    4. Test Adapter Log Parser 2.4.x Latest
      Thomas Braun Most Active @AFi last edited by
      @afi sagte in Test Adapter Log Parser 2.1.x Latest:
      Auf was schaust Du
      Auf alles.
      • AFi
        AFi @AFi last edited by
        @afi Hier die diag:
        ========== Start marking the full check here ===========
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
         Static hostname: NUCioBroker
               Icon name: computer-desktop
                 Chassis: desktop 🖥️
                  Kernel: Linux 6.1.0-31-amd64
            Architecture: x86-64
         Hardware Vendor: Intel_R_ Client Systems
          Hardware Model: NUC8i3BEH
        Firmware Version: BECFL357.86A.0077.2019.1127.1452
        OS is similar to:
        model name      : Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         20:11:58 up  8:24,  2 users,  load average: 0.49, 0.33, 0.24
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Sat 2025-03-01 20:11:58 CET
                   Universal time: Sat 2025-03-01 19:11:58 UTC
                         RTC time: Sat 2025-03-01 19:11:58
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        afischer
        HOME=/home/afischer
        GROUPS=afischer cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout sudo audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:             16G        2.8G         12G        1.6M        2.0G         13G
        Swap:            17G          0B         17G
        Total:           33G        2.8G         29G
        Active iob-Instances:   24
                15863 M total memory
                 2646 M used memory
                  876 M active memory
                 2823 M inactive memory
                11686 M free memory
                  401 M buffer memory
                 1464 M swap cache
                16253 M total swap
                    0 M used swap
                16253 M free swap
        top - 20:11:58 up  8:24,  2 users,  load average: 0.49, 0.33, 0.24
        Tasks: 158 total,   1 running, 157 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15863.3 total,  11686.5 free,   2646.2 used,   1865.5 buff/cache
        MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13217.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  7.8G     0  7.8G   0% /dev
        tmpfs          tmpfs     1.6G  928K  1.6G   1% /run
        /dev/nvme0n1p2 ext4      213G   18G  184G   9% /
        tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
        tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
        [Sat Mar  1 11:47:38 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Mar  1 11:47:38 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET      SOURCE         FSTYPE OPTIONS
        /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
        `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        2.2G    /var/
        1.1G    /var/log
        1007M   /var/log/journal/................................................................
        837M    /var/lib
        Archived and active journals take up 88.2M in the file system.
        /opt/iobroker/backups:
        648M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        3.5G    /opt/iobroker/iobroker-data/
        2.0G    /opt/iobroker/iobroker-data/history
        1.3G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        42M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.3
        /usr/bin/node           v20.18.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.30.0
        nodejs:
          Installed: 20.18.3-1nodesource1
          Candidate: 20.18.3-1nodesource1
          Version table:
         *** 20.18.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 7322)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.4.10
        javascript:     8.8.3
        nodejs modules from github:     1
        +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#............................................)
        Adapter State
        + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.devices.0                : devices               : NUCioBroker                              -  enabled
        + system.adapter.discovery.0              : discovery             : NUCioBroker                              -  enabled
          system.adapter.dwd.0                    : dwd                   : NUCioBroker                              -  enabled
        + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : NUCioBroker                              -  enabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
          system.adapter.feiertage.0              : feiertage             : NUCioBroker                              -  enabled
          system.adapter.flot.0                   : flot                  : NUCioBroker                              -  enabled
        + system.adapter.followthesun.0           : followthesun          : NUCioBroker                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
        + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
        + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : NUCioBroker                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUCioBroker                              -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : NUCioBroker                              -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : NUCioBroker                              -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUCioBroker                              -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUCioBroker                              -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUCioBroker                              -  enabled
        + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
        + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
          system.adapter.logparser.0              : logparser             : NUCioBroker                              - disabled
        + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
        + system.adapter.plenticore.0             : plenticore            : NUCioBroker                              -  enabled, port: 80
          system.adapter.ring.0                   : ring                  : NUCioBroker                              - disabled
        + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
        + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : NUCioBroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sony-bravia.0            : sony-bravia           : NUCioBroker                              -  enabled
        + system.adapter.statistics.0             : statistics            : NUCioBroker                              -  enabled
        + system.adapter.velux.0                  : velux                 : NUCioBroker                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : NUCioBroker                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUCioBroker                              -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUCioBroker                              -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUCioBroker                              -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUCioBroker                              -  enabled
