    4. Test Adapter Log Parser 2.4.x Latest
    • AFi
      AFi @AFi last edited by
      Hi Thomas, der logparser bricht auch wieder ab und startet nicht. VG Axel
        Thomas Braun Most Active @AFi last edited by
        @afi
        Und was gibt
        iob upgrade logparser@2.2.2
        aus? Komplett...
          @afi
          Und gib mal die Langfassung von
          iob diag
          zum Besten.
          AFi 1 Reply Last reply Reply Quote 0
          • AFi
            AFi @Thomas Braun last edited by
            @thomas-braun Nach Update Fehlermeldungen
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: Node.js v20.18.3
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: }
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: Require stack:
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: ^
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: throw err;
            host.NUCioBroker
            	2025-03-01 19:12:30.089	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: Node.js v20.18.3
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: }
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: Require stack:
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: ^
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: throw err;
            host.NUCioBroker
            	2025-03-01 19:10:31.314	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
            Die Diag in Langversion bekomme ich leider nicht hier her, wie ich das kopiere ist mir leider nicht klar. Wenn Du eine bestimmte Frage hast, kann ich ja schauen.
            VG Axel
              @afi sagte in Test Adapter Log Parser 2.1.x Latest:
              Im Terminal markieren, kopieren, einfügen.
              Wie man jeden Text halt markiert, kopiert und einfügen kann.
              • AFi
                @thomas-braun Hallo Thomas, das habe ich versucht, dann ging es gleich weiter zur Zusammenfassung und war nicht mehr markierbar. In dieser Langfassung sind E-Mail - Adressen drin und eventuell noch andere nicht öffentliche Sachen, die ich jetzt nicht überblicken kann, da ich dies heute zum ersten mal aufgerufen habe, diese Dinge mache ich nicht gerne öffentlich. Auf was schaust Du, dann versuche ich diesen Bereich hier darzustellen. Sorry, natürlich suche ich Hilfe, verstehe mich bitte nicht falsch.
                VG Axel
                Thomas Braun AFi 2 Replies Last reply Reply Quote 0
                  Auf was schaust Du
                  Auf alles.
                  • AFi
                    @afi Hier die diag:
                    ========== Start marking the full check here ===========
                    ```bash
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                     Static hostname: NUCioBroker
                           Icon name: computer-desktop
                             Chassis: desktop 🖥️
                              Kernel: Linux 6.1.0-31-amd64
                        Architecture: x86-64
                     Hardware Vendor: Intel_R_ Client Systems
                      Hardware Model: NUC8i3BEH
                    Firmware Version: BECFL357.86A.0077.2019.1127.1452
                    OS is similar to:
                    model name      : Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
                    Docker          : false
                    Virtualization  : none
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     20:11:58 up  8:24,  2 users,  load average: 0.49, 0.33, 0.24
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    *** TIME AND TIMEZONES ***
                                   Local time: Sat 2025-03-01 20:11:58 CET
                               Universal time: Sat 2025-03-01 19:11:58 UTC
                                     RTC time: Sat 2025-03-01 19:11:58
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    afischer
                    HOME=/home/afischer
                    GROUPS=afischer cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout sudo audio video plugdev
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server: false
                    Desktop:
                    Terminal:       tty
                    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                    *** MEMORY ***
                    Mem:             16G        2.8G         12G        1.6M        2.0G         13G
                    Swap:            17G          0B         17G
                    Total:           33G        2.8G         29G
                    Active iob-Instances:   24
                            15863 M total memory
                             2646 M used memory
                              876 M active memory
                             2823 M inactive memory
                            11686 M free memory
                              401 M buffer memory
                             1464 M swap cache
                            16253 M total swap
                                0 M used swap
                            16253 M free swap
                    top - 20:11:58 up  8:24,  2 users,  load average: 0.49, 0.33, 0.24
                    Tasks: 158 total,   1 running, 157 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  15863.3 total,  11686.5 free,   2646.2 used,   1865.5 buff/cache
                    MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13217.1 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  7.8G     0  7.8G   0% /dev
                    tmpfs          tmpfs     1.6G  928K  1.6G   1% /run
                    /dev/nvme0n1p2 ext4      213G   18G  184G   9% /
                    tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                    /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
                    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
                    [Sat Mar  1 11:47:38 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Sat Mar  1 11:47:38 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
                    Show mounted filesystems:
                    TARGET      SOURCE         FSTYPE OPTIONS
                    /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
                    `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                    /var:
                    2.2G    /var/
                    1.1G    /var/log
                    1007M   /var/log/journal/................................................................
