    4. Test Adapter Log Parser 2.4.x Latest
      Thomas Braun Most Active @AFi last edited by Thomas Braun
      @afi
      sudo usermod -a G adm,iobroker afischer
      sudo systemctl set-default multi-user.target
      sudo rm /etc/apt/sources.list.d/grafana*
      sudo apt-get install -y apt-transport-https
      sudo apt-get install -y software-properties-common wget
      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
      sudo rm /etc/apt/sources.list.d/influ*
      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      rm influxdata-archive_compat.key
      Neustart.
      Dann
      cd /opt/iobroker && npm ls node-schedule
      AFi 1 Reply Last reply Reply Quote 0
      • AFi
        AFi @Thomas Braun last edited by
        @thomas-braun Anbei Ergebnis
        iobroker.inst@2.0.3 /opt/iobroker
        ├─┬ iobroker.followthesun@0.5.1
        │ └── node-schedule@2.1.0
        ├─┬ iobroker.javascript@8.8.3
        │ └── node-schedule@2.1.1
        ├─┬ iobroker.js-controller@7.0.6
        │ ├─┬ @iobroker/js-controller-adapter@7.0.6
        │ │ └── node-schedule@2.1.1
        └─┬ iobroker.ring@6.3.0
        Sagst Du mir später dann mal was wir machen und warum. Lerne gerne dazu.
        VG Axel
          @afi sagte in Test Adapter Log Parser 2.1.x Latest:
          Deine Installation gerade biegen.
          Den ganzen Kram zuvor ausgeführt? Neugestartet?
          Wie schaut
          iob diag
          nun aus?
          • AFi
            @thomas-braun Alles ausgeführt, logparser bringt aber immer noch die gleichen Fehler, anbei diag:
            ========== Start marking the full check here ===========
            Script v.2025-02-23
            *** BASE SYSTEM ***
             Static hostname: NUCioBroker
                   Icon name: computer-desktop
                     Chassis: desktop 🖥️
                      Kernel: Linux 6.1.0-31-amd64
                Architecture: x86-64
             Hardware Vendor: Intel_R_ Client Systems
              Hardware Model: NUC8i3BEH
            Firmware Version: BECFL357.86A.0077.2019.1127.1452
            OS is similar to:
            model name      : Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             21:53:26 up 19 min,  2 users,  load average: 0.39, 0.20, 0.18
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2025-03-01 21:53:26 CET
                       Universal time: Sat 2025-03-01 20:53:26 UTC
                             RTC time: Sat 2025-03-01 20:53:26
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            afischer
            HOME=/home/afischer
            GROUPS=afischer cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout sudo audio video plugdev
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:             16G        2.7G         12G        1.5M        1.3G         13G
            Swap:            17G          0B         17G
            Total:           33G        2.7G         30G
            Active iob-Instances:   24
                    15863 M total memory
                     2533 M used memory
                      455 M active memory
                     2699 M inactive memory
                    12379 M free memory
                      127 M buffer memory
                     1135 M swap cache
                    16253 M total swap
                        0 M used swap
                    16253 M free swap
            top - 21:53:26 up 19 min,  2 users,  load average: 0.39, 0.20, 0.18
            Tasks: 152 total,   1 running, 151 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  15863.3 total,  12379.5 free,   2534.0 used,   1263.8 buff/cache
            MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13329.3 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  7.8G     0  7.8G   0% /dev
            tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
            /dev/nvme0n1p2 ext4      213G   18G  184G   9% /
            tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
            tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
            [Sat Mar  1 21:33:59 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Mar  1 21:34:00 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET      SOURCE         FSTYPE OPTIONS
            /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
            `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
            /var:
            2.2G    /var/
            1.1G    /var/log
            1015M   /var/log/journal/d25f012e03a44a28958f2441a93e8860
            838M    /var/lib
            Archived and active journals take up 88.2M in the file system.
            /opt/iobroker/backups:
            648M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            3.6G    /opt/iobroker/iobroker-data/
            2.0G    /opt/iobroker/iobroker-data/history
            1.3G    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            29M     /opt/iobroker/iobroker-data/objects.jsonl
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            24M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.3
            /usr/bin/node           v20.18.3
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.30.0
            nodejs:
              Installed: 20.18.3-1nodesource1
              Candidate: 20.18.3-1nodesource1
              Version table:
             *** 20.18.3-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 1157)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.4.10
            javascript:     8.8.3
            nodejs modules from github:     1
            +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#................................)