          system.adapter.vis-history.0            : vis-history           : NUCioBroker                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUCioBroker                              -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : NUCioBroker                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : NUCioBroker                              -  enabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : NUCioBroker                              -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : NUCioBroker                              -  enabled
          system.adapter.vis-map.0                : vis-map               : NUCioBroker                              -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : NUCioBroker                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : NUCioBroker                              -  enabled
          system.adapter.vis-players.0            : vis-players           : NUCioBroker                              -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : NUCioBroker                              -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : NUCioBroker                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              -  enabled
          system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              -  enabled
          system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : NUCioBroker                              -  enabled
        + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wolf-smartset.0          : wolf-smartset         : NUCioBroker                              -  enabled
          system.adapter.worx.0                   : worx                  : NUCioBroker                              - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "cameras"      : 2.1.2    , installed 2.1.2
        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
        Adapter    "ring"         : 6.3.0    , installed 6.3.0
        Adapter    "senec"        : 1.6.17   , installed 1.6.17
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "velux"        : 0.0.8    , installed 0.0.8
        Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "wolf-smartset": 1.2.4    , installed 1.2.4
        Adapter    "worx"         : 3.1.1    , installed 3.1.1
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
        Objects and States
        Objects:        16842
        States:         14088
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://ftp.debian.org/debian bookworm-backports InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
        Get:5 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
        Get:6 https://repos.influxdata.com/debian stable InRelease [6907 B]
        Hit:7 https://repos.influxdata.com/debian bullseye InRelease
        Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
        Err:5 https://packages.grafana.com/oss/deb stable InRelease
        Err:6 https://repos.influxdata.com/debian stable InRelease
        Fetched 6907 B in 1s (9632 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18354      590/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14488      1/init
        tcp        0      0 ..........................    0.0.0.0:*               LISTEN      1001       294317     26500/io.hm-rpc.1
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       290741     26352/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       292954     26352/iobroker.js-c
        tcp        0      0 ..............................    0.0.0.0:*               LISTEN      1001       291509     26534/io.hm-rpc.2
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18975      590/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          14490      1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      0          20073      594/apache2
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        19138      695/grafana
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       292672     26690/io.socketio.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      113        20553      552/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       293699     26736/io.simple-api
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       292139     26370/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       291664     26675/io.web.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1821       521/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14489      1/init
        udp        0      0 0.0.0.0:52029           0.0.0.0:*                           106        1786       537/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        1784       537/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          14491      1/init
        udp6       0      0 :::5353                 :::*                                106        1785       537/avahi-daemon: r
        udp6       0      0 :::38942                :::*                                106        1787       537/avahi-daemon: r
        2025-03-01 20:10:49.105  - info: senec.0 (26644) LowPrio polling ...
        2025-03-01 20:11:00.003  - info: javascript.0 (26436) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
        2025-03-01 20:11:00.009  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.7293831050228311
        2025-03-01 20:11:00.010  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.5693023287671232
        2025-03-01 20:11:00.010  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.39.31211834728203
        2025-03-01 20:11:00.010  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.5693023287671232
        2025-03-01 20:11:00.010  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 44358
        2025-03-01 20:11:00.038  - info: javascript.0 (26436) script.js.common.Programme.RolloSonnenschutz: 17:30
        2025-03-01 20:11:00.793  - info: ical.0 (44358) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
        2025-03-01 20:11:01.348  - info: ical.0 (44358) processing URL: calendar1 https://calendar.google.com/calendar/ical/210a.420.630%40gmail.com/private-...................................................asic.ics
        2025-03-01 20:11:06.443  - info: ical.0 (44358) Terminated (NO_ERROR): Without reason
        2025-03-01 20:11:06.969  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 44358 terminated with code 0 (NO_ERROR)
        2025-03-01 20:11:38.500  - info: admin.0 (26370) <== Disconnect system.user.admin from ::ffff:.............. admin
        2025-03-01 20:11:38.853  - info: admin.0 (26370) failed connection to socket.io from ::ffff:.................: Passport was not initialized
        2025-03-01 20:12:00.003  - info: javascript.0 (26436) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
        2025-03-01 20:12:00.007  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 44729
        2025-03-01 20:12:00.027  - info: javascript.0 (26436) script.js.common.Programme.RolloSonnenschutz: 17:30
        2025-03-01 20:12:00.080  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.7049164383561645
        2025-03-01 20:12:00.081  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.5693023287671232
        2025-03-01 20:12:00.081  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.39.32160671942815
        2025-03-01 20:12:00.081  - info: javascript.0 (26436) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.5693023287671232
        2025-03-01 20:12:00.994  - info: ical.0 (44729) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
        2025-03-01 20:12:01.646  - info: ical.0 (44729) processing URL: calendar1 https://calendar.google.com/calendar/ical/210a.420.630%40gmail.com/private-............................................................
