    4. IOBroker stürzt ab und alle Adapter starten neu
      matrose65 @matrose65 last edited by wendy2702
      Bin wieder da und habe echt langsam die Schn... voll.
      Heute alleine 3 mal. 00:55 11:18 15:20 Wenn ich nur wüsste was der Fehler ist. aber im Log ist immer was anderes am Anfang.
      Nur um 11:20 habe ich einen Log-Eintrag über bestimmt 20 Seiten mit nur Text in verschiedenen Sprachen
      Ich hänge mal einen kleinen Teil hier an
      2025-02-28 11:20:26.832 - warn: host.iobroker Cannot parse system.repositories - {"_id":"system.repositories","type":"config","common":{"name":{"en":"System repositories","de":"System-Repositories","ru":"Системные репозитории","pt":"Repositórios do sistema","nl":"Systeemrepository's","fr":"Référentiels système","it":"Repository di sistema","es":"Repositorios del sistema","pl":"Repozytoria systemowe","zh-cn":"系统资料库"},"dontDelete":true},"native":{"repositories":{"stable":{"link":"http://download.iobroker.net/sources-dist.json","json":{"_repoInfo":{"stable":true,"name":{"en":"Official stable repository","de":"Offizielles stabiles Repository","ru":"Официальный стабильный репозиторий","pt":"Repositório estável oficial","nl":"Officiële stabiliteit","fr":"Dépôt stable officiel","it":"Repository stabile ufficiale","es":"Repositorio estable oficial","pl":"Repozytorium","zh-cn":"A. 正式稳定存放处"},"repoTime":"2025-02-27T14:28:43.892Z","recommendedVersions":{"nodeJsAccepted":[18,20,22],"nodeJsRecommended":20,"npmRecommended":10}},"accuweather":{"name":"accuweather","version":"2.1.0","news":{"2.1.0":{"en":"Change: min. js-controller to 6.0.11\nChange: Outdated data is updated at startup.\nNew: Photo link added in current weather\nNew: Metric and Imperial are available for selection - Will be taken into account with the next data update.\nNew: In the event of a data retrieval error, an attempt is made again after 10 minute\nRemove admin option (restart blocking)\nRewritten in Typescript\nFor error codes from the 400 series, do not attempt any unscheduled reconnections.","de":"Änderung: min. js-controller auf 6.0.11\nÄnderung: Veraltete Daten werden beim Start aktualisiert.\nNeu: Fotolinkdp im aktuellen Wetter hinzugefügt\nNeu: Metric und Imperial stehen zur Auswahl - Wird mit dem nächsten Datenupdate berücksichtigt.\nNeu: Bei einem Datenabruffehler wird nach 10 Minuten erneut versucht\nAdmin-Option entfernen (Restart blockieren)\nNeu geschrieben in Typescript\nBei Fehlercodes aus der 400er Serie wird kein wiederverbindungsversuch gestartet, es bleibt beim normalen Zyklus.","ru":"Изменение: мин. js-контроллер до 6.0.11\nИзменение: устаревшие данные обновляются при запуске.\nНовый: Фотоссылка добавлена в текущую погоду\nНовый: Метрик и Империал доступны для выбора - будут приняты во внимание при следующем обновлении данных.\nНовое: В случае ошибки поиска данных, попытка повторяется через 10 минут\nУдалить параметр администратора (перезапуск блокировки)\nПереписанные в Typescript\nДля кодов ошибок из 400-й серии не пытайтесь каких-либо незапланированных перезаключений.","pt":"Mudança: min. js-controller para 6.0.11\nChange: Os dados desatualizados são atualizados na inicialização.\nNovo: Foto link adicionado no tempo atual\nNovo: Metric e Imperial estão disponíveis para seleção - Será levado em conta com a próxima atualização de dados.\nNovo: Em caso de erro de recuperação de dados, uma tentativa é feita novamente após 10 minutos\nRemova a opção admin (reiniciar bloqueio)\nReescrito em Typescript\nPara códigos de erro da série 400, não tente nenhuma reconexão não programada.","nl":"Wijziging: min. js-controller tot 6.0.11\nVerandering: Verouderde gegevens worden bijgewerkt bij het opstarten.\nNieuw: Foto link toegevoegd bij het huidige weer\nNieuw: Metric en Imperial zijn beschikbaar voor selectie - zal in aanmerking worden genomen bij de volgende gegevensupdate.