    4. Test Adapter Garmin
    Test Adapter Garmin
      bommel_030 @tombox last edited by
      @tombox
      Leider das gleiche Ergebnis.
      Er macht alle 13 Minuten einen "Refresh Token". Das versucht er auch nach dem "Absturz" weiter.
      10:29 das letzte Mal aktuelle Daten abgerufen, nächster Durchlauf 10:59 mit Fehler (siehe unten).
      garmin.0
      2025-02-25 11:04:19.305	debug	HTTPError: Response code 500 (Internal Server Error)
      garmin.0
      2025-02-25 11:04:19.305	error	FGP missmatch. Please logout and login in garmin and update FGP in the settings
      garmin.0
      2025-02-25 11:04:19.305	debug	[object Object]
      garmin.0
      2025-02-25 11:04:18.473	debug	Refresh token
      garmin.0
      2025-02-25 10:59:46.707	error	undefined
      garmin.0
      2025-02-25 10:59:46.707	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:46.706	error	https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-19&endDate=2025-02-25
      garmin.0
      2025-02-25 10:59:46.561	error	undefined
      garmin.0
      2025-02-25 10:59:46.561	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:46.561	error	https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10
      garmin.0
      2025-02-25 10:59:46.418	error	undefined
      garmin.0
      2025-02-25 10:59:46.418	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:46.418	error	https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-25
      garmin.0
      2025-02-25 10:59:46.250	error	undefined
      garmin.0
      2025-02-25 10:59:46.250	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:46.250	error	https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-19
      garmin.0
      2025-02-25 10:59:46.051	error	undefined
      garmin.0
      2025-02-25 10:59:46.051	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:46.051	error	https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-25
      garmin.0
      2025-02-25 10:59:45.897	error	undefined
      garmin.0
      2025-02-25 10:59:45.896	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:45.896	error	https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-25&nonSleepBufferMinutes=60
      garmin.0
      2025-02-25 10:59:45.751	error	undefined
      garmin.0
      2025-02-25 10:59:45.751	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:45.750	error	https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical
      garmin.0
      2025-02-25 10:59:45.582	error	undefined
      garmin.0
      2025-02-25 10:59:45.582	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:45.581	error	https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030
      garmin.0
      2025-02-25 10:59:45.435	error	undefined
      garmin.0
      2025-02-25 10:59:45.435	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:45.435	error	https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-25
      garmin.0
      2025-02-25 10:59:45.013	error	undefined
      garmin.0
      2025-02-25 10:59:45.013	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:45.013	error	https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-25/2025-02-25
      garmin.0
      2025-02-25 10:59:44.848	error	undefined
      garmin.0
      2025-02-25 10:59:44.847	error	HTTPError: Response code 401 (Unauthorized)
      garmin.0
      2025-02-25 10:59:44.847	error	https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-25
      garmin.0
      2025-02-25 10:51:24.308	debug	HTTPError: Response code 500 (Internal Server Error)
      garmin.0
      2025-02-25 10:51:24.308	error	FGP missmatch. Please logout and login in garmin and update FGP in the settings
      garmin.0
      2025-02-25 10:51:24.307	debug	[object Object]
      garmin.0
      2025-02-25 10:51:23.706	debug	Refresh token
        tombox @bommel_030 last edited by
        @bommel_030 sollte mit der GitHub version gefixt werden
          @tombox
          Leider nein. Nach 2h ist mit 401 wieder Ende.
          Hab mir noch die Zugangsdaten für einen weiteren Account besorgt, da ist das gleiche Fehlerbild.
            @bommel_030 Mit version 1c2f1c714442701166c9aa2304b4fe6b87de6d83 ?
              @tombox
              Die neueste Version eigentlich...
              Kann ich die Nummer über den Admin auslesen?
              Hab gerade noch mal die GitHub Version installiert und starte noch Mal einen Durchlauf.
                @bommel_030 steht im log wenn der adapter gestartet wird
                  @tombox
                  Also...
                  Adapter noch mal installeirt...
                  Erster Abruf 12:43, Aktualisierung alle 30 min, Refresh token alle 13min.
                  14:39 ein erfolgreicher "Refresh Token", 14:43 Fehler 401.