                    837M    /var/lib
                    Archived and active journals take up 88.2M in the file system.
                    /opt/iobroker/backups:
                    648M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    3.5G    /opt/iobroker/iobroker-data/
                    2.0G    /opt/iobroker/iobroker-data/history
                    1.3G    /opt/iobroker/iobroker-data/files
                    617M    /opt/iobroker/iobroker-data/files/javascript.admin
                    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    42M     /opt/iobroker/iobroker-data/objects.jsonl
                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    Zigbee Network Settings on your coordinator/in nvbackup are:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    To unmask the settings run 'iob diag --unmask'
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.18.3
                    /usr/bin/node           v20.18.3
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.30.0
                    nodejs:
                      Installed: 20.18.3-1nodesource1
                      Candidate: 20.18.3-1nodesource1
                      Version table:
                     *** 20.18.3-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                            100 /var/lib/dpkg/status
                         20.18.2-1nodesource1 1001
                         20.18.1-1nodesource1 1001
                         20.18.0-1nodesource1 1001
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 7322)
                    Core adapters versions
                    js-controller:  7.0.6
                    admin:          7.4.10
                    javascript:     8.8.3
                    nodejs modules from github:     1
                    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#............................................)
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      system.adapter.devices.0                : devices               : NUCioBroker                              -  enabled
                    + system.adapter.discovery.0              : discovery             : NUCioBroker                              -  enabled
                      system.adapter.dwd.0                    : dwd                   : NUCioBroker                              -  enabled
                    + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : NUCioBroker                              -  enabled
                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
                      system.adapter.feiertage.0              : feiertage             : NUCioBroker                              -  enabled
                      system.adapter.flot.0                   : flot                  : NUCioBroker                              -  enabled
                    + system.adapter.followthesun.0           : followthesun          : NUCioBroker                              -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
                    + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
                    + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 12001
                    + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
                      system.adapter.ical.0                   : ical                  : NUCioBroker                              -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUCioBroker                              -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : NUCioBroker                              -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : NUCioBroker                              -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUCioBroker                              -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUCioBroker                              -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUCioBroker                              -  enabled
                    + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
                    + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
                      system.adapter.logparser.0              : logparser             : NUCioBroker                              - disabled
                    + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
                    + system.adapter.plenticore.0             : plenticore            : NUCioBroker                              -  enabled, port: 80
                      system.adapter.ring.0                   : ring                  : NUCioBroker                              - disabled
                    + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
                    + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.socketio.0               : socketio              : NUCioBroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sony-bravia.0            : sony-bravia           : NUCioBroker                              -  enabled
                    + system.adapter.statistics.0             : statistics            : NUCioBroker                              -  enabled
                    + system.adapter.velux.0                  : velux                 : NUCioBroker                              -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : NUCioBroker                              -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUCioBroker                              -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUCioBroker                              -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUCioBroker                              -  enabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUCioBroker                              -  enabled
                      system.adapter.vis-history.0            : vis-history           : NUCioBroker                              -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUCioBroker                              -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : NUCioBroker                              -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : NUCioBroker                              -  enabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : NUCioBroker                              -  enabled
                      system.adapter.vis-lcars.0              : vis-lcars             : NUCioBroker                              -  enabled
                      system.adapter.vis-map.0                : vis-map               : NUCioBroker                              -  enabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : NUCioBroker                              -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : NUCioBroker                              -  enabled
                      system.adapter.vis-players.0            : vis-players           : NUCioBroker                              -  enabled
                      system.adapter.vis-plumb.0              : vis-plumb             : NUCioBroker                              -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : NUCioBroker                              -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              -  enabled
                      system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : NUCioBroker                              -  enabled
                    + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wolf-smartset.0          : wolf-smartset         : NUCioBroker                              -  enabled
                      system.adapter.worx.0                   : worx                  : NUCioBroker                              - disabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.4.10   , installed 7.4.10
                    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
                    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
                    Adapter    "email"        : 1.3.1    , installed 1.3.1
                    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
                    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                    Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
                    Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                    Adapter    "ical"         : 1.16.1   , installed 1.16.1
                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                    Controller "js-controller": 7.0.6    , installed 7.0.6
                    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                    Adapter    "ring"         : 6.3.0    , installed 6.3.0
                    Adapter    "senec"        : 1.6.17   , installed 1.6.17
                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                    Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                    Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                    Adapter    "velux"        : 0.0.8    , installed 0.0.8
                    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                    Adapter    "wolf-smartset": 1.2.4    , installed 1.2.4
                    Adapter    "worx"         : 3.1.1    , installed 3.1.1
                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                    Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                    Objects and States
                    Objects:        16842
                    States:         14088
                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                    W: Some index files failed to download. They have been ignored, or old ones used instead.
