    4. [Vorlage] Script für automatisches Backup steuerbar durch VIS
    • Webranger
      Webranger last edited by
      hab auch die 1.0.4
      [{"tpl":"tplJquiInputDatetime","data":{"oid":"javascript.0.System.Iobroker.Backup.komplett.BackupZeit_Montag","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"timeOnly":true,"hideSeconds":true,"size":"1","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"797px","top":"92px","width":"60px","height":"","z-index":"2","font-weight":"bold"},"widgetSet":"jqui"}]
      • Peoples
        Peoples last edited by
        Schaut bei mir ganz normal aus, hast du vielleicht in deinem Projekt irgenwo Css - mäßig was definiert das hierrauf evtl. Auswirkungen hat?
        Wenn du noch das Main-Projekt hast könntest du es dort mal importieren und schauen wie es aussieht.
          Adnim last edited by
          hab es auch gerade installiert läuft klasse.
          Hatte aber auch anfangs die komische anzeige.
          Man muss unter Allgemein die Size von 1 erhöhen und nicht unten bei Css-allgemein.
          Danke für das Skript!!
          • Webranger
            Aaaaah DANKE das war es!
            Perfekt dann ist das erstmal erledigt und ich kann mir was neues ausdenken 😉
              eXTreMe last edited by
              @peoples:
              @eXTreMe:
              Das klappt!!!
              Wo liegt denn dann nun der Fehler? `
              Dann machen wir mal weiter, geh mal in das JavaScript und schreibe bspw. in Zeile 110 folgendes:
              backup_erstellen('komplett','','10','192.168.10.30','backup/ioBroker/','iobroker','DeinPasswort');
              Dann auf Speichern. Dadurch wird die Funktion backup_erstellen mit den angegebenen Parametern aufgerufen und führt die backup.sh aus.
              Auch hier wieder PW ändern und sagen was passiert. `
              Danke für deine Hilfe! habe den Fehler gefunden:
              Nach dem einfügen der Zeile gab es in log eine Meldung, dass das exec kommando in den javascript adapter settings aktiviert sein muss, ich hatte heute erst den javascript adapter geupdated, in der alten version (3.4.0 meine ich hatte ich davor) gab es diese einstellung nicht, da hatte ich nämlich auch schon mal nachgeschaut die tage.
              Haken rein und läuft.
              Am besten erwähnst du noch in deinem ersten Posting, dass die aktuelle version des Javascript adapters erforderlich ist.
              Danke nochmal!
              • Peoples
                erledigt!
                Danke für die Info
                • O
                  olifall last edited by
                  ich habe das Backup erfolgreich installieren können, erstmal danke für die tolle Arbeit.
                  Nach dem alles lief wollte ich es genauer austesten und habe ein komplettes und ein paar kleine Backups gemacht. Nach jedem Backup habe ich auf der Konsole geschaut ob es auch sicher vorhanden ist. Zum Glück habe ich das komplette auch mal auf mein NAS rüber geschoben, denn nach dem 7 kleinen Backup ist mein Raspi plötzlich nicht mehr erreichbar gewesen. Auch nach mehrmaligem Neustart komme ich nicht mehr drauf. (Wollte doch nur die 10 Versionen testen)
                  Nun zu meiner Frage, hat schon mal jemand ein Backup zurück gespielt?
                  Wenn ich das mache und es ohne Fehler durchgelaufen ist, hat sich im ioBroker nichts geändert ist immer noch gleich wie nach der Neuinstallation. Gemacht habe ich das so wie am Anfang geschrieben,
                  mit "tar -xzvf …...........
                  Gruss Oli
                  • O
                    ich habe den Fehler gefunden.
                    Der Befehl lautet nicht so: tar -xzvf Backupname.tar.gz -C /euer Iobroker Verzeichnis
                    Es muss vom root Verzeichnis aus so eingegeben werden: tar -xzvf Backupname.tar.gz -C /
                    Bei mir ist das ioBroker Verzeichnis hier: "/opt/iobroker und im Backup steht er auch genau so drin. Mit dem oberen Befehl wurde mir unter dem ioBroker Verzeichnis ein weiteres ioBroker Verzeichnis angelegt.
                    Gruss Oli
                    • Peoples
                      Hi Oli,
                      ich kam gestern Abend in die Verlegenheit ein komplettes Backup wiederherstellen zu müssen, habe auch gemerkt dass der Befehl so wie du es bereits klargestellt hast berichtigt werden muss.
                      Ich konnte das ganze Backup einspielen und dann den iobroker wieder starten, hat das bei dir auch geklappt?
                      Werde den Befehl im ersten Post sofort berichtigen war nur gestern ein bisschen angespannt und hatte keine Lust mehr :lol:
                      Danke für den Hinweis!
                      • Peoples
                        @olifall:
                        (Wollte doch nur die 10 Versionen testen) `
                        Hast du 10 komplette oder 10 normale gemacht bevor er abgeschmiert ist?