\nNieuw: Bij een fout bij het ophalen van gegevens wordt na 10 minuten opnieuw een poging ondernomen\nAdmin optie verwijderen (opnieuw blokkeren)\nHerschreven in typescript\nVoor foutcodes uit de 400-serie, probeer geen ongeplande reconnecties.","fr":"Changement : min. js-controller à 6.0.11\nChangement : Les données périmées sont mises à jour au démarrage.\nNouveau: Lien photo ajouté dans la météo actuelle\nNouveau: Metric et Imperial sont disponibles pour la sélection - sera pris en compte avec la prochaine mise à jour des données.\nNouveau: En cas d'erreur de récupération de données, une tentative est faite après 10 minutes\nSupprimer l'option admin (redémarrer le blocage)\nRéécrit dans Typescript\nPour les codes d'erreur de la série 400, ne tentez pas de reconnections non programmées.","it":"Cambio: min. js-controller a 6.0.11\nModifica: i dati obsoleti vengono aggiornati all'avvio.\nNuovo: Collegamento foto aggiunto nel tempo corrente\nNovità: Metric e Imperial sono disponibili per la selezione - Sarà preso in considerazione con il prossimo aggiornamento dati.\nNuovo: In caso di errore di recupero dati, un tentativo viene fatto di nuovo dopo 10 minuti\nRimuovere l'opzione admin (blocco di riavvio)\nRescritto in Tipografia\nPer i codici di errore della serie 400, non tentare alcuna riconnessione non programmata.","es":"Cambio: min. js-controller a 6.0.11\nCambio: Los datos actualizados se actualizan al iniciarse.\nNuevo: Enlace fotográfico añadido en el tiempo actual\nNuevo: Métrico e Imperial están disponibles para la selección - Se tendrá en cuenta con la siguiente actualización de datos.\nNuevo: En caso de error de recuperación de datos, se vuelve a intentar después de 10 minutos\nEliminar la opción de administración (bloqueo de reinicio)\nReescrito en Tiposcript\nPara los códigos de error de la serie 400, no intenten ninguna reconexión no programada.","pl":"Zmiana: min. js- controller do 6.0.11\nZmiana: Zaległe dane są aktualizowane przy starcie.\nNowy: link fotograficzny dodany w obecnej pogodzie\nNowy: Metric i Imperial są dostępne do wyboru - zostaną uwzględnione w następnej aktualizacji danych.\nNowy: W przypadku błędu w odzyskiwaniu danych, próba jest ponownie po 10 minutach\nUsuń opcję admin (ponowne uruchomienie blokady)\nPrzepisane na maszynie\nDla kodów błędów z serii 400, nie próbuj żadnych nieplanowanych ponownych połączeń.","uk":"Зміна: хв. js-controller до 6.0.11\nЗміна: Оновлення застарілих даних при запуску.\nНова: Фото посилання, додана в поточну погоду\nНовий: Metric і Imperial доступні для вибору - Буде враховано з наступним оновленням даних.\nНова: У разі перерозподілу даних спроба повторно виконана після 10 хвилин\nВидалити опцію адміністратора (блокування місця)\nПодати заявку\nДля кодів помилок з серії 400 не намагайтеся ніяких небажаних відключень.","zh-cn":"更改:min.js控制器改为6.0.11\n更改:过期数据在启动时更新.\n新建: 在当前天气中添加图片链接\n新增:计量和帝国可供选择 -- -- 将在下一次数据更新时加以考虑.\n新建:如果出现数据检索错误,10分钟后再次尝试\n删除管理选项( 重新开始屏蔽)\n重写字体\n对于400系列的错误代码,不要尝试任何不定期的重联."},"2.1.0-alpha.0":{"en":"Change: min. js-controller to 6.0.11\nChange: Outdated data is updated at startup.\nNew: Photo link added in current weather\nNew: Metric and Imperial are available for selection - Will be taken into account with the next data update.\nNew: In the event of a data retrieval error, an attempt is made again after 10 minute\nRemove admin option (restart blocking)\nRewritten in Typescript","de":"Änderung: min. js-controller auf 6.0.11\nÄnderung: Überholte Daten werden beim Start aktualisiert.\nNeu: Fotolink im aktuellen Wetter hinzugefügt\nNeu: Metric und Imperial stehen zur Auswahl - Wird mit dem nächsten Datenupdate berücksichtigt.\nNeu: Bei einem Datenabruffehler wird nach 10 Minuten erneut versucht\nAdmin-Option entfernen (Restart blockieren)\nNeu geschrieben in Typescript","ru":"Изменение: мин. js-контроллер до 6.0.11\nИзменение: устаревшие данные обновляются при запуске.\nНовый: Фотоссылка добавлена в текущую погоду\nНовый: Метрик и Империал доступны для выбора - будут приняты во внимание при следующем обновлении данных.