    • simatec
      simatec Developer Most Active @Negalein last edited by
      @negalein Gab es noch weitere Infos im Log?
      An welcher Stelle ist der fehler aufgetreten?
      • Negalein
        Negalein Global Moderator @simatec last edited by
        @simatec sagte in Test Adapter ioBroker.backitup v3.0.x:
        das ist alles
        23:12:22.043  - error: backitup.0 (479121) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        23:12:22.044  - error: backitup.0 (479121) unhandled promise rejection: undefined
        23:12:22.044  - error: backitup.0 (479121) Exception-Code: 429: undefined
        23:12:22.091  - warn: backitup.0 (479121) Terminated (UNCAUGHT_EXCEPTION): Without reason
        23:12:22.747  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        23:12:22.747  - error: host.ioBroker Caught by controller[1]: {
        23:12:22.747  - error: host.ioBroker Caught by controller[1]:   error_summary: 'too_many_requests/.',
        23:12:22.747  - error: host.ioBroker Caught by controller[1]:   error: { reason: { '.tag': 'too_many_requests' }, retry_after: 15 },
        23:12:22.747  - error: host.ioBroker Caught by controller[1]:   code: 429
        23:12:22.747  - error: host.ioBroker Caught by controller[1]: }
        23:12:22.747  - error: host.ioBroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        23:12:22.747  - info: host.ioBroker Restart adapter system.adapter.backitup.0 because enabled
        • simatec
          @negalein und kannst du sehen, bei welchem Backup der fehler passiert ist? Hattest du den debuglog von Backitup an?
          • Negalein
            nein, leider nicht 😞
            hab ihn seit Mitternacht aktiv.
            Werde heute beobachten.
              sigi234 Forum Testing Most Active @simatec last edited by sigi234
              @simatec
              Hallo, kann man das Backup von den History Adapter beim normalen Backup vom iob ausschließen?
              Ich möchte das History Backup nur manuell starten, was auch funktioniert.
              Windows System
              v3.0.27
              13:02:59.051INFOguiBackup gestartet ...
              13:03:07.440DEBUGiobrokerhost.SmartHome 24623 objects saved
              13:03:08.202DEBUGiobrokerhost.SmartHome 20996 states saved
              13:03:08.205DEBUGiobrokerhost.SmartHome Validating backup ...
              13:03:08.209DEBUGiobrokerhost.SmartHome "config.json" is valid
              13:03:08.215DEBUGiobrokerhost.SmartHome "objects.jsonl" exists
              13:03:08.220DEBUGiobrokerhost.SmartHome "states.jsonl" exists
              13:03:08.723DEBUGiobrokerhost.SmartHome JSONL lines are valid
              13:03:09.191DEBUGiobrokerhost.SmartHome The backup is valid!
              13:03:12.581DEBUGiobrokerBackup created: C:\SmartHome\backups\iobroker_2024_11_20-13_02_59_backupiobroker.tar.gz
              13:03:12.590DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
              13:03:13.642DEBUGiobrokerdone
              13:03:14.591DEBUGhistoryDBcompress from historyDB started ...
              13:03:24.584DEBUGhistoryDBPacked 225MB so far...
              13:03:34.592DEBUGhistoryDBPacked 460MB so far...
              13:03:44.583DEBUGhistoryDBPacked 696MB so far...
              13:03:54.583DEBUGhistoryDBPacked 933MB so far...
              13:04:04.582DEBUGhistoryDBPacked 1164MB so far...
              13:04:14.585DEBUGhistoryDBPacked 1404MB so far...
              13:04:24.606DEBUGhistoryDBPacked 1651MB so far...
              13:04:34.610DEBUGhistoryDBPacked 1873MB so far...
              13:04:44.582DEBUGhistoryDBPacked 2114MB so far...
              13:04:54.587DEBUGhistoryDBPacked 2363MB so far...
              13:05:04.595DEBUGhistoryDBPacked 2605MB so far...
              13:05:14.606DEBUGhistoryDBPacked 2839MB so far...
              13:05:24.595DEBUGhistoryDBPacked 3087MB so far...
              13:05:34.587DEBUGhistoryDBPacked 3332MB so far...
              13:05:44.602DEBUGhistoryDBPacked 3570MB so far...
