    4. "admin.0 Restart loop detected" und keine Trigger mehr
    • KlausStoertebeker
      KlausStoertebeker @mcm1957 last edited by
      @mcm1957
      Moin,
      ich habe stable-Repository angepasst, und das hat zum sofortigen Erfolg geführt. Und das latest-Repository habe ich gelöscht, weil ich da aktuell keinen Adapter von brauche.
      • KlausStoertebeker
        KlausStoertebeker @KlausStoertebeker last edited by KlausStoertebeker
        Und hier, wie angefordert, die Ausgabe von iob diag:
        Script v.2025-02-23
        *** BASE SYSTEM ***
         Static hostname: Nordmanns-Raspberry-Pi5
               Icon name: computer
                  Kernel: Linux 6.6.74+rpt-rpi-2712
            Architecture: arm64
        OS is similar to:
        Model		: Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         10:18:32 up 16:45,  4 users,  load average: 0.28, 0.32, 0.30
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2025-02-28 10:18:32 CET
                   Universal time: Fri 2025-02-28 09:18:32 UTC
                         RTC time: Fri 2025-02-28 09:18:32
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        ansgarhoeber
        HOME=/home/ansgarhoeber
        GROUPS=ansgarhoeber adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: true
        Desktop:
        Terminal: 	tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            8.5G        2.5G        3.9G         98M        2.2G        5.9G
        Swap:           209M          0B        209M
        Total:          8.7G        2.5G        4.1G
        Active iob-Instances: 	25
                 8064 M total memory
                 2427 M used memory
                 2371 M active memory
                 1450 M inactive memory
                 3700 M free memory
                  394 M buffer memory
                 1723 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 10:18:32 up 16:45,  4 users,  load average: 0.28, 0.32, 0.30
        Tasks: 267 total,   1 running, 266 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8064.1 total,   3699.6 free,   2427.9 used,   2118.0 buff/cache
        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5636.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     807M  6.4M  801M   1% /run
        /dev/nvme0n1p2 ext4      234G   12G  210G   6% /
        tmpfs          tmpfs     4.0G  288K  4.0G   1% /dev/shm
        tmpfs          tmpfs     5.0M   64K  5.0M   2% /run/lock
        /dev/nvme0n1p1 vfat      511M   77M  435M  15% /boot/firmware
        tmpfs          tmpfs     807M  208K  807M   1% /run/user/1000
        [Thu Feb 27 17:32:41 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:42:E1:7E vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=628bce8a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Thu Feb 27 17:32:42 2025] EXT4-fs (nvme0n1p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
        [Thu Feb 27 17:32:43 2025] EXT4-fs (nvme0n1p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET               SOURCE         FSTYPE      OPTIONS
        /                    /dev/nvme0n1p2 ext4        rw,noatime
        |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.3G	/var/
        1.6G	/var/cache/apt
        1.6G	/var/cache
        1.5G	/var/cache/apt/archives
        318M	/var/log
        Archived and active journals take up 316.6M in the file system.
        /opt/iobroker/backups:
        4.0K	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.4G	/opt/iobroker/iobroker-data/
        1.3G	/opt/iobroker/iobroker-data/files
        617M	/opt/iobroker/iobroker-data/files/javascript.admin
        560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
        24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-0658_0200-if00
        /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT2PTYKW-if00-port0
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.18.3
        /usr/bin/node 		v20.18.3
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.30.0
        nodejs:
          Installed: 20.18.3-1nodesource1
          Candidate: 20.18.3-1nodesource1
          Version table:
         *** 20.18.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
             18.19.0+dfsg-6~deb12u1 500
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        Nordmanns-Raspberry-Pi5 Nordmanns-Raspberry-Pi5 (version: 7.0.6, hostname: Nordmanns-Raspberry-Pi5, alive, uptime: 1348)
        Core adapters versions
        js-controller: 	7.0.6
        admin: 		7.4.10
        javascript: 	8.8.3
        nodejs modules from github: 	3
        +-- iobroker.homepilot20@0.0.68 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#d6dbb5c1b9a8cf5396bc139cd2e0dd7ad68aec10)
        +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
        | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
        Adapter State
          system.adapter.acme.0                   : acme                  : Nordmanns-Raspberry-Pi5                  - disabled
          system.adapter.adb.0                    : adb                   : Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.admin.0                  : admin                 : Nordmanns-Raspberry-Pi5                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.backitup.0               : backitup              : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : Nordmanns-Raspberry-Pi5                  -  enabled
          system.adapter.discovery.0              : discovery             : Nordmanns-Raspberry-Pi5                  - disabled
          system.adapter.dwd.0                    : dwd                   : Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.dysonairpurifier.0       : dysonairpurifier      : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.echarts.0                : echarts               : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.ekey.0                   : ekey                  : Nordmanns-Raspberry-Pi5                  -  enabled, port: 56000, bind: 0.0.0.0
          system.adapter.enocean.0                : enocean               : Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.ford.0                   : ford                  : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.homepilot20.0            : homepilot20           : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.hue.0                    : hue                   : Nordmanns-Raspberry-Pi5                  -  enabled, port: 443
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Nordmanns-Raspberry-Pi5                  - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.javascript.0             : javascript            : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.kodi.0                   : kodi                  : Nordmanns-Raspberry-Pi5                  -  enabled, port: 9090
