    4. Falsche admin Version obwohl aktuell
      jwerlsdf @haselchen last edited by
      @haselchen
      Ja
        Thomas Braun Most Active @jwerlsdf last edited by
        @jwerlsdf
        Dann zeig mal die Ausgabe von
        iob diag
        in der Langfassung, damit man mal sieht wo du da überhaupt unterwegs bist.
          jwerlsdf @Thomas Braun last edited by
           Static hostname: iobroker-master
                 Icon name: computer
                    Kernel: Linux 6.6.74+rpt-rpi-2712
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     3
          Pending iob updates:    2
          Nodejs-Installation:
          /usr/bin/nodejs         v20.18.3
          /usr/bin/node           v20.18.3
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.30.0
          Recommended versions are nodejs 20.18.3 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            8.4G        3.1G        1.8G        6.8M        3.6G        5.3G
          Swap:           209M          0B        209M
          Total:          8.7G        3.1G        2.0G
          Active iob-Instances:   43
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.6.2
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                28973
          States:                 25586
          Size of iob-Database:
          33M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/states.jsonl
          Operating System is the current Debian stable version codenamed 'bookworm'!
            @jwerlsdf
            Das ist nicht die Langfassung, nicht mal die Zusammenfassung vollständig.
              ```bash
              Script v.2025-02-23
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 5 Model B Rev 1.0
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               22:29:18 up 23:16,  3 users,  load average: 0.71, 0.89, 0.92
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Mon 2025-03-10 22:29:18 CET
                         Universal time: Mon 2025-03-10 21:29:18 UTC
                               RTC time: Mon 2025-03-10 21:29:18
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            8.4G        3.2G        1.7G        6.8M        3.6G        5.2G
              Swap:           209M          0B        209M
              Total:          8.7G        3.2G        1.9G
                       8052 M total memory
                       3058 M used memory
                       3550 M active memory
                       2294 M inactive memory
                       1629 M free memory
                        237 M buffer memory
                       3227 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 22:29:18 up 23:16,  3 users,  load average: 0.71, 0.89, 0.92
              Tasks: 242 total,   2 running, 240 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8052.2 total,   1628.2 free,   3060.1 used,   3465.0 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4992.1 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem                        Type      Size  Used Avail Use% Mounted on
              udev                              devtmpfs  3.9G     0  3.9G   0% /dev
              tmpfs                             tmpfs     806M  6.3M  799M   1% /run
              /dev/sda2                         ext4       55G   19G   34G  36% /
              tmpfs                             tmpfs     4.0G     0  4.0G   0% /dev/shm
              tmpfs                             tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/sda1                         vfat      510M   76M  435M  15% /boot/firmware
              //192.168.178.39/Sicherungskopien cifs       15T  5.4T  9.1T  38% /Sicherungskopien
              //192.168.178.39/video            cifs       15T  5.4T  9.1T  38% /video
              //192.168.178.39/Küche           cifs       15T  5.4T  9.1T  38% /Kueche
              //192.168.178.39/music            cifs       15T  5.4T  9.1T  38% /music
              tmpfs                             tmpfs     806M  160K  806M   1% /run/user/1000
              [Sun Mar  9 23:12:32 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:2F:B4:2F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eb2f63c1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Sun Mar  9 23:12:33 2025] EXT4-fs (sda2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
              [Sun Mar  9 23:12:33 2025] EXT4-fs (sda2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET              SOURCE                            FSTYPE OPTIONS
              /                   /dev/sda2                         ext4   rw,noatime
              |-/boot/firmware    /dev/sda1                         vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              |-/music            //192.168.178.39/music            cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
              |-/video            //192.168.178.39/video            cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
              |-/Sicherungskopien //192.168.178.39/Sicherungskopien cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
              `-/Kueche           //192.168.178.39/K\xc3\xbcche     cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
              /var:
              2.8G    /var/
              1.3G    /var/lib
              1.1G    /var/lib/docker/overlay2
              785M    /var/log
              Archived and active journals take up 783.8M in the file system.
