    4. nach update läuft mbus nicht und ... shelly z.T.
    • pille0557
      pille0557 @pille0557 last edited by
      ich vermute fast, dass es mit dem Firmware-Update der Shells zusammenhängt?
      1.4.4 ?
        Thomas Braun Most Active @pille0557 last edited by
        @pille0557
        Könnte eine falsche Installation von nodejs sein. Die Langfassung von
        iob diag
        sagt? Und KEINE Screenshots von Text.
        pille0557 1 Reply Last reply Reply Quote 0
        • pille0557
          pille0557 @Thomas Braun last edited by Homoran
          ========== Start marking the full check here ===========
          Script v.2025-02-23
          *** BASE SYSTEM ***
           Static hostname: debianiob
                 Icon name: computer-desktop
                   Chassis: desktop 🖥️
                    Kernel: Linux 6.1.0-31-amd64
              Architecture: x86-64
           Hardware Vendor: FUJITSU
            Hardware Model: FUTRO S740
          Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
          OS is similar to:
          model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
          Docker          : false
          Virtualization  : none
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           23:29:36 up 10:32,  2 users,  load average: 0.05, 0.34, 0.27
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** TIME AND TIMEZONES ***
                         Local time: Sat 2025-03-01 23:29:36 CET
                     Universal time: Sat 2025-03-01 22:29:36 UTC
                           RTC time: Sat 2025-03-01 22:29:36
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          peter
          HOME=/home/peter
          GROUPS=peter sudo iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             16G        1.9G         13G         31M        1.5G         14G
          Swap:           775M          0B        775M
          Total:           17G        1.9G         14G
          Active iob-Instances:   14
                  15762 M total memory
                   1783 M used memory
                    784 M active memory
                   1763 M inactive memory
                  12881 M free memory
                    459 M buffer memory
                    977 M swap cache
                    739 M total swap
                      0 M used swap
                    739 M free swap
          top - 23:29:37 up 10:32,  2 users,  load average: 0.05, 0.34, 0.27
          Tasks: 166 total,   1 running, 165 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  15762.3 total,  12881.5 free,   1783.9 used,   1437.1 buff/cache
          MiB Swap:    740.0 total,    740.0 free,      0.0 used.  13978.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  7.7G     0  7.7G   0% /dev
          tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
          /dev/sda1      ext4      233G   13G  209G   6% /
          tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
          tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
          /dev/sda2      vfat      300M  5.9M  294M   2% /boot/efi
          tmpfs          tmpfs     1.6G   48K  1.6G   1% /run/user/114
          tmpfs          tmpfs     1.6G   44K  1.6G   1% /run/user/1001
          [Sat Mar  1 12:57:07 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Mar  1 12:57:08 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET      SOURCE    FSTYPE OPTIONS
          /           /dev/sda1 ext4   rw,relatime,errors=remount-ro
          `-/boot/efi /dev/sda2 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
          /var:
          3.3G    /var/
          1.9G    /var/cache
          1.8G    /var/cache/apt/archives
          1.8G    /var/cache/apt
          1.3G    /var/log
          Archived and active journals take up 63.8M in the file system.
          /opt/iobroker/backups:
          47M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          240M    /opt/iobroker/iobroker-data/
          181M    /opt/iobroker/iobroker-data/files
          158M    /opt/iobroker/iobroker-data/files/admin.admin
          157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          7.7M    /opt/iobroker/iobroker-data/states.jsonl
          7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.3
          /usr/bin/node           v20.18.3
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.30.0
          nodejs:
            Installed: 20.18.3-1nodesource1
            Candidate: 20.18.3-1nodesource1
            Version table:
           *** 20.18.3-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 18737)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.4.10
          javascript:     "javascript" not found
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : debianiob                                -  enabled
            system.adapter.discovery.0              : discovery             : debianiob                                - disabled
          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
          + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
          + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
          + system.adapter.fronius.1                : fronius               : debianiob                                -  enabled
          + system.adapter.fronius.2                : fronius               : debianiob                                -  enabled
          + system.adapter.fronius.3                : fronius               : debianiob                                -  enabled
          + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
            system.adapter.mbus.0                   : mbus                  : debianiob                                - disabled, port: 3493
          + system.adapter.shelly.0                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.shelly.2                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.3                 : shelly                : debianiob                                -  enabled, port: 1884, bind: 0.0.0.0
            system.adapter.wireless-mbus.0          : wireless-mbus         : debianiob                                - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "fronius"      : 2.1.1    , installed 2.1.1
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "mbus"         : 2.7.0    , installed 2.7.0
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
          Objects and States
          Objects:        7017
          States:         5747
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
          Get:4 https://packages.grafana.com/enterprise/deb stable InRelease [7660 B]
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Err:4 https://packages.grafana.com/enterprise/deb stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       115625     13380/io.shelly.3
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       117802     13365/io.shelly.2
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       118832     13350/io.shelly.1
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          20995      649/cupsd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       116477     13129/iobroker.js-c
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       116482     13129/iobroker.js-c
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22504      672/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14290      1/init
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      117        22596      650/influxd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          20994      649/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          22506      672/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          919        1/init