        + system.adapter.logparser.0              : logparser             : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : Nordmanns-Raspberry-Pi5                  -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.netatmo.0                : netatmo               : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : Nordmanns-Raspberry-Pi5                  -  enabled, port: 23
        + system.adapter.scenes.0                 : scenes                : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.shelly.0                 : shelly                : Nordmanns-Raspberry-Pi5                  -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.signal-cmb.0             : signal-cmb            : Nordmanns-Raspberry-Pi5                  -  enabled
        + system.adapter.simple-api.0             : simple-api            : Nordmanns-Raspberry-Pi5                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sql.0                    : sql                   : Nordmanns-Raspberry-Pi5                  -  enabled, port: 3306
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Nordmanns-Raspberry-Pi5                  - disabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Nordmanns-Raspberry-Pi5                  - disabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.vis-2.0                  : vis-2                 : Nordmanns-Raspberry-Pi5                  -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Nordmanns-Raspberry-Pi5                  - disabled
        + system.adapter.web.0                    : web                   : Nordmanns-Raspberry-Pi5                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zwave2.0                 : zwave2                : Nordmanns-Raspberry-Pi5                  -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name     │ url                                            │ auto upgrade │
        │ 0       │ 'stable' │ 'https://repo.iobroker.live/sources-dist.json' │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "acme"         : 1.0.6    , installed 1.0.6
        Adapter    "adb"          : 0.0.7    , installed 0.0.7
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "dysonairpurifier": 3.2.6 , installed 3.2.6
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "ekey"         : 1.2.3    , installed 1.2.3
        Adapter    "ford"         : 1.0.4    , installed 1.0.4
        Adapter    "hue"          : 3.13.1   , installed 3.14.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "kodi"         : 3.1.0    , installed 3.1.0
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.1
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
        Objects and States
        Objects: 	10916
        States: 	7767
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7028       952/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          340595     4540/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       642705     6856/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       642700     6856/iobroker.js-co
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       643920     7030/io.mqtt.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       644598     7137/io.shelly.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       643921     7030/io.mqtt.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          7030       952/sshd: /usr/sbin
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          7019       938/xrdp-sesman
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          340594     4540/cupsd
        tcp6       0      0 :::3389                 :::*                    LISTEN      112        10341      959/xrdp
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       644313     6874/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       645370     7280/io.web.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       645341     7250/io.simple-api.
        udp        0      0 0.0.0.0:43600           0.0.0.0:*                           1001       643888     6989/io.broadlink2.
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       643886     6989/io.broadlink2.
        udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       644015     7174/io.ekey.0
        udp        0      0 0.0.0.0:40060           0.0.0.0:*                           104        6893       759/avahi-daemon: r
        udp        0      0 0.0.0.0:40763           0.0.0.0:*                           1001       643889     6989/io.broadlink2.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6891       759/avahi-daemon: r
        udp6       0      0 :::59916                :::*                                104        6894       759/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        6892       759/avahi-daemon: r
        2025-02-28 10:17:17.997  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:17:24.940  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:17:26.043  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:17:33.004  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:17:34.089  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:17:41.068  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:17:42.000  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:17:49.132  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:17:50.205  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:17:57.196  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:17:58.250  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:05.260  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:06.345  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:13.324  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:14.371  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:21.388  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:22.498  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:29.452  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:30.512  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:37.516  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:37.808  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:45.580  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:45.975  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        2025-02-28 10:18:53.644  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
        2025-02-28 10:18:54.257  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
        Wobei ich die Warning
        nicht verstehe, denn die Datei ist vorhanden und ich kann sie mir auch mit einem Bildbetrachter anschauen. An den Zugriffsrechten sollte es eigentlich auch nicht liegen, denn ich habe einen iob fix durchgeführt...
