    4. Tester für Zigbee Adapter 2.0.x gesucht
      bommel_030 @Asgothian last edited by
      @asgothian
      Hat etwas gedauert, hab jetzt die 2.0.2 aus dem latest installiert.
      Wenn ich auf neue Firmware prüfe werden die deaktivierten, bzw. nicht erreichbaren Geräte korrekt übersprungen. Danach gibt es Fehlermeldungen und die Instanz startet neu.
      zigbee.0
      2025-03-04 06:16:29.040	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
      zigbee.0
      2025-03-04 06:16:28.724	info	Starting Zigbee-Herdsman
      zigbee.0
      2025-03-04 06:16:28.723	info	Installed Version: iobroker.zigbee@2.0.2 (Converters 21.38.0 Herdsman 3.2.7)
      zigbee.0
      2025-03-04 06:16:28.708	info	Starting Adapter npm ...
      zigbee.0
      2025-03-04 06:16:28.707	info	delete old Backup files. keep only last 10
      zigbee.0
      2025-03-04 06:16:28.698	info	init localConfig
      zigbee.0
      2025-03-04 06:16:28.687	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
      host.iobroker-master
      2025-03-04 06:15:56.257	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:185:1)
      2025-03-04 06:15:56.257	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:275:1)
      2025-03-04 06:15:56.256	error	Caught by controller[0]: TypeError: request.headers.split is not a function
      zigbee.0
      2025-03-04 06:15:55.552	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2025-03-04 06:15:55.551	info	terminating
      zigbee.0
      2025-03-04 06:15:55.551	info	Saved local configuration data
      zigbee.0
      2025-03-04 06:15:55.551	info	local config saved
      zigbee.0
      2025-03-04 06:15:55.551	info	cleaned everything up...
      zigbee.0
      2025-03-04 06:15:55.542	error	request.headers.split is not a function
      zigbee.0
      2025-03-04 06:15:55.542	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:275:1) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:185:1) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
      zigbee.0
      2025-03-04 06:15:55.541	error	uncaught exception: request.headers.split is not a function
      zigbee.0
      2025-03-04 06:15:55.059	warn	Device zigbee.0.b4e3f9fffe752df1 is marked unavailable, skipping...
      zigbee.0
      2025-03-04 06:15:55.035	warn	Device zigbee.0.7cb03eaa00a86bde is deactivated, skipping...
      zigbee.0
      2025-03-04 06:15:55.035	warn	Device zigbee.0.7cb03eaa00af243e is deactivated, skipping...
      zigbee.0
      2025-03-04 06:15:38.542	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"01A64D3E","pnpId":"usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D3E-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"01A64D0F","pnpId":"usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D0F-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      zigbee.0
      2025-03-04 06:15:22.368	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"01A64D3E","pnpId":"usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D3E-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"01A64D0F","pnpId":"usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D0F-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      Die IKEA Trektakt Steckdose hat jetzt ein richtiges current/default Bild. Meine manuell hochgeladenen sind immernoch "defekt".
      Die habe ich per FTP hochgeladen, da der Admin nicht an der entsprechende Verzeichnis kommt.
      Bei den oberen beiden steht
      <img alt="" src="img/E22x4.png">
      Die runde IKEA Fernbedienung https://www.zigbee2mqtt.io/devices/E1524_E1810.html funktioniert einwandfrei.
      Bei der kleinen https://www.zigbee2mqtt.io/devices/E1743.html erscheint bei jedem Tastendruck
      	Device '0x04cd15fffe2e2772' announced itself
      Das war mit der 2.0.1 nicht.
        bommel_030 @Asgothian last edited by bommel_030
        @asgothian
        Wenn ich bei der Fernbedienung ein reconfigure versuche ist das laut LOG auch angeblich erfolgreich. Es folgt aber eine Warnung und die Infokachel sagt auch weiterhin configured = false
        zigbee.0
        2025-03-04 11:31:32.752	warn	do configure result is [""]
        zigbee.0
        2025-03-04 11:31:32.752	info	DeviceConfigure successful 0x04cd15fffe2e2772 TRADFRI on/off switch
        zigbee.0
        2025-03-04 11:31:24.122	info	-> Configuring 0x04cd15fffe2e2772 TRADFRI on/off switch
        zigbee.0
        2025-03-04 11:31:23.613	info	Device '0x04cd15fffe2e2772' announced itself
        Edit, es kommt auch weiterhin announced itself im Log. Der Status on bzw. off wird auch nicht immer aktualisiert. Wobei sich die LinkQualität allerdings ändert.
