    3. Off Topic
    4. Proxmox
    5. Problem mit unzureichendem Speicherplatz
      Homoran Global Moderator Administrators @bastler last edited by
      @bastler sagte in Problem mit unzureichendem Speicherplatz:
      /dev/sda1 ext4 31G 29G 470M 99% /
      viel ist da nicht mehr
        bastler @Homoran last edited by
        @homoran so jetzt noch einmal alles
        Script v.2025-02-23
        *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-31-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
        OS is similar to:
        model name	: Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         11:12:49 up  1:57,  2 users,  load average: 0.13, 0.19, 0.18
        CPU threads: 16
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-03-10 11:12:49 CET
                   Universal time: Mon 2025-03-10 10:12:49 UTC
                         RTC time: Mon 2025-03-10 10:12:49
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        ingo
        HOME=/home/ingo
        GROUPS=ingo adm cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:             11G        3.7G        7.4G        585K        982M        8.1G
        Swap:           1.0G          0B        1.0G
        Total:           12G        3.7G        8.4G
        Active iob-Instances: 	45
                11265 M total memory
                 3557 M used memory
                  422 M active memory
                 3459 M inactive memory
                 7048 M free memory
                  125 M buffer memory
                  811 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        top - 11:12:49 up  1:57,  2 users,  load average: 0.13, 0.19, 0.18
        Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  11265.7 total,   7048.9 free,   3557.6 used,    936.9 buff/cache
        MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7708.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  5.5G     0  5.5G   0% /dev
        tmpfs          tmpfs     1.2G  576K  1.1G   1% /run
        tmpfs          tmpfs     5.6G     0  5.6G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
        [Mon Mar 10 09:15:15 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Mar 10 09:15:16 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.6G	/var/
        975M	/var/log
        890M	/var/log/journal/00d6058392fa44d3b60e2dcfbf39a290
        427M	/var/cache
        Archived and active journals take up 889.8M in the file system.
        /opt/iobroker/backups:
        13G	/opt/iobroker/backups/
        516K	/opt/iobroker/backups/grafana_tmp
        264K	/opt/iobroker/backups/grafana_tmp/dashboards
        240K	/opt/iobroker/backups/grafana_tmp/dashboards_manually_restore
        8.0K	/opt/iobroker/backups/grafana_tmp/datasource
        /opt/iobroker/iobroker-data:
        1.9G	/opt/iobroker/iobroker-data/
        1.3G	/opt/iobroker/iobroker-data/files
        617M	/opt/iobroker/iobroker-data/files/javascript.admin
        560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        52M	/opt/iobroker/iobroker-data/objects.jsonl
        38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191141-if00
        *** ZigBee Settings ***
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.18.3
        /usr/bin/node 		v20.18.3
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.30.0
        nodejs:
          Installed: 20.18.3-1nodesource1
          Candidate: 20.18.3-1nodesource1
          Version table:
         *** 20.18.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 7038)
        Core adapters versions
        js-controller: 	7.0.6
        admin: 		7.4.10
        javascript: 	8.8.3
        nodejs modules from github: 	2
        +-- iobroker.deyeidc@0.2.0 (git+ssh://git@github.com/raschy/ioBroker.deyeidc.git#0504bb34191750e47bfb509c3c9fb08aef980eb2)
        +-- iobroker.zigbee@2.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#0a1913bc5e2c61db265a338e6474ed367959dc49)
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
        + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
        + system.adapter.esphome.0                : esphome               : ioBroker                                 -  enabled
          system.adapter.espresense.0             : espresense            : ioBroker                                 - disabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
        + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
          system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.nut.0                    : nut                   : ioBroker                                 - disabled
        + system.adapter.opendtu.0                : opendtu               : ioBroker                                 -  enabled
        + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
          system.adapter.philips-air.0            : philips-air           : ioBroker                                 - disabled
          system.adapter.powerfox2.0              : powerfox2             : ioBroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
        + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
        + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
        + system.adapter.reolink.2                : reolink               : ioBroker                                 -  enabled
        + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
        + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
        + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
        + system.adapter.tahoma.0                 : tahoma                : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191141-if00
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): Stable (default)
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: Stable (default)
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
        Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
        Adapter    "espresense"   : 0.4.8    , installed 0.4.8
        Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
        Adapter    "parser"       : 2.2.4    , installed 2.2.4
        Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
        Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "reolink"      : 1.2.1    , installed 1.2.1
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
        Adapter    "telegram"     : 4.0.0    , installed 4.0.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "welcome"      : 1.0.2    , installed 1.0.2
