    3. Off Topic
    4. Proxmox
    5. Problem mit unzureichendem Speicherplatz
      Homoran Global Moderator Administrators @bastler last edited by
      @bastler sagte in Problem mit unzureichendem Speicherplatz:
      Wie könnte ich es überprüfen?
      z.B. mit dem vollständigen Output von iob diag
        /dev/sda1 ext4 31G 29G 470M 99% /
        viel ist da nicht mehr
          bastler @Homoran last edited by
          @homoran so jetzt noch einmal alles
          Script v.2025-02-23
          *** BASE SYSTEM ***
           Static hostname: ioBroker
                 Icon name: computer-vm
                   Chassis: vm 🖴
            Virtualization: kvm
                    Kernel: Linux 6.1.0-31-amd64
              Architecture: x86-64
           Hardware Vendor: QEMU
            Hardware Model: Standard PC _i440FX + PIIX, 1996_
          Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
          OS is similar to:
          model name	: Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           11:12:49 up  1:57,  2 users,  load average: 0.13, 0.19, 0.18
          CPU threads: 16
          *** LIFE CYCLE STATUS ***
          Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
          *** TIME AND TIMEZONES ***
                         Local time: Mon 2025-03-10 11:12:49 CET
                     Universal time: Mon 2025-03-10 10:12:49 UTC
                           RTC time: Mon 2025-03-10 10:12:49
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          ingo
          HOME=/home/ingo
          GROUPS=ingo adm cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal: 	tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:             11G        3.7G        7.4G        585K        982M        8.1G
          Swap:           1.0G          0B        1.0G
          Total:           12G        3.7G        8.4G
          Active iob-Instances: 	45
                  11265 M total memory
                   3557 M used memory
                    422 M active memory
                   3459 M inactive memory
                   7048 M free memory
                    125 M buffer memory
                    811 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          top - 11:12:49 up  1:57,  2 users,  load average: 0.13, 0.19, 0.18
          Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  11265.7 total,   7048.9 free,   3557.6 used,    936.9 buff/cache
          MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7708.1 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  5.5G     0  5.5G   0% /dev
          tmpfs          tmpfs     1.2G  576K  1.1G   1% /run
          tmpfs          tmpfs     5.6G     0  5.6G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
          [Mon Mar 10 09:15:15 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Mar 10 09:15:16 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          1.6G	/var/
          975M	/var/log
          890M	/var/log/journal/00d6058392fa44d3b60e2dcfbf39a290
          427M	/var/cache
          Archived and active journals take up 889.8M in the file system.
          /opt/iobroker/backups:
          13G	/opt/iobroker/backups/
          516K	/opt/iobroker/backups/grafana_tmp
          264K	/opt/iobroker/backups/grafana_tmp/dashboards
          240K	/opt/iobroker/backups/grafana_tmp/dashboards_manually_restore
          8.0K	/opt/iobroker/backups/grafana_tmp/datasource
          /opt/iobroker/iobroker-data:
          1.9G	/opt/iobroker/iobroker-data/
          1.3G	/opt/iobroker/iobroker-data/files
          617M	/opt/iobroker/iobroker-data/files/javascript.admin
          560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
          52M	/opt/iobroker/iobroker-data/objects.jsonl
          38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191141-if00
          *** ZigBee Settings ***
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v20.18.3
          /usr/bin/node 		v20.18.3
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          /usr/bin/corepack 	0.30.0
          nodejs:
            Installed: 20.18.3-1nodesource1
            Candidate: 20.18.3-1nodesource1
            Version table:
           *** 20.18.3-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 7038)
          Core adapters versions
          js-controller: 	7.0.6
          admin: 		7.4.10
          javascript: 	8.8.3
          nodejs modules from github: 	2
          +-- iobroker.deyeidc@0.2.0 (git+ssh://git@github.com/raschy/ioBroker.deyeidc.git#0504bb34191750e47bfb509c3c9fb08aef980eb2)
          +-- iobroker.zigbee@2.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#0a1913bc5e2c61db265a338e6474ed367959dc49)
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
            system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
          + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
          + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.esphome.0                : esphome               : ioBroker                                 -  enabled
            system.adapter.espresense.0             : espresense            : ioBroker                                 - disabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
            system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.nut.0                    : nut                   : ioBroker                                 - disabled
          + system.adapter.opendtu.0                : opendtu               : ioBroker                                 -  enabled
          + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
            system.adapter.philips-air.0            : philips-air           : ioBroker                                 - disabled
            system.adapter.powerfox2.0              : powerfox2             : ioBroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
          + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
          + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
          + system.adapter.reolink.2                : reolink               : ioBroker                                 -  enabled
          + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
          + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
          + system.adapter.tahoma.0                 : tahoma                : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
          + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
            system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191141-if00
          + instance is alive
          ioBroker-Repositories
          │ (index) │ name               │ url                                                     │ auto upgrade │
          │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
          │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
          Active repo(s): Stable (default)
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: Stable (default)
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
          Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
