JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.
@elektroniker86 sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
Das ist jetzt aktuell.
bitte erst einmal nur ein Register abrufen.
Input <-> Holding gilt immer noch -
So, ein Register und Debug:
modbus.5 2025-03-06 17:14:13.892 info Disconnected from slave 192.168.1.123 modbus.5 2025-03-06 17:14:13.892 debug Closing client on purpose. modbus.5 2025-03-06 17:14:12.892 debug Cleaning up request fifo. modbus.5 2025-03-06 17:14:12.892 debug Clearing timeout of the current request. modbus.5 2025-03-06 17:14:12.892 debug Socket closed with error modbus.5 2025-03-06 17:14:12.891 warn [DevID_1] Poll error count: 3 code: {"err":"timeout","timeout":5000} modbus.5 2025-03-06 17:14:12.891 error Client in error state. modbus.5 2025-03-06 17:14:12.891 error Request timed out. modbus.5 2025-03-06 17:14:12.891 warn Error: undefined modbus.5 2025-03-06 17:14:07.890 debug [DevID_1/inputRegs] Poll address 4752 - 2 registers modbus.5 2025-03-06 17:14:07.889 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-06 17:14:06.839 warn [DevID_1] Poll error count: 2 code: "ReadInputRegisters: Invalid FC 32" modbus.5 2025-03-06 17:14:04.028 debug [DevID_1/inputRegs] Poll address 4752 - 2 registers modbus.5 2025-03-06 17:14:04.028 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-06 17:14:02.975 warn [DevID_1] Poll error count: 1 code: "App Timeout" modbus.5 2025-03-06 17:13:57.793 warn Error in handler for 4: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds modbus.5 2025-03-06 17:13:57.776 debug [DevID_1/inputRegs] Poll address 4752 - 2 registers modbus.5 2025-03-06 17:13:57.776 debug Initialization of scale factors done! modbus.5 2025-03-06 17:13:57.775 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-06 17:13:57.775 info Connected to slave 192.168.1.123 modbus.5 2025-03-06 17:13:57.721 debug Remove old object modbus.5.inputRegisters.4774_soc modbus.5 2025-03-06 17:13:57.677 debug Initialize Objects for holdingRegs: [] modbus.5 2025-03-06 17:13:57.677 debug Add inputRegisters.4752_Total_Battery_Voltage: {"_id":"inputRegisters.4752_Total_Battery_Voltage","type":"state","common":{"name":"bat vol","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"mV"},"native":{"regType":"inputRegs","address":4752,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1}} modbus.5 2025-03-06 17:13:57.677 debug Initialize Objects for inputRegs: [{"_address":4752,"deviceId":1,"name":"Total Battery Voltage","description":"bat vol","unit":"mV","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":false,"isScale":false,"address":4752,"id":"inputRegisters.4752_Total_Battery_Voltage"}] modbus.5 2025-03-06 17:13:57.676 debug Initialize Objects for coils: [] modbus.5 2025-03-06 17:13:57.676 debug Initialize Objects for disInputs: [] modbus.5 2025-03-06 17:13:57.621 info starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.18.3, js-controller: 7.0.6 modbus.5 2025-03-06 17:13:57.502 debug Plugin sentry Initialize Plugin (enabled=true) modbus.5 2025-03-06 17:13:57.487 debug States connected to redis: 0.0.0.0:9000 modbus.5 2025-03-06 17:13:57.433 debug States create User PubSub Client modbus.5 2025-03-06 17:13:57.433 debug States create System PubSub Client modbus.5 2025-03-06 17:13:57.424 debug Redis States: Use Redis connection: 0.0.0.0:9000 modbus.5 2025-03-06 17:13:57.406 debug Objects connected to redis: 0.0.0.0:9001 modbus.5 2025-03-06 17:13:57.405 debug Objects client initialize lua scripts modbus.5 2025-03-06 17:13:57.376 debug Objects create User PubSub Client modbus.5 2025-03-06 17:13:57.376 debug Objects create System PubSub Client modbus.5 2025-03-06 17:13:57.375 debug Objects client ready ... initialize now modbus.5 2025-03-06 17:13:57.358 debug Redis Objects: Use Redis connection: 0.0.0.0:9001 modbus.5 2025-03-06 17:13:53.655 info terminating modbus.5 2025-03-06 17:13:53.169 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason modbus.5 2025-03-06 17:13:53.169 debug Plugin sentry destroyed modbus.5 2025-03-06 17:13:53.169 info terminating modbus.5 2025-03-06 17:13:53.154 debug Closing client on purpose. modbus.5 2025-03-06 17:13:53.154 info Got terminate signal TERMINATE_YOURSELF -
Add inputRegisters
bitte Holdingregister nehmen
@homoran sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
Add inputRegisters
Und besser beim Port 502 bleiben.
