    4. Test Adapter Bosch ebik connect / flow
      Thomas Braun Most Active @Spectrum1981 last edited by Thomas Braun
      @spectrum1981
      Halb so wild, wenn alles korrekt installiert (und auf aktuellem Stand) ist:
      echad@chet:~ $ npm install canvas
      added 37 packages in 3m
      9 packages are looking for funding
        run `npm fund` for details
      npm notice
      npm notice New major version of npm available! 10.8.2 -> 11.1.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.1.0
      npm notice To update run: npm install -g npm@11.1.0
      npm notice
      echad@chet:~ $ npm ls canvas
      echad@ /home/echad
      └── canvas@3.1.0
      Da stimmen also die Voraussetzungen nicht. Hast du den Fixer ausgeführt?
        Spectrum1981 @Thomas Braun last edited by
        Ja,habe ich und auch schon neugestartet.
          @spectrum1981
          Dann zeig mal wie du da insgesamt unterwegs bist...
          iob diag
          in der Langfassung.
            Klar. Hier haste einiges zu lesen 🙂
            Und schon mal jetzt vielen Dank für die Hilfe!
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-02-23
            *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             21:53:35 up  4:53,  2 users,  load average: 1.13, 0.72, 0.53
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Tue 2025-03-04 21:53:35 CET
                       Universal time: Tue 2025-03-04 20:53:35 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev influxdb gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth redis gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.8G        3.1G        3.1G        0.0K        1.6G        4.6G
            Swap:            99M          0B         99M
            Total:          7.9G        3.1G        3.2G
            Active iob-Instances:   25
                     7812 M total memory
                     3102 M used memory
                     3439 M active memory
                     1039 M inactive memory
                     3137 M free memory
                      122 M buffer memory
                     1449 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 21:53:36 up  4:53,  2 users,  load average: 1.13, 0.72, 0.53
            Tasks: 185 total,   2 running, 183 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 23.5 us,  8.8 sy,  0.0 ni, 67.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   7812.3 total,   3130.7 free,   3105.0 used,   1576.6 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4552.9 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4       58G   16G   40G  29% /
            devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     1.6G  892K  1.6G   1% /run
            /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
            tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
            [Tue Mar  4 17:00:27 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D6:FF:DA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=43dc5f67-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue Mar  4 17:00:28 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Mar  4 17:00:28 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Tue Mar  4 17:00:30 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            5.5G    /var/
            4.1G    /var/log
            4.0G    /var/log/journal/fac7f0655ecd4193826bcb0a2d76a163
            818M    /var/lib
            Archived and active journals take up 3.9G in the file system.
            /opt/iobroker/backups:
            2.6G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            129M    /opt/iobroker/iobroker-data/
            104M    /opt/iobroker/iobroker-data/history
            14M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            9.8M    /opt/iobroker/iobroker-data/objects.jsonl
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            1.6M    /opt/iobroker/iobroker-data/states.jsonl
            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_08e8a16dac1aec11a7fc74e5f01c6278-if00-port0
            /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0050-if00-port0
            *** ZigBee Settings ***
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyUSB1
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.3
            /usr/bin/node           v20.18.3
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.30.0
            nodejs:
              Installed: 20.18.3-1nodesource1
              Candidate: 20.18.3-1nodesource1
              Version table:
             *** 20.18.3-1nodesource1 600
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.18.2-1nodesource1 600
                 20.18.1-1nodesource1 600
                 20.18.0-1nodesource1 600
                 20.17.0-1nodesource1 600
                 20.16.0-1nodesource1 600
                 20.15.1-1nodesource1 600
                 20.15.0-1nodesource1 600
                 20.14.0-1nodesource1 600
                 20.13.1-1nodesource1 600
                 20.13.0-1nodesource1 600
                 20.12.2-1nodesource1 600
                 20.12.1-1nodesource1 600
                 20.12.0-1nodesource1 600
                 20.11.1-1nodesource1 600
                 20.11.0-1nodesource1 600
                 20.10.0-1nodesource1 600
                 20.9.0-1nodesource1 600
                 20.8.1-1nodesource1 600
                 20.8.0-1nodesource1 600
                 20.7.0-1nodesource1 600
                 20.6.1-1nodesource1 600
                 20.6.0-1nodesource1 600
                 20.5.1-1nodesource1 600
                 20.5.0-1nodesource1 600
                 20.4.0-1nodesource1 600
                 20.3.1-1nodesource1 600
                 20.3.0-1nodesource1 600
                 20.2.0-1nodesource1 600
                 20.1.0-1nodesource1 600
                 20.0.0-1nodesource1 600
                 12.22.12~dfsg-1~deb11u6 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            At least one iobroker host is running.