          Adapter    "espresense"   : 0.4.8    , installed 0.4.8
          Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
          Adapter    "parser"       : 2.2.4    , installed 2.2.4
          Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
          Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "reolink"      : 1.2.1    , installed 1.2.1
          Adapter    "sayit"        : 5.0.0    , installed 5.0.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
          Adapter    "telegram"     : 4.0.0    , installed 4.0.0
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "welcome"      : 1.0.2    , installed 1.0.2
          Adapter    "wireless-settings": 1.0.2, installed 1.0.2
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.14  , installed 2.0.3
          Objects and States
          Objects: 	18065
          States: 	15235
          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://repos.influxdata.com/debian bookworm InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1262       656/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1257       656/iobroker.js-con
          tcp        0      0 127.0.0.1:42623         0.0.0.0:*               LISTEN      1001       19344      1824/io.yahka.0
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       24041      1710/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22094      569/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15551      1/init
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       18952      937/io.sonoff.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1599       982/io.shelly.1
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20733      861/io.mqtt.0
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        19727      607/influxd
          tcp6       0      0 :::8086                 :::*                    LISTEN      998        15701      607/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18830      675/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21180      1665/io.web.0
          tcp6       0      0 :::45127                :::*                    LISTEN      1001       744        1824/io.yahka.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1414       891/io.sonos.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          22096      569/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          13349      1/init
          tcp6       0      0 :::41289                :::*                    LISTEN      1001       746        1824/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24254      1965/io.esphome.0
          udp        0      0 192.168.178.186:5353    0.0.0.0:*                           1001       13685      906/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           105        19711      544/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19851      876/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       548        1083/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       549        1083/io.tuya.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          215        421/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18577      1/init
          udp        0      0 0.0.0.0:58779           0.0.0.0:*                           105        19713      544/avahi-daemon: r
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1411       846/io.mihome-vacuu
          udp6       0      0 :::5353                 :::*                                105        19712      544/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          17808      1/init
          udp6       0      0 :::33044                :::*                                105        19714      544/avahi-daemon: r
          2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 472
          2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 225.1
          2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1675.1
          2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC unten = 472
          2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 978
          2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 469
          2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 225.1
          2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1672.1
          2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC oben = 978
          2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC gesamt = 1447
          2025-03-10 11:13:04.236  - debug: deyeidc.0 (1098) Response: (payload) {"register":7,"modbus":{"type":"Buffer","data":[1,3,6,0,80,0,100,255,255,161]}}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) Data reception for 7 registersets completed
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_Leistung+PV2_Leistung","key":"PV1_PV2_Leistung","name":"PV1+PV2 - Leistung","unit":"W","factor":0}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_PV2_Leistung+P_GEN_TOTAL","key":"PV_Gesamtleistung","name":"PV - Gesamtleistung","unit":"W","factor":0}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"P_BACKUP_LOAD_TOTAL+0","key":"Hausverbrauch","name":"Hausverbrauch","unit":"W","factor":0}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"Day_PV_Power_Wh-Day_GridSell_Power_Wh","key":"Day_Eigenverbrauch","name":"Day Eigenverbrauch","unit":"kWh","factor":0}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_PV2_Leistung*2","key":"PV_Gesamt-Cluster","name":"PV_Gesamt-Cluster","unit":"W","factor":0}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"Battery_Level*12.5/100","key":"Batterieladung","name":"Batterieladung","unit":"kWh","factor":2}
          2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData] ResultJson: [{"key":"PV1_PV2_Leistung","value":"1447.00","unit":"W","name":"PV1+PV2 - Leistung"},{"key":"PV_Gesamtleistung","value":"1456.00","unit":"W","name":"PV - Gesamtleistung"},{"key":"Hausverbrauch","value":"175.00","unit":"W","name":"Hausverbrauch"},{"key":"Day_Eigenverbrauch","value":"3.80","unit":"kWh","name":"Day Eigenverbrauch"},{"key":"PV_Gesamt_Cluster","value":"2912.00","unit":"W","name":"PV_Gesamt-Cluster"},{"key":"Batterieladung","value":"9.50","unit":"kWh","name":"Batterieladung"}]
          2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.Ost_West_zusammenfassung: Ost_Gesamt = 123.4
          2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.Ost_West_zusammenfassung: West_Gesamt113.19999999999999
          2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 978
          2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 469
          2025-03-10 11:13:06.928  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 224.9
          2025-03-10 11:13:06.928  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1671.9
          ? Codierknecht 2 Replies Last reply Reply Quote 0
            A Former User @bastler last edited by
            @bastler
            hast du vielleicht in der gleichen VM noch andere Anwendungen installiert, ausser iobroker?