\nНовое: В случае ошибки поиска данных, попытка повторяется через 10 минут\nУдалить параметр администратора (перезапуск блокировки)\nПереписанные в Typescript","pt":"Mudança: min. js-controller para 6.0.11\nChange: Os dados desatualizados são atualizados na inicialização.\nNovo: Foto link adicionado no tempo atual\nNovo: Metric e Imperial estão disponíveis para seleção - Será levado em conta com a próxima atualização de dados.\nNovo: Em caso de erro de recuperação de dados, uma tentativa é feita novamente após 10 minutos\nRemova a opção admin (reiniciar bloqueio)\nReescrito em Typescript","nl":"Wijziging: min. js-controller tot 6.0.11\nVerandering: Verouderde gegevens worden bijgewerkt bij het opstarten.\nNieuw: Foto link toegevoegd bij het huidige weer\nNieuw: Metric en Imperial zijn beschikbaar voor selectie - zal in aanmerking worden genomen bij de volgende gegevensupdate.\nNieuw: Bij een fout bij het ophalen van gegevens wordt na 10 minuten opnieuw een poging ondernomen\nAdmin optie verwijderen (opnieuw blokkeren)\nHerschreven in typescript","fr":"Changement : min. js-controller à 6.0.11\nChangement : Les données périmées sont mises à jour au démarrage.\nNouveau: Lien photo ajouté dans la météo actuelle\nNouveau: Metric et Imperial sont disponibles pour la sélection - sera pris en compte avec la prochaine mise à jour des données.\nNouveau: En cas d'erreur de récupération de données, une tentative est faite après 10 minutes\nSupprimer l'option admin (redémarrer le blocage)\nRéécrit dans Typescript","it":"Cambio: min. js-controller a 6.0.11\nModifica: i dati obsoleti vengono aggiornati all'avvio.\nNuovo: Collegamento foto aggiunto nel tempo corrente\nNovità: Metric e Imperial sono disponibili per la selezione - Sarà preso in considerazione con il prossimo aggiornamento dati.\nNuovo: In caso di errore di recupero dati, un tentativo viene fatto di nuovo dopo 10 minuti\nRimuovere l'opzione admin (blocco di riavvio)\nRescritto in Tipografia","es":"Cambio: min. js-controller a 6.0.11\nCambio: Los datos actualizados se actualizan al iniciarse.\nNuevo: Enlace fotográfico añadido en el tiempo actual\nNuevo: Métrico e Imperial están disponibles para la selección - Se tendrá en cuenta con la siguiente actualización de datos.\nNuevo: En caso de error de recuperación de datos, se vuelve a intentar después de 10 minutos\nEliminar la opción de administración (bloqueo de reinicio)\nReescrito en Tiposcript","pl":"Zmiana: min. js- controller do 6.0.11\nZmiana: Zaległe dane są aktualizowane przy starcie.\nNowy: link fotograficzny dodany w obecnej pogodzie\nNowy: Metric i Imperial są dostępne do wyboru - zostaną uwzględnione w następnej aktualizacji danych.\nNowy: W przypadku błędu w odzyskiwaniu danych, próba jest ponownie po 10 minutach\nUsuń opcję admin (ponowne uruchomienie blokady)\nPrzepisane na maszynie","uk":"Зміна: хв. js-controller до 6.0.11\nЗміна: Оновлення застарілих даних при запуску.\nНова: Фото посилання, додана в поточну погоду\nНовий: Metric і Imperial доступні для вибору - Буде враховано з наступним оновленням даних.\nНова: У разі перерозподілу даних спроба повторно виконана після 10 хвилин\nВидалити опцію адміністратора (блокування місця)\nПодати заявку","zh-cn":"更改:min.js控制器改为6.0.11\n更改:过期数据在启动时更新.\n新建: 在当前天气中添加图片链接\n新增:计量和帝国可供选择 -- -- 将在下一次数据更新时加以考虑.\n新建:如果出现数据检索错误,10分钟后再次尝试\n删除管理选项( 重新开始屏蔽)\n重写字体"},"2.0.1":{"en":"BREAKING: Requires Nodejs 20 or higher\nBREAKING: Command states are now buttons and only respond to ack=false. \nadmin option: No data is updated on adapter startup (default: true). \napikey renamed and encrypted\nDependencies and eslint updated\nAdd nextHour.CloudCover","de":"BREAKING: Erfordert Nodejs 20 oder höher\nBREAKING: Befehlszustände sind jetzt Tasten und reagieren nur auf ack=false.\nadmin-Option: Beim Adapter-Startup werden keine Daten aktualisiert (Standard: true).\napikey umbenannt un
      das wird so gar nicht angezeigt
        hier mal als Text
        • Chaot
          Chaot @matrose65 last edited by
          @matrose65 Sag mal, wie ist denn der Proxmox konfiguriert?