                  Da ich im Meeting war konnte ich nicht nachsehen bzw. den Adapter stoppen.
                  14:52 dann wieder ein erfolgreicher "Refresh Token" und 15:13 wieder ein erfolgreicher Abruf...
                  Ich schau mal was in 2h passiert...
                    @tombox
                    Der Adapter ruft jetzt seit gestern durchgehend Daten ab. Alle 2h haut er aber das LOG voll.
                    2025-02-28 10:33:05.017	error	undefined
                    2025-02-28 10:33:05.017	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:05.017	error	https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-22&endDate=2025-02-28
                    2025-02-28 10:33:04.870	error	undefined
                    2025-02-28 10:33:04.870	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:04.870	error	https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10
                    2025-02-28 10:33:04.717	error	undefined
                    2025-02-28 10:33:04.717	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:04.717	error	https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-28
                    2025-02-28 10:33:04.199	error	undefined
                    2025-02-28 10:33:04.198	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:04.198	error	https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-22
                    2025-02-28 10:33:04.032	error	undefined
                    2025-02-28 10:33:04.032	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:04.032	error	https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-28
                    2025-02-28 10:33:03.883	error	undefined
                    2025-02-28 10:33:03.883	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:03.883	error	https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-28&nonSleepBufferMinutes=60
                    2025-02-28 10:33:03.730	error	undefined
                    2025-02-28 10:33:03.730	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:03.730	error	https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical
                    2025-02-28 10:33:03.568	error	undefined
                    2025-02-28 10:33:03.568	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:03.568	error	https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030
                    2025-02-28 10:33:03.380	error	undefined
                    2025-02-28 10:33:03.380	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:03.380	error	https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-28
                    2025-02-28 10:33:03.224	error	undefined
                    2025-02-28 10:33:03.224	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:03.224	error	https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-28/2025-02-28
                    2025-02-28 10:33:03.072	error	undefined
                    2025-02-28 10:33:03.072	error	HTTPError: Response code 401 (Unauthorized)
                    2025-02-28 10:33:03.072	error	https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-28
                    Kann man das noch irgendwie abfangen? Wenn nicht, die Logstufe evtl. auf "Warn" setzen?
                      @bommel_030 Wenn das kommt sollten aber keine Daten reinkommen oder
                        @tombox
                        Nein, bei dem Abruf der den Fehler 401 erzeugt kommen keine Daten. Bei dem darauffolgenden kommen dann wieder Daten.
                          @bommel_030 hast du ein größeren log ausschnitt mit refresh token
                            @tombox
                            Mit refresh vor und nach 401. Reicht das?
                            2025-02-28 00:20:30.918 - debug: garmin.0 (2133783) Refresh token
                            2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:13:16.024Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:13:16.024Z","sameSite":"none"},{"key":"JWT_FGP","value":"a90b9183-b21b-4477-a473-6b4346295d77","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T21:24:18.016Z","lastAccessed":"2025-02-27T23:20:30.918Z"},{"key":"ADRUM_BTa","value":"R:0|g:e5a90d46-5b0e-4249-be6a-ebe67936c980|n:garmin_869629ee-d273-481d-b5a4-f4b0a8c4d5a3","expires":"2025-02-27T23:13:45.000Z","maxAge":30,"domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":true,"creation":"2025-02-27T23:13:14.122Z","lastAccessed":"2025-02-27T23:13:16.024Z"},{"key":"ADRUM_BT1","value":"R:0|i:137465|e:23|t:1740697995888","expires":"2025-02-27T23:13:45.000Z","maxAge":30,"domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":true,"creation":"2025-02-27T23:13:14.122Z","lastAccessed":"2025-02-27T23:13:16.024Z"}]}
                            2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.ZVboYSNZS-o7BgcCmfggSwzN_8_odrsX97qdCrhEwWTcVjsVjjxhrbKnbMbvGZ2Iu2-JdY4v2YWpxe1ghApY2ag4t84UQcIUmMewqkTnmTeBM_ggSEK6ix3NyiVjpDkbLnoXeOuyYI8mSCEX0jpmHZx76w0yNESfIhh_wTJySjz-mKR7CFdFtVnw97jck4mqU9nRZTvKCka2UhjkuJp_MXPSgQofOdPm0lk9HwacALZVEwxnT2q4HtWq8MZM2NkcV3AMirow8p8Cwx8LPdWJhWXr_cF90Y8zoI_zloCxmFRFhUwZrCGb9FE7WKUAN363-kDEt-63NLYQ8lt7YAFU8w
                            2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImRlNmRhOTdlLWViNTUtNDgzZi1hMTY1LWIzOTlmY2NjNmUxZSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==
