    4. Tester für Zigbee Adapter 2.0.x gesucht
      dimaiv @Asgothian last edited by dimaiv
      @asgothian
      Update von 2.0.2 auf 2.0.3 und dann kamm folgender Meldung:
      2025-03-08 11:35:42.109 - info: zigbee.0 (59376) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
      2025-03-08 11:35:42.150 - warn: zigbee.0 (59376) trying to add "fz = require(../zigbee-herdsman-converters/converters/fromZigbee)" to sandbox
      2025-03-08 11:35:42.152 - error: zigbee.0 (59376) Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/fromZigbee'
      Require stack:
      - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      2025-03-08 11:35:42.153 - warn: zigbee.0 (59376) trying to add "tz = require(../zigbee-herdsman-converters/converters/toZigbee)" to sandbox
      2025-03-08 11:35:42.154 - error: zigbee.0 (59376) Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/toZigbee'
      Require stack:
      2025-03-08 11:35:42.155 - warn: zigbee.0 (59376) trying to add "exposes = require(../zigbee-herdsman-converters/lib/exposes)" to sandbox
      2025-03-08 11:35:42.155 - error: zigbee.0 (59376) Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/exposes'
      Require stack:
      2025-03-08 11:35:42.156 - warn: zigbee.0 (59376) trying to add "reporting = require(../zigbee-herdsman-converters/lib/reporting)" to sandbox
      2025-03-08 11:35:42.157 - error: zigbee.0 (59376) Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/reporting'
      Require stack:
      2025-03-08 11:35:42.162 - warn: zigbee.0 (59376) Trying to run sandbox for /opt/iobroker/iobroker-data/zigbee_0/Flower_Neu.js
      2025-03-08 11:35:42.179 - error: zigbee.0 (59376) Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/Flower_Neu.js - the code does not run: ReferenceError: exposes is not defined
      Converter sieht so aus am Anfang:
      const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
      const tz = require('zigbee-herdsman-converters/converters/toZigbee');
      const exposes = require('zigbee-herdsman-converters/lib/exposes');
      const reporting = require('zigbee-herdsman-converters/lib/reporting');
      const e = exposes.presets;
      const ea = exposes.access;
      und ich musste es ändern auf:
      const fz = require('zigbee-herdsman-converters/dist/converters/fromZigbee');
      const tz = require('zigbee-herdsman-converters/dist/converters/toZigbee');
      const exposes = require('zigbee-herdsman-converters/dist/lib/exposes');
      const reporting = require('zigbee-herdsman-converters/dist/lib/reporting');
        Shadowhunter23 @Asgothian last edited by
        @asgothian
        Gerade installiert.
          Homoran Global Moderator Administrators @Asgothian last edited by
          @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
          Das ist eigentlich nicht ok
          Hab da gerade noch etwas entdeckt!
          Vorab:
          die angemeckerten Geräte sind meine gesamten Lidl-Messteckdosen.
          Wegen des anscheinend falschen Routings hatte ich bereits angefangen einzelne gegen IKEA Inspelning zu tauschen.
          Von denen macht keine einzige Probleme.
          Aber die Lidl befinden sich (noch) im Netz.
          Hab jetzt eine Lidl aus dem System gelöscht, auf Werkseinstellungen zurückgesetzt, und wieder angelernt.
          keine Änderung!
          Habe dann gesehen, dass "configured" auf false steht.
          Das war bereits mit der 1.x so.
          und ist es auch jetzt bei allen Geräten.
          Mit dem branch der 2.0.3 von @arteck stand configured auf true!
            A Former User @Asgothian last edited by A Former User
            @asgothian
            Ich kann dich verstehen, aber dafuer muss ich mir das gesamte Logfile von heute durchforsten.. und mit Statistiken bin ich eh sowas von fern.. aber ich schau mal, was ich so herausfinde..