        Adapter    "wireless-settings": 1.0.2, installed 1.0.2
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.14  , installed 2.0.3
        Objects and States
        Objects: 	18065
        States: 	15235
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://repos.influxdata.com/debian bookworm InRelease
        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1262       656/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1257       656/iobroker.js-con
        tcp        0      0 127.0.0.1:42623         0.0.0.0:*               LISTEN      1001       19344      1824/io.yahka.0
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       24041      1710/io.jarvis.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22094      569/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15551      1/init
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       18952      937/io.sonoff.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1599       982/io.shelly.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20733      861/io.mqtt.0
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        19727      607/influxd
        tcp6       0      0 :::8086                 :::*                    LISTEN      998        15701      607/influxd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18830      675/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21180      1665/io.web.0
        tcp6       0      0 :::45127                :::*                    LISTEN      1001       744        1824/io.yahka.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1414       891/io.sonos.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          22096      569/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          13349      1/init
        tcp6       0      0 :::41289                :::*                    LISTEN      1001       746        1824/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24254      1965/io.esphome.0
        udp        0      0 192.168.178.186:5353    0.0.0.0:*                           1001       13685      906/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           105        19711      544/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19851      876/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       548        1083/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       549        1083/io.tuya.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          215        421/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18577      1/init
        udp        0      0 0.0.0.0:58779           0.0.0.0:*                           105        19713      544/avahi-daemon: r
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1411       846/io.mihome-vacuu
        udp6       0      0 :::5353                 :::*                                105        19712      544/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          17808      1/init
        udp6       0      0 :::33044                :::*                                105        19714      544/avahi-daemon: r
        2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 472
        2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 225.1
        2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1675.1
        2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC unten = 472
        2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 978
        2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 469
        2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 225.1
        2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1672.1
        2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC oben = 978
        2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC gesamt = 1447
        2025-03-10 11:13:04.236  - debug: deyeidc.0 (1098) Response: (payload) {"register":7,"modbus":{"type":"Buffer","data":[1,3,6,0,80,0,100,255,255,161]}}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) Data reception for 7 registersets completed
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_Leistung+PV2_Leistung","key":"PV1_PV2_Leistung","name":"PV1+PV2 - Leistung","unit":"W","factor":0}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_PV2_Leistung+P_GEN_TOTAL","key":"PV_Gesamtleistung","name":"PV - Gesamtleistung","unit":"W","factor":0}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"P_BACKUP_LOAD_TOTAL+0","key":"Hausverbrauch","name":"Hausverbrauch","unit":"W","factor":0}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"Day_PV_Power_Wh-Day_GridSell_Power_Wh","key":"Day_Eigenverbrauch","name":"Day Eigenverbrauch","unit":"kWh","factor":0}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_PV2_Leistung*2","key":"PV_Gesamt-Cluster","name":"PV_Gesamt-Cluster","unit":"W","factor":0}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"Battery_Level*12.5/100","key":"Batterieladung","name":"Batterieladung","unit":"kWh","factor":2}
        2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData] ResultJson: [{"key":"PV1_PV2_Leistung","value":"1447.00","unit":"W","name":"PV1+PV2 - Leistung"},{"key":"PV_Gesamtleistung","value":"1456.00","unit":"W","name":"PV - Gesamtleistung"},{"key":"Hausverbrauch","value":"175.00","unit":"W","name":"Hausverbrauch"},{"key":"Day_Eigenverbrauch","value":"3.80","unit":"kWh","name":"Day Eigenverbrauch"},{"key":"PV_Gesamt_Cluster","value":"2912.00","unit":"W","name":"PV_Gesamt-Cluster"},{"key":"Batterieladung","value":"9.50","unit":"kWh","name":"Batterieladung"}]
        2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.Ost_West_zusammenfassung: Ost_Gesamt = 123.4
        2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.Ost_West_zusammenfassung: West_Gesamt113.19999999999999
        2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 978
        2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 469
        2025-03-10 11:13:06.928  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 224.9
        2025-03-10 11:13:06.928  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1671.9
        ? Codierknecht 2 Replies Last reply Reply Quote 0
          A Former User @bastler last edited by
          @bastler
          hast du vielleicht in der gleichen VM noch andere Anwendungen installiert, ausser iobroker?