        Und hier noch die Summary:
        			v.2025-02-23
               Icon name: computer
            Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		64 bit
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        Boot Target: 		graphical.target
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation:
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        Recommended versions are nodejs 20.18.3 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Swap:           209M          0B        209M
        ioBroker Core: 		js-controller 		7.0.6
        			admin 			7.4.10
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		10916
        States: 		7767
        Size of iob-Database:
        19M	/opt/iobroker/iobroker-data/objects.jsonl
        11M	/opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @KlausStoertebeker last edited by
          @klausstoertebeker sagte in "admin.0 Restart loop detected" und keine Trigger mehr:
          Schalt den aus.
          KlausStoertebeker 1 Reply Last reply Reply Quote 0
          • mcm1957
            mcm1957 @KlausStoertebeker last edited by
            @klausstoertebeker said in "admin.0 Restart loop detected" und keine Trigger mehr:
            pioneer_sc_vsx
            Wo hast den den den "Adapter" her?
            Unter Adapter State steht:
            Unter Installed ioBroker-Adapters ist er nicht gelistet.
            Der Adapter ist jedenfalls nicht in einem Repository gelistet. Egal wie du den in den System gepresst hast solltest du diesen hinterfragen. Eine saubere Github Installation scheint das auch nicht zu sein - auch wenn von Github only Adaptern dringend abgeraten wird.
            Hinweis:
            Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
            GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
            Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
            Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
            Und falls es irgendwie unklar ist:
            ioBroker unterstützt folgende Arten von Installation:
            • aus dem STABLE Repository
              Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
            • aus dem LATEST Repository
              Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
            • direkt von GITHUB
              Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
            • direkt von npm
              Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
            Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
            @mcm1957
            • KlausStoertebeker
              KlausStoertebeker @Thomas Braun last edited by
              Hallo Thomas,
              war am Wochenende nicht daheim, deshalb erst jetzt meine Antwort:
              Mein ioBroker läuft auf einem Raspberry Pi 5 (8 GByte) mit graphischer Benutzeroberfäche. Und das deutliche schneller als meinem Raspberry Pi 4B (8 GByte)...
              Oder glaubst Du, dass der in die ioBroker-Installation reinfunkt?
              • KlausStoertebeker
                @mcm1957
                Hallo mcm1957,
                danke für die Info.
                Aber der pioneer_sc_vsx ist der einzige Adapter (installiert mit npm), mit dem ich meinen betagten Pioneer VSX-921-Receiver steurrn kann. Und bisher hat der auch tadellos funktioniert.
                Der andere, über das stable-Repository verfügbare, Pioneer-Adapter ist für meinen Receiver nicht nutzbar.
                • KlausStoertebeker
                  Kann mir denn niemand erklären, warum ich keine Trigger mehr bekomme, weder ereignis- noch zeitgesteuert? Welcher Teil/Adapter von ioBroker ist denn für die Auslöung und Verarbeitung eines Triggers verantwortlich?
                  Ich habe jetzt alles aus dem stable-Repository installiert - bis auf drei Adapter (enocean, pioneer_sc_vsx und homepilot20) - und hatte gehofft, dass sich die Probleme damit gelöst haben.
                  Aber sie sind immer noch da und ich scheine ein Problem mit der Basisinstallation zu haben...
                  mcm1957 crunchip 2 Replies Last reply Reply Quote 0
                  • mcm1957
                    @klausstoertebeker
                    Also nach meinem Kenntnisstand sollte die events der js-controller an hand der Subscriptions raisen und der javescript Adapter sollte die empfangen bzw subscriben.