              /opt/iobroker/backups:
              2.2G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              890M    /opt/iobroker/iobroker-data/
              665M    /opt/iobroker/iobroker-data/files
              196M    /opt/iobroker/iobroker-data/files/vis-2
              120M    /opt/iobroker/iobroker-data/files/vis
              118M    /opt/iobroker/iobroker-data/backup-objects
              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
              16M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
              15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/118.cf753117.chunk.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              Zigbee Network Settings on your coordinator/in nvbackup are:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              To unmask the settings run 'iob diag --unmask'
              *** NodeJS-Installation ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Installed: 20.18.3-1nodesource1
                Candidate: 20.18.3-1nodesource1
                Version table:
               *** 20.18.3-1nodesource1 600
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.2-1nodesource1 600
                   20.18.1-1nodesource1 600
                   20.18.0-1nodesource1 600
                   20.17.0-1nodesource1 600
                   20.16.0-1nodesource1 600
                   20.15.1-1nodesource1 600
                   20.15.0-1nodesource1 600
                   20.14.0-1nodesource1 600
                   20.13.1-1nodesource1 600
                   20.13.0-1nodesource1 600
                   20.12.2-1nodesource1 600
                   20.12.1-1nodesource1 600
                   20.12.0-1nodesource1 600
                   20.11.1-1nodesource1 600
                   20.11.0-1nodesource1 600
                   20.10.0-1nodesource1 600
                   20.9.0-1nodesource1 600
                   20.8.1-1nodesource1 600
                   20.8.0-1nodesource1 600
                   20.7.0-1nodesource1 600
                   20.6.1-1nodesource1 600
                   20.6.0-1nodesource1 600
                   20.5.1-1nodesource1 600
                   20.5.0-1nodesource1 600
                   20.4.0-1nodesource1 600
                   20.3.1-1nodesource1 600
                   20.3.0-1nodesource1 600
                   20.2.0-1nodesource1 600
                   20.1.0-1nodesource1 600
                   20.0.0-1nodesource1 600
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker-master     iobroker-master (version: 7.0.6, hostname: iobroker-master, alive, uptime: 633)
              iobroker-slave      iobroker-slave (version: 7.0.6, hostname: iobroker-slave, alive, uptime: 1173)
              Core adapters versions
              js-controller:  7.0.6
              admin:          7.6.2
              javascript:     8.9.1
              nodejs modules from github:     1
              | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
              Adapter State
              + system.adapter.backitup.0               : backitup              : iobroker-master                          -  enabled
              + system.adapter.bring.0                  : bring                 : iobroker-master                          -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker-master                          -  enabled
              + system.adapter.deconz.0                 : deconz                : iobroker-master                          -  enabled, port: 6060
              + system.adapter.denon.0                  : denon                 : iobroker-master                          -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker-master                          -  enabled
                system.adapter.dwd.0                    : dwd                   : iobroker-master                          -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-master                          -  enabled
              + system.adapter.eusec.0                  : eusec                 : iobroker-master                          -  enabled
                system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
              + system.adapter.firetv.0                 : firetv                : iobroker-master                          -  enabled
                system.adapter.flot.0                   : flot                  : iobroker-master                          - disabled
              + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-master                          -  enabled
              + system.adapter.heos.0                   : heos                  : iobroker-master                          -  enabled
                system.adapter.history.0                : history               : iobroker-master                          - disabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
              + system.adapter.homeconnect.0            : homeconnect           : iobroker-master                          -  enabled
                system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
                system.adapter.ical.1                   : ical                  : iobroker-master                          -  enabled
                system.adapter.ical.2                   : ical                  : iobroker-master                          -  enabled
                system.adapter.ical.3                   : ical                  : iobroker-master                          -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-master                          - disabled
              + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-master                          -  enabled, port: 54321
              + system.adapter.modbus.0                 : modbus                : iobroker-master                          -  enabled
              + system.adapter.modbus.1                 : modbus                : iobroker-master                          -  enabled
              + system.adapter.modbus.2                 : modbus                : iobroker-master                          -  enabled
              + system.adapter.mpd.0                    : mpd                   : iobroker-master                          -  enabled, port: 6600
              + system.adapter.netatmo.0                : netatmo               : iobroker-master                          -  enabled
              + system.adapter.nina.0                   : nina                  : iobroker-master                          -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : iobroker-master                          -  enabled
              + system.adapter.radar2.0                 : radar2                : iobroker-master                          -  enabled
              + system.adapter.rssfeed.0                : rssfeed               : iobroker-master                          -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 192.168.178.70