            Adapter State
            + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              system.adapter.devices.0                : devices               : NUCioBroker                              -  enabled
            + system.adapter.discovery.0              : discovery             : NUCioBroker                              -  enabled
              system.adapter.dwd.0                    : dwd                   : NUCioBroker                              -  enabled
            + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : NUCioBroker                              -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
              system.adapter.feiertage.0              : feiertage             : NUCioBroker                              -  enabled
              system.adapter.flot.0                   : flot                  : NUCioBroker                              -  enabled
            + system.adapter.followthesun.0           : followthesun          : NUCioBroker                              -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
            + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
            + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 12001
            + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : NUCioBroker                              -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUCioBroker                              -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : NUCioBroker                              -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : NUCioBroker                              -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUCioBroker                              -  enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUCioBroker                              -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUCioBroker                              -  enabled
            + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
            + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
              system.adapter.logparser.0              : logparser             : NUCioBroker                              - disabled
            + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
            + system.adapter.plenticore.0             : plenticore            : NUCioBroker                              -  enabled, port: 80
              system.adapter.ring.0                   : ring                  : NUCioBroker                              - disabled
            + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
            + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : NUCioBroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sony-bravia.0            : sony-bravia           : NUCioBroker                              -  enabled
            + system.adapter.statistics.0             : statistics            : NUCioBroker                              -  enabled
            + system.adapter.velux.0                  : velux                 : NUCioBroker                              -  enabled
              system.adapter.vis-bars.0               : vis-bars              : NUCioBroker                              -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUCioBroker                              -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUCioBroker                              -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUCioBroker                              -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUCioBroker                              -  enabled
              system.adapter.vis-history.0            : vis-history           : NUCioBroker                              -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUCioBroker                              -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : NUCioBroker                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : NUCioBroker                              -  enabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : NUCioBroker                              -  enabled
              system.adapter.vis-lcars.0              : vis-lcars             : NUCioBroker                              -  enabled
              system.adapter.vis-map.0                : vis-map               : NUCioBroker                              -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : NUCioBroker                              -  enabled
              system.adapter.vis-metro.0              : vis-metro             : NUCioBroker                              -  enabled
              system.adapter.vis-players.0            : vis-players           : NUCioBroker                              -  enabled
              system.adapter.vis-plumb.0              : vis-plumb             : NUCioBroker                              -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : NUCioBroker                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              -  enabled
              system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              -  enabled
              system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : NUCioBroker                              -  enabled
            + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wolf-smartset.0          : wolf-smartset         : NUCioBroker                              -  enabled
              system.adapter.worx.0                   : worx                  : NUCioBroker                              - disabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.4.10   , installed 7.4.10
            Adapter    "cameras"      : 2.1.2    , installed 2.1.2
            Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
            Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "followthesun" : 0.5.1    , installed 0.5.1
            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
            Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homekit-controller": 0.5.11, installed 0.5.11
            Adapter    "ical"         : 1.16.1   , installed 1.16.1
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "logparser"    : 2.2.2    , installed 2.2.2
            Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
            Adapter    "ring"         : 6.3.0    , installed 6.3.0
            Adapter    "senec"        : 1.6.17   , installed 1.6.17
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "velux"        : 0.0.8    , installed 0.0.8
            Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "wolf-smartset": 1.2.4    , installed 1.2.4
            Adapter    "worx"         : 3.1.1    , installed 3.1.1
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
            Objects and States
            Objects:        16842
            States:         14079
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:4 http://ftp.debian.org/debian bookworm-backports InRelease
            Get:5 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
            Get:6 https://repos.influxdata.com/debian stable InRelease [6907 B]
            Hit:7 https://repos.influxdata.com/debian bullseye InRelease
            Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
            Err:5 https://packages.grafana.com/oss/deb stable InRelease
            Err:6 https://repos.influxdata.com/debian stable InRelease
            Fetched 6907 B in 1s (9483 B/s)
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.188.52:42010    0.0.0.0:*               LISTEN      1001       20141      931/io.hm-rpc.2
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16223      686/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16240      686/iobroker.js-con
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16146      583/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14402      1/init
            tcp        0      0 192.168.188.52:12001    0.0.0.0:*               LISTEN      1001       21886      895/io.hm-rpc.1
            tcp6       0      0 :::3000                 :::*                    LISTEN      112        17397      685/grafana
            tcp6       0      0 :::22                   :::*                    LISTEN      0          20671      583/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          14404      1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      0          20649      591/apache2
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22146      1133/io.simple-api.