                    Ob nun irgendein anderer Adapter da stören kann - keine Ahnung.
                      jetzt muss ich doch mal genauer nachfragen, bzw würde vllt ein Beispiel helfen
                      z.b. ein Beispiel script mit den entsprechenden Datenpunkten/Zeitstempel, bzw das log aus dem script
                        crunchip Forum Testing Most Active @KlausStoertebeker last edited by
                        oben ist es aber
                        • KlausStoertebeker
                          KlausStoertebeker @crunchip last edited by
                          @crunchip said in "admin.0 Restart loop detected" und keine Trigger mehr:
                          Moin moin crunchip,
                          mache ich gerne. Aber ich habe mir gestern Abend den Kopf zermartert, wie ich das machen wie ich Dir diese Informationen so zur Verfügung stellen kann, dass Du alles auf einmal sehen kannst...
                          Wäre ein "Bildschirm-Video" sinnvoll, in dem ich drei Firefox-Fenster aufnehme, in denen jeweils die Informationen parallel dargestellt werden?
                          • KlausStoertebeker
                            oben ist es aber
                            Mittlerweile habe ich den Adapter iobroker.icons-open-icon-library-png auf die Version 0.1.2 downgegraded - die ist im stable-Repository verfügbar.
                            Und ich habe den enocean-Adapter (mit npm installiert) deinstalliert, ebenso wie den zwave2-Adapter (den hatte ich über das stable-Repository installiert).
                            Die einzigen Adapter, die ich jetzt noch von außerhalb des stable-Repository installiert habe, sind der homepilot20 - da läuft aber gerade die Bitte, den in das stable-Repository zu integrieren - und der pioneer_sc_vsx. Für letzteren gibt es nur die Möglichkeit, über npm zu installieren.
                            Somit habe ich nur noch Adapter installiert, die ich wirklich benötige...
                              crunchip Forum Testing Most Active @KlausStoertebeker last edited by crunchip
                              @klausstoertebeker du kannst doch irgendein passendes Script aufrufen und das darunterliegende Log zeigen bei script start.(ggf debug log einbauen)
                              Oder auch mal einen Datenpunkt aus deinen Objekten, da müsste sich doch der Zeit Stempel ändern, wenn etwas geschaltet wird
                              KlausStoertebeker 2 Replies Last reply Reply Quote 0
                              • KlausStoertebeker
                                @crunchip
                                Das bekomme ich hin. Dann werde ich das Script-Log hier in Code-Tags einfügen und den Zeitstempel der Datenpunktänderung in den Text einfügen 🙂
                                • KlausStoertebeker
                                  @crunchip
                                  Hallo crunchip,
                                  ich habe mich doch für ein Video Video entschieden, weil ich dort durch entsprechende Anordnung der Fenster die Reaktionen von ioBroker gleichzeitig darstellen kann und ich das für besser halte als das komplizierte Beschreiben mit Worten,
                                  In dem Video siehst Du, wie
                                  • ich in der Visualisierung "VIS-2" einen Button anklicke, der mit dem boolschen Objekt Schalter_Arbeitszimmer_Server-2 verknüft ist (Fenster links oben)
                                  • das Objekt Schalter_Arbeitszimmer_Server-2 den Wert wechselt (unterer Bereich, markierte Zeile; Wechsel von false -> true -> false)
                                  • die Funktion "Unterprogramm Server-2 schalten" nicht ausgelöst wird (ich habe mehrere "debug"-Blöcke eingefügt, keiner schreibt jedoch ins Skript-Log)
                                    Das Blockly-Skript hat folgenden Inhalt:
                                    <variables>
                                      <variable id="}.JK6ksO42P4EA)Pm/q:">Server-2_heruntergefahren</variable>
                                    </variables>
                                    <block type="on" id="dpfW@o|Xb4KE-N4[V6kj" x="63" y="-87">
                                      <field name="OID">0_userdata.0.Schalter.Schalter_Arbeitszimmer_Server-2</field>
                                        <block type="debug" id="9MmQ)U(CW|$CoZ{4:j_L">
                                          <field name="Severity">info</field>
                                          <value name="TEXT">
                                            <shadow type="text" id="(0ibH02O]P8f;LJnWxv8">
                                            <block type="text" id="~3{3/4%#`IS700N)${Y?">
                                              <field name="TEXT">"Unterprogramm Server-2 schalten" gestartet</field>
                                            <block type="controls_if" id="ZhJrg)}pep`{Pfq:@MR)">
                                                <block type="logic_compare" id="D}jsUEOC#BX=VjIs$=@u">
                                                  <field name="OP">EQ</field>
                                                    <block type="get_value" id="=1(_*k?^+dvYJ$h-@W5_">
                                                    <block type="logic_boolean" id="/.z^fx89LEs[CUCacev,">