@Elektroniker86 : gibt es bei dem Konverter noch ein erweitertes Menu oder kann man da wo TCP Server steht was anderes auswählen?
Ich habe jetzt das Register beim Reiter Holding eingetragen. und bei eingang rausgelöscht. Hoffe das ist richtig so?
modbus.5 2025-03-06 17:28:01.562 info Disconnected from slave 192.168.1.123 modbus.5 2025-03-06 17:28:01.562 debug Closing client on purpose. modbus.5 2025-03-06 17:28:00.563 debug Cleaning up request fifo. modbus.5 2025-03-06 17:28:00.563 debug Clearing timeout of the current request. modbus.5 2025-03-06 17:28:00.563 debug Socket closed with error modbus.5 2025-03-06 17:28:00.562 warn [DevID_1] Poll error count: 3 code: {"err":"timeout","timeout":5000} modbus.5 2025-03-06 17:28:00.562 error Client in error state. modbus.5 2025-03-06 17:28:00.562 error Request timed out. modbus.5 2025-03-06 17:28:00.561 warn Error: undefined modbus.5 2025-03-06 17:27:55.560 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-06 17:27:55.560 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-06 17:27:54.510 warn [DevID_1] Poll error count: 2 code: "ReadHoldingRegisters: Invalid FC 32" modbus.5 2025-03-06 17:27:54.428 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-06 17:27:54.427 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-06 17:27:53.377 warn [DevID_1] Poll error count: 1 code: "App Timeout" modbus.5 2025-03-06 17:27:48.324 warn Error in handler for 3: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds modbus.5 2025-03-06 17:27:48.178 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-06 17:27:48.178 debug Initialization of scale factors done! modbus.5 2025-03-06 17:27:48.177 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-06 17:27:48.177 info Connected to slave 192.168.1.123 modbus.5 2025-03-06 17:27:48.083 debug Add holdingRegisters.4752_Total_Battery_Voltage: {"_id":"holdingRegisters.4752_Total_Battery_Voltage","type":"state","common":{"name":"bat vol","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"mV"},"native":{"regType":"holdingRegs","address":4752,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}} modbus.5 2025-03-06 17:27:48.083 debug Initialize Objects for holdingRegs: [{"_address":"4752","name":"Total Battery Voltage","description":"bat vol","unit":"mV","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":1,"address":4752,"id":"holdingRegisters.4752_Total_Battery_Voltage"}] modbus.5 2025-03-06 17:27:48.083 debug Initialize Objects for inputRegs: [] modbus.5 2025-03-06 17:27:48.083 debug Initialize Objects for coils: [] modbus.5 2025-03-06 17:27:48.083 debug Initialize Objects for disInputs: [] modbus.5 2025-03-06 17:27:48.025 info starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.18.3, js-controller: 7.0.6 modbus.5 2025-03-06 17:27:47.911 debug Plugin sentry Initialize Plugin (enabled=true) modbus.5 2025-03-06 17:27:47.897 debug States connected to redis: 0.0.0.0:9000 modbus.5 2025-03-06 17:27:47.844 debug States create User PubSub Client modbus.5 2025-03-06 17:27:47.843 debug States create System PubSub Client modbus.5 2025-03-06 17:27:47.795 debug Redis States: Use Redis connection: 0.0.0.0:9000 modbus.5 2025-03-06 17:27:47.770 debug Objects connected to redis: 0.0.0.0:9001 modbus.5 2025-03-06 17:27:47.768 debug Objects client initialize lua scripts modbus.5 2025-03-06 17:27:47.736 debug Objects create User PubSub Client modbus.5 2025-03-06 17:27:47.736 debug Objects create System PubSub Client modbus.5 2025-03-06 17:27:47.736 debug Objects client ready ... initialize now modbus.5 2025-03-06 17:27:47.719 debug Redis Objects: Use Redis connection: 0.0.0.0:9001 modbus.5 2025-03-06 17:27:43.961 info terminating modbus.5 2025-03-06 17:27:43.476 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason modbus.5 2025-03-06 17:27:43.476 debug Plugin sentry destroyed modbus.5 2025-03-06 17:27:43.476 info terminating modbus.5 2025-03-06 17:27:43.460 debug Closing client on purpose. modbus.5 2025-03-06 17:27:43.459 info Got terminate signal TERMINATE_YOURSELF -
Port stell ich um und probiere nochmal aus.
