf 15min und er holt nach dem Start auch Daten.garmin has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
Die Meldung kommt noch beim Start. Ist mir vorher im Log Level Debug scheinbar nicht aufgefallen.