            Influx vielleicht?
            • Codierknecht
              Codierknecht Developer Most Active @bastler last edited by Codierknecht
              @bastler
              Da liegen noch 13 GB in Backups.
              Außerdem bootest Du nach graphical.target. Bewusst? Ansonsten solltest Du den Hinweis auch ernst nehmen.
                bastler @Guest last edited by
                @neuschwansteini Ja, die läuft in einer eigenen VM.
                Codierknecht ? 2 Replies Last reply Reply Quote 0
                • Codierknecht
                  Dann hat influx ja auch sein eigenes Dateisystem.
                    @bastler
                    wie @Codierknecht schon sagte.. da liegen 13GB im Backup.. deine 32GB VM ist daher zu 99% voll..
                    also die Backups mal dahin schaffen, wo se hingehoeren..
                      bastler @Guest last edited by bastler
                      @neuschwansteini
                      Dann ist es kein Wunder 😵 Nur woher kommt die Umstellung?
                      === Mark text until here for copying ===
                      ingo@ioBroker:~$ /opt/iobroker/backups/
                      -bash: /opt/iobroker/backups/: Ist ein Verzeichnis
                      ingo@ioBroker:~$ cd /opt/iobroker/backups/
                      ingo@ioBroker:/opt/iobroker/backups$ dir
                      grafana_2024_11_08-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_13-03_35_13_backupiobroker.tar.gz	iobroker_2024_12_16-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_01_22-03_35_54_backupiobroker.tar.gz	   zigbee.0_2024_11_09-03_35_43_backupiobroker.tar.gz
                      grafana_2024_11_09-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_14-03_35_13_backupiobroker.tar.gz	iobroker_2024_12_17-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_05-03_35_50_backupiobroker.tar.gz	   zigbee.0_2024_11_10-03_35_43_backupiobroker.tar.gz
                      grafana_2024_11_10-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_15-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_02-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_21-03_35_52_backupiobroker.tar.gz	   zigbee.0_2024_11_11-03_35_47_backupiobroker.tar.gz
                      grafana_2024_11_11-03_35_47_backupiobroker.tar.gz   influxDB_2024_11_16-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_11-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_26-03_35_50_backupiobroker.tar.gz	   zigbee.0_2024_11_12-03_35_44_backupiobroker.tar.gz
                      grafana_2024_11_12-03_35_45_backupiobroker.tar.gz   influxDB_2024_11_26-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_22-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_03_08-03_35_37_backupiobroker.tar.gz	   zigbee.0_2024_11_13-03_35_44_backupiobroker.tar.gz
                      grafana_2024_11_13-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_29-03_35_15_backupiobroker.tar.gz	iobroker_2025_02_05-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_08-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_14-03_35_43_backupiobroker.tar.gz
                      grafana_2024_11_14-03_35_43_backupiobroker.tar.gz   influxDB_2024_12_16-03_35_14_backupiobroker.tar.gz	iobroker_2025_02_21-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_09-03_35_49_backupiobroker.tar.gz  zigbee.0_2024_11_15-03_35_42_backupiobroker.tar.gz
                      grafana_2024_11_15-03_35_43_backupiobroker.tar.gz   influxDB_2024_12_17-03_35_15_backupiobroker.tar.gz	iobroker_2025_02_26-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_10-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_16-03_35_45_backupiobroker.tar.gz
                      grafana_2024_11_16-03_35_45_backupiobroker.tar.gz   influxDB_2025_01_02-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_08-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_11-03_35_53_backupiobroker.tar.gz  zigbee.0_2024_11_26-03_35_46_backupiobroker.tar.gz
                      grafana_2024_11_26-03_35_46_backupiobroker.tar.gz   influxDB_2025_01_11-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_09-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_12-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_29-03_35_47_backupiobroker.tar.gz
                      grafana_2024_11_29-03_35_47_backupiobroker.tar.gz   influxDB_2025_01_22-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_10-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_13-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_12_16-03_35_50_backupiobroker.tar.gz