            Objects type: redis
            States  type: redis
            Hosts:
            raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 17556)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.4.10
            javascript:     8.8.3
            nodejs modules from github:     3
            +-- iobroker.ankersolix2@1.1.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#b60ae2fdf9087fc1b27da425d483dec2e0cb0a6b)
            +-- iobroker.bosch-ebike@0.1.12 (git+ssh://git@github.com/TA2k/ioBroker.bosch-ebike.git#71ad7a8139a8af772f671e9c37eddf2ad064c69e)
            +-- iobroker.lovelace@4.1.11 (git+ssh://git@github.com/ioBroker/ioBroker.lovelace.git#0fbfd8694eb401357df1c47fa41dd0e7147e582d)
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
              system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
            + system.adapter.ankersolix2.0            : ankersolix2           : raspberrypi                              -  enabled
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
            + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
            + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 192.168.81.250, run as: admin
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
            + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
            + system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
            + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB1
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.4.10   , installed 7.4.10
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "lovelace"     : 4.1.10   , installed 4.1.11
            Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "roborock"     : 0.6.18   , installed 0.6.18
            Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
            Adapter    "shelly"       : 8.5.1    , installed 8.5.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
            Objects and States
            Objects:        7634
            States:         6440
            Hit:1 https://repos.influxdata.com/debian stable InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:5 https://packages.grafana.com/oss/deb stable InRelease
            Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       254603     8885/sshd: pi@pts/0
            tcp        0      0 192.168.81.250:2001     0.0.0.0:*               LISTEN      1001       18662      1312/io.hm-rpc.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17595      1124/io.sonoff.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17076      1297/io.shelly.0
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        14235      525/redis-server 12
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1687       568/sshd: /usr/sbin
            tcp        0      0 192.168.81.250:8091     0.0.0.0:*               LISTEN      1001       16135      1479/io.lovelace.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15604      937/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17334      1456/io.web.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16331      1556/io.socketio.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        15033      794/influxd
            tcp6       0      0 :::7906                 :::*                    LISTEN      1001       15305      1016/io.roborock.0
            tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       254602     8885/sshd: pi@pts/0
            tcp6       0      0 :::3000                 :::*                    LISTEN      110        15550      904/grafana
            tcp6       0      0 :::6824                 :::*                    LISTEN      1001       15304      1016/io.roborock.0
            tcp6       0      0 :::1984                 :::*                    LISTEN      1000       12791      424/go2rtc_linux_ar
            tcp6       0      0 ::1:6379                :::*                    LISTEN      109        14236      525/redis-server 12
            tcp6       0      0 :::8555                 :::*                    LISTEN      1000       12794      424/go2rtc_linux_ar
            tcp6       0      0 :::8554                 :::*                    LISTEN      1000       14542      424/go2rtc_linux_ar
            tcp6       0      0 :::22                   :::*                    LISTEN      0          1689       568/sshd: /usr/sbin
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17275      1430/io.mihome-vacu
            udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       18954      1441/io.mihome-vacu
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1645       419/avahi-daemon: r
            udp        0      0 0.0.0.0:55408           0.0.0.0:*                           108        1647       419/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12811      737/dhcpcd
            udp6       0      0 :::546                  :::*                                0          1702       737/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        1646       419/avahi-daemon: r
            udp6       0      0 :::35851                :::*                                108        1648       419/avahi-daemon: r
            2025-03-04 21:50:14.330  - info: smartmeter.0 (1379) Received 22 values, 13 updated
            2025-03-04 21:50:22.050  - info: javascript.0 (1070) script.js.fussbodenheizung.steuerung: Temperatur kleiner als: 19.89 Heizkreis Flur OG wird eingeschaltet