                    Hit:1 http://ftp.debian.org/debian bookworm-backports InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                    Get:5 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
                    Get:6 https://repos.influxdata.com/debian stable InRelease [6907 B]
                    Hit:7 https://repos.influxdata.com/debian bullseye InRelease
                    Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Err:5 https://packages.grafana.com/oss/deb stable InRelease
                    Err:6 https://repos.influxdata.com/debian stable InRelease
                    Fetched 6907 B in 1s (9632 B/s)
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18354      590/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14488      1/init
                    tcp        0      0 ..........................    0.0.0.0:*               LISTEN      1001       294317     26500/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       290741     26352/iobroker.js-c
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       292954     26352/iobroker.js-c
                    tcp        0      0 ..............................    0.0.0.0:*               LISTEN      1001       291509     26534/io.hm-rpc.2
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          18975      590/sshd: /usr/sbin
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          14490      1/init
                    tcp6       0      0 :::80                   :::*                    LISTEN      0          20073      594/apache2
                    tcp6       0      0 :::3000                 :::*                    LISTEN      112        19138      695/grafana
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       292672     26690/io.socketio.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      113        20553      552/influxd
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       293699     26736/io.simple-api
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       292139     26370/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       291664     26675/io.web.0
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1821       521/dhclient
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14489      1/init
                    udp        0      0 0.0.0.0:52029           0.0.0.0:*                           106        1786       537/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        1784       537/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          14491      1/init
                    udp6       0      0 :::5353                 :::*                                106        1785       537/avahi-daemon: r
                    udp6       0      0 :::38942                :::*                                106        1787       537/avahi-daemon: r
                    2025-03-01 20:10:49.105  - info: senec.0 (26644) LowPrio polling ...
                    2025-03-01 20:11:00.003  - info: javascript.0 (26436) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                    2025-03-01 20:11:00.009  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.7293831050228311
                    2025-03-01 20:11:00.010  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.5693023287671232
                    2025-03-01 20:11:00.010  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.39.31211834728203
                    2025-03-01 20:11:00.010  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.5693023287671232
                    2025-03-01 20:11:00.010  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 44358
                    2025-03-01 20:11:00.038  - info: javascript.0 (26436) script.js.common.Programme.RolloSonnenschutz: 17:30
                    2025-03-01 20:11:00.793  - info: ical.0 (44358) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                    2025-03-01 20:11:01.348  - info: ical.0 (44358) processing URL: calendar1 https://calendar.google.com/calendar/ical/210a.420.630%40gmail.com/private-...................................................asic.ics
                    2025-03-01 20:11:06.443  - info: ical.0 (44358) Terminated (NO_ERROR): Without reason
                    2025-03-01 20:11:06.969  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 44358 terminated with code 0 (NO_ERROR)
                    2025-03-01 20:11:38.500  - info: admin.0 (26370) <== Disconnect system.user.admin from ::ffff:.............. admin
                    2025-03-01 20:11:38.853  - info: admin.0 (26370) failed connection to socket.io from ::ffff:.................: Passport was not initialized
                    2025-03-01 20:12:00.003  - info: javascript.0 (26436) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                    2025-03-01 20:12:00.007  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 44729
                    2025-03-01 20:12:00.027  - info: javascript.0 (26436) script.js.common.Programme.RolloSonnenschutz: 17:30
                    2025-03-01 20:12:00.080  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.7049164383561645
                    2025-03-01 20:12:00.081  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.5693023287671232
                    2025-03-01 20:12:00.081  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.39.32160671942815
                    2025-03-01 20:12:00.081  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.5693023287671232
                    2025-03-01 20:12:00.994  - info: ical.0 (44729) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                    2025-03-01 20:12:01.646  - info: ical.0 (44729) processing URL: calendar1 https://calendar.google.com/calendar/ical/210a.420.630%40gmail.com/private-............................................................