            tcp6       0      0 :::8086                 :::*                    LISTEN      113        16191      568/influxd
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23596      1102/io.socketio.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20294      1087/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19921      758/io.admin.0
            udp        0      0 0.0.0.0:39313           0.0.0.0:*                           106        20616      539/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16133      521/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14403      1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        20614      539/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          14405      1/init
            udp6       0      0 :::5353                 :::*                                106        20615      539/avahi-daemon: r
            udp6       0      0 :::46354                :::*                                106        20617      539/avahi-daemon: r
            2025-03-01 21:51:08.986  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3597 terminated with code 0 (NO_ERROR)
            2025-03-01 21:51:29.509  - info: web.0 (1087) ==> Connected system.user.admin from ::ffff:192.168.188.57
            2025-03-01 21:51:32.115  - info: web.0 (1087) ==> Connected system.user.admin from ::ffff:192.168.188.57
            2025-03-01 21:52:00.003  - info: javascript.0 (826) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
            2025-03-01 21:52:00.013  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3643
            2025-03-01 21:52:00.024  - info: javascript.0 (826) script.js.common.Programme.RolloSonnenschutz: 17:30
            2025-03-01 21:52:00.048  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.509183105022831
            2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.4079523287671233
            2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.40.00817389522731
            2025-03-01 21:52:00.049  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.4079523287671233
            2025-03-01 21:52:00.860  - info: ical.0 (3643) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-03-01 21:52:01.406  - info: ical.0 (3643) processing URL: calendar1 https://calendar.google.com/calendar/ical/...........................................................................................
            2025-03-01 21:52:06.517  - info: ical.0 (3643) Terminated (NO_ERROR): Without reason
            2025-03-01 21:52:07.034  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3643 terminated with code 0 (NO_ERROR)
            2025-03-01 21:53:00.003  - info: javascript.0 (826) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.509183105022831
            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.4079523287671233
            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.40.01497310070676
            2025-03-01 21:53:00.013  - info: javascript.0 (826) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.4079523287671233
            2025-03-01 21:53:00.017  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3719
            2025-03-01 21:53:00.169  - info: javascript.0 (826) script.js.common.Programme.RolloSonnenschutz: 17:30
            2025-03-01 21:53:00.924  - info: ical.0 (3719) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-03-01 21:53:01.496  - info: ical.0 (3719) processing URL: calendar1 https://calendar.google.com/calendar/ical/........................................................................
            2025-03-01 21:53:06.597  - info: ical.0 (3719) Terminated (NO_ERROR): Without reason
            2025-03-01 21:53:07.127  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 3719 terminated with code 0 (NO_ERROR)
            • AFi
              AFi @AFi last edited by
              Hallo Thomas,
              ich habe zuerst nicht verstanden, dass ich alle Befehle ausführen muss, morgen gehts weiter, ich sende Dir dann eine neue diag.
              Gruß Axel
              • AFi
                Hallo Thomas,
                anbei diag:
                Script v.2025-02-23
                *** BASE SYSTEM ***
                         Chassis: desktop 🖥️
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 07:58:07 up  9:39,  2 users,  load average: 0.62, 0.37, 0.26
                CPU threads: 4
                               Local time: Sun 2025-03-02 07:58:07 CET
                           Universal time: Sun 2025-03-02 06:58:07 UTC
                                 RTC time: Sun 2025-03-02 06:58:07
                              NTP service: active
                          RTC in local TZ: no
                afischer
                HOME=/home/afischer
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             16G        2.8G         12G        1.6M        1.8G         13G
                Swap:            17G          0B         17G
                Total:           33G        2.8G         29G
                         2677 M used memory
                          693 M active memory
                         2996 M inactive memory
                        11814 M free memory
                          333 M buffer memory
                         1363 M swap cache
                        16253 M total swap
                            0 M used swap
                        16253 M free swap
                top - 07:58:07 up  9:39,  2 users,  load average: 0.65, 0.38, 0.26
                Tasks: 151 total,   1 running, 150 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  15863.3 total,  11813.9 free,   2678.6 used,   1696.5 buff/cache
                MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13184.6 avail Mem
                *** FILESYSTEM ***
                [Sat Mar  1 22:18:45 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sat Mar  1 22:18:46 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
                /var:
                2.2G    /var/
                1.1G    /var/log/journal/d25f012e03a44a28958f2441a93e8860
                1.1G    /var/log
                842M    /var/lib
                Archived and active journals take up 92.5M in the file system.