                            2025-02-28 00:20:31.518 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.g92Uywmjq_hgvI9ZHINo6wtzQz7P_NUW1LkVFL-MbxGk4X0T9wvLm5PmCELi_KCwcaVHoRO3ntyZBlMqXG0sFLB9k_NHgmBtKNuvdoUyl1gj79SIXmN6F0pOBOKbj3kpYVKe_ksNzkLgcC0NilHbOnNi35jJwKw-zfScV1bxePf4ba1U-leVXCl7EOl3cQ2n4kjxqHfAd8js1oFNgA79loGPu1aYD4R-RJwnAs-PtaVdmIpAk2X8u2qXnfWZXSGiMuPZbuQhik1P2Ypkq1X3oO8rpx4craAuupzk97xDOMfOcIggYfWKE9G-qXprp16aBpNYVnyP6oex2JCVJhrC3g\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImZjYThjMDNkLTUwMWQtNGViMS04N2JjLTJhYTI5ZTJmYTRlZCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"d4eee4a1-3da5-4ab8-a7b3-62c5356b5d74\",\"refresh_token_expires_in\":7199}"
                            2025-02-28 00:33:25.684 - debug: garmin.0 (2133783) Refresh token
                            2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:20:30.921Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:20:30.921Z","sameSite":"none"},{"key":"JWT_FGP","value":"7fe4bd67-6230-4d20-b739-1f2abd78f1bc","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T21:24:18.016Z","lastAccessed":"2025-02-27T23:33:25.685Z"}]}
                            2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.g92Uywmjq_hgvI9ZHINo6wtzQz7P_NUW1LkVFL-MbxGk4X0T9wvLm5PmCELi_KCwcaVHoRO3ntyZBlMqXG0sFLB9k_NHgmBtKNuvdoUyl1gj79SIXmN6F0pOBOKbj3kpYVKe_ksNzkLgcC0NilHbOnNi35jJwKw-zfScV1bxePf4ba1U-leVXCl7EOl3cQ2n4kjxqHfAd8js1oFNgA79loGPu1aYD4R-RJwnAs-PtaVdmIpAk2X8u2qXnfWZXSGiMuPZbuQhik1P2Ypkq1X3oO8rpx4craAuupzk97xDOMfOcIggYfWKE9G-qXprp16aBpNYVnyP6oex2JCVJhrC3g
                            2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImZjYThjMDNkLTUwMWQtNGViMS04N2JjLTJhYTI5ZTJmYTRlZCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==
                            2025-02-28 00:33:26.324 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInRASDsdfsdverzbezbdgvI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"d396d226-0b4a-4627-a1fa-3975e5f1a6ad\",\"refresh_token_expires_in\":7199}"
                            2025-02-28 00:43:13.708 - error: garmin.0 (2133783) https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-27
                            2025-02-28 00:43:13.708 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:13.708 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.088 - error: garmin.0 (2133783) https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-27/2025-02-27
                            2025-02-28 00:43:14.088 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.088 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.242 - error: garmin.0 (2133783) https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-27
                            2025-02-28 00:43:14.242 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.242 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.395 - error: garmin.0 (2133783) https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030
                            2025-02-28 00:43:14.396 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.396 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.543 - error: garmin.0 (2133783) https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical
                            2025-02-28 00:43:14.543 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.543 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.690 - error: garmin.0 (2133783) https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-27&nonSleepBufferMinutes=60
                            2025-02-28 00:43:14.690 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.690 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.837 - error: garmin.0 (2133783) https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-27
                            2025-02-28 00:43:14.838 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.838 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:14.986 - error: garmin.0 (2133783) https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-21
                            2025-02-28 00:43:14.986 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:14.986 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:15.159 - error: garmin.0 (2133783) https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-27
                            2025-02-28 00:43:15.160 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:15.160 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:15.307 - error: garmin.0 (2133783) https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10
                            2025-02-28 00:43:15.308 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:15.308 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:43:15.451 - error: garmin.0 (2133783) https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-21&endDate=2025-02-27
                            2025-02-28 00:43:15.451 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
                            2025-02-28 00:43:15.451 - error: garmin.0 (2133783) undefined
                            2025-02-28 00:46:20.452 - debug: garmin.0 (2133783) Refresh token
                            2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"JWT_FGP","value":"983a4a62-9e24-40ea-89ef-c57b224611fa","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:46:20.452Z"}]}
                            2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA
                            2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==
                            2025-02-28 00:46:21.181 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVdtzbudzbdbtZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"c08f4f2e-08bf-4022-afff-273700e389b7\",\"refresh_token_expires_in\":7199}"
                            2025-02-28 00:59:15.219 - debug: garmin.0 (2133783) Refresh token
                              @bommel_030 mmh und nach dem zweiten refresh geht es dann wieder?