          Hast du alle 16 Gb Speicher komplett dem ioBroker zugeordnet? Laufen da noch weiter VMs drauf?
            matrose65 @Chaot last edited by
            @chaot
            es sind gesamt 32 Gb Speicher 16 Gb für den Iobroker und 4 Gb für den RaspberryMatic
            das ist alles
            • Chaot
              @matrose65 Ok, war nur so ein Gedanke. Ich hatte das mal, als ich irrtümlich für Proxmox nichts mehr freigelassen habe.
                @chaot
                Danke ich bin für jede Idee offen. Ich kann das alles auch noch verkleinern.
                IOB verbraucht aktuell 2,59Gb und Rasp 1,0 Gb
                Was mir noch aufgefallen ist, als ich vorhin das Log für heute aufgerufen habe wurde der Bildschirm gleich grau und wieder wurden die Adapter neu gestartet
                • Chaot
                  @matrose65 Offiziell reichen ja 4 Gb. Bei mir hat sich 6 Gb als optimal herausgestellt. Das läuft seit Jahren flüssig.
                  • wendy2702
                    wendy2702 last edited by
                    Hast du nach dem löschen und stoppen der Skripte die Vm oder den ganzen Server mal komplett neu gestartet?
                    Nicht das es da noch irgendwelche Geister gibt.
                      matrose65 @wendy2702 last edited by
                      @wendy2702
                      Ja habe ich gestern gemacht, auch kein erfolg
                        Hallo zusammen
                        Am Freitag habe ich es nicht mehr ausgehalten mit den ganzen Abstürzen. Ich hatte noch einen W-Lan ZigBee Stick und habe jetzt den IoBroker als Container installiert. (Danke an alle, die diese super Anleitungen schreiben)
                        Habe Freitag angefangen und den Samstag Mittag war alles neu und zwar ohne ein Backup.
                        Seitdem läuft der IOB ohne Abstürze.
                        Danke an alle die hier geholfen haben
                          jan_xx @matrose65 last edited by jan_xx
                          @all
                          Mein Iobroker startet auch alle paar Wochen mal neu, jetzt wollte ich der Sache versuchen auf den Grund zu gehen, ich bin auch per Terminal auf meinen Raspi und haben wie oben beschrieben dmesg -e eingegeben und zu der Absturzzeit gegen 17:01 Uhr diese Meldungen im LOG.->siehe Bild anbei
                          Also ich schau da wie die Sau ins Uhrwerk, hat hier jemand eine Idee?
                            +0,000010] [   6324]     0  6324      107        4    20480        0             0 modprobe
                          [  +0,000007] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=iobroker.js-con,pid=32744,uid=1000
                          [  +0,000065] Out of memory: Killed process 32744 (iobroker.js-con) total-vm:962560kB, anon-rss:762052kB, file-rss:0kB, shmem-rss:0kB, UID:1000 pgtables:3316kB oom_score_adj:0
                          [Apr 2 17:04] w1_master_driver w1_bus_master1: Family 0 for 00.6da080000000.14 is not registered.
                          [ +50,643970] w1_master_driver w1_bus_master1: Attaching one wire slave 00.eda080000000 crc 98
                          [  +0,007374] w1_master_driver w1_bus_master1: Family 0 for 00.eda080000000.98 is not registered.
                          [Apr 2 17:05] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1da080000000 crc ec
                          [  +0,
                          • wendy2702
                            wendy2702 @jan_xx last edited by
                            @jan_xx steht doch fast im Klartext da:
                            Out of Memory
                            Dir geht der verfügbare Speicher aus.
                            Was ist das für ein PI?
                            Zeige mal langfassung von
                            iob diag
                              jan_xx @wendy2702 last edited by
                              @wendy2702
                              Meinst du das alles?->siehe anbei
                              von meinem 4GB Raspi. habe ich 2,4GB verwendet?