          Influx vielleicht?
          • Codierknecht
            Codierknecht Developer Most Active @bastler last edited by Codierknecht
            @bastler
            Da liegen noch 13 GB in Backups.
            Außerdem bootest Du nach graphical.target. Bewusst? Ansonsten solltest Du den Hinweis auch ernst nehmen.
              bastler @Guest last edited by
              @neuschwansteini Ja, die läuft in einer eigenen VM.
              Codierknecht ? 2 Replies Last reply Reply Quote 0
              • Codierknecht
                Dann hat influx ja auch sein eigenes Dateisystem.
                  @bastler
                  wie @Codierknecht schon sagte.. da liegen 13GB im Backup.. deine 32GB VM ist daher zu 99% voll..
                  also die Backups mal dahin schaffen, wo se hingehoeren..
                    bastler @Guest last edited by bastler
                    @neuschwansteini
                    Dann ist es kein Wunder 😵 Nur woher kommt die Umstellung?
                    === Mark text until here for copying ===
                    ingo@ioBroker:~$ /opt/iobroker/backups/
                    -bash: /opt/iobroker/backups/: Ist ein Verzeichnis
                    ingo@ioBroker:~$ cd /opt/iobroker/backups/
                    ingo@ioBroker:/opt/iobroker/backups$ dir
                    grafana_2024_11_08-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_13-03_35_13_backupiobroker.tar.gz	iobroker_2024_12_16-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_01_22-03_35_54_backupiobroker.tar.gz	   zigbee.0_2024_11_09-03_35_43_backupiobroker.tar.gz
                    grafana_2024_11_09-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_14-03_35_13_backupiobroker.tar.gz	iobroker_2024_12_17-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_05-03_35_50_backupiobroker.tar.gz	   zigbee.0_2024_11_10-03_35_43_backupiobroker.tar.gz
                    grafana_2024_11_10-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_15-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_02-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_21-03_35_52_backupiobroker.tar.gz	   zigbee.0_2024_11_11-03_35_47_backupiobroker.tar.gz
                    grafana_2024_11_11-03_35_47_backupiobroker.tar.gz   influxDB_2024_11_16-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_11-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_26-03_35_50_backupiobroker.tar.gz	   zigbee.0_2024_11_12-03_35_44_backupiobroker.tar.gz
                    grafana_2024_11_12-03_35_45_backupiobroker.tar.gz   influxDB_2024_11_26-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_22-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_03_08-03_35_37_backupiobroker.tar.gz	   zigbee.0_2024_11_13-03_35_44_backupiobroker.tar.gz
                    grafana_2024_11_13-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_29-03_35_15_backupiobroker.tar.gz	iobroker_2025_02_05-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_08-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_14-03_35_43_backupiobroker.tar.gz
                    grafana_2024_11_14-03_35_43_backupiobroker.tar.gz   influxDB_2024_12_16-03_35_14_backupiobroker.tar.gz	iobroker_2025_02_21-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_09-03_35_49_backupiobroker.tar.gz  zigbee.0_2024_11_15-03_35_42_backupiobroker.tar.gz
                    grafana_2024_11_15-03_35_43_backupiobroker.tar.gz   influxDB_2024_12_17-03_35_15_backupiobroker.tar.gz	iobroker_2025_02_26-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_10-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_16-03_35_45_backupiobroker.tar.gz
                    grafana_2024_11_16-03_35_45_backupiobroker.tar.gz   influxDB_2025_01_02-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_08-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_11-03_35_53_backupiobroker.tar.gz  zigbee.0_2024_11_26-03_35_46_backupiobroker.tar.gz
                    grafana_2024_11_26-03_35_46_backupiobroker.tar.gz   influxDB_2025_01_11-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_09-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_12-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_29-03_35_47_backupiobroker.tar.gz
                    grafana_2024_11_29-03_35_47_backupiobroker.tar.gz   influxDB_2025_01_22-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_10-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_13-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_12_16-03_35_50_backupiobroker.tar.gz
                    grafana_2024_12_16-03_35_51_backupiobroker.tar.gz   influxDB_2025_02_05-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_08-03_35_50_backupiobroker.tar.gz  javascripts_2024_11_14-03_35_49_backupiobroker.tar.gz  zigbee.0_2024_12_17-03_35_46_backupiobroker.tar.gz