            2025-03-04 21:50:25.349  - info: smartmeter.0 (1379) Received 22 values, 14 updated
            2025-03-04 21:50:36.328  - info: smartmeter.0 (1379) Received 22 values, 11 updated
            2025-03-04 21:50:47.319  - info: smartmeter.0 (1379) Received 22 values, 11 updated
            2025-03-04 21:50:58.323  - info: smartmeter.0 (1379) Received 22 values, 12 updated
            2025-03-04 21:51:09.318  - info: smartmeter.0 (1379) Received 22 values, 10 updated
            2025-03-04 21:51:20.334  - info: smartmeter.0 (1379) Received 22 values, 10 updated
            2025-03-04 21:51:31.327  - info: smartmeter.0 (1379) Received 22 values, 8 updated
            2025-03-04 21:51:42.333  - info: smartmeter.0 (1379) Received 22 values, 8 updated
            2025-03-04 21:51:53.373  - info: smartmeter.0 (1379) Received 22 values, 10 updated
            2025-03-04 21:52:04.357  - info: smartmeter.0 (1379) Received 22 values, 13 updated
            2025-03-04 21:52:15.324  - info: smartmeter.0 (1379) Received 22 values, 10 updated
            2025-03-04 21:52:26.316  - info: smartmeter.0 (1379) Received 22 values, 9 updated
            2025-03-04 21:52:28.508  - info: javascript.0 (1070) script.js.fussbodenheizung.steuerung: Temperatur größer als: 21.53 Heizkreis Kind wird ausgeschaltet
            2025-03-04 21:52:37.342  - info: smartmeter.0 (1379) Received 22 values, 12 updated
            2025-03-04 21:52:48.340  - info: smartmeter.0 (1379) Received 22 values, 13 updated
            2025-03-04 21:52:59.328  - info: smartmeter.0 (1379) Received 22 values, 13 updated
            2025-03-04 21:53:10.326  - info: smartmeter.0 (1379) Received 22 values, 9 updated
            2025-03-04 21:53:21.350  - info: smartmeter.0 (1379) Received 22 values, 10 updated
            2025-03-04 21:53:32.359  - info: smartmeter.0 (1379) Received 22 values, 11 updated
            2025-03-04 21:53:43.328  - info: smartmeter.0 (1379) Received 22 values, 9 updated
            2025-03-04 21:53:54.307  - info: smartmeter.0 (1379) Received 22 values, 7 updated
            2025-03-04 21:54:05.349  - info: smartmeter.0 (1379) Received 22 values, 13 updated
            2025-03-04 21:54:16.326  - info: smartmeter.0 (1379) Received 22 values, 12 updated
            iob diag has finished.
            Copy text starting here:
                                    v.2025-02-23
                     Icon name: computer
                  Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            Boot Target:            multi-user.target
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            Recommended versions are nodejs 20.18.3 and npm 10.8.2
            nodeJS installation is correct
            MEMORY:
            Mem:            7.8G        3.1G        3.3G        0.0K        1.4G        4.6G
            Swap:            99M          0B         99M
            Total:          7.9G        3.1G        3.4G
            ioBroker Core:          js-controller           7.0.6
                                    admin                   7.4.10
            Objects type: redis
            States  type: redis
            Objects:                7634
            States:                 6440
            Size of iob-Database:
            === Mark text until here for copying ===
              @spectrum1981 sagte in Test Adapter Bosch ebik connect / flow:
              Nee, muss ich nicht.
              Bring das per NEUINSTALLATION auf Debian 12 'Bookworm'.
              Danach schau ich mir das gegebenenfalls weiter an.
                Ok, das hier ist keine Option auch wenn nicht die Sauberste? Da ist leider noch mehr drauf wie der iobroker alleine 😞
                https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                  @spectrum1981
                  Nicht wirklich.
                    Ok, ich plane das mal und werde das angehen. Vielen Dank!
                      @spectrum1981
                      Ein Backup-Konzept musste ja eh haben, egal wieviel Zeug auf der Kiste läuft.
                      Könnte ja auch sein, dass der Hobel aus anderen Gründen neuinstalliert werden muss.
                        schienw last edited by
                        Hallo McLane,
                        eine Frage, was machst du mit den Daten der einzelnen Ausfahrten?
                        Ich würde mir gerne auch meine Fahrten, vor allem die unterschiedlichen Stufen, anzeigen lassen. Vielleicht sogar die map dazu. Hast du hierzu einen Ansatz wie die Daten zu visualisieren sind?
                        Da
                        nke
                        VG
                        Schienw
                        M bahnuhr 2 Replies Last reply Reply Quote 0
                          McLane @schienw last edited by McLane
                          @schienw Da ich mit der Trennung der beiden Adapter nicht wirklich weiter gekommen bin, visualisiere ich im Moment nur meine gefahrenen Kilometer in einer Jahrestabelle. Letzte Woche wollte ich noch mal zum Vergleich den onebikeapp-ios Link von der Instanz 2 über die Konsole holen, und selbst das geht jetzt nicht mehr, weil die Browser alle melden, das Cookies nicht gefunden wurden. Ein entsprechender Link wurde nicht wieder angezeigt. Hoffe da irgendwann weiter zu kommen.