                    2025-03-01 20:12:06.743  - info: ical.0 (44729) Terminated (NO_ERROR): Without reason
                    2025-03-01 20:12:07.266  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 44729 terminated with code 0 (NO_ERROR)
                    VG Axel
                      Thomas Braun Most Active @AFi last edited by Thomas Braun
                      @afi
                      sudo usermod -a G adm,iobroker afischer
                      sudo systemctl set-default multi-user.target
                      sudo rm /etc/apt/sources.list.d/grafana*
                      sudo apt-get install -y apt-transport-https
                      sudo apt-get install -y software-properties-common wget
                      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                      sudo rm /etc/apt/sources.list.d/influ*
                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                      rm influxdata-archive_compat.key
                      Neustart.
                      Dann
                      cd /opt/iobroker && npm ls node-schedule
                      • AFi
                        @thomas-braun Anbei Ergebnis
                        iobroker.inst@2.0.3 /opt/iobroker
                        ├─┬ iobroker.followthesun@0.5.1
                        │ └── node-schedule@2.1.0
                        ├─┬ iobroker.javascript@8.8.3
                        │ └── node-schedule@2.1.1
                        ├─┬ iobroker.js-controller@7.0.6
                        │ ├─┬ @iobroker/js-controller-adapter@7.0.6
                        │ │ └── node-schedule@2.1.1
                        └─┬ iobroker.ring@6.3.0
                        Sagst Du mir später dann mal was wir machen und warum. Lerne gerne dazu.
                        VG Axel
                          Deine Installation gerade biegen.
                          Den ganzen Kram zuvor ausgeführt? Neugestartet?
                          Wie schaut
                          iob diag
                          nun aus?
                          • AFi
                            @thomas-braun Alles ausgeführt, logparser bringt aber immer noch die gleichen Fehler, anbei diag:
                            Script v.2025-02-23
                            *** BASE SYSTEM ***
                                     Chassis: desktop 🖥️
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             21:53:26 up 19 min,  2 users,  load average: 0.39, 0.20, 0.18
                            CPU threads: 4
                                           Local time: Sat 2025-03-01 21:53:26 CET
                                       Universal time: Sat 2025-03-01 20:53:26 UTC
                                             RTC time: Sat 2025-03-01 20:53:26
                                          NTP service: active
                                      RTC in local TZ: no
                            afischer
                            HOME=/home/afischer
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:             16G        2.7G         12G        1.5M        1.3G         13G
                            Swap:            17G          0B         17G
                            Total:           33G        2.7G         30G
                                     2533 M used memory
                                      455 M active memory
                                     2699 M inactive memory
                                    12379 M free memory
                                      127 M buffer memory
                                     1135 M swap cache
                                    16253 M total swap
                                        0 M used swap
                                    16253 M free swap
                            top - 21:53:26 up 19 min,  2 users,  load average: 0.39, 0.20, 0.18
                            Tasks: 152 total,   1 running, 151 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  15863.3 total,  12379.5 free,   2534.0 used,   1263.8 buff/cache
                            MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13329.3 avail Mem
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
                            [Sat Mar  1 21:33:59 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sat Mar  1 21:34:00 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
                            /var:
                            2.2G    /var/
                            1.1G    /var/log
                            1015M   /var/log/journal/d25f012e03a44a28958f2441a93e8860
                            838M    /var/lib
                            3.6G    /opt/iobroker/iobroker-data/
                            29M     /opt/iobroker/iobroker-data/objects.jsonl
                            24M     /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 1157)
                            admin:          7.4.10
                            javascript:     8.8.3
                            +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#................................)