                    grafana_2024_12_17-03_35_47_backupiobroker.tar.gz   influxDB_2025_02_21-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_09-03_35_49_backupiobroker.tar.gz  javascripts_2024_11_15-03_35_48_backupiobroker.tar.gz  zigbee.0_2025_01_02-03_35_48_backupiobroker.tar.gz
                    grafana_2025_01_02-03_35_49_backupiobroker.tar.gz   influxDB_2025_02_26-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_10-03_35_49_backupiobroker.tar.gz  javascripts_2024_11_16-03_35_51_backupiobroker.tar.gz  zigbee.0_2025_01_11-03_35_48_backupiobroker.tar.gz
                    grafana_2025_01_11-03_35_49_backupiobroker.tar.gz   influxDB_2025_03_08-03_35_14_backupiobroker.tar.gz	jarvis.0_2024_11_11-03_35_52_backupiobroker.tar.gz  javascripts_2024_11_26-03_35_52_backupiobroker.tar.gz  zigbee.0_2025_01_22-03_35_49_backupiobroker.tar.gz
                    grafana_2025_01_22-03_35_49_backupiobroker.tar.gz   iobroker_2024_11_08-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_12-03_35_50_backupiobroker.tar.gz  javascripts_2024_11_29-03_35_53_backupiobroker.tar.gz  zigbee.0_2025_02_05-03_35_45_backupiobroker.tar.gz
                    grafana_2025_02_05-03_35_45_backupiobroker.tar.gz   iobroker_2024_11_09-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_13-03_35_49_backupiobroker.tar.gz  javascripts_2024_12_16-03_35_56_backupiobroker.tar.gz  zigbee.0_2025_02_21-03_35_46_backupiobroker.tar.gz
                    grafana_2025_02_21-03_35_47_backupiobroker.tar.gz   iobroker_2024_11_10-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_14-03_35_48_backupiobroker.tar.gz  javascripts_2024_12_17-03_35_52_backupiobroker.tar.gz  zigbee.0_2025_02_26-03_35_45_backupiobroker.tar.gz
                    grafana_2025_02_26-03_35_45_backupiobroker.tar.gz   iobroker_2024_11_11-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_15-03_35_48_backupiobroker.tar.gz  javascripts_2025_01_02-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_08-03_35_32_backupiobroker.tar.gz
                    grafana_2025_03_08-03_35_32_backupiobroker.tar.gz   iobroker_2024_11_12-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_16-03_35_50_backupiobroker.tar.gz  javascripts_2025_01_11-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_09-03_35_21_backupiobroker.tar.gz
                    grafana_tmp					    iobroker_2024_11_13-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_26-03_35_51_backupiobroker.tar.gz  javascripts_2025_01_22-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_10-03_35_24_backupiobroker.tar.gz
                    influxDB_2024_11_08-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_14-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_29-03_35_53_backupiobroker.tar.gz  javascripts_2025_02_05-03_35_51_backupiobroker.tar.gz  zigbee.1_2025_03_08-03_35_32_backupiobroker.tar.gz
                    influxDB_2024_11_09-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_15-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_12_16-03_35_56_backupiobroker.tar.gz  javascripts_2025_02_21-03_35_52_backupiobroker.tar.gz  zigbee.1_2025_03_09-03_35_21_backupiobroker.tar.gz
                    influxDB_2024_11_10-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_16-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_12_17-03_35_52_backupiobroker.tar.gz  javascripts_2025_02_26-03_35_51_backupiobroker.tar.gz  zigbee.1_2025_03_10-03_35_24_backupiobroker.tar.gz
                    influxDB_2024_11_11-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_26-03_35_10_backupiobroker.tar.gz	jarvis.0_2025_01_02-03_35_54_backupiobroker.tar.gz  javascripts_2025_03_08-03_35_38_backupiobroker.tar.gz
                    influxDB_2024_11_12-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_29-03_35_10_backupiobroker.tar.gz	jarvis.0_2025_01_11-03_35_54_backupiobroker.tar.gz  zigbee.0_2024_11_08-03_35_44_backupiobroker.tar.gz
                    • Codierknecht
                      @bastler
                      Treten beim Backup Fehler auf?
                      Dann werden die Dateien nicht aufs NAS geschoben.
                        paul53 @bastler last edited by
                        @bastler sagte:
                          bastler @Codierknecht last edited by
                          @codierknecht Hatte gerade versucht vom Backup Adapter aus eine neue Sicherung durchzuführen. Da gab es eine Fehlermeldung bei der Influx Sicherung. Nach einem 2. Durchlauf sieht es jetzt wie unten dargestellt aus. Es scheint, das alle Daten eben nur lokal gesichert werden?