                          Was die einzelnen Werte in den "assistModeUsage" Spalten bedeuten, kann ich dir nicht sagen.
                          Hoffe du kommst weiter!
                          Jo
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @schienw last edited by
                            @schienw sagte in Test Adapter Bosch ebik connect / flow:
                            Suche benutzt ?
                            z.B. hier:
                            https://forum.iobroker.net/topic/55918/maps-mit-streckendarstellung/47?_=1741421233456
                              schienw @bahnuhr last edited by
                              @bahnuhr
                              anscheinend nicht erfolgreich, aber dank deiner Hilfe bin ich jetzt schon sehr weit gekommen.
                              Ich kann mir in einer Tabelle alle Fahrten mit Datum und Fahrstrecke je Unterstützung anzeigen lassen. Zu den Touren werden in der zweiten Spalte auch alle Maps in klein angezeigt, Mittelpunkt ist Start der Tour.
                              Als nächstes versuche ich nun noch das Höhenprofil als Grafik anzeigen zu lassen.
                              Vielen Dank
                              Schienw
                              • bahnuhr
                                Na, dann stell doch deine Lösung mal hier ein.
                                  @bahnuhr
                                  Anbei mein Script:
                                  // Script um aus den DP vom Adapter "bosch-ebike" eine MAP zu erstellen und den Weg zu zeichnen
                                  // bahnuhr, 03_2024
                                  // Variablen
                                      var poly ="";       // hier werden die GPS gespeichert
                                     // var trip = "03";    // DP bei den Objekten der eingelesen werden soll: bosch-ebike.0.trips.xx.details
                                      var logging = true;
                                      var center_gps = "53.465, 11.71";    // Mittelpunkt der Karte
                                      var zoom = 17                       // Zoom der Karte
                                      var pfad = "route.html"             // Dateiname - wird in vis.0 gespeichert
                                  // GPS einlesen und der Variablen poly zuweisen
                                  // html erzeugen und speichern in /vis.0/xxx.html
                                      var string = '<!DOCTYPE html>\n<html>\n<head>\n<title>Simple Leaflet Map</title>\n<meta charset="utf-8" />\n'
                                      string = string + '<body>\n'
                                      string = string + '<table border=0>'
                                      string = string + '<tr>'
                                      const idsCO2 = $('bosch-ebike.0.trips.*.id');
                                      var f = 2
                                      var hilf = 0
                                      idsCO2.each(function(id, i) {
                                          var poly ="";
                                        var h= getState(id).val
                                        if (i < 9){
                                            ii = i + 1
                                          hilf = "0" + ii
                                        else{
                                          ii =i + 1
                                          hilf = i + 1
                                       distance = 0
                                        var distance = getState("bosch-ebike.0.trips." + hilf + ".attributes.distance").val;
                                        var startTime = getState("bosch-ebike.0.trips." + hilf + ".attributes.startTime").val;
                                        var ModeUsage01_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage01.name").val;
                                        var ModeUsage01_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage01.assistModeUsage").val;
                                        var ModeUsage01_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.color").val;
                                        var ModeUsage02_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.name").val;
                                        var ModeUsage02_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.assistModeUsage").val;
                                        var ModeUsage02_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.color").val;
                                        var ModeUsage03_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.name").val;
                                        var ModeUsage03_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.assistModeUsage").val;
                                        var ModeUsage03_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.color").val;
                                        var ModeUsage04_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.name").val;
                                        var ModeUsage04_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.assistModeUsage").val;
                                        var ModeUsage04_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.color").val;
                                        var ModeUsage05_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.name").val;
                                        var ModeUsage05_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.assistModeUsage").val;
                                        var ModeUsage05_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.color").val;
                                        var date = formatDate(startTime, "TT.MM.JJJJ SS:mm")
                                        string = string + '<td>'
                                        string = string + date + ' ' + distance/1000 + " KM"
                                            string = string + '<td bgcolor=yellow>'
                                              string = string + ModeUsage01_name
                                            string = string + '</td>'
                                            string = string + '<td bgcolor=blue>'