              + system.adapter.smartgarden.0            : smartgarden           : iobroker-master                          -  enabled
              + system.adapter.sonos.0                  : sonos                 : iobroker-master                          -  enabled
              + system.adapter.synochat.0               : synochat              : iobroker-master                          -  enabled
              + system.adapter.synology.0               : synology              : iobroker-master                          -  enabled, port: 5000
              + system.adapter.synology.1               : synology              : iobroker-master                          -  enabled, port: 5000
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-master                          -  enabled
              + system.adapter.telegram.0               : telegram              : iobroker-master                          -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.time-switch.0            : time-switch           : iobroker-master                          -  enabled
              + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker-master                          -  enabled
              + system.adapter.trashschedule.1          : trashschedule         : iobroker-master                          -  enabled
                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker-master                          -  enabled
                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker-master                          -  enabled
                system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker-master                          -  enabled
                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker-master                          -  enabled
                system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker-master                          -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : iobroker-master                          -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-master                          - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-master                          - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-master                          - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-master                          - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-master                          - disabled
                system.adapter.vis-metro.0              : vis-metro             : iobroker-master                          - disabled
                system.adapter.vis-players.0            : vis-players           : iobroker-master                          - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-master                          - disabled
                system.adapter.vis.0                    : vis                   : iobroker-master                          -  enabled
              + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-master                          -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker-master                          -  enabled
              + system.adapter.wled.0                   : wled                  : iobroker-master                          -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): beta
              Installed ioBroker-Adapters
              Used repository: beta
              Adapter    "admin"        : 7.6.2    , installed 7.6.2
              Adapter    "backitup"     : 3.1.0    , installed 3.1.0
              Adapter    "bring"        : 1.9.1    , installed 1.9.1
              Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
              Adapter    "deconz"       : 1.6.4    , installed 1.6.4
              Adapter    "denon"        : 1.15.12  , installed 1.15.12
              Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
              Adapter    "eusec"        : 1.3.3    , installed 1.3.3
              Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
              Adapter    "firetv"       : 2.1.0    , installed 2.1.0
              Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
              Adapter    "heos"         : 2.2.4    , installed 2.2.4
              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
              Adapter    "ical"         : 1.16.1   , installed 1.16.1
              Adapter    "javascript"   : 8.9.1    , installed 8.9.1
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "mihome-vacuum": 5.2.0    , installed 4.2.0  [Updatable]
              Adapter    "modbus"       : 6.4.0    , installed 6.4.0
              Adapter    "mpd"          : 2.2.0    , installed 2.2.0
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "nina"         : 0.0.26   , installed 0.0.26
              Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
              Adapter    "radar2"       : 2.2.0    , installed 2.2.0
              Adapter    "rssfeed"      : 3.4.1    , installed 3.4.1
              Adapter    "shelly"       : 9.1.0    , installed 9.1.0
              Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
              Adapter    "socketio"     : 7.0.8    , installed 7.0.8
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "synochat"     : 1.3.3    , installed 1.3.3
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "telegram"     : 4.0.0    , installed 4.0.0
              Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "trashschedule": 4.0.0    , installed 3.4.1  [Updatable]
              Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
              Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
              Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
              Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
              Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
              Adapter    "vis-2-widgets-weather-and-heating": 0.10.0, installed 0.10.0
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "web"          : 7.0.6    , installed 7.0.6
              Adapter    "wled"         : 0.7.3    , installed 0.7.3
              Adapter    "ws"           : 3.0.19   , installed 3.0.19
              Objects and States
              Objects:        28973
              States:         25586
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://download.docker.com/linux/debian bookworm InRelease
              Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 3
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          6896       1485/docker-proxy
              tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       1139990    47089/adb
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          66615      4529/cupsd
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1138522    46787/iobroker.js-c
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1138527    46787/iobroker.js-c
              tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      1000       9834       1618/node