                          Die Einstellungen in der Backup Instanz sieht so aus.
                          11:43:20.780INFOguiBackup gestartet ...
                          11:43:22.899DEBUGiobrokerhost.ioBroker 18075 objects saved
                          11:43:23.531DEBUGiobrokerhost.ioBroker 15235 states saved
                          11:43:23.533DEBUGiobrokerhost.ioBroker Validating backup ...
                          11:43:23.576DEBUGiobrokerhost.ioBroker "config.json" is valid
                          11:43:23.579DEBUGiobrokerhost.ioBroker "objects.jsonl" exists
                          11:43:23.664DEBUGiobrokerhost.ioBroker "states.jsonl" exists
                          11:43:23.826DEBUGiobrokerhost.ioBroker JSONL lines are valid
                          11:43:23.830DEBUGiobrokerhost.ioBroker The backup is valid!
                          11:43:24.212DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz
                          11:43:24.217DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                          11:43:25.226DEBUGiobrokerdone
                          11:43:25.379DEBUGinfluxDBInfluxDB-Backup started ...
                          11:43:25.382DEBUGinfluxDBInfluxDB Backup tmp directory created
                          11:43:28.329DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker"
                          11:43:28.352DEBUGinfluxDB2025/03/10 11:43:25 backing up metastore to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/meta.00
                          2025/03/10 11:43:25 backing up db=iobroker
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1283 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01283.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1291 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01291.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1299 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01299.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1307 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01307.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1315 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01315.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1323 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01323.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1331 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01331.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1339 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01339.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1347 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01347.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1355 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01355.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1363 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01363.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1371 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01371.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1379 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01379.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1387 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01387.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1395 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01395.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1403 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01403.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1411 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01411.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1419 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01419.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1427 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01427.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1435 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01435.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1443 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01443.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1451 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01451.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1459 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01459.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1467 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01467.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1475 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01475.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1483 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01483.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1491 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01491.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1499 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01499.00 since 0001-01-01T00:00:00Z
                          2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1507 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01507.00 since 0001-01-01T00:00:00Z
                          11:43:28.401DEBUGinfluxDBdone
                          11:43:29.246DEBUGzigbeefound zigbee database: zigbee.0,zigbee.1
                          11:43:29.289DEBUGzigbeedone
                          11:43:29.550DEBUGgrafanaStart Grafana Backup ...
                          11:43:29.553DEBUGgrafanaCreated dashboards_manually_restore directory
                          11:43:29.557DEBUGgrafanastart Grafana request ...
                          11:43:29.599DEBUGgrafanaGrafana is available ... Status: 200
                          11:43:29.603DEBUGgrafanafound Dashboard: heizung
                          11:43:29.605DEBUGgrafanafound Dashboard: new-dashboard-copy
                          11:43:29.608DEBUGgrafanafound Dashboard: espeasy-2
                          11:43:29.652DEBUGgrafanafound Dashboard: 1-dashboard
                          11:43:29.712DEBUGgrafanastart Grafana backup compress ...
                          11:43:34.723DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                          11:43:34.769DEBUGgrafanadone
                          11:43:34.875DEBUGjarvisCreated jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
                          11:43:34.878DEBUGjarvisfound Jarvis Instance: 0
                          11:43:34.892DEBUGjarvisstart Jarvis Backup for Instance 0...
                          11:43:34.893DEBUGjarvis/opt/iobroker/iobroker-data/jarvis/0 copy success!