            Zur Zeit warnt er noch damit:
            025-03-09 16:08:04.473  - warn: zigbee.0 (2426662) DeviceConfigure:Timeout trying to configure 0x00124b002a524ccb MS01.
            2025-03-09 16:08:36.851  - info: zigbee.0 (2426662) List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
            2025-03-09 16:08:37.563  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.564  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.564  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 2 -  332242049
            2025-03-09 16:08:37.565  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.565  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 1 -  332242049
            2025-03-09 16:08:37.566  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 1 -  332242049
            2025-03-09 16:08:37.566  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.566  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: -1949790169 -  332242049
            2025-03-09 16:08:37.567  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.567  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 1 -  332242049
            2025-03-09 16:08:37.567  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: -671910541 -  -671910541
            2025-03-09 16:08:37.568  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.568  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 2 -  332242049
            2025-03-09 16:08:37.568  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: -1217940983 -  217189513
            2025-03-09 16:08:37.569  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.569  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 2 -  332242049
            2025-03-09 16:08:37.570  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.570  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 217189513 -  217189513
            2025-03-09 16:08:37.571  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.571  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 217189513 -  217189513
            2025-03-09 16:08:37.572  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.572  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 217189513 -  217189513
            2025-03-09 16:08:37.572  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: -1949790169 -  332242049
            2025-03-09 16:08:37.572  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 2 -  332242049
            2025-03-09 16:08:37.573  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 332242049 -  332242049
            2025-03-09 16:08:37.573  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 1 -  332242049
            2025-03-09 16:08:37.573  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: 217189513 -  217189513
            2025-03-09 16:08:37.573  - warn: zigbee.0 (2426662) DeviceConfigure:should configure: none -  332242049
            Edit:
            das muesste ein Tuya-Motion-Sensor sein 00124b002a524ccb wenn ich das richtig sehe im Log.. wundert mich nicht, der ist sowieso "speziell" was sein ganzes verhalten angeht.. hab irgendwo noch 10 von den Dingern, 2 sind noch im Einsatz, der rest liegt in der Kruschkiste.. 🙂
            • Asgothian
              Asgothian Developer @Homoran last edited by
              @homoran das ist eine der Änderungen von 2.0.2 auf 2.0.3 - das korrigieren des configure,mince. Der Anzeige.
              A.
              • Asgothian
                Asgothian Developer @Guest last edited by
                @neuschwansteini das ist eine Meldung die ich zum Testen da rein gepackt hab. So oft sollte die aber nicht kommen - da ist noch was faul. Ich schau mal.
                  so für alle bei den die 2.0.3 Probleme verursacht... bitte die 2.0.4 installieren...
                  wenns läuft ERSTMAL auf der 2.0.3 bleiben... bis auf weiteres
                  1 Reply Last reply Reply Quote 5
                    @asgothian
                    Habe heute Nachmittag noch mal deine Testversion installiert mit ZHC 23.4.0 , hat wieder nicht funktioniert. Nach 2 Stunden mit 14 Geräten keine Funktion mehr... CPU Last über 100%...
                    • Asgothian
                      Asgothian Developer @dimaiv last edited by
                      @dimaiv Das ist seltsam - bei mir läuft sie stabil ohne Effekte. Du hast direkt von meinem Fork dem Branch 1.11 installiert ?
                        Ja, direkt.
                        Jetzt läuft 2.0.4. überall über Nacht. Morgen werde ich deine Testversion noch mal wo anders testen.
                        • Asgothian
                          Asgothian Developer @dimaiv last edited by Asgothian
                          @dimaiv Seltsam. Tu mir mal bitte einen gefallen:
                          Patch mal das shouldConfigure so das es
                          • ins Log schreibt wenn es aufgerufen wird
                          • immer direkt ein false zurück liefert, so das keine Konfiguration gestartet wird.
                          Und dann lass den Adapter nochmal laufen. Ich vermute das sich da irgend etwas aufschaukeln könnte. Ansonsten hab ich in diesem issue bei Koenkk nachgefragt, aber er steht auch auf dem Schlauch.