                      grafana_2024_12_16-03_35_51_backupiobroker.tar.gz   influxDB_2025_02_05-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_08-03_35_50_backupiobroker.tar.gz  javascripts_2024_11_14-03_35_49_backupiobroker.tar.gz  zigbee.0_2024_12_17-03_35_46_backupiobroker.tar.gz
                      grafana_2024_12_17-03_35_47_backupiobroker.tar.gz   influxDB_2025_02_21-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_09-03_35_49_backupiobroker.tar.gz  javascripts_2024_11_15-03_35_48_backupiobroker.tar.gz  zigbee.0_2025_01_02-03_35_48_backupiobroker.tar.gz
                      grafana_2025_01_02-03_35_49_backupiobroker.tar.gz   influxDB_2025_02_26-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_10-03_35_49_backupiobroker.tar.gz  javascripts_2024_11_16-03_35_51_backupiobroker.tar.gz  zigbee.0_2025_01_11-03_35_48_backupiobroker.tar.gz
                      grafana_2025_01_11-03_35_49_backupiobroker.tar.gz   influxDB_2025_03_08-03_35_14_backupiobroker.tar.gz	jarvis.0_2024_11_11-03_35_52_backupiobroker.tar.gz  javascripts_2024_11_26-03_35_52_backupiobroker.tar.gz  zigbee.0_2025_01_22-03_35_49_backupiobroker.tar.gz
                      grafana_2025_01_22-03_35_49_backupiobroker.tar.gz   iobroker_2024_11_08-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_12-03_35_50_backupiobroker.tar.gz  javascripts_2024_11_29-03_35_53_backupiobroker.tar.gz  zigbee.0_2025_02_05-03_35_45_backupiobroker.tar.gz
                      grafana_2025_02_05-03_35_45_backupiobroker.tar.gz   iobroker_2024_11_09-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_13-03_35_49_backupiobroker.tar.gz  javascripts_2024_12_16-03_35_56_backupiobroker.tar.gz  zigbee.0_2025_02_21-03_35_46_backupiobroker.tar.gz
                      grafana_2025_02_21-03_35_47_backupiobroker.tar.gz   iobroker_2024_11_10-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_14-03_35_48_backupiobroker.tar.gz  javascripts_2024_12_17-03_35_52_backupiobroker.tar.gz  zigbee.0_2025_02_26-03_35_45_backupiobroker.tar.gz
                      grafana_2025_02_26-03_35_45_backupiobroker.tar.gz   iobroker_2024_11_11-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_15-03_35_48_backupiobroker.tar.gz  javascripts_2025_01_02-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_08-03_35_32_backupiobroker.tar.gz
                      grafana_2025_03_08-03_35_32_backupiobroker.tar.gz   iobroker_2024_11_12-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_16-03_35_50_backupiobroker.tar.gz  javascripts_2025_01_11-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_09-03_35_21_backupiobroker.tar.gz
                      grafana_tmp					    iobroker_2024_11_13-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_26-03_35_51_backupiobroker.tar.gz  javascripts_2025_01_22-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_10-03_35_24_backupiobroker.tar.gz
                      influxDB_2024_11_08-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_14-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_29-03_35_53_backupiobroker.tar.gz  javascripts_2025_02_05-03_35_51_backupiobroker.tar.gz  zigbee.1_2025_03_08-03_35_32_backupiobroker.tar.gz
                      influxDB_2024_11_09-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_15-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_12_16-03_35_56_backupiobroker.tar.gz  javascripts_2025_02_21-03_35_52_backupiobroker.tar.gz  zigbee.1_2025_03_09-03_35_21_backupiobroker.tar.gz
                      influxDB_2024_11_10-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_16-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_12_17-03_35_52_backupiobroker.tar.gz  javascripts_2025_02_26-03_35_51_backupiobroker.tar.gz  zigbee.1_2025_03_10-03_35_24_backupiobroker.tar.gz
                      influxDB_2024_11_11-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_26-03_35_10_backupiobroker.tar.gz	jarvis.0_2025_01_02-03_35_54_backupiobroker.tar.gz  javascripts_2025_03_08-03_35_38_backupiobroker.tar.gz
                      influxDB_2024_11_12-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_29-03_35_10_backupiobroker.tar.gz	jarvis.0_2025_01_11-03_35_54_backupiobroker.tar.gz  zigbee.0_2024_11_08-03_35_44_backupiobroker.tar.gz
                      • Codierknecht
                        @bastler
                        Treten beim Backup Fehler auf?
