    3. Entwicklung
    4. Adapter debugging mit VSCode remote ssh
    • Asgothian
      Asgothian Developer @ticaki last edited by
      Hmm.. ich hab auf dem PI wo mein Produktiv System läuft (zum testen) mal den dev-server als dev-dependency installiert, so wie das auf Github beschrieben ist.
      Die Ausgaben sind aber ähnlich
      │   dev-server was sucessfully set up in                              │
      │   /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default.   │
      │   You may now execute one of the following commands                 │
      │   dev-server run default                                            │
      │   dev-server watch default                                          │
      │   dev-server debug default                                          │
      │   to use dev-server.                                                │
      stormy@stormbroker:/opt/iobroker/node_modules/iobroker.zigbee $ dev-server
      bash: dev-server: command not found
      stormy@stormbroker:/opt/iobroker/node_modules/iobroker.zigbee $ npm run dev-server watch default
      > iobroker.zigbee@2.0.3 dev-server
      Using profile name "default"
      Using adapter name "zigbee"
      Install local iobroker.zigbee
      /opt/iobroker/node_modules/iobroker.zigbee> npm pack
      Packed to iobroker.zigbee-2.0.3.tgz
      /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default> npm install "/opt/iobroker/node_modules/iobroker.zigbee/iobroker.zigbee-2.0.3.tgz"
      up to date, audited 475 packages in 2s
      65 packages are looking for funding
        run `npm fund` for details
      20 vulnerabilities (16 moderate, 4 high)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues (including breaking changes), run:
        npm audit fix --force
      Run `npm audit` for details.
      /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default> node --inspect=127.0.0.1:9228 --preserve-symlinks --preserve-symlinks-main node_modules/iobroker.js-controller/controller.js
      Waiting for js-controller to start...
      Waiting for port 26426 to be available...
      Debugger listening on ws://127.0.0.1:9228/8d9ad1ff-b7b6-42d7-a5ca-e48002dafd53
      For help, see: https://nodejs.org/en/docs/inspector
      2025-03-08 21:47:13.303  - info: host.dev-zigbee-stormbroker iobroker.js-controller version 7.0.6 js-controller starting
      2025-03-08 21:47:13.306  - info: host.dev-zigbee-stormbroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-03-08 21:47:13.307  - info: host.dev-zigbee-stormbroker hostname: dev-zigbee-stormbroker, node: v20.18.2
      2025-03-08 21:47:13.308  - info: host.dev-zigbee-stormbroker ip addresses: 192.168.2.222 192.168.2.43 fda3:8957:951:5a48:55fd:7999:b19e:8ea fe80::a937:f532:3c5b:b02
      2025-03-08 21:47:13.312  - debug: host.dev-zigbee-stormbroker-Server Data File: /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/objects.jsonl
      2025-03-08 21:47:13.331  - debug: host.dev-zigbee-stormbroker-Server  Redis inMem-objects listening on port 9001
      2025-03-08 21:47:13.332  - debug: host.dev-zigbee-stormbroker Redis Objects: Use Redis connection: 127.0.0.1:26426
      2025-03-08 21:47:13.343  - debug: host.dev-zigbee-stormbroker Objects client ready ... initialize now
      2025-03-08 21:47:13.386  - debug: host.dev-zigbee-stormbroker Objects create System PubSub Client
      2025-03-08 21:47:13.397  - debug: host.dev-zigbee-stormbroker Objects client initialize lua scripts
      2025-03-08 21:47:13.404  - debug: host.dev-zigbee-stormbroker Objects connected to redis: 127.0.0.1:26426
      2025-03-08 21:47:13.456  - debug: host.dev-zigbee-stormbroker-Server Data File: /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/states.jsonl
      2025-03-08 21:47:13.459  - debug: host.dev-zigbee-stormbroker-Server  Redis inMem-states listening on port 9000
      2025-03-08 21:47:13.460  - debug: host.dev-zigbee-stormbroker Redis States: Use Redis connection: 127.0.0.1:24426
      2025-03-08 21:47:13.506  - debug: host.dev-zigbee-stormbroker States create System PubSub Client
      2025-03-08 21:47:13.551  - debug: host.dev-zigbee-stormbroker States connected to redis: 127.0.0.1:24426
      2025-03-08 21:47:13.563  - info: host.dev-zigbee-stormbroker connected to Objects and States
      2025-03-08 21:47:13.564  - debug: host.dev-zigbee-stormbroker Could not read notifications.json: /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/notifications.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/notifications.json'