                                              string = string + ModeUsage02_name
                                            string = string + '<td bgcolor=green>'
                                              string = string + ModeUsage03_name
                                            string = string + '<td bgcolor=orange>'
                                              string = string + ModeUsage04_name
                                            string = string + '<td bgcolor=red>'
                                              string = string + ModeUsage05_name
                                          string = string + '</tr>'
                                              string = string + ModeUsage01_assistModeUsage/1000
                                              string = string + ModeUsage02_assistModeUsage/1000
                                              string = string + ModeUsage03_assistModeUsage/1000
                                              string = string + ModeUsage04_assistModeUsage/1000
                                              string = string + ModeUsage05_assistModeUsage/1000
                                          var Prokm = distance /100
                                              string = string + Math.round(ModeUsage01_assistModeUsage/Prokm) + ' %'
                                              string = string + Math.round(ModeUsage02_assistModeUsage/Prokm) + ' %'
                                              string = string + Math.round(ModeUsage03_assistModeUsage/Prokm) + ' %'
                                              string = string + Math.round(ModeUsage04_assistModeUsage/Prokm) + ' %'
                                              string = string + Math.round(ModeUsage05_assistModeUsage/Prokm) + ' %'
                                        string = string + '</table>'
                                          var poly ="";
                                          var string3 = "";
                                          var obj = JSON.parse(getState("bosch-ebike.0.trips." + hilf + ".details").val);
                                          var end = obj.activityData.length - 1;
                                          var center_gps = '"' + obj.activityData[30].lat + ', ' + obj.activityData[30].lon + '"';
                                      for (var x=0; x<=end; x++) {
                                          if (obj.activityData[x].lat != null)        {
                                            poly = poly + "["+obj.activityData[x].lat+", "+obj.activityData[x].lon+"]"
                                          if (x < end) poly = poly + ","
                                          else      {
                                      if (logging) log (poly);
                                      var center_gps = "48.90376, 11.93504";    // Mittelpunkt der Karte
                                      var zoom = 11
                                      string = string + '<link rel="stylesheet" href="https://unpkg.com/leaflet@1.6.0/dist/leaflet.css"integrity="sha512-xwE/Az9zrjBIphAcBb3F6JVqxf46+CDLwfLMHloNu6KEQCAWi6HcDUbeOfBIptF7tcCzusKFjFw2yuvEpDL9wQ=="crossorigin=""/></head>\n'
                                      string = string + '<body>\n<div id="map' + hilf + '" style="width: 600px; height: 400px"></div>\n<script src="https://unpkg.com/leaflet@1.6.0/dist/leaflet.js"integrity="sha512-gZwIG9x3wUXg2hdXF6+rVkLF/0Vi9U8D2Ntg4Ga5I5BZpVkVxlJWbSQtXPSiUTtC0TjtGOmxa1AJPuV0CPthew=="crossorigin=""></script>\n<script>\n'
                                      string = string + "var map"+  hilf + " = L.map('map" + hilf + "').setView([" + center_gps + "], " + zoom + ");\n"
                                      string = string + "mapLink = '<a href=" + '"http://openstreetmap.org"' + ">OpenStreetMap</a>';\n"
                                      string = string + "L.tileLayer( 'http://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png', {attribution: '&copy; ' + mapLink + ' Contributors', maxZoom: 18,}).addTo(map" + hilf + ");\n"
                                      string = string + 'var polyline = L.polyline([ \n' + poly + '\n], { color: "blue", weight: 3, opacity: .7, lineJoin: "round" } ).addTo(map' + hilf + ');\n'
                                      string = string + '</script>\n'
                                      string = string + '</body>\n</html>'
                                      writeFile("vis.0", "/" + pfad, string, (error) => {
                                          if (logging) log('Datei "" gespeichert!');
                                  bahnuhr Chaot 2 Replies Last reply Reply Quote 0
                                  • bahnuhr
                                    @schienw
                                    Super
                                    Und wenns funktioniert noch besser.
                                      ae55 last edited by ae55
                                      Habe gerade versucht, den Adapter einzurichten, jedoch kam keine onebikeapp-ios:// URL sondern nur ein Link, der mit "https://p9.authz.bosch.com/auth/realms/obc/broker/skid/endpoint" beginnt...
                                      Ich habe die Flow App mit einem Kiox300 und einer LED Remote am E-Bike.
                                      Samson71 T 2 Replies Last reply Reply Quote 0
                                      • Samson71
                                        Samson71 Global Moderator @ae55 last edited by
                                        @ae55
                                        Warum auf Englisch im deutschen Bereich und in einem deutschen Post? Der IP nach sollte Dir Deutsch nicht fremd sein.
                                          ae55 @Samson71 last edited by
                                          @samson71 Sorry, war es halt noch gewohnt vom Home Assistant-Forum alles auf Englisch zu schreiben :-)...
                                            tombox @ae55 last edited by
                                            @ae55 also ich würde vermuten der browser blockiert irgendwas wie cookies
                                            178
                                            32307
