    4. nach update läuft mbus nicht und ... shelly z.T.
      Thomas Braun Most Active @pille0557 last edited by
      @pille0557
      Könnte eine falsche Installation von nodejs sein. Die Langfassung von
      iob diag
      sagt? Und KEINE Screenshots von Text.
      pille0557 1 Reply Last reply Reply Quote 0
      • pille0557
        pille0557 @Thomas Braun last edited by Homoran
        ========== Start marking the full check here ===========
        Script v.2025-02-23
        *** BASE SYSTEM ***
         Static hostname: debianiob
               Icon name: computer-desktop
                 Chassis: desktop 🖥️
                  Kernel: Linux 6.1.0-31-amd64
            Architecture: x86-64
         Hardware Vendor: FUJITSU
          Hardware Model: FUTRO S740
        Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
        OS is similar to:
        model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         23:29:36 up 10:32,  2 users,  load average: 0.05, 0.34, 0.27
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Sat 2025-03-01 23:29:36 CET
                   Universal time: Sat 2025-03-01 22:29:36 UTC
                         RTC time: Sat 2025-03-01 22:29:36
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        peter
        HOME=/home/peter
        GROUPS=peter sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             16G        1.9G         13G         31M        1.5G         14G
        Swap:           775M          0B        775M
        Total:           17G        1.9G         14G
        Active iob-Instances:   14
                15762 M total memory
                 1783 M used memory
                  784 M active memory
                 1763 M inactive memory
                12881 M free memory
                  459 M buffer memory
                  977 M swap cache
                  739 M total swap
                    0 M used swap
                  739 M free swap
        top - 23:29:37 up 10:32,  2 users,  load average: 0.05, 0.34, 0.27
        Tasks: 166 total,   1 running, 165 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15762.3 total,  12881.5 free,   1783.9 used,   1437.1 buff/cache
        MiB Swap:    740.0 total,    740.0 free,      0.0 used.  13978.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  7.7G     0  7.7G   0% /dev
        tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
        /dev/sda1      ext4      233G   13G  209G   6% /
        tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        /dev/sda2      vfat      300M  5.9M  294M   2% /boot/efi
        tmpfs          tmpfs     1.6G   48K  1.6G   1% /run/user/114
        tmpfs          tmpfs     1.6G   44K  1.6G   1% /run/user/1001
        [Sat Mar  1 12:57:07 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Mar  1 12:57:08 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET      SOURCE    FSTYPE OPTIONS
        /           /dev/sda1 ext4   rw,relatime,errors=remount-ro
        `-/boot/efi /dev/sda2 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        3.3G    /var/
        1.9G    /var/cache
        1.8G    /var/cache/apt/archives
        1.8G    /var/cache/apt
        1.3G    /var/log
        Archived and active journals take up 63.8M in the file system.
        /opt/iobroker/backups:
        47M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        240M    /opt/iobroker/iobroker-data/
        181M    /opt/iobroker/iobroker-data/files
        158M    /opt/iobroker/iobroker-data/files/admin.admin
        157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        7.7M    /opt/iobroker/iobroker-data/states.jsonl
        7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.3
        /usr/bin/node           v20.18.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.30.0
        nodejs:
          Installed: 20.18.3-1nodesource1
          Candidate: 20.18.3-1nodesource1
          Version table:
         *** 20.18.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 18737)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.4.10
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : debianiob                                -  enabled
          system.adapter.discovery.0              : discovery             : debianiob                                - disabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
        + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
        + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
        + system.adapter.fronius.1                : fronius               : debianiob                                -  enabled
        + system.adapter.fronius.2                : fronius               : debianiob                                -  enabled
        + system.adapter.fronius.3                : fronius               : debianiob                                -  enabled
        + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
          system.adapter.mbus.0                   : mbus                  : debianiob                                - disabled, port: 3493
        + system.adapter.shelly.0                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.2                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.3                 : shelly                : debianiob                                -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.wireless-mbus.0          : wireless-mbus         : debianiob                                - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "mbus"         : 2.7.0    , installed 2.7.0
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
        Objects and States
        Objects:        7017
        States:         5747
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
        Get:4 https://packages.grafana.com/enterprise/deb stable InRelease [7660 B]
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Err:4 https://packages.grafana.com/enterprise/deb stable InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       115625     13380/io.shelly.3
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       117802     13365/io.shelly.2
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       118832     13350/io.shelly.1
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          20995      649/cupsd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       116477     13129/iobroker.js-c
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       116482     13129/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22504      672/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14290      1/init
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      117        22596      650/influxd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          20994      649/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          22506      672/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          919        1/init
        tcp6       0      0 :::3000                 :::*                    LISTEN      118        24176      1134/grafana