      2025-03-08 21:47:13.579  - info: host.dev-zigbee-stormbroker Node.js version has changed from unknown to 20.18.2
      2025-03-08 21:47:13.591  - info: host.dev-zigbee-stormbroker added notifications configuration of host
      2025-03-08 21:47:13.592  - info: host.dev-zigbee-stormbroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2025-03-08 21:47:13.648  - debug: host.dev-zigbee-stormbroker Plugin sentry Do not initialize Plugin (enabled=false)
      2025-03-08 21:47:13.700  - info: host.dev-zigbee-stormbroker 3 instances found
      2025-03-08 21:47:13.700  - debug: host.dev-zigbee-stormbroker check instance "system.adapter.admin.0" for host "dev-zigbee-stormbroker"
      2025-03-08 21:47:13.702  - debug: host.dev-zigbee-stormbroker check instance "system.adapter.backitup.0" for host "dev-zigbee-stormbroker"
      2025-03-08 21:47:13.703  - debug: host.dev-zigbee-stormbroker check instance "system.adapter.zigbee.0" for host "dev-zigbee-stormbroker"
      2025-03-08 21:47:13.703  - info: host.dev-zigbee-stormbroker starting 2 instances
      Port 26426 is available...
      Waiting for port 24426 to be available...
      Port 24426 is available...
      Running inside /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default
      Waiting for port 20426 to be available...
      2025-03-08 21:47:13.768  - debug: host.dev-zigbee-stormbroker added notifications configuration of system.adapter.admin.0
      2025-03-08 21:47:13.768  - debug: host.dev-zigbee-stormbroker startInstance admin.0 loglevel=info, compact=false
      2025-03-08 21:47:13.773  - info: host.dev-zigbee-stormbroker instance system.adapter.admin.0 in version "7.6.1" started with pid 2430157
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      2025-03-08 21:47:14.761  - debug: host.dev-zigbee-stormbroker Incoming Host message getRepository
      2025-03-08 21:47:14.764  - info: host.dev-zigbee-stormbroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2025-03-08 21:47:14.861  - debug: host.dev-zigbee-stormbroker Incoming Host message getHostInfo
      2025-03-08 21:47:14.985  - debug: host.dev-zigbee-stormbroker Incoming Host message getHostInfo
      2025-03-08 21:47:15.017  - debug: host.dev-zigbee-stormbroker Incoming Host message getRepository
      2025-03-08 21:47:15.017  - debug: host.dev-zigbee-stormbroker Repository update already running, registered instance "system.adapter.admin.0"
      Port 20426 is available...
      Starting React build
      Waiting for first successful React build...
      /opt/iobroker/node_modules/iobroker.zigbee> npm run watch:parcel
      > iobroker.zigbee@2.0.3 watch:parcel
      > parcel admin/src/index.tsx -d admin/build --hmr-port 1235
      sh: 1: parcel: not found
      dev-server watch [profile]
      Run ioBroker dev-server and start the adapter in "watch" mode. The adapter will automatically
      restart when its source code changes. You may attach a debugger to the running adapter.
      Options:
            --version     Show version number                                                    [boolean]
        -t, --temp        Temporary directory where the dev-server data will be located
        [string] [default: ".dev-server"]
            --help        Show help                                                              [boolean]
        -n, --noStart     Do not start the adapter itself, only watch for changes and sync them. [boolean]
        -x, --noInstall   Do not build and install the adapter before starting.                  [boolean]
        -w, --doNotWatch  Do not watch the given files or directories for changes (provide paths relative
                          to the adapter base directory.                                          [string]
      Error: Exited with 127
          at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/dev-server/dist/index.js:1495:44)
          at ChildProcess.emit (node:events:530:35)
          at ChildProcess._handle.onexit (node:internal/child_process:293:12)
      • mcm1957
        mcm1957 @Asgothian last edited by
        @asgothian said in Adapter debugging mit VSCode remote ssh:
        @mcm1957 sagte in Adapter debugging mit VSCode remote ssh:
        Also wenn du den Adapetr direkt am MAC starten kannst, dann versuch doch noch mal den dev-server und lass uns wissen welche Fehlermeldungen du bekommst...
        bin gerade dabei - nebenbei - discord ist der allgemeine iobroker discord ? da bin ich auch drauf. Telegram hab ich leider keins.