              13:05:54.595DEBUGhistoryDBPacked 3811MB so far...
              13:06:04.586DEBUGhistoryDBPacked 4054MB so far...
              13:06:14.588DEBUGhistoryDBPacked 4275MB so far...
              13:06:24.615DEBUGhistoryDBPacked 4524MB so far...
              13:06:34.600DEBUGhistoryDBPacked 4771MB so far...
              13:06:44.586DEBUGhistoryDBPacked 5017MB so far...
              13:06:54.587DEBUGhistoryDBPacked 5267MB so far...
              13:07:04.587DEBUGhistoryDBPacked 5515MB so far...
              13:07:14.586DEBUGhistoryDBPacked 5755MB so far...
              13:07:24.600DEBUGhistoryDBPacked 6007MB so far...
              13:07:34.586DEBUGhistoryDBPacked 6256MB so far...
              13:07:44.596DEBUGhistoryDBPacked 6497MB so far...
              13:07:54.587DEBUGhistoryDBPacked 6743MB so far...
              13:08:04.600DEBUGhistoryDBPacked 6994MB so far...
              13:08:14.586DEBUGhistoryDBPacked 7233MB so far...
              13:08:24.595DEBUGhistoryDBPacked 7482MB so far...
              13:08:34.586DEBUGhistoryDBPacked 7731MB so far...
              13:08:44.587DEBUGhistoryDBPacked 7969MB so far...
              13:08:54.601DEBUGhistoryDBPacked 8219MB so far...
              13:09:04.595DEBUGhistoryDBPacked 8464MB so far...
              13:09:14.592DEBUGhistoryDBPacked 8695MB so far...
              13:09:14.668DEBUGhistoryDBBackup created: C:\SmartHome\backups\historyDB_2024_11_20-13_03_14_backupiobroker.tar.gz
              13:09:14.672DEBUGhistoryDBdone
              13:09:15.303DEBUGjarvisCreated jarvis_tmp directory: "C:/SmartHome/backups/tmpJavis0"
              13:09:15.323DEBUGjarvisstart Jarvis Backup for Instance 0...
              13:09:15.441DEBUGjarvisC:\SmartHome\iobroker-data\jarvis\0 copy success!
              13:09:15.443DEBUGjarvisCreated states_tmp directory: "C:/SmartHome/backups/tmpJavis0/states"
              13:09:15.745DEBUGjarvisTry deleting the Jarvis tmp directory: "C:/SmartHome/backups/tmpJavis0"
              13:09:15.754DEBUGjarvisJarvis tmp directory "C:/SmartHome/backups/tmpJavis0" successfully deleted
              13:09:15.759DEBUGjarvisdone
              13:09:16.337DEBUGjavascriptsCreated javascript_tmp directory: "C:/SmartHome/backups/tmpScripts"
              13:09:16.439DEBUGjavascriptsfound Script: SKRIPTE GEKÜRZT!
              13:10:08.039DEBUGjavascriptsfound Script: Servicemeldungen12
              13:10:08.361DEBUGjavascriptsTry deleting the Javascript tmp directory: "C:/SmartHome/backups/tmpScripts"
              13:10:08.373DEBUGjavascriptsdone
              13:10:09.299DEBUGcifsused copy path: H:/Backitup
              13:10:09.321DEBUGcifsCopy iobroker_2024_11_20-13_02_59_backupiobroker.tar.gz...
              13:10:10.417DEBUGcifsCopy historyDB_2024_11_20-13_03_14_backupiobroker.tar.gz...
              13:11:18.895DEBUGcifsCopy jarvis.0_2024_11_20-13_09_15_backupiobroker.tar.gz...
              13:11:18.947DEBUGcifsCopy javascripts_2024_11_20-13_09_16_backupiobroker.tar.gz...
              13:11:18.978DEBUGcifsdone
              13:11:19.635WARNcleanNo older backup files are deleted, because this backup was started manually
              13:11:19.641DEBUGcleandone
              13:11:19.802DEBUGhistoryHTMLnew history html values created
              13:11:19.836DEBUGhistoryHTMLdone
              13:11:20.017DEBUGhistoryJSONnew history json values created
              13:11:20.027DEBUGhistoryJSONdone
              13:11:22.580DEBUGnotificationdone
              13:11:22.744INFOguiDas Backup wurde erfolgreich erstellt!