        2025-03-01 20:12:06.743  - info: ical.0 (44729) Terminated (NO_ERROR): Without reason
        2025-03-01 20:12:07.266  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 44729 terminated with code 0 (NO_ERROR)
        VG Axel
          Thomas Braun Most Active @AFi last edited by Thomas Braun
          @afi
          sudo usermod -a G adm,iobroker afischer
          sudo systemctl set-default multi-user.target
          sudo rm /etc/apt/sources.list.d/grafana*
          sudo apt-get install -y apt-transport-https
          sudo apt-get install -y software-properties-common wget
          sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
          echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
          sudo rm /etc/apt/sources.list.d/influ*
          wget -q https://repos.influxdata.com/influxdata-archive_compat.key
          echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
          echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
          rm influxdata-archive_compat.key
          Neustart.
          Dann
          cd /opt/iobroker && npm ls node-schedule
          AFi 1 Reply Last reply Reply Quote 0
          • AFi
            AFi @Thomas Braun last edited by
            @thomas-braun Anbei Ergebnis
            iobroker.inst@2.0.3 /opt/iobroker
            ├─┬ iobroker.followthesun@0.5.1
            │ └── node-schedule@2.1.0
            ├─┬ iobroker.javascript@8.8.3
            │ └── node-schedule@2.1.1
            ├─┬ iobroker.js-controller@7.0.6
            │ ├─┬ @iobroker/js-controller-adapter@7.0.6
            │ │ └── node-schedule@2.1.1
            └─┬ iobroker.ring@6.3.0
            Sagst Du mir später dann mal was wir machen und warum. Lerne gerne dazu.
            VG Axel
              Deine Installation gerade biegen.
              Den ganzen Kram zuvor ausgeführt? Neugestartet?
              Wie schaut
              iob diag
              nun aus?
              • AFi
                @thomas-braun Alles ausgeführt, logparser bringt aber immer noch die gleichen Fehler, anbei diag:
                Script v.2025-02-23
                *** BASE SYSTEM ***
                         Chassis: desktop 🖥️
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 21:53:26 up 19 min,  2 users,  load average: 0.39, 0.20, 0.18
                CPU threads: 4
                               Local time: Sat 2025-03-01 21:53:26 CET
                           Universal time: Sat 2025-03-01 20:53:26 UTC
                                 RTC time: Sat 2025-03-01 20:53:26
                              NTP service: active
                          RTC in local TZ: no
                afischer
                HOME=/home/afischer
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             16G        2.7G         12G        1.5M        1.3G         13G
                Swap:            17G          0B         17G
                Total:           33G        2.7G         30G
                         2533 M used memory
                          455 M active memory
                         2699 M inactive memory
                        12379 M free memory
                          127 M buffer memory
                         1135 M swap cache
                        16253 M total swap
                            0 M used swap
                        16253 M free swap
                top - 21:53:26 up 19 min,  2 users,  load average: 0.39, 0.20, 0.18
                Tasks: 152 total,   1 running, 151 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  15863.3 total,  12379.5 free,   2534.0 used,   1263.8 buff/cache
                MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13329.3 avail Mem
                *** FILESYSTEM ***
                tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
                [Sat Mar  1 21:33:59 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sat Mar  1 21:34:00 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
                /var:
                2.2G    /var/
                1.1G    /var/log
                1015M   /var/log/journal/d25f012e03a44a28958f2441a93e8860
                838M    /var/lib
                3.6G    /opt/iobroker/iobroker-data/
                29M     /opt/iobroker/iobroker-data/objects.jsonl
                24M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 1157)
                admin:          7.4.10
                javascript:     8.8.3
                +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#................................)
