    4. Test Adapter Log Parser 2.4.x Latest
      babl last edited by
      @arteck installiert. Danke
        arteck Developer Most Active @Negalein last edited by
        @negalein das ist die alte version.. die hilft nicht
        Negalein Quarkmax 3 Replies Last reply Reply Quote 0
        • Negalein
          Negalein Global Moderator @arteck last edited by Negalein
          @arteck sagte in Test Adapter Log Parser 2.1.x Latest:
          komisch. Ich hab zuvor bestimmt https://github.com/iobroker-community-adapters/ioBroker.logparser/tarball/logOutput installiert.
          jetzt nochmal. Im Install-Log seh ich nichts von Version X.
          $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.logparser/tarball/logOutput --host ioBroker --debug
          install iobroker-community-adapters/ioBroker.logparser#logOutput
          NPM version: 10.8.2
          Installing iobroker-community-adapters/ioBroker.logparser#logOutput... (System call)
          up to date in 6s
          516 packages are looking for funding run `npm fund` for details
          upload [13] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [12] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [11] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [10] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [9] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [8] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [7] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [6] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [5] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [4] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          upload [3] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [2] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/jsonConfig.json jsonConfig.json application/json
          upload [1] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/logparser.png logparser.png image/png
          upload [0] logparser.admin /opt/iobroker/node_modules/iobroker.logparser/admin/words.js words.js application/javascript
          Process exited with code 0
          • Quarkmax
            Quarkmax @arteck last edited by
            Hallo @arteck
            kurzer Zwischenstand,
            tsToDateString1 bricht irgendwann ab, tsToDateString2 übernimmt dann und läuft sauber durch.
            2024-10-21 19:07:26.848 - info: logparser.0 (95086) tsToDateString1 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:07:26.848 - info: logparser.0 (95086) todayStr Heute yesterdayStr Gestern
            2024-10-21 19:07:26.848 - info: logparser.0 (95086) format #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:07:26.848 - info: logparser.0 (95086) todayYesterdayTxt Heute
            2024-10-21 19:07:26.848 - info: logparser.0 (95086) strResult Heute hh:mm
            2024-10-21 19:07:26.849 - info: logparser.0 (95086) strResult2 Heute 16:25
            2024-10-21 19:07:26.893 - info: logparser.0 (95086) tsToDateString1 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:07:26.894 - info: logparser.0 (95086) todayStr Heute yesterdayStr Gestern
            2024-10-21 19:07:26.894 - info: logparser.0 (95086) format #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:07:26.894 - info: logparser.0 (95086) todayYesterdayTxt Heute
            2024-10-21 19:07:26.894 - info: logparser.0 (95086) strResult Heute hh:mm
            2024-10-21 19:07:26.894 - info: logparser.0 (95086) strResult2 Heute 16:25
            2024-10-21 19:08:06.397 - warn: apcups.0 (95460) UPS '3Q2009X16095' is available again
            2024-10-21 19:08:06.406 - info: logparser.0 (95086) tsToDateString2 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:08:06.407 - info: logparser.0 (95086) todayStr Heute yesterdayStr Gestern
            2024-10-21 19:08:06.407 - info: logparser.0 (95086) format #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:08:06.407 - info: logparser.0 (95086) todayYesterdayTxt Heute
            2024-10-21 19:08:06.407 - info: logparser.0 (95086) strResult Heute hh:mm
            2024-10-21 19:08:06.408 - info: logparser.0 (95086) strResult2 Heute 19:08
            2024-10-21 19:08:06.409 - info: logparser.0 (95086) tsToDateString2 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:08:06.409 - info: logparser.0 (95086) todayStr Heute yesterdayStr Gestern
            2024-10-21 19:08:06.409 - info: logparser.0 (95086) format #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:08:06.409 - info: logparser.0 (95086) todayYesterdayTxt Heute
            2024-10-21 19:08:06.410 - info: logparser.0 (95086) strResult Heute hh:mm
            2024-10-21 19:08:06.410 - info: logparser.0 (95086) strResult2 Heute 19:08
            2024-10-21 19:15:52.554 - info: logparser.0 (95086) Got terminate signal TERMINATE_YOURSELF
            2024-10-21 19:15:52.555 - info: logparser.0 (95086) cleaned everything up...
            2024-10-21 19:15:52.555 - info: logparser.0 (95086) terminating
            2024-10-21 19:15:52.555 - info: logparser.0 (95086) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-10-21 19:15:53.057 - info: logparser.0 (95086) terminating
            2024-10-21 19:15:57.560 - info: logparser.0 (99680) starting. Version 2.2.2 (non-npm: iobroker-community-adapters/ioBroker.logparser#logOutput) in /opt/iobroker/node_modules/iobroker.logparser, node: v20.18.0, js-controller: 7.0.1
            2024-10-21 19:15:57.726 - info: logparser.0 (99680) tsToDateString1 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:15:57.727 - info: logparser.0 (99680) todayStr Heute yesterdayStr Gestern
            2024-10-21 19:15:57.727 - info: logparser.0 (99680) format #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:15:57.753 - info: logparser.0 (99680) todayYesterdayTxt Heute
            2024-10-21 19:15:57.754 - info: logparser.0 (99680) strResult Heute hh:mm
            2024-10-21 19:15:57.754 - info: logparser.0 (99680) strResult2 Heute 18:46
            2024-10-21 19:15:57.754 - info: logparser.0 (99680) tsToDateString1 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:15:57.755 - info: logparser.0 (99680) todayStr Heute yesterdayStr Gestern
            2024-10-21 19:15:57.755 - info: logparser.0 (99680) format #DD.MM.# hh:mm - #DD.MM.# hh:mm
            2024-10-21 19:15:57.756 - info: logparser.0 (99680) todayYesterdayTxt Heute
            2024-10-21 19:15:57.756 - info: logparser.0 (99680) strResult Heute hh:mm
            2024-10-21 19:15:57.756 - info: logparser.0 (99680) strResult2 Heute 17:46
            2024-10-21 19:15:57.757 - info: logparser.0 (99680) tsToDateString1 #DD.MM.# hh:mm - #DD.MM.# hh:mm
            Hatte vorher einen Proxmox reboot. Vor dem Proxmox reboot lief die "2" anstandslos mit Gestern/Heute und Uhrzeit durch. Nach dem Start von ioBroker wieder 1 dann 2 (siehe Log) und Neustart Logparser wieder 1.