                        Dann werden die Dateien nicht aufs NAS geschoben.
                          paul53 @bastler last edited by
                          @bastler sagte:
                            bastler @Codierknecht last edited by
                            @codierknecht Hatte gerade versucht vom Backup Adapter aus eine neue Sicherung durchzuführen. Da gab es eine Fehlermeldung bei der Influx Sicherung. Nach einem 2. Durchlauf sieht es jetzt wie unten dargestellt aus. Es scheint, das alle Daten eben nur lokal gesichert werden?
                            Die Einstellungen in der Backup Instanz sieht so aus.
                            11:43:20.780INFOguiBackup gestartet ...
                            11:43:22.899DEBUGiobrokerhost.ioBroker 18075 objects saved
                            11:43:23.531DEBUGiobrokerhost.ioBroker 15235 states saved
                            11:43:23.533DEBUGiobrokerhost.ioBroker Validating backup ...
                            11:43:23.576DEBUGiobrokerhost.ioBroker "config.json" is valid
                            11:43:23.579DEBUGiobrokerhost.ioBroker "objects.jsonl" exists
                            11:43:23.664DEBUGiobrokerhost.ioBroker "states.jsonl" exists
                            11:43:23.826DEBUGiobrokerhost.ioBroker JSONL lines are valid
                            11:43:23.830DEBUGiobrokerhost.ioBroker The backup is valid!
                            11:43:24.212DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz
                            11:43:24.217DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                            11:43:25.226DEBUGiobrokerdone
                            11:43:25.379DEBUGinfluxDBInfluxDB-Backup started ...
                            11:43:25.382DEBUGinfluxDBInfluxDB Backup tmp directory created
                            11:43:28.329DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker"
                            11:43:28.352DEBUGinfluxDB2025/03/10 11:43:25 backing up metastore to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/meta.00
                            2025/03/10 11:43:25 backing up db=iobroker
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1283 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01283.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1291 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01291.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1299 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01299.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1307 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01307.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1315 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01315.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1323 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01323.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1331 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01331.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1339 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01339.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1347 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01347.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1355 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01355.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1363 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01363.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1371 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01371.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1379 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01379.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1387 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01387.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1395 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01395.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1403 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01403.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1411 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01411.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1419 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01419.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1427 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01427.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1435 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01435.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1443 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01443.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1451 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01451.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1459 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01459.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1467 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01467.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1475 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01475.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1483 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01483.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1491 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01491.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1499 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01499.00 since 0001-01-01T00:00:00Z
                            2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1507 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01507.00 since 0001-01-01T00:00:00Z
                            11:43:28.401DEBUGinfluxDBdone
                            11:43:29.246DEBUGzigbeefound zigbee database: zigbee.0,zigbee.1
                            11:43:29.289DEBUGzigbeedone
                            11:43:29.550DEBUGgrafanaStart Grafana Backup ...
                            11:43:29.553DEBUGgrafanaCreated dashboards_manually_restore directory
                            11:43:29.557DEBUGgrafanastart Grafana request ...
                            11:43:29.599DEBUGgrafanaGrafana is available ... Status: 200
                            11:43:29.603DEBUGgrafanafound Dashboard: heizung
                            11:43:29.605DEBUGgrafanafound Dashboard: new-dashboard-copy
                            11:43:29.608DEBUGgrafanafound Dashboard: espeasy-2
                            11:43:29.652DEBUGgrafanafound Dashboard: 1-dashboard
                            11:43:29.712DEBUGgrafanastart Grafana backup compress ...
                            11:43:34.723DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                            11:43:34.769DEBUGgrafanadone
                            11:43:34.875DEBUGjarvisCreated jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
                            11:43:34.878DEBUGjarvisfound Jarvis Instance: 0
                            11:43:34.892DEBUGjarvisstart Jarvis Backup for Instance 0...
                            11:43:34.893DEBUGjarvis/opt/iobroker/iobroker-data/jarvis/0 copy success!
