    4. Tester für Zigbee Adapter 2.0.x gesucht
      Shadowhunter23 @Asgothian last edited by
      @asgothian
      Kann man zu dieser Meldung was sagen? War auch schon in der 2.0.2 so.
      zigbee.3
      2025-03-07 15:30:07.937	error	Failed to open the network: Error: --> 'SREQ: AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,2,2,10,0,0]}}' failed with status '(0x11: BUFFER_FULL)' (expected '(0x00: SUCCESS)') at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:258:27 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1100:9) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:746:13 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.sendZclFrameToAll (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:744:16) at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:277:13) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:317:13) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:668:13)
      Asgothian S 2 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @Shadowhunter23 last edited by
        @shadowhunter23 Dein Koordinator bekommt das Netzwerk nicht auf. Er hat keinen Platz im internen Puffer um die entsprechenden Daten abzulegen. Dieses kommt üblicherweise durch ein instabiles Zigbee-Netzwerk zu Stande (bzw. oft in Kombination mit einem schwachen Koordinator auf CC2531 oder cc2538 basis.
        Du kannst es temporär dadurch beheben das du den Koordinator redetest:
        • Adapter anhalten
        • Koordinator abziehen (oder vom Strom trennen bei Netzwerk Koordinatoren
        • 60 sekunden warten (Wichtig)
        • Koordinator anstecken
        • 30 Sekunden warten
        • Adapter starten.
        A.
        S ? 2 Replies Last reply Reply Quote 0
          Shadowhunter23 @Asgothian last edited by Shadowhunter23
          @asgothian
          Ist dieser hier:
          https://github.com/codm/cc2652p2-tcp-zigbee
          Erster Versuch war erfolglos...
          Edit
          Firmware flash hat geholfen.
            A Former User @Asgothian last edited by
            @asgothian
            update auf 2.0.3:
            meine Rauchmelder werden alle der Reihe nach mit
            zigbee.0
            2025-03-07 16:32:16.259	warn	DeviceConfigure:0x0015bc003100960d SMSZB-120 Failed to configure. --> Bind 0x0015bc003100960d/35 ssIasZone from '0x00124b00219fc127/1' failed (Status 'TABLE_FULL')
            anscheinend nicht mehr configured?
            Muss ich die nochmal neu anlernen, der Fehler war vorher mit 2.0.1 und 2.0.2 nicht im Log. ( hab se zwar manuell mal ausgeloest, um zu wissen, dass sie gehen.. aber wenn nix im Log steht, denkt man ja, alles is ok.. )
            • Asgothian
              Asgothian Developer @Guest last edited by
              @neuschwansteini Du musst wahrscheinlich deinen Koordinator Rosetten. Siehe hier: https://forum.iobroker.net/topic/80035/tester-für-zigbee-adapter-2-0-x-gesucht/93?_=1741340148101
              Dann sollten die sich konfigurieren lassen.
              A.
                @asgothian
                Den link von dir kann ich zwar aufrufen, führt aber zu meinem eigenen Beitrag..
                Ich hab den Adapter gestoppt, gewartet, den Koordinator vom Strom und Netzwerk genommen für 3 Minuten, dann wieder angeschlossen, gewartet bis er wieder verbunden war und dann den Adapter wieder gestartet.
                Leider das gleiche Schauspiel, endlosschleife beim config der Rauchmelder… das hört nicht auf …
                • Asgothian
                  @neuschwansteini Das ist seltsam - die Änderung zwischen 2.0.2 und 2.0.3 kann ich erklären - es wird geprüft ob ein Gerät bereits konfiguriert wurde, und ggf. wird eine erneute Konfiguration angestossen. Was sich mir nicht erschliessen will ist warum die Konfiguration nicht durch geht. Kannst du versuchen einen der Rauchmelder aus dem Netz zu nehmen und neu zu pairen - damit wir sehen können ob die Meldung vom Gerät oder Konfigurator kommt ?
                  A.
                    @asgothian
                    Sehe gerade, die Flora kann er auch nicht… da kommt nicht mal ein Error..
                    Heute kann ich da nicht mehr testen .. Morgen Nachmittag erst wieder..