          tcp6       0      0 :::3000                 :::*                    LISTEN      118        24176      1134/grafana
          tcp6       0      0 :::8086                 :::*                    LISTEN      117        16974      650/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1002       113446     13147/io.admin.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        20898      572/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1002       116697     13231/io.shelly.0
          udp        0      0 0.0.0.0:38742           0.0.0.0:*                           109        20900      572/avahi-daemon: r
          udp        0      0 0.0.0.0:48497           0.0.0.0:*                           1002       162344     13231/io.shelly.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          918        1/init
          udp6       0      0 :::5353                 :::*                                109        20899      572/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          1721       1/init
          udp6       0      0 fe80::5b6b:3490:c74:546 :::*                                0          129191     608/NetworkManager
          udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          17171      608/NetworkManager
          udp6       0      0 :::35836                :::*                                109        20901      572/avahi-daemon: r
          2025-03-01 18:55:56.231  - info: admin.0 (13147) ==> Connected system.user.admin from ::ffff:192.168.1.74
          2025-03-01 18:56:56.242  - info: admin.0 (13147) <== Disconnect system.user.admin from ::ffff:192.168.1.74 admin
          2025-03-01 18:57:18.611  - info: admin.0 (13147) ==> Connected system.user.admin from ::ffff:192.168.0.76
          2025-03-01 19:16:17.354  - error: fronius-solarweb.0 (13320) refresh token failed
          2025-03-01 19:16:17.362  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
          2025-03-01 19:16:17.362  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
          2025-03-01 19:16:17.363  - error: fronius-solarweb.0 (13320) Start relogin in 1min
          2025-03-01 19:24:37.344  - info: admin.0 (13147) <== Disconnect system.user.admin from ::ffff:192.168.0.76 admin
          2025-03-01 19:24:38.598  - info: admin.0 (13147) failed connection to socket.io from ::ffff:192.168.0.76: Passport was not initialized
          2025-03-01 20:14:34.830  - error: fronius-solarweb.0 (13320) refresh token failed
          2025-03-01 20:14:34.837  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
          2025-03-01 20:14:34.838  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
          2025-03-01 20:14:34.838  - error: fronius-solarweb.0 (13320) Start relogin in 1min
          2025-03-01 21:12:54.845  - error: fronius-solarweb.0 (13320) refresh token failed
          2025-03-01 21:12:54.852  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
          2025-03-01 21:12:54.853  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
          2025-03-01 21:12:54.853  - error: fronius-solarweb.0 (13320) Start relogin in 1min
          2025-03-01 22:11:14.751  - error: fronius-solarweb.0 (13320) refresh token failed
          2025-03-01 22:11:14.759  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
          2025-03-01 22:11:14.759  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
          2025-03-01 22:11:14.760  - error: fronius-solarweb.0 (13320) Start relogin in 1min
          2025-03-01 23:09:34.750  - error: fronius-solarweb.0 (13320) refresh token failed
          2025-03-01 23:09:34.757  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
          2025-03-01 23:09:34.758  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
          2025-03-01 23:09:34.759  - error: fronius-solarweb.0 (13320) Start relogin in 1min
          iob diag has finished.
                                  v.2025-02-23
                   Chassis: desktop 🖥️
          Installation:           native
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1001
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          Recommended versions are nodejs 20.18.3 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Swap:           775M          0B        775M
          Total:           17G        1.9G         14G
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.4.10
          Objects type: jsonl
          States  type: jsonl
          Objects:                7017
          States:                 5747
          Size of iob-Database:
          7.8M    /opt/iobroker/iobroker-data/states.jsonl
          • pille0557
            pille0557 @pille0557 last edited by pille0557
            @pille0557
            so ... iobroker auf einem raspi neu installiert
            mbus läuft hier jetzt wieder
            bzgl. shelly wieder das gleiche Ergebnis:
            shelly0 ist Gen2 - Shelly Pro 1PM Port 1882
            shelly1 ist Gen2 - Shelly Pro 1PM Port 1883
            shelly2 ist Gen2 - Shelly Plus 1PM Port 1884
            shelly0-2 wieder alle das gleiche adminPW und mqttPW, nur auf verschiedenen Ports
            • pille0557
              @pille0557
              habe mal für shelly.0 und shelly.2 auf dn Geräten einen anderen Port eintragen, das Passwort auch nochmal eingetragen ... und siehe da Instanzen liefen wieder ... ?
              • mcm1957
                mcm1957 @pille0557 last edited by
                @pille0557
                Hat zwar per se mal nichts mit deinem Problem zu tun aber darf man fragen warum du drei Shelly Instanzen betreibst?
                • pille0557
                  pille0557 @mcm1957 last edited by
                  @mcm1957
                  Es sind sogar 4!
                  Ich brauche doch für jeden Shelly eine Instanz?
                  1 Shelly3em für WP, Heizstab und Nuos
                  2 pro1pm für 2 Growatt WR und einen weiteren …
                  crunchip mcm1957 2 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @pille0557 last edited by crunchip
                    @pille0557 sagte in nach update läuft mbus nicht und ... shelly z.T.:
                    Nein, eine reicht, ausser du hast Gen1 und Gen2 Geräte.
                    Letztere laufen nur per mqtt, Gen 1 können coloT(coap) und/oder mqtt, jedoch bei mqtt als Protokoll keine cloud Verbindung.
                    In der Regel 1882 für shelly Geräte.
                    Steht aber eigentlich alles in der Readme beschrieben
                    • pille0557
                      pille0557 @crunchip last edited by pille0557
                      @crunchip
                      ok, der 3em ist Gen.1
                      und alle anderen Gen.2 mit mqtt auf demselben Port ... aha, na dann muss ich nochmal probieren
                      • mcm1957
                        @pille0557 said in nach update läuft mbus nicht und ... shelly z.T.:
                        @mcm1957
                        Es sind sogar 4!
                        Ne
                        normaler Weise reichen max 2 Instanzeb
                        eine mit Einstellung coap für gen 1 Shellies
                        eine .it Einstellung MQTT für gen 2 und neuere Shellies.
                        • pille0557
                          @mcm1957
                          Ok, ich dachte, es wäre wie bei den Fronius Adaptern, da brauche ich ja für jeder WR einen eigenen Adapter
                          450