                          Ein anderer Test wäre folgender : Installier von diesem Branch: https://github.com/asgothian/ioBroker.zigbee/tarball/2.0.5ZHC21. Das ist der identische Code zum branch 1.11, nur mit der dependency auf ZHC21.38.0
                          A.
                            @asgothian
                            Die 2.0.5ZHC21 läuft seit 3 Stunden stabil an 2 Orten.
                            • Asgothian
                              @dimaiv Danke. Lassen wir die mal länger laufen - und schauen wir mal ob Koenkk einen Vorschlag macht wo ich suchen kann
                              A.
                                @asgothian
                                Beim ZHC23.x könnte man schon nach 20 Minuten sehen wo die CPU Last hin geht...
                                • Asgothian
                                  @dimaiv An 2 Orten heisst auf 2 unterschiedlichen ioBrokern, sprich Du könntest eine davon zum Mitschreiben nutzen ? Dann würde ich gesondertes Logging einbauen und eine Doku machen wie du zhc austauschen kannst ohne neu zu installieren.
                                  Sofern du sagst das könntest Du probieren, natürlich. nur.Bei mir bringt es nix, die ZHC23 läuft bei mir seit 2 Tagen ohne Auffälligkeiten
                                  A.
                                    @asgothian
                                    Ja, ich würde gerne es so machen.
                                    • Asgothian
                                      Asgothian Developer last edited by
                                      @dimaiv Ich brauch leider noch etwas für die logging version - musste mich heute um was anderes erst kümmern. Ich denke morgen kann ich 2 Versionen (identisch ausser Herdsman-converters) bereitstellen
                                      A.
                                        Shadowhunter23 @Shadowhunter23 last edited by Shadowhunter23
                                        @Asgothian
                                        Heute hatte ich das wieder mit einer anderen Instanz ( Zigbee Instanz 2 ). Einige Jahre lief das ohne Probleme. Jetzt mit der 2.0.x ist zweimal doch schon oft...
                                        Firmware neu Flaschen hilft aber ist nicht wirklich gut wenn auf einmal das Netz nicht mehr geht.
                                        Im Einsatz ist immer Koordinator:
                                        https://github.com/codm/cc2652p2-tcp-zigbee
                                        @shadowhunter23 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                        @asgothian
                                        Kann man zu dieser Meldung was sagen? War auch schon in der 2.0.2 so.
                                        zigbee.3
                                        2025-03-07 15:30:07.937	error	Failed to open the network: Error: --> 'SREQ: AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,2,2,10,0,0]}}' failed with status '(0x11: BUFFER_FULL)' (expected '(0x00: SUCCESS)') at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:258:27 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1100:9) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:746:13 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.sendZclFrameToAll (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:744:16) at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:277:13) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:317:13) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:668:13)
                                        Asgothian D 2 Replies Last reply Reply Quote 0
                                        • Asgothian
                                          Asgothian Developer @Shadowhunter23 last edited by
                                          Da kann ich wenig zu sagen - ich fürchte das da entweder der Koordinator ein Problem hat oder es so starke Störungen geht das der aus dem Tritt kommt.
                                          Jedenfalls kommt die Meldung nicht aus dem Zigbee-Adapter sondern aus dem zigbee-herdsman. Da setzen wir schon die aktuelle Version ein.
                                          A.
                                            dimaiv @Shadowhunter23 last edited by dimaiv
                                            @shadowhunter23
                                            Firmware Version ?
                                            Stromversorgung beim Coordinator stabil ? Was für Netzteil?
                                            Beim Firmware flaschen wird nicht unbedingt NVRAM mit gelöscht.
                                            Ich würde dir empfehlen ein mal NVRAM zu löschen.
                                            Wichtig vorher sauber Zigbee Adapter runterfahren.
                                            Beim wiederstarten länger warten.
                                            zigbee 2.0.1
                                            50
                                            525
                                            74251