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16842
                States:         14079
                Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:4 http://ftp.debian.org/debian bookworm-backports InRelease
                Fetched 6907 B in 1s (9483 B/s)
                Pending Updates: 0
                tcp        0      0 192.168.188.52:42010    0.0.0.0:*               LISTEN      1001       20141      931/io.hm-rpc.2
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16223      686/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16240      686/iobroker.js-con
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16146      583/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14402      1/init
                tcp        0      0 192.168.188.52:12001    0.0.0.0:*               LISTEN      1001       21886      895/io.hm-rpc.1
                tcp6       0      0 :::3000                 :::*                    LISTEN      112        17397      685/grafana
                tcp6       0      0 :::22                   :::*                    LISTEN      0          20671      583/sshd: /usr/sbin
                tcp6       0      0 :::111                  :::*                    LISTEN      0          14404      1/init
                tcp6       0      0 :::80                   :::*                    LISTEN      0          20649      591/apache2
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22146      1133/io.simple-api.
                tcp6       0      0 :::8086                 :::*                    LISTEN      113        16191      568/influxd
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23596      1102/io.socketio.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20294      1087/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19921      758/io.admin.0
                udp        0      0 0.0.0.0:39313           0.0.0.0:*                           106        20616      539/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16133      521/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14403      1/init
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        20614      539/avahi-daemon: r
                udp6       0      0 :::111                  :::*                                0          14405      1/init
                udp6       0      0 :::5353                 :::*                                106        20615      539/avahi-daemon: r
                udp6       0      0 :::46354                :::*                                106        20617      539/avahi-daemon: r
                2025-03-01 21:51:08.986  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3597 terminated with code 0 (NO_ERROR)
                2025-03-01 21:51:29.509  - info: web.0 (1087) ==> Connected system.user.admin from ::ffff:192.168.188.57
                2025-03-01 21:51:32.115  - info: web.0 (1087) ==> Connected system.user.admin from ::ffff:192.168.188.57
                2025-03-01 21:52:00.003  - info: javascript.0 (826) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                2025-03-01 21:52:00.013  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3643
                2025-03-01 21:52:00.024  - info: javascript.0 (826) script.js.common.Programme.RolloSonnenschutz: 17:30
                2025-03-01 21:52:00.048  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.509183105022831
                2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.4079523287671233
                2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.40.00817389522731
                2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.4079523287671233
                2025-03-01 21:52:00.860  - info: ical.0 (3643) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                2025-03-01 21:52:01.406  - info: ical.0 (3643) processing URL: calendar1 https://calendar.google.com/calendar/ical/...........................................................................................
                2025-03-01 21:52:06.517  - info: ical.0 (3643) Terminated (NO_ERROR): Without reason
                2025-03-01 21:52:07.034  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3643 terminated with code 0 (NO_ERROR)
                2025-03-01 21:53:00.003  - info: javascript.0 (826) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.509183105022831
                2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.4079523287671233
                2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.40.01497310070676
                2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.4079523287671233
                2025-03-01 21:53:00.017  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3719
                2025-03-01 21:53:00.169  - info: javascript.0 (826) script.js.common.Programme.RolloSonnenschutz: 17:30
                2025-03-01 21:53:00.924  - info: ical.0 (3719) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                2025-03-01 21:53:01.496  - info: ical.0 (3719) processing URL: calendar1 https://calendar.google.com/calendar/ical/........................................................................
                2025-03-01 21:53:06.597  - info: ical.0 (3719) Terminated (NO_ERROR): Without reason
                2025-03-01 21:53:07.127  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3719 terminated with code 0 (NO_ERROR)
                • AFi
                  Hallo Thomas,
                  ich habe zuerst nicht verstanden, dass ich alle Befehle ausführen muss, morgen gehts weiter, ich sende Dir dann eine neue diag.
                  Gruß Axel
                  • AFi
                    Hallo Thomas,
                    anbei diag:
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                             Chassis: desktop 🖥️
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                     07:58:07 up  9:39,  2 users,  load average: 0.62, 0.37, 0.26
                    CPU threads: 4
                                   Local time: Sun 2025-03-02 07:58:07 CET
                               Universal time: Sun 2025-03-02 06:58:07 UTC
                                     RTC time: Sun 2025-03-02 06:58:07
                                  NTP service: active
                              RTC in local TZ: no
                    afischer
                    HOME=/home/afischer
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:             16G        2.8G         12G        1.6M        1.8G         13G
                    Swap:            17G          0B         17G
                    Total:           33G        2.8G         29G
                             2677 M used memory
                              693 M active memory
                             2996 M inactive memory
                            11814 M free memory
                              333 M buffer memory
                             1363 M swap cache
                            16253 M total swap
                                0 M used swap
                            16253 M free swap
                    top - 07:58:07 up  9:39,  2 users,  load average: 0.65, 0.38, 0.26
                    Tasks: 151 total,   1 running, 150 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  15863.3 total,  11813.9 free,   2678.6 used,   1696.5 buff/cache
                    MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13184.6 avail Mem
                    *** FILESYSTEM ***
                    [Sat Mar  1 22:18:45 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Sat Mar  1 22:18:46 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
                    /var:
                    2.2G    /var/
                    1.1G    /var/log/journal/d25f012e03a44a28958f2441a93e8860
                    1.1G    /var/log
                    842M    /var/lib
                    Archived and active journals take up 92.5M in the file system.