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        16842
                            States:         14079
                            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:4 http://ftp.debian.org/debian bookworm-backports InRelease
                            Fetched 6907 B in 1s (9483 B/s)
                            Pending Updates: 0
                            tcp        0      0 192.168.188.52:42010    0.0.0.0:*               LISTEN      1001       20141      931/io.hm-rpc.2
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16223      686/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16240      686/iobroker.js-con
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16146      583/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14402      1/init
                            tcp        0      0 192.168.188.52:12001    0.0.0.0:*               LISTEN      1001       21886      895/io.hm-rpc.1
                            tcp6       0      0 :::3000                 :::*                    LISTEN      112        17397      685/grafana
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          20671      583/sshd: /usr/sbin
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          14404      1/init
                            tcp6       0      0 :::80                   :::*                    LISTEN      0          20649      591/apache2
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22146      1133/io.simple-api.
                            tcp6       0      0 :::8086                 :::*                    LISTEN      113        16191      568/influxd
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23596      1102/io.socketio.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20294      1087/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19921      758/io.admin.0
                            udp        0      0 0.0.0.0:39313           0.0.0.0:*                           106        20616      539/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16133      521/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14403      1/init
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        20614      539/avahi-daemon: r
                            udp6       0      0 :::111                  :::*                                0          14405      1/init
                            udp6       0      0 :::5353                 :::*                                106        20615      539/avahi-daemon: r
                            udp6       0      0 :::46354                :::*                                106        20617      539/avahi-daemon: r
                            2025-03-01 21:51:08.986  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3597 terminated with code 0 (NO_ERROR)
                            2025-03-01 21:51:29.509  - info: web.0 (1087) ==> Connected system.user.admin from ::ffff:192.168.188.57
                            2025-03-01 21:51:32.115  - info: web.0 (1087) ==> Connected system.user.admin from ::ffff:192.168.188.57
                            2025-03-01 21:52:00.003  - info: javascript.0 (826) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                            2025-03-01 21:52:00.013  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3643
                            2025-03-01 21:52:00.024  - info: javascript.0 (826) script.js.common.Programme.RolloSonnenschutz: 17:30
                            2025-03-01 21:52:00.048  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.509183105022831
                            2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.4079523287671233
                            2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.40.00817389522731
                            2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.4079523287671233
                            2025-03-01 21:52:00.860  - info: ical.0 (3643) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                            2025-03-01 21:52:01.406  - info: ical.0 (3643) processing URL: calendar1 https://calendar.google.com/calendar/ical/...........................................................................................
                            2025-03-01 21:52:06.517  - info: ical.0 (3643) Terminated (NO_ERROR): Without reason
                            2025-03-01 21:52:07.034  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3643 terminated with code 0 (NO_ERROR)
                            2025-03-01 21:53:00.003  - info: javascript.0 (826) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.509183105022831
                            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.4079523287671233
                            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.40.01497310070676
                            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.4079523287671233
                            2025-03-01 21:53:00.017  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3719
                            2025-03-01 21:53:00.169  - info: javascript.0 (826) script.js.common.Programme.RolloSonnenschutz: 17:30
                            2025-03-01 21:53:00.924  - info: ical.0 (3719) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                            2025-03-01 21:53:01.496  - info: ical.0 (3719) processing URL: calendar1 https://calendar.google.com/calendar/ical/........................................................................