            Ich lass es weiterlaufen, falls du mehr benötigst.
            • Negalein
              jetzt aber 😉
              neu 1.txt
                Hansi1234 last edited by
                Hi zusammen,
                ich verwende zum ersten Mal diesen Adapter und habe vermutlich ein einfaches Problem. Ich habe einen Filter gesetzt, welcher auch immer erkannt und in die json Datei geschrieben/aktualisiert wird. Sollte dann nicht auch die visualisierungs json automatisch aktualisiert werden?
                • AFi
                  AFi last edited by
                  Hi, benutze den logparser seit längerer Zeit, seit kurzem habe ich folgende Fehlermeldung:
                  Komme da nicht wirklich weiter.
                  VG AFi
                    Thomas Braun Most Active @AFi last edited by
                    @afi
                    Installier den nochmal.
                    Und bitte von Logtext keine Bildchen von chronologisch falschen Einträgen.
                    AFi 1 Reply Last reply Reply Quote 0
                    • AFi
                      AFi @Thomas Braun last edited by
                      @thomas-braun Hi Thomas, danke für die Hilfe. Wie meinst Du dies, Adapter aus der Instanze löschen oder komplett runter vom System und neu aus GitHub ziehen?
                      VG Axel
                        @afi
                        Aus dem GitHub ziehst du gar keine Adapter. Wo kommt eigentlich diese Unart her?
                        Der 'logparser' wird ganz normal aus dem aktivien Repo installiert.
                        • AFi
                          @thomas-braun Hi Thomas, hat mich jetzt nicht weiter gebracht, die Fehlermeldung scheint immer noch die gleiche zu sein wie im Bild.
                          Abschluss der Fehlermeldung ist:
                          "host.NUCioBroker 2025-03-01 17:43:20.108 warn adapter "logparser" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt"
                          VG
                          Axel
                          AFi Thomas Braun 2 Replies Last reply Reply Quote 0
                          • AFi
                            AFi @AFi last edited by
                            Hi Thomas, node.js ist 20.18.3. VG Axel
                              @afi sagte in Test Adapter Log Parser 2.1.x Latest:
                              Mehr zeigen...
                              iob update
                              iob upgrade logparser@2.2.2
                              • AFi
                                @thomas-braun Hi Thomas, ich komme da nicht wirklich weiter, habe den Adapter nochmals frisch installiert, anbei nochmals die Fehlermeldung.
                                Irgend wie glaube ich, dass es mit node.js und der neuesten Version zutun hat.
                                VG Axel
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: throw err;
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: ^
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: Require stack:
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: }
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker Caught by controller[0]: Node.js v20.18.3
                                2025-03-01 18:21:13.208 - error: host.NUCioBroker instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-03-01 18:21:13.208 - info: host.NUCioBroker Adapter system.adapter.logparser.0 needs rebuild and will be restarted afterwards.
                                2025-03-01 18:21:13.208 - info: host.NUCioBroker system.adapter.logparser.0 will be rebuilt
                                2025-03-01 18:21:13.208 - warn: host.NUCioBroker adapter "logparser" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                • AFi
                                  Hi Thomas, der logparser bricht auch wieder ab und startet nicht. VG Axel
                                    @afi
                                    Und was gibt
                                    aus? Komplett...
                                      @afi
                                      Und gib mal die Langfassung von
                                      iob diag
                                      zum Besten.
                                      • AFi
                                        @thomas-braun Nach Update Fehlermeldungen
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: Node.js v20.18.3
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: }
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: Require stack:
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: ^
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: throw err;
                                        host.NUCioBroker
                                        	2025-03-01 19:12:30.089	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: Node.js v20.18.3
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: }
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: Require stack:
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: ^
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: throw err;
                                        host.NUCioBroker
                                        	2025-03-01 19:10:31.314	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                        Die Diag in Langversion bekomme ich leider nicht hier her, wie ich das kopiere ist mir leider nicht klar. Wenn Du eine bestimmte Frage hast, kann ich ja schauen.
                                        VG Axel
                                          Im Terminal markieren, kopieren, einfügen.
                                          Wie man jeden Text halt markiert, kopiert und einfügen kann.
                                          • AFi
                                            @thomas-braun Hallo Thomas, das habe ich versucht, dann ging es gleich weiter zur Zusammenfassung und war nicht mehr markierbar. In dieser Langfassung sind E-Mail - Adressen drin und eventuell noch andere nicht öffentliche Sachen, die ich jetzt nicht überblicken kann, da ich dies heute zum ersten mal aufgerufen habe, diese Dinge mache ich nicht gerne öffentlich. Auf was schaust Du, dann versuche ich diesen Bereich hier darzustellen. Sorry, natürlich suche ich Hilfe, verstehe mich bitte nicht falsch.
                                            VG Axel
                                            Thomas Braun AFi 2 Replies Last reply Reply Quote 0
                                            107
                                            11182