                                @tombox
                                Danach geht es wieder. Die nächsten Zeilen vom LOG direkt im Anschluss wenn das was hilft.
                                2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==
                                2025-02-28 00:46:21.181 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"c08f4f2e-08bf-4022-afff-273700e389b7\",\"refresh_token_expires_in\":7199}"
                                2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:46:20.455Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:46:20.455Z","sameSite":"none"},{"key":"JWT_FGP","value":"af387cb9-d3a3-41b3-8c89-a668d7401461","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:59:15.219Z"}]}
                                2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg
                                2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==
                                2025-02-28 00:59:16.148 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.CYPtRMD30ZXSlqlMAvw2Dj7z4yKqyUyuWOnbCLz3UYBj64QvREE9N3XXER3OjlZcBUNiKuc5xirbslTnnPS2P-DOX6UAxiE6Ads-Q-L_zgE59z-1GxWV23TUWl2mxwj-I257mwP-1q2ixj95E4C_ge1xQ5Q-JbLNpBIQZponcm2sx-Oirub4vwgGY9gQELLtCsJS1jslnfKgDs5YH53tm5xS8MXC2VP-J3ZIoFNTO3q1xC9No_YDN-98aAE2Ra-2o19oBFCwO7wcldLpf01ldqvWyzX1AFApC-FCrmrNXGTuge9XYVFKi83DWLcNUSgHpzJ5H07rYD2lCTJu5uv2Bw\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImFjNThjNmEyLWJiNjYtNDQ4Yy05ZGUzLTQ5MDEyZTAyODY3YyIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"4b3be690-0ef3-4ddd-b93e-8ea8d391c52d\",\"refresh_token_expires_in\":7199}"
                                2025-02-28 01:12:09.985 - debug: garmin.0 (2133783) Refresh token
                                2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:59:15.223Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:59:15.223Z","sameSite":"none"},{"key":"JWT_FGP","value":"05589760-e24e-46f8-a04f-b85cb72a10e6","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-28T00:12:09.985Z"}]}
                                2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.CYPtRMD30ZXSlqlMAvw2Dj7z4yKqyUyuWOnbCLz3UYBj64QvREE9N3XXER3OjlZcBUNiKuc5xirbslTnnPS2P-DOX6UAxiE6Ads-Q-L_zgE59z-1GxWV23TUWl2mxwj-I257mwP-1q2ixj95E4C_ge1xQ5Q-JbLNpBIQZponcm2sx-Oirub4vwgGY9gQELLtCsJS1jslnfKgDs5YH53tm5xS8MXC2VP-J3ZIoFNTO3q1xC9No_YDN-98aAE2Ra-2o19oBFCwO7wcldLpf01ldqvWyzX1AFApC-FCrmrNXGTuge9XYVFKi83DWLcNUSgHpzJ5H07rYD2lCTJu5uv2Bw
                                2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImFjNThjNmEyLWJiNjYtNDQ4Yy05ZGUzLTQ5MDEyZTAyODY3YyIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==
                                2025-02-28 01:12:10.684 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.TRYFENyJT0pBz4kqnkATNbG5EV-rb_2NJEsemuPlbOeWV89rOoVW0WJ5N1WXuvbCN3HYibS6Lnwg7nqvExbdBSBAH1MbtVNb8xSDlq2HdMjyYhwcC66W-wy0g9ciXCX6P1kyUcwdayD6LMSxJI_SQ9FE6KzUqOpxjX2JGq7myg38QGSXVDjFJpffcfb4Mvg2F4pMeK5uiPyj9K5lWlmMo4rinnWeKuRW7lx9tIaEJ7lqs6hSGNCSw4yXWXKEp3k4wZrX16WyvN6E9djYoYrlvjCxR6y3oQ3CTzUpsbUFc7o2Pp7Lz5j6F7k9Yx8He3gnUDtKQ1QsUiEZAIDqlHYXLw\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImRmOGRiOTg1LTVjMTktNDQ4Zi05ZGQ1LTEyMGViMzhmZGYzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"be8a9cd4-5c9c-49ba-93fe-a91c9bf1b9fe\",\"refresh_token_expires_in\":7199}"