                               Static hostname: raspberrypi
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 5.15.84-v7l+
                                    Architecture: arm
                              OS is similar to: debian
                              Model		: Raspberry Pi 4 Model B Rev 1.4
                              Docker          : false
                              Virtualization  : none
                              Kernel          : armv7l
                              Userland        : 32 bit
                              Systemuptime and Load:
                               08:20:10 up 40 days, 23:21,  2 users,  load average: 2.94, 1.93, 1.67
                              CPU threads: 4
                              *** LIFE CYCLE STATUS ***
                              Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              ~ Under-voltage has occurred
                              ~ Arm frequency capping has occurred
                              ~ Throttling has occurred
                              ~ Soft temperature limit has occurred
                              *** TIME AND TIMEZONES ***
                                             Local time: Thu 2025-04-03 08:20:10 CEST
                                         Universal time: Thu 2025-04-03 06:20:10 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              iobroker
                              XDG_CONFIG_HOME=/home/iobroker/.config
                              HOME=/home/iobroker
                              GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
                              iobroker
                              HOME=/home/iobroker
                              A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                              A root login is not required in most Linux Distributions.
                              Run 'iobroker fix' or use the system tools to create a user.
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server: false
                              Desktop: 	LXDE-pi
                              Terminal: 	x11
                              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                              *** MEMORY ***
                              Mem:            3.8G        2.3G        542M         34M        1.0G        1.4G
                              Swap:            99M         99M        0.0K
                              Total:          3.9G        2.4G        543M
                              Active iob-Instances: 	45
                                       3837 M total memory
                                       2288 M used memory
                                        588 M active memory
                                       2515 M inactive memory
                                        542 M free memory
                                        112 M buffer memory
                                        894 M swap cache
                                         99 M total swap
                                         99 M used swap
                                          0 M free swap
                              top - 08:20:11 up 40 days, 23:21,  2 users,  load average: 2.94, 1.93, 1.67
                              Tasks: 238 total,   4 running, 234 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 44.6 us, 12.2 sy,  0.0 ni, 41.9 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
                              MiB Mem :   3837.9 total,    541.0 free,   2289.0 used,   1007.9 buff/cache
                              MiB Swap:    100.0 total,      0.4 free,     99.6 used.   1377.8 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
                              * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              1 loaded units listed.
                              Homoran ? Thomas Braun 4 Replies Last reply Reply Quote 0
                                Homoran Global Moderator Administrators @jan_xx last edited by
                                @jan_xx sagte in IOBroker stürzt ab und alle Adapter starten neu:
                                Natürlich
                                  A Former User @jan_xx last edited by
                                  Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred
                                  Das zitierte sind die Hardware Probleme, und dazu noch jede Menge Software Probleme, die du hast.
                                  Lies dich bitte mal in die Doku ein, dazu ein paar kleine Linux Basics und installiere iobroker neu mit Bookworm 64bit, wie zur Zeit empfohlen.
                                  Du betreibst ein totes Betriebssystem mit etlichen Fehlern. ( root rechte, System EOL, usw.. )
                                  @Homoran
                                  Da braucht man kein komplettes iob diag mehr. Das Ding is fertich..
                                  J Homoran 2 Replies Last reply Reply Quote 0
                                    jan_xx @Guest last edited by
                                    @neuschwansteini
                                    Bei Bookworm wird aber die USB Schnittstelle nicht mehr unterstützt habe ich irgendwo gelesen?
                                    Ich brauche die USB Geschichte, da hängt mein Victron Laderegler dran.
                                      @jan_xx natuerlich wird bei Bookworm USB unterstuetzt..
                                        Homoran Global Moderator Administrators @Guest last edited by
                                        @neuschwansteini sagte in IOBroker stürzt ab und alle Adapter starten neu:
                                        war das eben schon so drin?
                                        Dann Sorry, ging bei mir nur bis Zeile 17 und war nicht zu scrollen.
                                          Homoran Global Moderator Administrators @jan_xx last edited by Homoran
                                          Auch wenn jetzt genug RAM zur Verfügung staht, war das nicht immer so.
                                            @neuschwansteini
                                            Ich habe mich schon sehr oft vor dem Update gescheut, da es damals schon eine ganze große Aktion war den USB Port zu überzeugen sich mit dem Laderegler zu unterhalten...
                                            Also wenn mein System fertig ist, werde ich wohl nicht drumherum kommen, vlt. sollte ich mir ein Zweitsystem aufbauen und dann langsam irgendwie umziehen. Der Raspi ist ja auch nicht unbedingt die Endlösung, dazu habe ich schon viel gelesen und einige fangen mit der Ärgerkiste garnicht erst an. Nutzt ihr ein NUC?
                                            Homoran ? 2 Replies Last reply Reply Quote 0
                                            82
                                            9305