              tcp        0      0 0.0.0.0:5004            0.0.0.0:*               LISTEN      0          17409      2630/node
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8478       944/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          6898       1497/docker-proxy
              tcp        0      0 192.168.178.70:2010     0.0.0.0:*               LISTEN      1001       1140107    47229/io.hm-rpc.1
              tcp        0      0 192.168.178.70:2001     0.0.0.0:*               LISTEN      1001       1139642    47214/io.hm-rpc.0
              tcp        0      0 192.168.178.70:1882     0.0.0.0:*               LISTEN      1001       1140290    47385/io.shelly.0
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          66614      4529/cupsd
              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1141895    47141/io.fullybrows
              tcp6       0      0 :::8000                 :::*                    LISTEN      0          6897       1491/docker-proxy
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1145040    47812/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1138562    46805/io.admin.0
              tcp6       0      0 :::3502                 :::*                    LISTEN      1001       1142215    47400/io.sonos.0
              tcp6       0      0 :::3501                 :::*                    LISTEN      1000       10351      1618/node
              tcp6       0      0 :::3500                 :::*                    LISTEN      0          17411      2630/node
              tcp6       0      0 :::22                   :::*                    LISTEN      0          8480       944/sshd: /usr/sbin
              tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1143323    47595/go2rtc
              tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1143322    47595/go2rtc
              tcp6       0      0 :::5900                 :::*                    LISTEN      992        8491       906/wayvnc
              tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1140542    47595/go2rtc
              tcp6       0      0 :::9443                 :::*                    LISTEN      0          6899       1504/docker-proxy
              udp        0      0 0.0.0.0:57268           0.0.0.0:*                           1001       1139624    46847/io.javascript
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1142167    47349/io.radar2.0
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1143144    47508/io.mihome-vac
              udp        0      0 0.0.0.0:37608           0.0.0.0:*                           1001       1139614    47184/io.heos.0
              udp        0      0 0.0.0.0:41971           0.0.0.0:*                           1001       1139625    46847/io.javascript
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1145884    47827/io.wled.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7643       710/avahi-daemon: r
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1139410    46915/io.deconz.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1139406    46915/io.deconz.0
              udp        0      0 0.0.0.0:55930           0.0.0.0:*                           1001       1139613    47184/io.heos.0
              udp        0      0 0.0.0.0:52219           0.0.0.0:*                           1001       1142496    47569/io.eusec.0
              udp        0      0 0.0.0.0:52298           0.0.0.0:*                           104        7645       710/avahi-daemon: r
              udp6       0      0 :::8555                 :::*                                1001       1143324    47595/go2rtc
              udp6       0      0 fe80::2188:5528:66b:546 :::*                                0          6676       831/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        7644       710/avahi-daemon: r
              udp6       0      0 :::55035                :::*                                104        7646       710/avahi-daemon: r
              udp6       0      0 :::1900                 :::*                                1001       1139412    46915/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       1139411    46915/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       1139409    46915/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       1139408    46915/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       1139407    46915/io.deconz.0
              2025-03-10 22:21:59.781  - info: vis-2.0 (47857) vis-2 license is OK.
              2025-03-10 22:22:00.486  - info: weather-warnings.0 (47842) Refresh Interval: 15 minutes
              2025-03-10 22:22:00.557  - info: weather-warnings.0 (47842) [telegram] Create notification service telegram adapter: telegram.0.
              2025-03-10 22:22:00.558  - info: weather-warnings.0 (47842) DWD 106631000 activated. Retrieve data.
              2025-03-10 22:22:00.563  - info: weather-warnings.0 (47842) UWZ activated. Retrieve data.
              2025-03-10 22:22:01.806  - info: host.iobroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 47877
              2025-03-10 22:22:02.317  - info: wled.0 (47827) WLED initialisation finalized, ready to do my job have fun !
              2025-03-10 22:22:02.528  - info: web.0 (47812) ==> Connected system.user.admin from ::ffff:192.168.178.52
              2025-03-10 22:22:03.550  - info: energiefluss-erweitert.0 (47877) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.3, js-controller: 7.0.6
              2025-03-10 22:22:03.603  - info: energiefluss-erweitert.0 (47877) Adapter started. Loading config!
              2025-03-10 22:22:04.394  - info: energiefluss-erweitert.0 (47877) Configuration loaded!
              2025-03-10 22:22:04.395  - info: energiefluss-erweitert.0 (47877) Requesting the following states: energiefluss-erweitert.0.configuration,modbus.1.inputRegisters.1.13033_Total_active_power,modbus.1.inputRegisters.1.13021_Battery_power,modbus.1.inputRegisters.1.13022_Battery_level,modbus.1.inputRegisters.1.13001_Daily_PV_Generation,modbus.1.inputRegisters.1.13002_Total_PV_Generation,modbus.1.inputRegisters.1.5016_Total_DC_Power,modbus.1.inputRegisters.1.13004_Daily_export_energy_from_PV,modbus.1.inputRegisters.1.13005_Total_export_energy_from_PV,modbus.1.inputRegisters.1.13009_Export_power,modbus.1.inputRegisters.1.13007_Load_power,modbus.1.inputRegisters.1.13035_Daily_Import_Energy,modbus.1.inputRegisters.1.13036_Total_Import_Energy,modbus.1.inputRegisters.1.13044_Daily_export_energy,modbus.1.inputRegisters.1.13045_Total_export_energy
              2025-03-10 22:24:25.847  - info: host.iobroker-master iobroker del admin --debug
              2025-03-10 22:24:26.748  - info: host.iobroker-master iobroker Delete adapter "admin"
              2025-03-10 22:24:26.796  - info: host.iobroker-master iobroker host.iobroker-master Counted 1 instances of admin
              2025-03-10 22:24:26.864  - info: host.iobroker-master iobroker Cannot remove adapter "admin", because instance "backitup" depends on it!