Mehr gibts nicht einzustellen bei dem adapter
Das sieht für mich so aus als wenn die Antwort zu lang ist und der reservierte Buffer nicht reicht.
In deinem Link aus dem JSON steht für länge 0, hilft uns aber auch nicht weiter.
Software zum testen:
ModbusPoll
GmodbusMaster
RMMS (Radzio Modbus Master Simulator -
@wendy2702 sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
@Elektroniker86
auch wenn (oder gerade weil) du nur ein Register haben willst, stell mal in den Grundeinstellungen die Anzahl gepollte Register auf einen niedrigen Wert.@elektroniker86 sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
und Abfrage angehakt?
Ja, habe ich angehakt:
Probiere ich aus.
Habe ich auch getestet habe die Werte auf die Hälfte eingestellt.
modbus.5 2025-03-07 10:01:01.501 debug Closing client on purpose. modbus.5 2025-03-07 10:01:00.499 debug Cleaning up request fifo. modbus.5 2025-03-07 10:01:00.499 debug Clearing timeout of the current request. modbus.5 2025-03-07 10:01:00.499 debug Socket closed with error modbus.5 2025-03-07 10:01:00.491 info Disconnected from slave 192.168.1.146 modbus.5 2025-03-07 10:01:00.491 debug Closing client on purpose. modbus.5 2025-03-07 10:01:00.441 warn [DevID_1] Poll error count: 6 code: "App Timeout" modbus.5 2025-03-07 10:00:55.314 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:55.241 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:55.241 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:54.189 warn [DevID_1] Poll error count: 5 code: "App Timeout" modbus.5 2025-03-07 10:00:49.053 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:48.988 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:48.988 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:47.938 warn [DevID_1] Poll error count: 4 code: "App Timeout" modbus.5 2025-03-07 10:00:42.840 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:42.737 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:42.737 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:41.686 warn [DevID_1] Poll error count: 3 code: "App Timeout" modbus.5 2025-03-07 10:00:36.577 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:36.485 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:36.485 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:35.434 warn [DevID_1] Poll error count: 2 code: "App Timeout" modbus.5 2025-03-07 10:00:30.313 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:30.233 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:30.233 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:29.182 warn [DevID_1] Poll error count: 1 code: "App Timeout" modbus.5 2025-03-07 10:00:24.100 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:23.981 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:23.981 debug Initialization of scale factors done! modbus.5 2025-03-07 10:00:23.981 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:23.980 info Connected to slave 192.168.1.146 modbus.5 2025-03-07 10:00:23.886 debug Add holdingRegisters.4752_Total_Battery_Voltage: {"_id":"holdingRegisters.4752_Total_Battery_Voltage","type":"state","common":{"name":"bat vol","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"mV"},"native":{"regType":"holdingRegs","address":4752,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}} modbus.5 2025-03-07 10:00:23.885 debug Initialize Objects for holdingRegs: [{"_address":"4752","name":"Total Battery Voltage","description":"bat vol","unit":"mV","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":1,"address":4752,"id":"holdingRegisters.4752_Total_Battery_Voltage"}] modbus.5 2025-03-07 10:00:23.885 debug Initialize Objects for inputRegs: [] modbus.5 2025-03-07 10:00:23.885 debug Initialize Objects for coils: [] modbus.5 2025-03-07 10:00:23.885 debug Initialize Objects for disInputs: [] modbus.5 2025-03-07 10:00:23.828 info starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.18.3, js-controller: 7.0.6 modbus.5 2025-03-07 10:00:23.711 debug Plugin sentry Initialize Plugin (enabled=true) modbus.5 2025-03-07 10:00:19.818 info terminating modbus.5 2025-03-07 10:00:19.332 