                    31M     /opt/iobroker/iobroker-data/objects.jsonl
                    25M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 34758)
                    admin:          7.4.10
                    javascript:     8.8.3
                    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        16834
                    States:         14071
                    Hit:5 https://apt.grafana.com stable InRelease
                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 ................................:12001    0.0.0.0:*               LISTEN      1001       22772      905/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21552      689/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20583      689/iobroker.js-con
                    tcp        0      0 .......................:42010    0.0.0.0:*               LISTEN      1001       19222      941/io.hm-rpc.2
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20498      592/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1322       1/init
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21131      1097/io.socketio.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23554      1143/io.simple-api.
                    tcp6       0      0 :::8086                 :::*                    LISTEN      113        18777      561/influxd
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18864      738/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23025      1082/io.web.0
                    tcp6       0      0 :::3000                 :::*                    LISTEN      112        21589      688/grafana
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          20500      592/sshd: /usr/sbin
                    tcp6       0      0 :::80                   :::*                    LISTEN      0          20484      594/apache2
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          1324       1/init
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13167      540/avahi-daemon: r
                    udp        0      0 0.0.0.0:48151           0.0.0.0:*                           106        13169      540/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18578      520/dhclient
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1323       1/init
                    udp6       0      0 :::44674                :::*                                106        13170      540/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                106        13168      540/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          1325       1/init
                    2025-03-02 07:56:49.438  - info: weatherunderground.0 (31989) Terminated (NO_ERROR): Without reason
                    2025-03-02 07:56:49.940  - warn: weatherunderground.0 (31989) get state error: Connection is closed.
                    2025-03-02 07:56:49.950  - info: host.NUCioBroker instance system.adapter.weatherunderground.0 having pid 31989 terminated with code 0 (NO_ERROR)
                    2025-03-02 07:57:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                    2025-03-02 07:57:00.009  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32027
                    2025-03-02 07:57:00.021  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
                    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9251164383561645
                    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
                    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.35477667638539
                    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13530643784915464
                    2025-03-02 07:57:00.825  - info: ical.0 (32027) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                    2025-03-02 07:57:01.387  - info: ical.0 (32027) processing URL: calendar1 https://calendar.google.com/calendar/ical/..........................................
                    2025-03-02 07:57:06.485  - info: ical.0 (32027) Terminated (NO_ERROR): Without reason
                    2025-03-02 07:57:06.999  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32027 terminated with code 0 (NO_ERROR)
                    2025-03-02 07:58:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9006497716894978
                    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
                    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.356973533392654
                    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13181142043582644
                    2025-03-02 07:58:00.029  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32164
                    2025-03-02 07:58:00.035  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
                    2025-03-02 07:58:00.885  - info: ical.0 (32164) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                    2025-03-02 07:58:01.490  - info: ical.0 (32164) processing URL: calendar1 https://calendar.google.com/calendar/ical/.............................................................
                    2025-03-02 07:58:06.605  - info: ical.0 (32164) Terminated (NO_ERROR): Without reason
                    2025-03-02 07:58:07.132  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32164 terminated with code 0 (NO_ERROR)
                    Der logparser geht leider immer noch nicht, die gleichen Fehler und er wird auch nicht grün.
                    VG Axel
                      @afi
                      Dann die Kiste neu starten, damit der afischer auch in den richtigen Gruppen ist.
                      Und die Fehlermeldungen als Text hier rein.