              2025-03-10 22:24:26.898  - info: homeconnect.0 (47244) 484030535042007636/programs/selected/options: There is no program selected.
              2025-03-10 22:24:27.880  - info: host.iobroker-master iobroker exit 47
              2025-03-10 22:24:33.319  - info: admin.0 (46805) <== Disconnect system.user.admin from ::ffff:192.168.178.86 admin
              2025-03-10 22:24:33.833  - info: admin.0 (46805) ==> Connected system.user.admin from ::ffff:192.168.178.86
              2025-03-10 22:24:41.165  - info: admin.0 (46805) <== Disconnect system.user.admin from ::ffff:192.168.178.86 admin
              2025-03-10 22:25:14.011  - info: host.iobroker-master instance system.adapter.dwd.0 in version "2.8.5" started with pid 48041
              2025-03-10 22:25:15.071  - info: dwd.0 (48041) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
              2025-03-10 22:25:15.499  - info: dwd.0 (48041) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2025-03-10 22:25:16.010  - info: host.iobroker-master instance system.adapter.dwd.0 having pid 48041 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              iob diag has finished.
                @jwerlsdf
                Am Rande: Deine CIFS-Freigaben hängen da falsch und SMB=1.0 ist hoffentlich falsch.
                iob update
                iob upgrade all
                • BananaJoe
                  BananaJoe Most Active @jwerlsdf last edited by
                  @jwerlsdf sagte in Falsche admin Version obwohl aktuell:
                  Hallo, ich kann keinen neuen Adapter mehr installieren, da der Admin wohl zu alt ist.
                  Ich bekomme folgenden Fehler
                  Invalid version of admin. Required >=7.4.10. Current 6.17.14
                  Installiert ist aber folgendes:
                  Verfügbare Version:
                  7.6.2
                  Installierte Version:
                  7.6.2
                  Iob fix funktioniert leider nicht. Was kann ich noch machen?
                  Welchen Adapter versuchst du denn zu installieren?
                  Dein diag sah - für mich - erst einmal ok aus.
                    jwerlsdf @BananaJoe last edited by
                    @bananajoe
                    Schulferien
                    Jetzt klappt es auf einmal. Keine Ahnung woran es genau gelegen hat. Danke trotzdem für die Hilfe. Hoffentlich bleibt es auch dabei, dass es funktioniert.
                      Homoran Global Moderator Administrators @jwerlsdf last edited by
                      hast du multihost?
                      wie ist die admin version auf dem slave?
                        jwerlsdf @Homoran last edited by
                        Oh danke. Habe tatsächlich die 6er Version installiert gehabt. Habe dort das upgrade ebenfalls durchgeführt. Ich benutze den slave so selten, dass ich es total vergessen habe.
                          @jwerlsdf
                          Ein Slave hat auch keinen eigenen Admin. Der wird 'leer' an die Hauptinstallation angekoppelt und dann über dessen Admin-Instanz verwaltet.
                            wieder ein Grund mehr, den Slave ohne jede Instanz aufzusetzen.
                              Wird nicht der admin beim slave mit installiert? War bei mir so gewesen...
                                @jwerlsdf
                                Jein. Zunächst ist das ja erstmal eine volle Installation mit den vorinstallierten Adaptern.
                                Wenn diese Installation zum Nebensystem 'degradiert' wird schmeißt man alle Adapter raus und dockt dann diese leere Hülle an das führende System an. Und dann kann man die Instanzen verscheiben oder bei Neuinstallationen direkt das Nebensystem als Ziel angeben.
                                  und backitup und discovery.
                                  Die kann man aber wieder vor der Kopplung löschen.
                                  Das mache ich schon lange so.
                                    Ergo kann ich über den Befehl iobroker del adapter alle löschen einschließlich admin?
                                      ja!
                                      Aber nur auf dem zukünftigen Slave vor der Kopplung
                                      969