        tcp6       0      0 :::8086                 :::*                    LISTEN      117        16974      650/influxd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1002       113446     13147/io.admin.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        20898      572/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1002       116697     13231/io.shelly.0
        udp        0      0 0.0.0.0:38742           0.0.0.0:*                           109        20900      572/avahi-daemon: r
        udp        0      0 0.0.0.0:48497           0.0.0.0:*                           1002       162344     13231/io.shelly.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          918        1/init
        udp6       0      0 :::5353                 :::*                                109        20899      572/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          1721       1/init
        udp6       0      0 fe80::5b6b:3490:c74:546 :::*                                0          129191     608/NetworkManager
        udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          17171      608/NetworkManager
        udp6       0      0 :::35836                :::*                                109        20901      572/avahi-daemon: r
        2025-03-01 18:55:56.231  - info: admin.0 (13147) ==> Connected system.user.admin from ::ffff:192.168.1.74
        2025-03-01 18:56:56.242  - info: admin.0 (13147) <== Disconnect system.user.admin from ::ffff:192.168.1.74 admin
        2025-03-01 18:57:18.611  - info: admin.0 (13147) ==> Connected system.user.admin from ::ffff:192.168.0.76
        2025-03-01 19:16:17.354  - error: fronius-solarweb.0 (13320) refresh token failed
        2025-03-01 19:16:17.362  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
        2025-03-01 19:16:17.362  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
        2025-03-01 19:16:17.363  - error: fronius-solarweb.0 (13320) Start relogin in 1min
        2025-03-01 19:24:37.344  - info: admin.0 (13147) <== Disconnect system.user.admin from ::ffff:192.168.0.76 admin
        2025-03-01 19:24:38.598  - info: admin.0 (13147) failed connection to socket.io from ::ffff:192.168.0.76: Passport was not initialized
        2025-03-01 20:14:34.830  - error: fronius-solarweb.0 (13320) refresh token failed
        2025-03-01 20:14:34.837  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
        2025-03-01 20:14:34.838  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
        2025-03-01 20:14:34.838  - error: fronius-solarweb.0 (13320) Start relogin in 1min
        2025-03-01 21:12:54.845  - error: fronius-solarweb.0 (13320) refresh token failed
        2025-03-01 21:12:54.852  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
        2025-03-01 21:12:54.853  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
        2025-03-01 21:12:54.853  - error: fronius-solarweb.0 (13320) Start relogin in 1min
        2025-03-01 22:11:14.751  - error: fronius-solarweb.0 (13320) refresh token failed
        2025-03-01 22:11:14.759  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
        2025-03-01 22:11:14.759  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
        2025-03-01 22:11:14.760  - error: fronius-solarweb.0 (13320) Start relogin in 1min
        2025-03-01 23:09:34.750  - error: fronius-solarweb.0 (13320) refresh token failed
        2025-03-01 23:09:34.757  - error: fronius-solarweb.0 (13320) AxiosError: Request failed with status code 400
        2025-03-01 23:09:34.758  - error: fronius-solarweb.0 (13320) {"responseError":1120,"responseMessage":"Refresh token invalid."}
        2025-03-01 23:09:34.759  - error: fronius-solarweb.0 (13320) Start relogin in 1min
        iob diag has finished.
                                v.2025-02-23
                 Chassis: desktop 🖥️
        Installation:           native
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1001
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        Recommended versions are nodejs 20.18.3 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Swap:           775M          0B        775M
        Total:           17G        1.9G         14G
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.4.10
        Objects type: jsonl
        States  type: jsonl
        Objects:                7017
        States:                 5747
        Size of iob-Database:
        7.8M    /opt/iobroker/iobroker-data/states.jsonl
        • pille0557
          pille0557 @pille0557 last edited by pille0557
          @pille0557
          so ... iobroker auf einem raspi neu installiert
          mbus läuft hier jetzt wieder
          bzgl. shelly wieder das gleiche Ergebnis:
          shelly0 ist Gen2 - Shelly Pro 1PM Port 1882
          shelly1 ist Gen2 - Shelly Pro 1PM Port 1883
          shelly2 ist Gen2 - Shelly Plus 1PM Port 1884
          shelly0-2 wieder alle das gleiche adminPW und mqttPW, nur auf verschiedenen Ports
          • pille0557
            @pille0557
            habe mal für shelly.0 und shelly.2 auf dn Geräten einen anderen Port eintragen, das Passwort auch nochmal eingetragen ... und siehe da Instanzen liefen wieder ... ?
            • mcm1957
              mcm1957 @pille0557 last edited by
              @pille0557
              Hat zwar per se mal nichts mit deinem Problem zu tun aber darf man fragen warum du drei Shelly Instanzen betreibst?
              • pille0557
                pille0557 @mcm1957 last edited by
                @mcm1957
                Es sind sogar 4!
                Ich brauche doch für jeden Shelly eine Instanz?
                1 Shelly3em für WP, Heizstab und Nuos
                2 pro1pm für 2 Growatt WR und einen weiteren …
                crunchip mcm1957 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @pille0557 last edited by crunchip
                  @pille0557 sagte in nach update läuft mbus nicht und ... shelly z.T.:
                  Nein, eine reicht, ausser du hast Gen1 und Gen2 Geräte.
                  Letztere laufen nur per mqtt, Gen 1 können coloT(coap) und/oder mqtt, jedoch bei mqtt als Protokoll keine cloud Verbindung.
                  In der Regel 1882 für shelly Geräte.
                  Steht aber eigentlich alles in der Readme beschrieben
                  • pille0557
                    pille0557 @crunchip last edited by pille0557
                    @crunchip
                    ok, der 3em ist Gen.1
                    und alle anderen Gen.2 mit mqtt auf demselben Port ... aha, na dann muss ich nochmal probieren
                    • mcm1957
                      @pille0557 said in nach update läuft mbus nicht und ... shelly z.T.:
                      @mcm1957
                      Es sind sogar 4!
                      Ne
                      normaler Weise reichen max 2 Instanzeb
                      eine mit Einstellung coap für gen 1 Shellies
                      eine .it Einstellung MQTT für gen 2 und neuere Shellies.
                      • pille0557
                        @mcm1957
                        Ok, ich dachte, es wäre wie bei den Fronius Adaptern, da brauche ich ja für jeder WR einen eigenen Adapter
                        450