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason modbus.5 2025-03-07 10:00:19.332 debug Plugin sentry destroyed modbus.5 2025-03-07 10:00:19.332 info terminating modbus.5 2025-03-07 10:00:19.317 debug Closing client on purpose. modbus.5 2025-03-07 10:00:19.316 info Got terminate signal TERMINATE_YOURSELF modbus.5 2025-03-07 10:00:12.413 debug Closing client on purpose. modbus.5 2025-03-07 10:00:11.412 debug Cleaning up request fifo. modbus.5 2025-03-07 10:00:11.412 debug Clearing timeout of the current request. modbus.5 2025-03-07 10:00:11.412 debug Socket closed with error modbus.5 2025-03-07 10:00:11.404 info Disconnected from slave 192.168.1.146 modbus.5 2025-03-07 10:00:11.404 debug Closing client on purpose. modbus.5 2025-03-07 10:00:11.353 warn [DevID_1] Poll error count: 10 code: "App Timeout" modbus.5 2025-03-07 10:00:06.266 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:00:06.153 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:00:06.153 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:00:06.153 info Connected to slave 192.168.1.146 modbus.5 2025-03-07 09:59:07.158 debug Closing client on purpose. modbus.5 2025-03-07 09:59:06.158 debug Cleaning up request fifo. modbus.5 2025-03-07 09:59:06.158 debug Clearing timeout of the current request. modbus.5 2025-03-07 09:59:06.158 debug Socket closed with error modbus.5 2025-03-07 09:59:06.151 info Disconnected from slave 192.168.1.146 modbus.5 2025-03-07 09:59:06.151 debug Closing client on purpose. modbus.5 2025-03-07 09:59:06.100 warn [DevID_1] Poll error count: 9 code: "App Timeout" modbus.5 2025-03-07 09:59:00.997 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 09:59:00.901 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 09:59:00.900 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 09:59:00.900 info Connected to slave 192.168.1.146 -
bitte auf 1 oder 2 stellen
es gibt Geräte die sich sonst aufhängen.Muss nicht die Ursache sein, würde ich gerne ausschließen
wo steht der Parameter denn?
Hier
steht 0, nicht 4 -
modbus.5 2025-03-07 10:16:18.537 debug Closing client on purpose. modbus.5 2025-03-07 10:16:17.536 debug Cleaning up request fifo. modbus.5 2025-03-07 10:16:17.536 debug Clearing timeout of the current request. modbus.5 2025-03-07 10:16:17.536 debug Socket closed with error modbus.5 2025-03-07 10:16:17.531 info Disconnected from slave 192.168.1.146 modbus.5 2025-03-07 10:16:17.531 debug Closing client on purpose. modbus.5 2025-03-07 10:16:17.480 warn [DevID_1] Poll error count: 6 code: "App Timeout" modbus.5 2025-03-07 10:16:12.369 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:16:12.279 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:16:12.279 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:16:11.228 warn [DevID_1] Poll error count: 5 code: "App Timeout" modbus.5 2025-03-07 10:16:06.105 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:16:06.027 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:16:06.027 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:16:04.975 warn [DevID_1] Poll error count: 4 code: "App Timeout" modbus.5 2025-03-07 10:15:59.843 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:15:59.775 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:15:59.775 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:15:58.724 warn [DevID_1] Poll error count: 3 code: "App Timeout" modbus.5 2025-03-07 10:15:53.629 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:15:53.523 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:15:53.523 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:15:52.471 warn [DevID_1] Poll error count: 2 code: "App Timeout" modbus.5 2025-03-07 10:15:47.365 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:15:47.270 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:15:47.270 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:15:46.219 warn [DevID_1] Poll error count: 1 code: "App Timeout" modbus.5 2025-03-07 10:15:41.103 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4 modbus.5 2025-03-07 10:15:41.019 