                            11:43:34.924DEBUGjarvisCreated states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
                            11:43:35.025DEBUGjarvisTry deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
                            11:43:35.030DEBUGjarvisJarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
                            11:43:35.071DEBUGjarvisBackup created: /opt/iobroker/backups/jarvis.0_2025_03_10-11_43_34_backupiobroker.tar.gz
                            11:43:35.073DEBUGjarvisdone
                            11:43:35.345DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                            11:43:35.408DEBUGjavascriptsfound Script: Wama_und_Trockner_Meldung
                            11:43:35.516DEBUGjavascriptsfound Script: Alias_anlegen
                            11:43:35.667DEBUGjavascriptsfound Script: Gaszähler
                            11:43:35.818DEBUGjavascriptsfound Script: Stromüberschuss3
                            11:43:35.969DEBUGjavascriptsfound Script: Wasserverbrauch2
                            11:43:36.120DEBUGjavascriptsfound Script: Stromüberschuss_Kühlschank
                            11:43:36.271DEBUGjavascriptsfound Script: Wasserverbrauch
                            11:43:36.422DEBUGjavascriptsfound Script: Gasverbrauch
                            11:43:36.572DEBUGjavascriptsfound Script: Einspeisung
                            11:43:36.723DEBUGjavascriptsfound Script: Brunnenwasser
                            11:43:36.875DEBUGjavascriptsfound Script: Nur_Brunnenwasser
                            11:43:37.026DEBUGjavascriptsfound Script: Brunnenwasser_alt
                            11:43:37.175DEBUGjavascriptsfound Script: Gesamtverbräuche
                            11:43:37.325DEBUGjavascriptsfound Script: Stromüberschuss_Heizer
                            11:43:37.475DEBUGjavascriptsfound Script: Steckdose_Robo
                            11:43:37.628DEBUGjavascriptsfound Script: Windberechnung
                            11:43:37.777DEBUGjavascriptsfound Script: Licht_Esszimmer
                            11:43:37.927DEBUGjavascriptsfound Script: Watchdog_Adapter1
                            11:43:38.083DEBUGjavascriptsfound Script: Gefrierschrank
                            11:43:38.231DEBUGjavascriptsfound Script: Drucker_an_aus
                            11:43:38.383DEBUGjavascriptsfound Script: Garage_korrigierter_Verbrauch
                            11:43:38.534DEBUGjavascriptsfound Script: Ost_West_zusammenfassung
                            11:43:38.684DEBUGjavascriptsfound Script: _beide_Anlagen
                            11:43:38.834DEBUGjavascriptsfound Script: Deckenventilator
                            11:43:38.985DEBUGjavascriptsfound Script: Stromüberschuss_Deckenlüfter_Terrasse_
                            11:43:39.135DEBUGjavascriptsfound Script: 1i
                            11:43:39.284DEBUGjavascriptsfound Script: 1j
                            11:43:39.435DEBUGjavascriptsfound Script: 1k
                            11:43:39.586DEBUGjavascriptsfound Script: Schalter_Stube_Ikea_
                            11:43:39.737DEBUGjavascriptsfound Script: Schalter_Terrasse_Ikea_
                            11:43:39.887DEBUGjavascriptsfound Script: Gewächshaus
                            11:43:40.039DEBUGjavascriptsfound Script: Stromüberschuss_Lüfter_Keller
                            11:43:40.189DEBUGjavascriptsfound Script: Shelly_Temp_Brunnenpumpe1
                            11:43:40.339DEBUGjavascriptsfound Script: Shelly_Temp_Garagenboden1
                            11:43:40.490DEBUGjavascriptsfound Script: Staubsauger_Garage
                            11:43:40.641DEBUGjavascriptsfound Script: Brunnenwasser_neu
                            11:43:40.803DEBUGjavascriptsfound Script: Stromkosten_täglich
                            11:43:40.941DEBUGjavascriptsfound Script: Jalousie
                            11:43:41.093DEBUGjavascriptsfound Script: Jalousie_Test
                            11:43:41.244DEBUGjavascriptsfound Script: Kostenersparnis
                            11:43:41.395DEBUGjavascriptsfound Script: Lüfter_WR
                            11:43:41.545DEBUGjavascriptsfound Script: _Dach
                            11:43:41.694DEBUGjavascriptsfound Script: Berechnung_Hausverbrauch
                            11:43:41.855DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                            11:43:41.900DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_03_10-11_43_35_backupiobroker.tar.gz
                            11:43:41.901DEBUGjavascriptsdone
                            11:43:43.210DEBUGgoogledriveGoogle Drive: Copy iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz...