                                                <block type="control" id="Z}:7nmbOWJ^dl0_h.K!N">
                                                  <field name="OID">alias.0.Arbeitszimmer Server-2 Verbrauch und Schalter.Schalter</field>
                                                    <block type="logic_boolean" id="T}_]4*Xa:sCj#0])Q{@_">
                                                    <block type="debug" id="buTzmBW)ufvlE+k17)62">
                                                      <value name="TEXT">
                                                        <block type="text" id="+*O/[2o#pc](Cq|_*[be">
                                                          <field name="TEXT">Server-2 eingeschatet</field>
                                              <value name="IF1">
                                                <block type="logic_compare" id="MusPF0c$(T)4h!V]4RoQ">
                                                    <block type="get_value" id="#II_Alpp%c2MKX#:].$l">
                                                    <block type="logic_boolean" id="9s@KTW1P}:t1}n8?Rzhs">
                                              <statement name="DO1">
                                                <block type="control" id="{s_XQ;qrGJ)tHqnB!l?K">
                                                  <field name="OID">0_userdata.0.Hilfsobjekte.Server-Ausschaltbefehl</field>
                                                    <block type="text_replace" id="0|#Go{/Im:rLY9M5K5eU">
                                                      <value name="FROM">
                                                        <shadow type="text" id="X#T|Tfy`+jTZh4ztgY`2">
                                                          <field name="TEXT">x</field>
                                                        <block type="text_newline" id="jFvT@+lbKG!6v|3|*dp7">
                                                          <field name="Type">\n</field>
                                                      <value name="TO">
                                                        <shadow type="text" id="A)}{b7Gm2)tE]2g4~=KX">
                                                          <field name="TEXT">y</field>
                                                        <block type="text" id="(XZX6%uN`Z[h2QW0e^%5">
                                                          <field name="TEXT"></field>
                                                      <value name="TEXT">
                                                        <shadow type="text" id="tKZBuIpOe{/kC7q%j#2y">
                                                        <block type="text_join" id="Z0L-cG-_C)?/QTu+o%*a">
                                                          <value name="ADD0">
                                                            <block type="text" id="g8xwdz:?VoM!t1VQJ$*8">
                                                              <field name="TEXT">ssh admin@</field>
                                                          <value name="ADD1">
                                                            <block type="get_value" id=";SU=2SU{O/PjSk[wj~l/">
                                                              <field name="OID">0_userdata.0.Netzwerkadressen.IP-Adresse_Server-2</field>
                                                          <value name="ADD2">
                                                            <block type="text" id="m!H8v?xWJ/dFVX|-EA[D">
                                                              <field name="TEXT"> poweroff</field>
                                                    <block type="exec" id="dINM^XRtRKI2zo0kDsWK">
                                                      <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                                      <field name="WITH_STATEMENT">FALSE</field>
                                                      <field name="LOG">debug</field>
                                                      <value name="COMMAND">
                                                        <shadow type="text" id="+x)UNfi@Pd09uZn+)nj0">
                                                          <field name="TEXT">pwd</field>
                                                        <block type="text_replace" id="A-tOS.,Ab5-0p]4P=~y9">
                                                          <value name="FROM">
                                                            <block type="text_newline" id="W:HGu5V97#-a3jjZU.e^">
                                                          <value name="TO">
                                                            <block type="text" id="@*Ka=3uUO=13YbFc/{GG">
                                                          <value name="TEXT">
                                                            <block type="text_join" id="boC#i7RN}`2VmfBbk6zH">
                                                              <value name="ADD0">
        <block type="text" id="RmGi6+2VY8]{d[q1mAR1">
                                                              <value name="ADD1">
        <block type="get_value" id="a?wbLJ5YSs6!.a$*LMxn">