                31M     /opt/iobroker/iobroker-data/objects.jsonl
                25M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 34758)
                admin:          7.4.10
                javascript:     8.8.3
                +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16834
                States:         14071
                Hit:1 http://ftp.debian.org/debian bookworm-backports InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Hit:5 https://apt.grafana.com stable InRelease
                Hit:6 https://repos.influxdata.com/debian stable InRelease
                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 ................................:12001    0.0.0.0:*               LISTEN      1001       22772      905/io.hm-rpc.1
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21552      689/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20583      689/iobroker.js-con
                tcp        0      0 .......................:42010    0.0.0.0:*               LISTEN      1001       19222      941/io.hm-rpc.2
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20498      592/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1322       1/init
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21131      1097/io.socketio.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23554      1143/io.simple-api.
                tcp6       0      0 :::8086                 :::*                    LISTEN      113        18777      561/influxd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18864      738/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23025      1082/io.web.0
                tcp6       0      0 :::3000                 :::*                    LISTEN      112        21589      688/grafana
                tcp6       0      0 :::22                   :::*                    LISTEN      0          20500      592/sshd: /usr/sbin
                tcp6       0      0 :::80                   :::*                    LISTEN      0          20484      594/apache2
                tcp6       0      0 :::111                  :::*                    LISTEN      0          1324       1/init
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13167      540/avahi-daemon: r
                udp        0      0 0.0.0.0:48151           0.0.0.0:*                           106        13169      540/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18578      520/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1323       1/init
                udp6       0      0 :::44674                :::*                                106        13170      540/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                106        13168      540/avahi-daemon: r
                udp6       0      0 :::111                  :::*                                0          1325       1/init
                2025-03-02 07:56:49.438  - info: weatherunderground.0 (31989) Terminated (NO_ERROR): Without reason
                2025-03-02 07:56:49.940  - warn: weatherunderground.0 (31989) get state error: Connection is closed.
                2025-03-02 07:56:49.950  - info: host.NUCioBroker instance system.adapter.weatherunderground.0 having pid 31989 terminated with code 0 (NO_ERROR)
                2025-03-02 07:57:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                2025-03-02 07:57:00.009  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32027
                2025-03-02 07:57:00.021  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9251164383561645
                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.35477667638539
                2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13530643784915464
                2025-03-02 07:57:00.825  - info: ical.0 (32027) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                2025-03-02 07:57:01.387  - info: ical.0 (32027) processing URL: calendar1 https://calendar.google.com/calendar/ical/..........................................
                2025-03-02 07:57:06.485  - info: ical.0 (32027) Terminated (NO_ERROR): Without reason
                2025-03-02 07:57:06.999  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32027 terminated with code 0 (NO_ERROR)
                2025-03-02 07:58:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9006497716894978
                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.356973533392654
                2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13181142043582644
                2025-03-02 07:58:00.029  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32164
                2025-03-02 07:58:00.035  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
                2025-03-02 07:58:00.885  - info: ical.0 (32164) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
                2025-03-02 07:58:01.490  - info: ical.0 (32164) processing URL: calendar1 https://calendar.google.com/calendar/ical/.............................................................
                2025-03-02 07:58:06.605  - info: ical.0 (32164) Terminated (NO_ERROR): Without reason
                2025-03-02 07:58:07.132  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32164 terminated with code 0 (NO_ERROR)
                Der logparser geht leider immer noch nicht, die gleichen Fehler und er wird auch nicht grün.
                VG Axel
                  @afi
                  Dann die Kiste neu starten, damit der afischer auch in den richtigen Gruppen ist.
                  Und die Fehlermeldungen als Text hier rein.
                  • AFi
                    @thomas-braun Alles ausgeführt, anbei Situation:
                    843
                    Log-Größe: 16.1 KB
                    Zeit
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: Node.js v20.18.3
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: }
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: Require stack:
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: ^
                    host.NUCioBroker
                    	2025-03-02 08:54:39.794	error	Caught by controller[0]: throw err;
                    host.NUCioBroker
                    	2025-03-02 08:54:39.793	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: Node.js v20.18.3
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: }
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: Require stack:
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: ^
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: throw err;
                    host.NUCioBroker
                    	2025-03-02 08:54:28.381	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: Node.js v20.18.3
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: }
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: Require stack:
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: ^
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: throw err;
                    host.NUCioBroker
                    	2025-03-02 08:54:16.894	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                    host.NUCioBroker
                    	2025-03-02 08:54:04.513	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.513	error	Caught by controller[0]: Node.js v20.18.3
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: }
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: Require stack:
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
                    host.NUCioBroker
                    	2025-03-02 08:54:04.512	error	Caught by controller[0]: ^
                    host.NUCioBroker
                    	2025-03-02 08:54:04.511	error	Caught by controller[0]: throw err;
                    host.NUCioBroker
                    	2025-03-02 08:54:04.511	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
                    VG Axel
                    • mcm1957
                      mcm1957 @AFi last edited by mcm1957
                      @afi
                      Ich glaub ich kann das abkürzen.