        Wenn ja können wir die Diskussion nach da verlegen 🙂
        Hmm - ich benutze nur Telegramm. Keine Ahnung was der ganz normale Telegramm Discord ist 🙂 Ich weiß nur dass Telegramm und Discor gegenseitig via Bot synchronisiert werden 🙂
        Genrell sind in Telegramm / Discord mehr Entwickler - insbesondere auch core - unterwegs.
        • mcm1957
          mcm1957 @mcm1957 last edited by mcm1957
          @mcm1957
          Uff - du hast da ja noch Schikanen drinnen 🙂
          Ich glaub mit React verträgt dich der dev-sever nicht. Aber zum ganzen Komplex react build kann fast nur Bluefox was sagen.
          Was ich raten würde (zumidnest mal zum testen)
          -) Adapter bauen (npm run build)
          -) dev-server run
          Damit sollte mal der dev-sver laufen und admin auf Port 80xx erreichbar sein.
          -) Adaptercode in vsCode starten:
          Adapterverzeichnis in vsCode öffnen
          Launch "Launch normal" verwenden.
          Launch.json sieht bei mir so aus:
              // Verwendet IntelliSense zum Ermitteln möglicher Attribute.
              // Zeigen Sie auf vorhandene Attribute, um die zugehörigen Beschreibungen anzuzeigen.
              // Weitere Informationen finden Sie unter https://go.microsoft.com/fwlink/?linkid=830387
              "version": "0.2.0",
              "configurations": [
                      "name": "Launch normal",
                      "program": "${workspaceFolder}/build/main.js",
                      "args": ["--instance", "0", "--force", "--logs", "--debug"],
                      "request": "launch",
                      "stopOnEntry": true,
                      "console": "internalConsole",
                      "outputCapture": "std",
                      "skipFiles": [
                          "<node_internals>/**"
                      "type": "node"
                      "name": "Attach by Process ID",
                      "processId": "${command:PickProcess}",
                      "request": "attach",
                      "skipFiles": [
                      "type": "node"
          Program Zeile je nach TS / JS und ggF main,js Namen halt anpassen
          • mcm1957
            Damit wird mal der Bauvorgang rausgehalten und React sollte da mal in Bezug auf Bau keine Probleme bereiten. (Ob npm run build geht ist dann eine Sache unabhängig vom dev-server)
            • mcm1957
              @mcm1957
              Aber wie schon ticaki geschrieben hat, @Apollon77 entwickelt m.W. nach auch auf einem mac. Und Matter hat da sicher alle möglichen Spezialitäten zu bieten. :-).
              Du erreichst ihn auch am besten auf Telegramm / Discord (auchunter @Apollon77)
              • Asgothian
                Asgothian Developer @mcm1957 last edited by
                @mcm1957 Ich hab da mal ein Hallo auf dem Discord rein geschrieben. Kannst du schauen ob das die richtige Stelle ist ?
                T mcm1957 2 Replies Last reply Reply Quote 0
                  ticaki @Asgothian last edited by
                  @asgothian
                  Ja ist der richtige
                  • mcm1957
                    @asgothian
                    Wenn du dort pk.nalon bist dann ists angekommen 🙂
                    • OliverIO
                      OliverIO @Asgothian last edited by
                      @asgothian
                      Rufe ich glaube ich habe es auf Discord schon geschrieben.
                      Das Parcel Zeug muss weg, das sind wahrscheinlich Reste vom dev containe
                      Wenn du für den Adapter keinen Build aus, dann entferne diese Seite aus dem Package.json
                      Läuft den der Adapter generell auf Mac?
                      wenn nicht, wird es auf Mac natürlich schwierig, wenn er nicht an die Hardware rankommt
                      • Asgothian
                        Asgothian Developer @OliverIO last edited by
                        Allen erst einmal Vielen Dank für die Hilfe. Wir haben die Diskussion auf Discord verlegt. Ist wenn ich das recht verstanden habe einfacher.
                        A.
                        1.0k
                        1920