                                                              <value name="ADD2">
        <block type="text" id="Jh*.IX(cz:U|oD~{u[7^">
                                                        <block type="debug" id="FmqPTzo7kT3t`]ZC-uM-">
                                                          <value name="TEXT">
                                                            <block type="text" id="wi|%p$JN)Ou9]*1Vzjrz">
                                                              <field name="TEXT">Server-2 wird heruntergefahren</field>
                                                            <block type="debug" id="!-#Y#V,z_/BkVke1Yfbh">
                                                              <value name="TEXT">
        <block type="get_value" id="YW0V%+Psc`G?+Sq6L+OV">
        <block type="variables_set" id="_SZ^${a4.da.HVtVflw?">
        <field name="VAR" id="}.JK6ksO42P4EA)Pm/q:">Server-2_heruntergefahren</field>
        <block type="logic_boolean" id="]4cEN?|P.r=JC]R/0gDK">
        <block type="controls_whileUntil" id="Jg$ka*@unOMXF)%64UHa">
        <field name="MODE">WHILE</field>
        <value name="BOOL">
        <block type="logic_compare" id="NV(rf0!]lu5I{X@1BMHM">
        <block type="variables_get" id="NGdQ)Elb3*]VK_oaDWP+">
        <block type="logic_boolean" id="q,s[qKLIpOnk9[%tP|,V">
        <statement name="DO">
        <block type="exec" id="M@mW6FL%_,0v]D|3(x4?">
        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
        <field name="WITH_STATEMENT">TRUE</field>
        <field name="LOG"></field>
        <shadow type="text" id="2ISya|QWuK=oZ_Q{6whi">
        <block type="text_join" id=".F*K;}^Ro%VIk;36qkkN">
        <value name="ADD0">
        <block type="text" id="xpen|W3sk1@1mMI^X$dx">
        <field name="TEXT">ping -c 1 </field>
        <value name="ADD1">
        <block type="get_value" id="+LBmpXG*J,6^@M@Gwrr8">
        <block type="controls_if" id="jDa`a4aMS,t+/r[Do_j/">
        <block type="logic_compare" id=":vrMh+x=v2bHQY;)}LC8">
        <field name="OP">NEQ</field>
        <block type="text_indexOf" id="RJ/#yna;Hqk(.JEQv+rQ">
        <field name="END">FIRST</field>
        <block type="exec_result" id="G/5sXUTA6F*eMir{LT(W">
        <field name="ATTR">result</field>
        <value name="FIND">
        <shadow type="text" id="XsuuVumbmWIWoZ69JRxC">
        <field name="TEXT">abc</field>
        <block type="text" id=",v,6RfJ4n1ZN@SdO?,@/">
        <field name="TEXT">Destination Host Unreachable</field>
        <block type="math_number" id="CD*8GZP9X4Ans5BZAy7t">
        <field name="NUM">0</field>
        <block type="variables_set" id="|vwYEzXZi}d;JR/hNu6j">
        <block type="logic_boolean" id="My%k3.H/,N]8O*b[;1z!">
        <block type="timeouts_wait" id="KxzjUAu%2G~]*e7mro5Y">
        <field name="DELAY">60000</field>
        <field name="UNIT">ms</field>
        <block type="control" id="6ke8|yGP0)D=`8]C1-m%">
        <block type="logic_boolean" id="FL9Lkobw[krO}u*2Ef9L">
                                  Hier das Admin-Log zum Download: Admin-Adapter-Log.json
                                  Hier das Javascript-Log zum Download: Javascript-Adapter-Log.json
                                  Ich hoffe, die Informationen reichen für den Anfang 🙂
                                  Codierknecht crunchip 2 Replies Last reply Reply Quote 0
                                  • Codierknecht
                                    Codierknecht Developer Most Active @KlausStoertebeker last edited by
                                    Blockly bitte immer auch als Screenshot.
                                    Nur wenige werden Lust haben, das erstmal zu importieren um einen Blick darauf werfen zu können.
                                      • KlausStoertebeker
                                        @crunchip
                                        Ok, hier das Blockly-Skript als Bild:
                                        Und hier das detaillierte Skript-Log nach betätigen des Buttons:
                                        javascript.0	21:29:33.426	info	Stopping script script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten
                                        javascript.0	21:29:33.475	info	Start JavaScript script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten (Blockly)
                                        javascript.0	21:29:33.486	info	script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten: subscribe: {"pattern":{"id":"0_userdata.0.Schalter.Schalter_Arbeitszimmer_Server-2","change":"ne","q":0},"name":"script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten"}
                                        javascript.0	21:29:33.486	info	script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        Das Skript wurde wieder nicht getriggert.
                                        Homoran crunchip Codierknecht 3 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @KlausStoertebeker last edited by
                                          @klausstoertebeker Was ist das für ein "Schalter"?
                                            da sollte eigentlich mehr kommen
                                            vllt, findet man etwas im debug modus?
                                            6443