        • Asgothian
          Asgothian Developer @bommel_030 last edited by Asgothian
          @bommel_030 Das configured im UI scheint nicht sauber aktualisiert zu werden - da bin ich gerade dran.
          Bitte schalte deine Fernbedienung mal auf Debug, so dass du Warnmeldungen bekommst zu dem was die Sendet (Anleitung siehe hier).
          Zu dem Bild - dein Screenshot ist unlesbar für mich.
          Auffällig ist aber das der Link stimmt - der Adapter soll die Datei von da wo du sie Hingeladen hast in den Datenbereich des Admin kopieren, damit dieser das Bild darstellen kann. das hat entweder nicht funktioniert oder das Bild ist nicht ok. Mach mal bitte folgendes über die Konsole (nicht ftp)
          Kopiere aus dem Verzeichnis /opt/iobroker/node_modules/iobroker.zigbee/admin/img die Datei 'innr_plug.png' in das Verzeichnis wo deine Bilder liegen, und benenn sie darin dann um.
          Dann schau nochmal ob dieses Bild korrekt dargestellt wird.
          Die 'device announced itself' Meldungen werden vom Gerät aus angestoßen - da ist der Adapter unbeteiligt. Warum das jetzt auftritt weiss ich nicht - das kenne ich aber von Ikea-Geräten sporadisch.
          A.
          • Asgothian
            @bommel_030 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
            Dein Log beinhaltet keine Fehlermeldungen. Damit kann ich dem nicht nachgehen.
              @asgothian
              Du meinst das Log vom Firmware Update? Da steht doch u.a. :
              zigbee.0
              zigbee.0
              Oder ich kann dir nicht folgen....
              Sorry für das Bild, wollte eigentlich den kompletten Link reinkopieren, aber mehr als 1000 Zeichen sind nicht erlaubt.
              Wenn ich das innr Bild über die Konsole kopiere erscheint es richtig. Benenne ich es um (via Konsole) ist wieder defekt.
              Unten das nicht umbenannte innr, oben das als E2204.png umbenannt.
              Das richtige Bild erscheint in der Entwicklerkonsole als
              <img alt="" src="data:image/png; base64, iVBORw0KGgoAAAANSUhEUgAAAPoAAAD6CAYAAACI7Fo9AAADTmlUWHRYTUw6Y29tLmFkb2JlL
              Das falsche als
              <img alt="" src="iVBORw0KGgoAAAANSUhEUgAAAPoAAAD6CAYAAACI7Fo9AAAD
              Der Teil data:image/png; base64, geht scheinbar beim umbenennen verloren ?!? Wenn ich den in der Entwicklerkonsole hinzufüge erscheint das Bild.
              • Asgothian
                wieviele Zeichen hat das was in "src" drin steht ?
                A.
                  @asgothian
                  Beim innr ca. 38.852 Zeichen, Trektakt 100.536 Zeichen.
                  "Mein" altes Trektat Bild funktioniert auch, wenn ich die base64 codierung davor setze....
                  • Asgothian
                    @asgothian
                    ich bin irritiert - die base64 Notierung wird vor den String gesetzt wenn dieser länger ist als 50 Zeichen.
                      @asgothian
                      So, um mich vollends zu verwirren, ich habe heute früh Admin und web auf die neueste Version aus dem latest gebracht. Seitdem ist es egal ob ich per Konsole oder FTP kopiere und umbenennen, die Bilder werden immer richtig dargestellt. Kann das damit zusammenhängen?
                      Bzgl. der kleinen IKEA Fernbedienung, die habe ich vor deinen Post noch einmal neu angelernt. Seitdem scheint sie zu funktionieren. Sollte sie wieder zicken probiere ich das mit dem Debug. Irgendwo hab ich auch nicht eine weitere rumliegen und könnte damit debuggen wenn es von Interesse ist.
                      Das einzige was nicht klappt sind die Firmware Updates, da stürzt er immer ab. Kann ich da außer den Logs oben noch mehr liefern?
                      • Asgothian
                        Bedingt - da scheint etwas in einer externen Bibliothek schief zu gehen. Das ist eigentlich alles per try/catch abgefangen, weswegen ich da maximal irritiert bin. Es findet sich in deinem Log auch kein Hinweis auf den Code der da betroffen ist.
                        Was du mal tun kannst:
                        • die Sentry integration ausschalten (Bild: obere Instanz: Sentry aktiv, untere Instanz: Sentry inaktiv)
                        • versuchen die einzelnen Geräte zu deaktivieren um heraus zu bekommen welches Gerät den Absturz hervorruft.