                    Hier mal noch der Auszug vom log, bin leider nur noch mit dem iPad connected..
                    zigbee.0
                    2025-03-07 17:44:12.717	info	Configuring 0x00124b0022ff500c DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:12.626	info	Configuring 0x0015bc0031009604 SMSZB-120
                    zigbee.0
                    2025-03-07 17:44:12.547	info	Configuring 0x0015bc0031009604 SMSZB-120
                    zigbee.0
                    2025-03-07 17:44:12.030	info	Configuring 0x00124b002257644d DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:11.432	info	Configuring 0x00124b0022ff500c DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:11.249	warn	DeviceConfigure:0x0015bc0031009956 SMSZB-120 Failed to configure. --> Bind 0x0015bc0031009956/35 genBinaryInput from '0x00124b00219fc127/1' failed (Status 'TABLE_FULL')
                    zigbee.0
                    2025-03-07 17:44:11.166	info	Configuring 0x00124b00226080a8 DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:10.497	warn	DeviceConfigure:0x0015bc0031009956 SMSZB-120 Failed to configure. --> Bind 0x0015bc0031009956/35 genBinaryInput from '0x00124b00219fc127/1' failed (Status 'TABLE_FULL')
                    zigbee.0
                    2025-03-07 17:44:09.703	info	Configuring 0x00124b002257644d DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:08.482	info	Configuring 0x00124b00226080a8 DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:07.831	info	Configuring 0x0015bc00310097b8 SMSZB-120
                    zigbee.0
                    2025-03-07 17:44:07.749	info	Configuring 0x00124b0022ff500c DIYRuZ_Flower
                    zigbee.0
                    2025-03-07 17:44:07.224	info	Configuring 0x00124b00226080a8 DIYRuZ_Flower
                    • Asgothian
                      @neuschwansteini das sieht eher danach aus das die Flower erfolgreich konfiguriert werden. Es kommt keine Fehlermeldung, und die gepusteten Meldungen kommen von unterschiedlichen Geräten.
                      A.
                        @asgothian
                        ja, aber bei den Flower hab ich nur 5 Stk., dann sollte die Meldung doch 5x kommen, ist konfiguriert und dann nicht mehr?
                        Er versucht das aber immer wieder, genau wie bei den Rauchmeldern, nur die geben dann einen Error wieder.
                        Musste gestern abend wieder zurueck auf die 2.0.2, da die 2.0.3 anscheinend durch die Fehler eine Verzoegerung von 1-2sek bei den Scripten verursacht hat..
                        Melde mich, wenn ich wieder getestet habe.
                        • David G.
                          Bei mir vermutlich nichts auffälliges.
                          Beim ersten Start der 2.0.3 wurden einige Geräte laut log sehr oft hintereinander konfiguriert.
                          Beim Neustart des Adapters war es ruiher.
                          Allerdings mehr Meldungen als Geräte nicht verfügbar.
                          zigbee.0
                          2025-03-08 10:51:49.392	warn	DeviceConfigure:Timeout trying to configure 0xa4c138ebcf547772 TS0207: 10 attempts remaining
                          zigbee.0
                          2025-03-08 10:51:39.364	info	Configuring 0xa4c138ebcf547772 TS0207
                          zigbee.0
                          2025-03-08 10:51:39.363	warn	DeviceConfigure:Timeout trying to configure 0xa4c138932f7d376a TS0044: 10 attempts remaining
                          zigbee.0
                          2025-03-08 10:51:16.266	info	Configuring 0xa4c138932f7d376a TS0044
                          zigbee.0
                          2025-03-08 10:51:16.264	warn	DeviceConfigure:0xa4c1385864ba12d4 TS011F Failed to configure. --> ZCL command 0xa4c1385864ba12d4/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                          zigbee.0
                          2025-03-08 10:50:51.913	info	Configuring 0xa4c1385864ba12d4 TS011F
                          zigbee.0
                          2025-03-08 10:50:51.910	warn	DeviceConfigure:Timeout trying to configure 0xa4c13876d17ec059 TS0202: 10 attempts remaining
                          zigbee.0
                          2025-03-08 10:50:41.894	info	Configuring 0xa4c13876d17ec059 TS0202
                          zigbee.0
                          2025-03-08 10:50:41.894	warn	DeviceConfigure:Timeout trying to configure 0x804b50fffefb471f TRADFRI on/off switch: 10 attempts remaining
                          zigbee.0
                          2025-03-08 10:50:31.867	info	Configuring 0x804b50fffefb471f TRADFRI on/off switch
                          zigbee.0
                          2025-03-08 10:50:31.867	warn	DeviceConfigure:Timeout trying to configure 0xa4c138757132f69d TS0207: 10 attempts remaining
                          zigbee.0
                          2025-03-08 10:50:31.717	info	Failed to ping 0xf0d1b800001c4c80 Plug Value
                          zigbee.0
                          2025-03-08 10:50:21.714	info	Configuring 0xa4c138757132f69d TS0207
                          zigbee.0
                          2025-03-08 10:50:21.714	warn	DeviceConfigure:Timeout trying to configure 0xf0d1b800001c4c80 Plug Value: 10 attempts remaining