                            2025-03-01 21:53:06.597  - info: ical.0 (3719) Terminated (NO_ERROR): Without reason
                            2025-03-01 21:53:07.127  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3719 terminated with code 0 (NO_ERROR)
                            • AFi
                              Hallo Thomas,
                              ich habe zuerst nicht verstanden, dass ich alle Befehle ausführen muss, morgen gehts weiter, ich sende Dir dann eine neue diag.
                              Gruß Axel
                              • AFi
                                Hallo Thomas,
                                anbei diag:
                                Script v.2025-02-23
                                *** BASE SYSTEM ***
                                         Chassis: desktop 🖥️
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 07:58:07 up  9:39,  2 users,  load average: 0.62, 0.37, 0.26
                                CPU threads: 4
                                               Local time: Sun 2025-03-02 07:58:07 CET
                                           Universal time: Sun 2025-03-02 06:58:07 UTC
                                                 RTC time: Sun 2025-03-02 06:58:07
                                              NTP service: active
                                          RTC in local TZ: no
                                afischer
                                HOME=/home/afischer
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:             16G        2.8G         12G        1.6M        1.8G         13G
                                Swap:            17G          0B         17G
                                Total:           33G        2.8G         29G
                                         2677 M used memory
                                          693 M active memory
                                         2996 M inactive memory
                                        11814 M free memory
                                          333 M buffer memory
                                         1363 M swap cache
                                        16253 M total swap
                                            0 M used swap
                                        16253 M free swap
                                top - 07:58:07 up  9:39,  2 users,  load average: 0.65, 0.38, 0.26
                                Tasks: 151 total,   1 running, 150 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :  15863.3 total,  11813.9 free,   2678.6 used,   1696.5 buff/cache
                                MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13184.6 avail Mem
                                *** FILESYSTEM ***
                                [Sat Mar  1 22:18:45 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sat Mar  1 22:18:46 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
                                /var:
                                2.2G    /var/
                                1.1G    /var/log/journal/d25f012e03a44a28958f2441a93e8860
                                1.1G    /var/log
                                842M    /var/lib
                                Archived and active journals take up 92.5M in the file system.
                                31M     /opt/iobroker/iobroker-data/objects.jsonl
                                25M     /opt/iobroker/iobroker-data/states.jsonl
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 34758)
                                admin:          7.4.10
                                javascript:     8.8.3
                                +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        16834
                                States:         14071
                                Hit:5 https://apt.grafana.com stable InRelease
                                Hit:6 https://repos.influxdata.com/debian stable InRelease
                                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 ................................:12001    0.0.0.0:*               LISTEN      1001       22772      905/io.hm-rpc.1
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21552      689/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20583      689/iobroker.js-con
                                tcp        0      0 .......................:42010    0.0.0.0:*               LISTEN      1001       19222      941/io.hm-rpc.2
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20498      592/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1322       1/init
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21131      1097/io.socketio.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23554      1143/io.simple-api.
                                tcp6       0      0 :::8086                 :::*                    LISTEN      113        18777      561/influxd
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18864      738/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23025      1082/io.web.0
                                tcp6       0      0 :::3000                 :::*                    LISTEN      112        21589      688/grafana
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          20500      592/sshd: /usr/sbin
                                tcp6       0      0 :::80                   :::*                    LISTEN      0          20484      594/apache2
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          1324       1/init
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13167      540/avahi-daemon: r
                                udp        0      0 0.0.0.0:48151           0.0.0.0:*                           106        13169      540/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18578      520/dhclient
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1323       1/init
                                udp6       0      0 :::44674                :::*                                106        13170      540/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                106        13168      540/avahi-daemon: r
                                udp6       0      0 :::111                  :::*                                0          1325       1/init
                                2025-03-02 07:56:49.438  - info: weatherunderground.0 (31989) Terminated (NO_ERROR): Without reason
                                2025-03-02 07:56:49.940  - warn: weatherunderground.0 (31989) get state error: Connection is closed.