                        • die 2.0.3 RC3 von meinem Repository (https://github.com/asgothian/ioBroker.zigbee/tarball/1.11) installieren und schauen ob der Fehler da auch noch auftritt.
                        A.
                        p.s. mit der 2.0.3 RC3 (die intern noch als 2.0.2 angezeigt wird) bekommst du dann auch das debug-interface 🙂
                          @asgothian
                          Treffer, versenkt...
                          Sentry abschalten und der Check läuft durch.
                          Mangels verfügbarem Update kann ich allerdings nicht testen ob das laufen würde.
                          • Asgothian
                            Was meinst Du damit ?
                              deta Most Active last edited by Homoran
                              Seit Version 2, wird beim
                              model:RTCGQ11LM
                              description:Motion sensor
                              Nicht mehr der Punkt "no_motion" ausgelesen.
                              Unter Version 1.10.14 funktionierte es noch.
                              Adapter version
                              2.0.2
                              2-1.2.7.1
                              Coordinator
                              Sonoff zStack3x0
                              Setup
                              Mini PC
                              Antwort bei Issues: (https://github.com/ioBroker/ioBroker.zigbee/issues/2400)
                              Wie soll ich das verstehen? Warum Aufgegeben? Es ist doch ein wichtiger Punkt, wann
                              die letzte Reaktion war!
                              cu Deta
                              detafun created this issue in ioBroker/ioBroker.zigbee
                              closed Problem mit Xiaomi Menschlicher Körpersensor Zigbee #2400
                              • Asgothian
                                Asgothian Developer last edited by
                                @deta so wie es da steht. Der Punkt wird von den zigbee-herdsman-converters nicht weiter unterstützt. Deswegen ist er im zigbee-Adapter ab 2.0 nicht mehr vorhanden.
                                A.
                                  @asgothian
                                  Ohne Sentry kann ich wieder nach Updates suchen, aber da für keins meiner Geräte ein Update verfügbar ist kann ich keins starten.
                                    deta Most Active @Asgothian last edited by
                                    @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                    A.
                                    Ich hatte den Punkt benutz um nach einer bestimmten Zeit das Licht wieder abzuschalten. Wenn keine Bewegung mehr nach einer weile im Raum war.
                                    Gibt es eine andere Lösung?
                                    • Asgothian
                                      @bommel_030 ah.. ok.
                                      • Asgothian
                                        Asgothian Developer @deta last edited by Asgothian
                                        @deta sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                        A.
                                        der standard weg ist:
                                        let timeout = null;
                                        on({ID:'...occupancy', change: ne}. function(obj) {
                                           if (obj.val) {
                                          // light on
                                            clearTimeout(timeout);
                                          else
                                             timeout = setTimeout(function() {
                                                // light off
                                              },time)
                                        oder das Äquivalent in einer anderen Logik-Maschine.
                                        A.
                                        • Duffy
                                          Duffy @Asgothian last edited by
                                          @asgothian
                                          mir ist etwas aufgefallen was den Zigbee Adapter v2.02 betrifft.
                                          Da ich nicht weis ob es an mir oder dem Adapter liegt schreibe ich es hier einfach mal nieder.
                                          Also, ich habe auf meine Testsystem den o.g. Adapter installiert.
                                          Nun hat ein Tuya Fingerbot im Aktivsystem nicht mehr funktioniert was mich dazu veranlasste diesen im Aktivsystem zu löschen.
                                          Dann habe ich ihn im Testsystem über den Zigbee 2.02 Adapter installiert und er hat funktioniert.
                                          (Also muß ich ihn erst mal nicht entsorgen)
                                          Dann wollte ich ihn wieder aus dem Testsystem löschen was aber nicht mehr gelang. Er ist hartnäckig gekoppelt geblieben. (Löschen über die Kachel, Mülleimer, dann gelöscht bzw auch das Häkchen gesetzt und gelöscht)
                                          Erst als ich den Zigbee Adapter 2.02 deaktiviert hatte konnte ich den Fingerbot erneut im Aktivsysten mit Zigbee 1.10.14 erneut koppeln.
                                          Kann das ein Bug sein?
                                          Wenn nein, einfach meinen Post löschen.
                                          VG Duffy
                                          • Asgothian
                                            Asgothian Developer @Duffy last edited by
                                            @duffy das kenne ich von bestimmten “dummen” Geräten, die sich nicht einfach so vollständig zurück setzen lassen.
                                            Ob das bei den fingerbots der Fall ist weiss ich nicht - was passiert ist das die Geräte nicht sauber ins pairing gehen solange sie ein “altes” Netzwerk kontaktieren können.
                                            A.
                                            zigbee 2.0.1
                                            50
                                            525
                                            76167