                      Beim Adapter logparser fehlt die dependency zu node-schedule. Ist ein Bug des Adapters.
                      Ich werd im Laufe des Vormittags eine neue Release erstellen. Wenn du so lange warten willst ok, wenn nicht musst du das package node-schedule vorerst mal manuell installieren. Thomas kann da am besten sagen wie da maccht und dabie nicht allzuviel zerstörst :-).
                        Thomas Braun Most Active @mcm1957 last edited by
                        @mcm1957 sagte in Test Adapter Log Parser 2.1.x Latest:
                        Okay, hatte mich schon gewundert, bei meiner Testinstallation hab ich nämlich das Modul gar nicht als Dependency im tree gesehen.
                        AFi mcm1957 2 Replies Last reply Reply Quote 0
                        • AFi
                          Hi zusammen,
                          erst mal vielen Dank an Thomas für die Geduld, ich kann warten, er läuft ja schon ca. 1 Woche nicht mehr, ich hatte nur gestern die Zeit.
                          VG Axel
                          • mcm1957
                            mcm1957 @Thomas Braun last edited by
                            Wahrscheinlich verwenden das Modul zig andere Adapter. Und damit fällt der Fehler nur auf, wenn das System sehr wenige Adapter enthält.
                            Egal - das such ich nicht.
                            Fakt ist dass die Dependency im package.json nicht drinnen ist udn im Code geladen wird.
                            Ergo ist da was faul was zu beheben ist.
                              @mcm1957
                              Ja, das wird bei mir von zig anderen Adaptern verwendet. Deswegen hatte mich die Meldung, dass es nicht gefunden werden kann etwas verwundert. Aber wenn es im Bauplan des Adapters gar nicht erst drin ist kein Wunder.
                              • mcm1957
                                Bin noch dran - dauert noch ein wenig.
                                Aber wenigstens ist (mir) jetzt auch klar warum die Tests nicht schiefgegangen sind. node-schedule war als devDependency drinne. Damit gehts lokal am dev-server und auch die tests laden die dev-Dependencies (da sie ja den Test-Support brauchen)...
                                • AFi
                                  AFi @mcm1957 last edited by
                                  @mcm1957 Hi, mir ist aber nicht klar, warum es bis vor ca. 2 Wochen gelaufen ist und dann auf einmal nicht mehr. Der Log Parser lief mindestens 3 Jahre (hoffe ich hab mich in der Zeit nicht verhauen). VG Axel
                                  • mcm1957
                                    @afi
                                    möglicherweise hast du zu dem Zeitpunkt etwas deinstalliert oder aktualosiert u npm hat das nicht referenzierte Paket da weggeräumt.
                                    • mcm1957
                                      @afi
                                      Release 2.3.0 wurde eben erstellt und sollte ab morgen im LATEST / BETA Repository verfügbar sein. Änderungen siehe Releasenotes in README.md bzw. 1. Beitrag.
                                      Bitte mal testen obs damit besser geht.
                                      AFi 1 Reply Last reply Reply Quote 1
                                      • Nashra
                                        Nashra Most Active Forum Testing last edited by Nashra
                                        V 2.2.2
                                        Jetzt habe ich wieder das leidige Thema mit Heute, Gestern, Uhrzeit.
                                        Hatte die Tage 3 Adapter (Accuweather, Pegelalarm, Yr.no) deinstalliert
                                        und danach fing es wieder an. Ok, installieren wir mal die neue Beta 2.3.0,
                                        aber leider damit das selbe Problem 😞
                                        Was können wir tun?
                                          eitljoerggmx.at last edited by
                                          Hallo!
                                          Ich versuche Logeinträge in verschiedenen Farben dazustellen, schaffe es aber nicht, da ich keinen Weg finde.
                                          Toll wäre, wenn bei Logeinträgen nach Begriffen gesucht werden könnte und dann die entsprechende Farbe für den gesamten Logeintrag anpassbar wäre.
                                          Als Beispiel: Ein Logeintrag enthält den Begriff "Klimaanlage". Der gesamte Logtext wird dann in der gewählten Farbe ausgegeben.
                                          Kennt da jemand einen Weg?
                                          Liebe Grüße
                                          • AFi
                                            @mcm1957 Hi, wann kommt den die Release 2.3....
                                            107
                                            11276