                                2025-02-28 01:13:14.544 - debug: garmin.0 (2133783) {"userProfileId":2400759,"totalKilocalories":27,"activeKilocalories":0,"bmrKilocalories":27,"wellnessKilocalories":27,"burnedKilocalories":null,"consumedKilocalories":null,"remainingKilocalories":1500,"totalSteps":null,"netCalorieGoal":1500,"totalDistanceMeters":null,"wellnessDistanceMeters":null,"wellnessActiveKilocalories":0,"netRemainingKilocalories":1500,"userDailySummaryId":2400759,"calendarDate":"2025-02-28","rule":{"typeId":3,"typeKey":"subscribers"},"uuid":"3cc5c04cce824a92bf67d8616a334a6e","dailyStepGoal":14280,"wellnessStartTimeGmt":"2025-02-27T23:00:00.0","wellnessStartTimeLocal":"2025-02-28T00:00:00.0","wellnessEndTimeGmt":"2025-02-27T23:18:00.0","wellnessEndTimeLocal":"2025-02-28T00:18:00.0","durationInMilliseconds":1080000,"wellnessDescription":null,"highlyActiveSeconds":0,"activeSeconds":0,"sedentarySeconds":1080,"sleepingSeconds":0,"includesWellnessData":true,"includesActivityData":false,"includesCalorieConsumedData":false,"privacyProtected":false,"moderateIntensityMinutes":0,"vigorousIntensityMinutes":0,"floorsAscendedInMeters":0,"floorsDescendedInMeters":0,"floorsAscended":0,"floorsDescended":0,"intensityMinutesGoal":150,"userFloorsAscendedGoal":10,"minHeartRate":68,"maxHeartRate":70,"restingHeartRate":67,"lastSevenDaysAvgRestingHeartRate":63,"source":"GARMIN","averageStressLevel":26,"maxStressLevel":28,"stressDuration":720,"restStressDuration":360,"activityStressDuration":null,"uncategorizedStressDuration":null,"totalStressDuration":1080,"lowStressDuration":720,"mediumStressDuration":null,"highStressDuration":null,"stressPercentage":66.67,"restStressPercentage":33.33,"activityStressPercentage":0,"uncategorizedStressPercentage":0,"lowStressPercentage":66.67,"mediumStressPercentage":0,"highStressPercentage":0,"stressQualifier":"UNKNOWN","measurableAwakeDuration":1080,"measurableAsleepDuration":0,"lastSyncTimestampGMT":"2025-02-27T23:18:53.423","minAvgHeartRate":69,"maxAvgHeartRate":70,"bodyBatteryChargedValue":0,"bodyBatteryDrainedValue":0,"bodyBatteryHighestValue":5,"bodyBatteryLowestValue":5,"bodyBatteryMostRecentValue":5,"bodyBatteryDuringSleep":null,"bodyBatteryAtWakeTime":null,"bodyBatteryVersion":2,"abnormalHeartRateAlertsCount":null,"averageSpo2":90,"lowestSpo2":87,"latestSpo2":91,"latestSpo2ReadingTimeGmt":"2025-02-27T23:18:00.0","latestSpo2ReadingTimeLocal":"2025-02-28T00:18:00.0","averageMonitoringEnvironmentAltitude":-4,"restingCaloriesFromActivity":null,"avgWakingRespirationValue":14,"highestRespirationValue":16,"lowestRespirationValue":12,"latestRespirationValue":16,"latestRespirationTimeGMT":"2025-02-27T23:18:00.0","respirationAlgorithmVersion":100}
                                2025-02-28 01:13:14.555 - debug: garmin.0 (2133783) Type changed for usersummary.totalSteps from number to mixed
                                2025-02-28 01:13:14.561 - debug: garmin.0 (2133783) Type changed for usersummary.totalDistanceMeters from number to mixed
                                2025-02-28 01:13:14.566 - debug: garmin.0 (2133783) Type changed for usersummary.wellnessDistanceMeters from number to mixed
                                2025-02-28 01:13:14.618 - debug: garmin.0 (2133783) Type changed for usersummary.activityStressDuration from number to mixed