              Grund ist das die History-DB schon sehr Groß ist.
              Natürlich könnte ich es auch manuell unter den Host löschen, bin mir aber nicht sicher ob das den Adapter nicht durcheinander bringt?
                Homoran Global Moderator Administrators @sigi234 last edited by
                @sigi234 sagte in Test Adapter ioBroker.backitup v3.0.x:
                Das dauert natürlich!
                  sigi234 Forum Testing Most Active @Homoran last edited by
                  @homoran sagte in Test Adapter ioBroker.backitup v3.0.x:
                  Ja, manuell ca.10 Minuten.
                  Sonst wird es automatisch ja um 2 Uhr gemacht, habe da keine Probleme.
                  Nur das ich fast 10 GB doppelt habe und mir die Systemplatte Voll macht.
                    dann hast du aber einen Turborechner.
                    Hab es nie gemessen, aber denke, dass ich auf dem Pi5 mit meinen 3GB gepackter History auch fast daran komme.
                    Manchmal hab ich den Eindruck dass zu der Zeit Meldungen im log auftauchen weil der Pi da doch ans keuchen kommt.
                      sigi234 Forum Testing Most Active @Homoran last edited by sigi234
                      Ja, komplettes Backup fertig in 9 Minuten. 😁
                      Mit 8,5 GB History
                      • Siggi0904
                        Siggi0904 last edited by
                        Hi @simatec , warum Maerz und nicht März?
                        • simatec
                          simatec Developer Most Active @Siggi0904 last edited by
                          @siggi0904 Welche Version ist installiert?
                          Siggi0904 haselchen 3 Replies Last reply Reply Quote 0
                          • Siggi0904
                            Siggi0904 @simatec last edited by
                            @simatec Hallo, aktuelle Stable 3.0.31
                            • Siggi0904
                              @simatec Mahlzeit, hattest du die Korrektur gefunden?
                              Oder sollte ich da ein Issue erstellen?
                              • haselchen
                                haselchen Most Active @simatec last edited by
                                @simatec
                                Bin mir nicht sicher mit welchem, der letzten Updates das kam.
                                In der Seitenleiste sind die Icons weg
                                simatec Thomas Braun bahnuhr 3 Replies Last reply Reply Quote 0
                                • simatec
                                  simatec Developer Most Active @haselchen last edited by
                                  @haselchen Welche Version hast du installiert?
                                    Thomas Braun Most Active @haselchen last edited by
                                    @haselchen sagte in Test Adapter ioBroker.backitup v3.0.x:
                                    Bei mir nicht.
                                    system.adapter.backitup 3.0.37
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @haselchen last edited by
                                      @haselchen
                                      Ich hab 3.0.31
                                      Bei mir ist alles ok.
                                      • haselchen
                                        haselchen Most Active @simatec last edited by haselchen
                                        @simatec
                                        3.0.37
                                        Bin nicht sicher, ob die Icons auch schon in Vorversionen weg waren.
                                        Ist mir eben erst aufgefallen.
                                        Edit:
                                        Hab nochmal ein Upload hinterhergeschoben, jetzt sind sie da .
                                        • simatec
                                          @siggi0904 Wurde in v3.1.0 gefixt
                                          • JB_Sullivan
                                            JB_Sullivan last edited by
                                            @simatec Gibt es irgend welche Beschränkungen, was das löschen von temporären Backups betrifft?
                                            Soll heißen, ich habe Adapter in der Version 3.1.0. In den Einstellungen habe ich festgelegt, das ich 3 historische Backups behalten möchte.
                                            Beim erstellen des Backups werden diese auf einem Windows System lokal unter c:\iobroker\GLT\backups\ abgelegt und mit jedem neuen Backup wird der älteste Tag entsprechend gelöscht - soweit so gut.
                                            Parallel dazu werden sie auf Google Drive gesichert.
                                            2025-03-29 02:41:40.540  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy zigbee.0_2025_03_29-02_24_10_backupiobroker.tar.gz...
                                            2025-03-29 02:41:42.743  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy grafana_2025_03_29-02_24_16_backupiobroker.tar.gz...
                                            2025-03-29 02:41:44.977  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy javascripts_2025_03_29-02_24_22_backupiobroker.tar.gz...