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:15:41.019 debug Initialization of scale factors done! modbus.5 2025-03-07 10:15:41.018 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:15:41.018 info Connected to slave 192.168.1.146 modbus.5 2025-03-07 10:15:40.927 debug Add holdingRegisters.4752_Total_Battery_Voltage: {"_id":"holdingRegisters.4752_Total_Battery_Voltage","type":"state","common":{"name":"bat vol","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"mV"},"native":{"regType":"holdingRegs","address":4752,"deviceId":1,"type":"uint32be","len":2,"offset":4,"factor":1,"poll":true}} modbus.5 2025-03-07 10:15:40.927 debug Initialize Objects for holdingRegs: [{"_address":"4752","name":"Total Battery Voltage","description":"bat vol","unit":"mV","type":"uint32be","len":2,"factor":1,"offset":4,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":1,"address":4752,"id":"holdingRegisters.4752_Total_Battery_Voltage"}] modbus.5 2025-03-07 10:15:40.927 debug Initialize Objects for inputRegs: [] modbus.5 2025-03-07 10:15:40.927 debug Initialize Objects for coils: [] modbus.5 2025-03-07 10:15:40.927 debug Initialize Objects for disInputs: [] modbus.5 2025-03-07 10:15:40.874 info starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.18.3, js-controller: 7.0.6 modbus.5 2025-03-07 10:15:40.764 debug Plugin sentry Initialize Plugin (enabled=true) modbus.5 2025-03-07 10:15:36.922 info terminating modbus.5 2025-03-07 10:15:36.437 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason modbus.5 2025-03-07 10:15:36.437 debug Plugin sentry destroyed modbus.5 2025-03-07 10:15:36.437 info terminating modbus.5 2025-03-07 10:15:36.422 debug Closing client on purpose. modbus.5 2025-03-07 10:15:36.422 info Got terminate signal TERMINATE_YOURSELFSehr komisch alles, habe mit Modbus noch nie Probleme gehabt. Habe alle SMA Wechselrichter drin plus Energiezähler von EASTRoN und Heidelberg Ladestation die funktionieren super.
Ich habe zum Test jetzt auch mal noch ein ELFIN RS485 Adapter probiert aber auch hier das selbe
2025-03-07 10:15:40.927 debug Initialize Objects for holdingRegs: [{"_address":"4752","name":"Total Battery Voltage","description":"bat vol","unit":"mV","type":"uint32be","len":2,"factor":1,"offset":4,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":1,"address":4752,"id":"holdingRegisters.4752_Total_Battery_Voltage"}]wo kommt der offset 4 her?
edit!
hast du den in der Zwischenzeit eingestellt?
Warum?Das ist im Moment der einzige Fehler
Hier
steht 0, nicht 4
Ich habe es so verstanden das ich den so einstellen soll
Sorry -
nein!
Ich habe den ZLAN wieder angeschlossen und offset auf 0
modbus.5 2025-03-07 10:47:53.458 info Disconnected from slave 192.168.1.123 modbus.5 2025-03-07 10:47:53.458 debug Closing client on purpose. modbus.5 2025-03-07 10:47:52.457 debug Cleaning up request fifo. modbus.5 2025-03-07 10:47:52.457 debug Clearing timeout of the current request. modbus.5 2025-03-07 10:47:52.457 debug Socket closed with error modbus.5 2025-03-07 10:47:52.457 warn [DevID_1] Poll error count: 7 code: {"err":"timeout","timeout":5000} modbus.5 2025-03-07 10:47:52.456 error Client in error state. modbus.5 2025-03-07 10:47:52.456 error Request timed out. modbus.5 2025-03-07 10:47:52.456 warn Error: undefined modbus.5 2025-03-07 10:47:47.456 debug [DevID_1/holdingRegs] Poll address 4752 - 2 registers modbus.5 2025-03-07 10:47:47.456 debug [DevID_1] Poll start --------------------- modbus.5 2025-03-07 10:47:47.456 info Connected to slave 192.168.1.123 -
2025-03-07 10:47:52.456 warn Error: undefinedmacht keinen Spaß
den ZLAN
ist was?
gibt es da was einzustellen, was nicht zu den Adapter Einstellungen oder WR Einstellungen passt? -
Den habe ich mal runtergeladen, aber da passiert überhaupt nichts habe die verbindung über den usb und den tcp Adapter probiert unten bei TX RX passiert nichts.
Mit dem Programm vom JK BMS klappt die Verbindung mit dem usb Adapter einwandfrei.
mit dem usb Adapter
den sollte man immer nehmen, wenn möglich.
Einen TCP2RS485 Konverter zwischenzuschalten bringt immer weitere Fehlermöglichkeiten mit sich