                      • AFi
                        @thomas-braun Alles ausgeführt, anbei Situation:
                        843
                        Log-Größe: 16.1 KB
                        Zeit
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: Node.js v20.18.3
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: }
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: Require stack:
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: ^
                        host.NUCioBroker
                        	2025-03-02 08:54:39.794	error	Caught by controller[0]: throw err;
                        host.NUCioBroker
                        	2025-03-02 08:54:39.793	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: Node.js v20.18.3
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: }
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: Require stack:
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: ^
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: throw err;
                        host.NUCioBroker
                        	2025-03-02 08:54:28.381	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: Node.js v20.18.3
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: }
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: Require stack:
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: ^
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: throw err;
                        host.NUCioBroker
                        	2025-03-02 08:54:16.894	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                        host.NUCioBroker
                        	2025-03-02 08:54:04.513	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.513	error	Caught by controller[0]: Node.js v20.18.3
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: }
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: Require stack:
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                        host.NUCioBroker
                        	2025-03-02 08:54:04.512	error	Caught by controller[0]: ^
                        host.NUCioBroker
                        	2025-03-02 08:54:04.511	error	Caught by controller[0]: throw err;
                        host.NUCioBroker
                        	2025-03-02 08:54:04.511	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                        VG Axel
                        • mcm1957
                          mcm1957 @AFi last edited by mcm1957
                          @afi
                          Ich glaub ich kann das abkürzen.
                          Beim Adapter logparser fehlt die dependency zu node-schedule. Ist ein Bug des Adapters.
                          Ich werd im Laufe des Vormittags eine neue Release erstellen. Wenn du so lange warten willst ok, wenn nicht musst du das package node-schedule vorerst mal manuell installieren. Thomas kann da am besten sagen wie da maccht und dabie nicht allzuviel zerstörst :-).
                            Thomas Braun Most Active @mcm1957 last edited by
                            @mcm1957 sagte in Test Adapter Log Parser 2.1.x Latest:
                            Okay, hatte mich schon gewundert, bei meiner Testinstallation hab ich nämlich das Modul gar nicht als Dependency im tree gesehen.
                            AFi mcm1957 2 Replies Last reply Reply Quote 0
                            • AFi
                              Hi zusammen,
                              erst mal vielen Dank an Thomas für die Geduld, ich kann warten, er läuft ja schon ca. 1 Woche nicht mehr, ich hatte nur gestern die Zeit.
                              VG Axel
                              • mcm1957
                                mcm1957 @Thomas Braun last edited by
                                Wahrscheinlich verwenden das Modul zig andere Adapter. Und damit fällt der Fehler nur auf, wenn das System sehr wenige Adapter enthält.
                                Egal - das such ich nicht.
                                Fakt ist dass die Dependency im package.json nicht drinnen ist udn im Code geladen wird.
                                Ergo ist da was faul was zu beheben ist.
                                  @mcm1957
                                  Ja, das wird bei mir von zig anderen Adaptern verwendet. Deswegen hatte mich die Meldung, dass es nicht gefunden werden kann etwas verwundert. Aber wenn es im Bauplan des Adapters gar nicht erst drin ist kein Wunder.
                                  • mcm1957
                                    Bin noch dran - dauert noch ein wenig.
                                    Aber wenigstens ist (mir) jetzt auch klar warum die Tests nicht schiefgegangen sind. node-schedule war als devDependency drinne. Damit gehts lokal am dev-server und auch die tests laden die dev-Dependencies (da sie ja den Test-Support brauchen)...
                                    • AFi
                                      AFi @mcm1957 last edited by
                                      @mcm1957 Hi, mir ist aber nicht klar, warum es bis vor ca. 2 Wochen gelaufen ist und dann auf einmal nicht mehr. Der Log Parser lief mindestens 3 Jahre (hoffe ich hab mich in der Zeit nicht verhauen). VG Axel
                                      • mcm1957
                                        @afi
                                        möglicherweise hast du zu dem Zeitpunkt etwas deinstalliert oder aktualosiert u npm hat das nicht referenzierte Paket da weggeräumt.
                                        • mcm1957
                                          @afi
                                          Release 2.3.0 wurde eben erstellt und sollte ab morgen im LATEST / BETA Repository verfügbar sein. Änderungen siehe Releasenotes in README.md bzw. 1. Beitrag.
                                          Bitte mal testen obs damit besser geht.
                                          AFi 1 Reply Last reply Reply Quote 1
                                          • Nashra
                                            Nashra Most Active Forum Testing last edited by Nashra
                                            V 2.2.2
                                            Jetzt habe ich wieder das leidige Thema mit Heute, Gestern, Uhrzeit.
                                            Hatte die Tage 3 Adapter (Accuweather, Pegelalarm, Yr.no) deinstalliert
                                            und danach fing es wieder an. Ok, installieren wir mal die neue Beta 2.3.0,
                                            aber leider damit das selbe Problem 😞
                                            Was können wir tun?
                                            107
                                            11274