                                            2025-03-29 02:41:47.664  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete iobroker_2025_03_26-02_00_10_backupiobroker.tar.gz
                                            2025-03-29 02:41:48.260  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete influxDB_2025_03_26-02_00_42_backupiobroker.tar.gz
                                            2025-03-29 02:41:48.874  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete zigbee.0_2025_03_26-02_24_45_backupiobroker.tar.gz
                                            2025-03-29 02:41:49.415  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete grafana_2025_03_26-02_24_52_backupiobroker.tar.gz
                                            2025-03-29 02:41:49.940  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete javascripts_2025_03_26-02_24_58_backupiobroker.tar.gz
                                            2025-03-29 02:41:50.439  - debug: backitup.0 (2896) [iobroker/googledrive] done
                                            2025-03-29 02:41:50.599  - debug: backitup.0 (2896) [iobroker/clean] delete C:\ioBroker\GLT\backups\iobroker_2025_03_26-02_00_10_backupiobroker.tar.gz
                                            2025-03-29 02:41:50.603  - debug: backitup.0 (2896) [iobroker/clean] done
                                            2025-03-29 02:41:50.764  - debug: backitup.0 (2896) [iobroker/historyHTML] new history html values created
                                            2025-03-29 02:41:50.785  - debug: backitup.0 (2896) [iobroker/historyHTML] done
                                            2025-03-29 02:41:50.968  - debug: backitup.0 (2896) [iobroker/historyJSON] new history json values created
                                            2025-03-29 02:41:50.969  - debug: backitup.0 (2896) [iobroker/historyJSON] done
                                            2025-03-29 02:41:51.434  - debug: backitup.0 (2896) [iobroker/email] done
                                            Seit ca. einer Woche löscht er aber das älteste Backup auf Googel Drive nicht mehr (lokal schon) und gibt mir den folgenden Fehler aus (Zeile 24 - der Rest ist zur Information). Dies passierte von einem Tag auf den anderen, ohne das am System irgend welche Änderungen vorgenommen wurden (ich war zu der Zeit sogar im Urlaub). Die Sicherung der InfluxDB auf Google ist ca. 6,5 GB groß. Kann das ein Problem sein?
                                            2025-03-29 02:24:48.445  - debug: backitup.0 (2896) [iobroker/javascripts] Try deleting the Javascript tmp directory: "C:/ioBroker/GLT/backups/tmpScripts"
                                            2025-03-29 02:24:48.454  - debug: backitup.0 (2896) [iobroker/javascripts] Javascript tmp directory "C:/ioBroker/GLT/backups/tmpScripts" successfully deleted
                                            2025-03-29 02:24:48.455  - debug: backitup.0 (2896) [iobroker/javascripts] Backup created: C:\ioBroker\GLT\backups\javascripts_2025_03_29-02_24_22_backupiobroker.tar.gz
                                            2025-03-29 02:24:48.455  - debug: backitup.0 (2896) [iobroker/javascripts] done
                                            2025-03-29 02:24:51.006  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy iobroker_2025_03_29-02_00_10_backupiobroker.tar.gz...
                                            2025-03-29 02:24:55.822  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy influxDB_2025_03_29-02_00_40_backupiobroker.tar.gz...
                                            2025-03-29 02:41:51.438  - warn: email.0 (3284) From email address is not equal to the configured email address for authentication. Some services do not allow this!
                                            2025-03-29 02:41:51.440  - info: email.0 (3284) Send email: {"text":"Backitup:\nIhr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!\n\ncifs: Error: EPERM: operation not permitted, stat 'C:\\ioBroker\\GLT\\backups\\influxDB_2025_03_18-02_00_42_backupiobroker.tar.gz'","to":"meinemailadresse@arcor.de","subject":"Backitup","from":"meinemailadresse@arcor.de"}
                                            2025-03-29 02:41:53.495  - debug: backitup.0 (2896) [iobroker/notification] Admin notification will be sent
                                            2025-03-29 02:41:53.496  - debug: backitup.0 (2896) [iobroker/notification] done
                                            2025-03-29 02:41:53.656  - debug: backitup.0 (2896) [iobroker] exec: done
                                            simatec Negalein 3 Replies Last reply Reply Quote 0
                                            170
                                            2780
                                            2373863