                              Homoran Global Moderator Administrators @bastler last edited by Homoran
                              das ist normal, wenn es nicht am Ziel ankommt.
                              backup.dir dürfte nicht der Pfad zu Google sein
                              ... wäre wahrscheinlich das wichtigste
                                A Former User @paul53 last edited by
                                @paul53 sagte in Problem mit unzureichendem Speicherplatz:
                                @bastler sagte:
                                @bastler
                                zuerst platz machen, solange deine Platte voll ist, geht auch kein backup.. er kanns ja nicht zwischenspeichern..
                                  @neuschwansteini Ich habe den Fehler entdeckt, Google Drive war zu voll! Kann mich aber nicht an eine Fehlermeldung erinnern. Es ist dann wohl so, dass das Backup auf dem lokalen Laufwerk durchgeführt wird.
                                  Gibt es eine Möglichkeit über so ein Problem (Google Speicher voll) informiert zu werden?
                                  Danke an alle Helfer!
                                  Homoran crunchip 2 Replies Last reply Reply Quote 0
                                    ja!
                                    @homoran sagte in Problem mit unzureichendem Speicherplatz:
                                      crunchip Forum Testing Most Active @bastler last edited by
                                      Bekommt man da nicht unabhängig vom Smarthome eine Mail, da benachrichtigt dich doch Google.
                                        bastler @crunchip last edited by
                                        @crunchip Nein, nur direkt in Google Drive wurde mir angezeigt, dass nur noch 83% frei sind und ein Speichern von weiteren Dateien nicht mehr möglich ist.
                                          bastler @Homoran last edited by bastler
                                          @homoran Der Backup Vorgang läuft scheinbar nicht weiter? Google Drive ist mit 8GB belegt von 17GB. Die alten Backups im lokalen LW und auch im Google Drive habe ich gelöscht. Wenn ich direkt in Google Drive nachschaue, ist das Verzeichnis noch leer. Bin ich zu ungeduldig? Aber 700MB sollten doch in 15 Minuten locker hochgeladen werden?
                                          Habe jetzt den Vorgang gestoppt, den ioBroker neu gestartet und noch einmal den Upload angeschoben. Sieht nicht anders aus. Oben im Fenster läuft der blaue Balken von links nach rechts, mehr passiert nicht.
                                          Habe nun den Token versucht neu anzufordern, war aber nicht nötig, da der Zugriff möglich war. Allerdings schien da doch etwas geklemmt zu haben, denn danach klappte die Sicherung.
                                            mago @bastler last edited by
                                            ich hänge mich hier mal dran mit einem ähnlichen Problem. Hatte dieselbe Meldung und hab nach einiger Recherche schonmal ein paar Caches und Backups gelöscht.
                                            Nun kondensiert sich das Ganze im Wesentlichen auf Javascript:
                                                3.0 GiB [#################] /opt
                                                1.2 GiB [######           ] /usr
                                              324.5 MiB [#                ] /home
                                            . 249.2 MiB [#                ] /var
                                            .   3.2 MiB [                 ] /etc
                                            und weiter
                                            --- /opt/iobroker -----------------------------------------------------------------------------------------------------------
                                                1.4 GiB [#################] /node_modules
                                              920.9 MiB [##########       ] /iobroker-data
                                              453.7 MiB [#####            ] /backups
                                                1.5 MiB [                 ] /log
                                            In den beiden größten Foldern sind jeweils javascript Unterordner die Maßgeblichen:
                                            --- /opt/iobroker/node_modules ----------------------------------------------------------------------------------------------
                                              621.7 MiB [#################] /iobroker.javascript
                                              181.0 MiB [####             ] /canvas
                                              152.2 MiB [####             ] /iobroker.echarts
                                               84.0 MiB [##               ] /iobroker.admin
                                            und
                                            --- /opt/iobroker/iobroker-data/files ---------------------------------------------------------------------------------------
                                              616.2 MiB [#################] /javascript.admin
                                               66.2 MiB [#                ] /echarts.admin
                                               60.5 MiB [#                ] /echarts
                                            Kann mir jemand sagen woran das liegt und wie ich hier ein bisschen entschlacken kann?
                                            Vielen Dank & viele Grüße
                                            Marco
                                            2732