                                2025-02-28 01:13:14.622 - debug: garmin.0 (2133783) Type changed for usersummary.uncategorizedStressDuration from mixed to mixed
                                2025-02-28 01:13:14.629 - debug: garmin.0 (2133783) Type changed for usersummary.mediumStressDuration from mixed to mixed
                                2025-02-28 01:13:14.653 - debug: garmin.0 (2133783) Type changed for usersummary.bodyBatteryDuringSleep from mixed to mixed
                                2025-02-28 01:13:14.657 - debug: garmin.0 (2133783) Type changed for usersummary.bodyBatteryAtWakeTime from mixed to mixed
                                2025-02-28 01:13:14.671 - debug: garmin.0 (2133783) Type changed for usersummary.restingCaloriesFromActivity from mixed to mixed
                                2025-02-28 01:13:14.712 - debug: garmin.0 (2133783) []
                                2025-02-28 01:13:14.893 - debug: garmin.0 (2133783) {"userId":2400759,"calendarDate":"2025-02-28","valueInML":null,"goalInML":2800,"dailyAverageinML":null,"lastEntryTimestampLocal":null,"sweatLossInML":null,"activityIntakeInML":null}
                                2025-02-28 01:13:14.899 - debug: garmin.0 (2133783) Type changed for hydration.valueInML from mixed to mixed
                                2025-02-28 01:13:14.907 - debug: garmin.0 (2133783) Type changed for hydration.sweatLossInML from mixed to mixed
                                2025-02-28 01:13:14.911 - debug: garmin.0 (2133783) Type changed for hydration.activityIntakeInML from mixed to mixed
                                  @bommel_030 siehst du ein Muster wan es auftritt
                                    kirbsi @bommel_030 last edited by
                                    @bommel_030 nein leider immer nur wenige Stunden.
                                      @tombox
                                      Naja, exakt alle 2,5 h kommen die Meldungen.
                                      Ob das jetzt zufällig mit dem 30min Abrufintervall zusammenfällt, oder die Anzahl der Abrufe ist kann ich nicht sagen.
                                      Sobald ich wieder an nem PC sitze schraube ich das Abrufintervall Mal runter.
                                      Es ist auch kein zeitlicher Zusammenhang zu refresh Token und 401 zu sehen. Das was er an Daten abruft scheint damit nichts zu tun zu haben.
                                        @bommel_030 Ja refresh Token funktioniert immer ohne Probleme Vielleicht tmla das interval 15 oder so setzen
                                          @tombox
                                          Intervall ist jetzt auf 15min und er holt nach dem Start auch Daten.
                                          garmin has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
                                          Die Meldung kommt noch beim Start. Ist mir vorher im Log Level Debug scheinbar nicht aufgefallen.
                                            @tombox
                                            Joar, Fehlerbild bleibt gleich. Jetzt halt nach 2:15 statt nach 2:30. Scheint also nicht an der Anzahl der Abrufe zu liegen.
                                            31.7k
                                            79.8k
                                            141
                                            15948