                          11:43:34.924DEBUGjarvisCreated states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
                          11:43:35.025DEBUGjarvisTry deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
                          11:43:35.030DEBUGjarvisJarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
                          11:43:35.071DEBUGjarvisBackup created: /opt/iobroker/backups/jarvis.0_2025_03_10-11_43_34_backupiobroker.tar.gz
                          11:43:35.073DEBUGjarvisdone
                          11:43:35.345DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                          11:43:35.408DEBUGjavascriptsfound Script: Wama_und_Trockner_Meldung
                          11:43:35.516DEBUGjavascriptsfound Script: Alias_anlegen
                          11:43:35.667DEBUGjavascriptsfound Script: Gaszähler
                          11:43:35.818DEBUGjavascriptsfound Script: Stromüberschuss3
                          11:43:35.969DEBUGjavascriptsfound Script: Wasserverbrauch2
                          11:43:36.120DEBUGjavascriptsfound Script: Stromüberschuss_Kühlschank
                          11:43:36.271DEBUGjavascriptsfound Script: Wasserverbrauch
                          11:43:36.422DEBUGjavascriptsfound Script: Gasverbrauch
                          11:43:36.572DEBUGjavascriptsfound Script: Einspeisung
                          11:43:36.723DEBUGjavascriptsfound Script: Brunnenwasser
                          11:43:36.875DEBUGjavascriptsfound Script: Nur_Brunnenwasser
                          11:43:37.026DEBUGjavascriptsfound Script: Brunnenwasser_alt
                          11:43:37.175DEBUGjavascriptsfound Script: Gesamtverbräuche
                          11:43:37.325DEBUGjavascriptsfound Script: Stromüberschuss_Heizer
                          11:43:37.475DEBUGjavascriptsfound Script: Steckdose_Robo
                          11:43:37.628DEBUGjavascriptsfound Script: Windberechnung
                          11:43:37.777DEBUGjavascriptsfound Script: Licht_Esszimmer
                          11:43:37.927DEBUGjavascriptsfound Script: Watchdog_Adapter1
                          11:43:38.083DEBUGjavascriptsfound Script: Gefrierschrank
                          11:43:38.231DEBUGjavascriptsfound Script: Drucker_an_aus
                          11:43:38.383DEBUGjavascriptsfound Script: Garage_korrigierter_Verbrauch
                          11:43:38.534DEBUGjavascriptsfound Script: Ost_West_zusammenfassung
                          11:43:38.684DEBUGjavascriptsfound Script: _beide_Anlagen
                          11:43:38.834DEBUGjavascriptsfound Script: Deckenventilator
                          11:43:38.985DEBUGjavascriptsfound Script: Stromüberschuss_Deckenlüfter_Terrasse_
                          11:43:39.135DEBUGjavascriptsfound Script: 1i
                          11:43:39.284DEBUGjavascriptsfound Script: 1j
                          11:43:39.435DEBUGjavascriptsfound Script: 1k
                          11:43:39.586DEBUGjavascriptsfound Script: Schalter_Stube_Ikea_
                          11:43:39.737DEBUGjavascriptsfound Script: Schalter_Terrasse_Ikea_
                          11:43:39.887DEBUGjavascriptsfound Script: Gewächshaus
                          11:43:40.039DEBUGjavascriptsfound Script: Stromüberschuss_Lüfter_Keller
                          11:43:40.189DEBUGjavascriptsfound Script: Shelly_Temp_Brunnenpumpe1
                          11:43:40.339DEBUGjavascriptsfound Script: Shelly_Temp_Garagenboden1
                          11:43:40.490DEBUGjavascriptsfound Script: Staubsauger_Garage
                          11:43:40.641DEBUGjavascriptsfound Script: Brunnenwasser_neu
                          11:43:40.803DEBUGjavascriptsfound Script: Stromkosten_täglich
                          11:43:40.941DEBUGjavascriptsfound Script: Jalousie
                          11:43:41.093DEBUGjavascriptsfound Script: Jalousie_Test
                          11:43:41.244DEBUGjavascriptsfound Script: Kostenersparnis
                          11:43:41.395DEBUGjavascriptsfound Script: Lüfter_WR
                          11:43:41.545DEBUGjavascriptsfound Script: _Dach
                          11:43:41.694DEBUGjavascriptsfound Script: Berechnung_Hausverbrauch
                          11:43:41.855DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                          11:43:41.900DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_03_10-11_43_35_backupiobroker.tar.gz
                          11:43:41.901DEBUGjavascriptsdone
                          11:43:43.210DEBUGgoogledriveGoogle Drive: Copy iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz...
                            Homoran Global Moderator Administrators @bastler last edited by Homoran
                            das ist normal, wenn es nicht am Ziel ankommt.
                            backup.dir dürfte nicht der Pfad zu Google sein
                            ... wäre wahrscheinlich das wichtigste
                              A Former User @paul53 last edited by
                              @paul53 sagte in Problem mit unzureichendem Speicherplatz:
                              @bastler sagte:
                              @bastler
                              zuerst platz machen, solange deine Platte voll ist, geht auch kein backup.. er kanns ja nicht zwischenspeichern..