                                2025-03-02 07:56:49.950  - info: host.NUCioBroker instance system.adapter.weatherunderground.0 having pid 31989 terminated with code 0 (NO_ERROR)
                                2025-03-02 07:57:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                                2025-03-02 07:57:00.009  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32027
                                2025-03-02 07:57:00.021  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
                                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9251164383561645
                                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
                                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.35477667638539
                                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13530643784915464
                                2025-03-02 07:57:00.825  - info: ical.0 (32027) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                                2025-03-02 07:57:01.387  - info: ical.0 (32027) processing URL: calendar1 https://calendar.google.com/calendar/ical/..........................................
                                2025-03-02 07:57:06.485  - info: ical.0 (32027) Terminated (NO_ERROR): Without reason
                                2025-03-02 07:57:06.999  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32027 terminated with code 0 (NO_ERROR)
                                2025-03-02 07:58:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9006497716894978
                                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
                                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.356973533392654
                                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13181142043582644
                                2025-03-02 07:58:00.029  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32164
                                2025-03-02 07:58:00.035  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
                                2025-03-02 07:58:00.885  - info: ical.0 (32164) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                                2025-03-02 07:58:01.490  - info: ical.0 (32164) processing URL: calendar1 https://calendar.google.com/calendar/ical/.............................................................
                                2025-03-02 07:58:06.605  - info: ical.0 (32164) Terminated (NO_ERROR): Without reason
                                2025-03-02 07:58:07.132  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32164 terminated with code 0 (NO_ERROR)
                                Der logparser geht leider immer noch nicht, die gleichen Fehler und er wird auch nicht grün.
                                VG Axel
                                  @afi
                                  Dann die Kiste neu starten, damit der afischer auch in den richtigen Gruppen ist.
                                  Und die Fehlermeldungen als Text hier rein.
                                  • AFi
                                    @thomas-braun Alles ausgeführt, anbei Situation:
                                    843
                                    Log-Größe: 16.1 KB
                                    Zeit
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: Node.js v20.18.3
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: }
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: Require stack:
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: ^
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: throw err;
                                    host.NUCioBroker
                                    	2025-03-02 08:54:39.793	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: Node.js v20.18.3
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: }
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: Require stack:
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: ^
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: throw err;
                                    host.NUCioBroker
                                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: Node.js v20.18.3
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: }
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: Require stack:
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: ^
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: throw err;
                                    host.NUCioBroker
                                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.513	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.513	error	Caught by controller[0]: Node.js v20.18.3
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: }
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: Require stack:
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: ^
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.511	error	Caught by controller[0]: throw err;
                                    host.NUCioBroker
                                    	2025-03-02 08:54:04.511	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                    VG Axel
                                    • mcm1957
                                      mcm1957 @AFi last edited by mcm1957
                                      @afi
                                      Ich glaub ich kann das abkürzen.
                                      Beim Adapter logparser fehlt die dependency zu node-schedule. Ist ein Bug des Adapters.
                                      Ich werd im Laufe des Vormittags eine neue Release erstellen. Wenn du so lange warten willst ok, wenn nicht musst du das package node-schedule vorerst mal manuell installieren. Thomas kann da am besten sagen wie da maccht und dabie nicht allzuviel zerstörst :-).
                                        Thomas Braun Most Active @mcm1957 last edited by
                                        @mcm1957 sagte in Test Adapter Log Parser 2.1.x Latest:
                                        Okay, hatte mich schon gewundert, bei meiner Testinstallation hab ich nämlich das Modul gar nicht als Dependency im tree gesehen.
                                        AFi mcm1957 2 Replies Last reply Reply Quote 0
                                        • AFi
                                          Hi zusammen,
                                          erst mal vielen Dank an Thomas für die Geduld, ich kann warten, er läuft ja schon ca. 1 Woche nicht mehr, ich hatte nur gestern die Zeit.
                                          VG Axel
                                          • mcm1957
                                            mcm1957 @Thomas Braun last edited by
                                            Wahrscheinlich verwenden das Modul zig andere Adapter. Und damit fällt der Fehler nur auf, wenn das System sehr wenige Adapter enthält.
                                            Egal - das such ich nicht.
                                            Fakt ist dass die Dependency im package.json nicht drinnen ist udn im Code geladen wird.
                                            Ergo ist da was faul was zu beheben ist.
                                            107
                                            11219