                          zigbee.0
                          2025-03-08 10:50:18.603	info	Failed to ping 0xa4c1385864ba12d4 TS011F
                          zigbee.0
                          2025-03-08 10:50:11.683	info	debug devices set to []
                          zigbee.0
                          2025-03-08 10:50:11.659	info	Configuring 0xf0d1b800001c4c80 Plug Value
                          zigbee.0
                          2025-03-08 10:50:11.656	info	Zigbee started
                            MeisterQ 0 last edited by Homoran
                            Hab bei mir die 2.0.3 drauf gemacht. Seit dem dreht der eine Lichtsensor durch. Einen Neustart habe ich auch schon gemacht. @Asgothian
                            zigbee.0
                            	2025-03-08 15:56:03.095	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:55:56.818	warn	DeviceConfigure:Timeout trying to configure 0x04cf8cdf3c775721 lumi.sen_ill.mgl01: 4 attempts remaining
                            zigbee.0
                            	2025-03-08 15:55:53.126	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:55:46.800	warn	DeviceConfigure:Timeout trying to configure 0x04cf8cdf3c775721 lumi.sen_ill.mgl01: 6 attempts remaining
                            zigbee.0
                            	2025-03-08 15:55:43.147	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:55:36.781	warn	DeviceConfigure:Timeout trying to configure 0x04cf8cdf3c775721 lumi.sen_ill.mgl01: 8 attempts remaining
                            zigbee.0
                            	2025-03-08 15:55:28.159	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:55:26.762	warn	DeviceConfigure:Timeout trying to configure 0x04cf8cdf3c775721 lumi.sen_ill.mgl01: 10 attempts remaining
                            zigbee.0
                            	2025-03-08 15:55:23.164	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:55:16.743	warn	DeviceConfigure:Timeout trying to configure 0x04cf8cdf3c775721 lumi.sen_ill.mgl01: 2 attempts remaining
                            zigbee.0
                            	2025-03-08 15:55:13.215	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:55:03.258	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                            zigbee.0
                            	2025-03-08 15:54:53.322	info	Configuring 0x04cf8cdf3c775721 lumi.sen_ill.mgl01
                              bin jetzt aus anderen Gründen auch auf 2.0.3
                              https://forum.iobroker.net/post/1256177
                              Meine Instanz hängt seitdem schon das zweite Mal
                              im log sehe ich nichts
                              • Asgothian
                                Asgothian Developer @Homoran last edited by
                                @homoran @MeisterQ-0 @David-G @Neuschwansteini
                                Bitte zurück auf die 2.0.2 gehen - anscheinend geht irgend ein Thread in der 2.0.3 durch - der Adapter zieht maximal Prozessorleistung.
                                Das ist bei meinen Tests nicht aufgefallen.
                                A.
                                Homoran M 2 Replies Last reply Reply Quote 1
                                  Homoran Global Moderator Administrators @Asgothian last edited by Homoran
                                  @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                  hmmm, ich teste gerade für/mit @arteck was an einem branch (nehm ich an)
                                  das seh ich im Moment nach Neustart der Instanz nicht.
                                    MeisterQ 0 @Asgothian last edited by
                                    @asgothian Bei mir ist nichts zu sehen. Iobroker 36% CPU und der NUC allegemein bei kleiner 30% CPU last.
                                    • Asgothian
                                      @homoran Das passiert über die Zeit, und ist Ursache dafür das der Adapter als 'nicht verbunden mit Host' angezeigt wird.
                                      Das muss nicht bei jedem Start und direkt passieren.
                                      A.
                                        @asgothian
                                        Ich hatte nicht genau nachgeschaut und etwas anderes in Verdacht...
                                        Bin nun auch wieder zurück auf 2.0.2
                                        • Asgothian
                                          @shadowhunter23 @Neuschwansteini
                                          Wärt Ihr (oder einer von euch) bereit eine Testversion laufen zu lassen die diesen Bug nicht mehr haben sollte ? Wenn ja kann ich einen Link bereit stellen - die Instanz läuft erst einmal bei Mir im Testlauf. Wenn sie die 2 Stunden übersteht dann leg ich den Link hier her.
                                          A
                                          S ? David G. 3 Replies Last reply Reply Quote 1
                                            @asgothian
                                            Ja mach ich gerne.
                                            zigbee 2.0.1
                                            50
                                            525
                                            76172