                                @neuschwansteini Ich habe den Fehler entdeckt, Google Drive war zu voll! Kann mich aber nicht an eine Fehlermeldung erinnern. Es ist dann wohl so, dass das Backup auf dem lokalen Laufwerk durchgeführt wird.
                                Gibt es eine Möglichkeit über so ein Problem (Google Speicher voll) informiert zu werden?
                                Danke an alle Helfer!
                                Homoran crunchip 2 Replies Last reply Reply Quote 0
                                  ja!
                                  @homoran sagte in Problem mit unzureichendem Speicherplatz:
                                    crunchip Forum Testing Most Active @bastler last edited by
                                    Bekommt man da nicht unabhängig vom Smarthome eine Mail, da benachrichtigt dich doch Google.
                                      bastler @crunchip last edited by
                                      @crunchip Nein, nur direkt in Google Drive wurde mir angezeigt, dass nur noch 83% frei sind und ein Speichern von weiteren Dateien nicht mehr möglich ist.
                                        bastler @Homoran last edited by bastler
                                        @homoran Der Backup Vorgang läuft scheinbar nicht weiter? Google Drive ist mit 8GB belegt von 17GB. Die alten Backups im lokalen LW und auch im Google Drive habe ich gelöscht. Wenn ich direkt in Google Drive nachschaue, ist das Verzeichnis noch leer. Bin ich zu ungeduldig? Aber 700MB sollten doch in 15 Minuten locker hochgeladen werden?
                                        Habe jetzt den Vorgang gestoppt, den ioBroker neu gestartet und noch einmal den Upload angeschoben. Sieht nicht anders aus. Oben im Fenster läuft der blaue Balken von links nach rechts, mehr passiert nicht.
                                        Habe nun den Token versucht neu anzufordern, war aber nicht nötig, da der Zugriff möglich war. Allerdings schien da doch etwas geklemmt zu haben, denn danach klappte die Sicherung.
                                          mago @bastler last edited by
                                          ich hänge mich hier mal dran mit einem ähnlichen Problem. Hatte dieselbe Meldung und hab nach einiger Recherche schonmal ein paar Caches und Backups gelöscht.
                                          Nun kondensiert sich das Ganze im Wesentlichen auf Javascript:
                                              3.0 GiB [#################] /opt
                                              1.2 GiB [######           ] /usr
                                            324.5 MiB [#                ] /home
                                          . 249.2 MiB [#                ] /var
                                          .   3.2 MiB [                 ] /etc
                                          und weiter
                                          --- /opt/iobroker -----------------------------------------------------------------------------------------------------------
                                              1.4 GiB [#################] /node_modules
                                            920.9 MiB [##########       ] /iobroker-data
                                            453.7 MiB [#####            ] /backups
                                              1.5 MiB [                 ] /log
                                          In den beiden größten Foldern sind jeweils javascript Unterordner die Maßgeblichen:
                                          --- /opt/iobroker/node_modules ----------------------------------------------------------------------------------------------
                                            621.7 MiB [#################] /iobroker.javascript
                                            181.0 MiB [####             ] /canvas
                                            152.2 MiB [####             ] /iobroker.echarts
                                             84.0 MiB [##               ] /iobroker.admin
                                          und
                                          --- /opt/iobroker/iobroker-data/files ---------------------------------------------------------------------------------------
                                            616.2 MiB [#################] /javascript.admin
                                             66.2 MiB [#                ] /echarts.admin
                                             60.5 MiB [#                ] /echarts
                                          Kann mir jemand sagen woran das liegt und wie ich hier ein bisschen entschlacken kann?
                                          Vielen Dank & viele Grüße
                                          Marco
                                          • mcm1957
                                            mcm1957 @mago last edited by mcm1957
                                            @mago
                                            Such mal hier im Forum. Irgendeine JS Version belegt sehr viel Speicher. Da kannst nix direkt machen außer aktualisisern.
                                            Hab den diesbezüglichen Thread aber nicht ium Kopf.
                                            Und mit Proxmox hat das eigentlich nix zu tun ...
                                            EDIT:
                                            8.8.3 belegt 648MB
                                            https://www.npmjs.com/package/iobroker.javascript/v/8.8.3
                                            8.9.2 belehgt nur 34,8MB
                                            https://www.npmjs.com/package/iobroker.javascript/v/8.9.2
                                            Ich kann aber keinerlei Empfehlungen zum Update / Downgrade geben.
                                            2734