                        Ich wüsste jetzt nicht warum das passiert ist, da ich keinen Raspberry benutze kann ich das mal auf die schnelle auch nicht reproduzieren, werde aber bei Gelegenheit mal einen Raspberry mit einem Image füttern und versuchen das nachzustellen.
                        • O
                          Hallo Steffen,
                          bei mir hat es jetzt funktioniert. 🙂
                          Folgendes konnte ich auch noch feststellen und zwar zwei mal, habe den Raspi zwei mal installiert. 🙂
                          Nach erfolgreichem zurückspielen vom Backup konnte ich den ioBroker starten aber nicht per Web darauf zugreifen.
                          Dann habe ich folgendes gemacht:
                          sudo iobroker status
                          Meldung = "No connection to states 127.0.0.0:6379[redis]"
                          sudo apt-get install redis-server
                          Danach lief es wieder und meine Daten waren da. 🙂
                          @Hatte ein komplettes und erst 6 Normale, nach dem 7ten ist er dann abgeschmiert. Was ich aber sagen muss vor dem testen hatte es geklappt.
                          Ich habe in der "backup.sh" Datein folgendes hinzugefügt: sudo mount -t cifs //IP-Adresse vom Nas/Share /media/nas/ -o username=????????,password=???????
                          und dann noch einen "scp" kopie Befehl der mir dann die Backups auf mein NAS schiebt. (Das war mein Glück, dadurch hatte ich ein Komplettes Backup)
                          Hat funktioniert bin mir aber nicht sicher ob das der richtige Weg ist, ich bin eigentlich ein Windows User. 🙂
                          Gruss Oli
                          • Peoples
                            Das kopieren auf den Nas macht doch das Script auch so?
                            Oder wolltest du anstelle des lftp-Befehls lieber den Kopiervorgang über scp machen?
                            • O
                              das mit dem Script habe ich nicht hinbekommen.
                              Kannst Du mir sagen wie ich das im Script richtig eintragen muss damit es funktioniert, das mit dem FTP hat nicht geklappt.
                              Gruss Oli
                              • Peoples
                                    Backup[1] = [];
                                    Backup[1][0] = 'komplett';                        // Backup Typ (nicht verändern)
                                    Backup[1][1] = '';                                   // Names Zusatz, wird an den Dateinamen angehängt bspw. Master/Slave (falls gewünscht, ansonsten leer lassen)
                                    Backup[1][2] = '10';                                // Alte Backups löschen nach X Tagen (falls gewünscht, ansonsten leer lassen)
                                    Backup[1][3] = '192.168.10.30';                // FTP-Host
                                    Backup[1][4] = 'backup/ioBroker/';             // genaue Verzeichnissangabe bspw. /volume1/Backup/ auf FTP-Server (falls gewünscht, ansonsten leer lassen)
                                    Backup[1][5] = 'iobroker';                         // Username für FTP - Verbindung
                                    Backup[1][6] = 'xxxx';                              // Passwort für FTP - Verbindung
                                Was hast du für einen Nas? Hast du ein spezielles Verzeichnis einen speziellen user?
                                • O
                                  das habe ich schon versucht, geht leider nicht. Mein NAS ist ein QNAP TS-219P, getestet mit einer normalen Freigabe und einem User mit Admin Rechten.
                                  Diesen Fehler konnte ich gestern nach einer erneuten Installation auf einem anderen Raspi wieder nachstellen:
                                  ****Nach erfolgreichem zurückspielen vom Backup konnte ich den ioBroker starten aber nicht per Web darauf zugreifen.
                                  sudo apt-get install redis-server****
                                  Gruss Oli
                                  • Peoples
                                    Ich habe gestern mal ein komplettes Backup meiner VM auf einem Raspberry mit einem Stretch image aus dem Downloadbereich der IoBroker HP "zurückgespielt" danach hab ich noch iobroker über putty gestartet und alles lief ganz normal hoch inkl. dem Webinterface.
                                    Aber es ist ein super Hinweis, dass wenn man auf das Webinterface keinen Zugriff hat man mit deiner Lösung wieder alles zum laufen bekommt. Habe diesen ebenfalls im ersten Post aufgenommen.
                                    Wegen dem Zugriff auf die Nas kann ich leider nicht weiterhelfen hab eine Synology, dort habe ich den User eingestellt und das Pw. Dann Script gestartet und alles lief inkl. dem lftp - Transfer. Ich sichere alle zwei Tage via IoBroker Backup und einmal im Monat ein Komplettes und bisher tut es stetig seinen Dienst.
                                    • O
                                      Hallo Steffen,
                                      alles klar, vielen Dank.
                                      Gruss Oli
                                      • Webranger
                                        Werden bei Dir die Dateien auf dem FTP auch gelöscht (älter als 10 tage)?
                                        Auf meinem raspi wird ordentlich gelöscht. Auf dem FTP seh ich das noch nicht
                                        • Peoples
                                          ne auf dem FTP nicht, das Backupscript löscht nur auf dem Raspberry. Wenn du sowas möchtest müsste man das noch einbauen.
                                          • Webranger
                                            Ist das aufwendig?
                                            Aufwand und nutzen!? Theoretisch kann man auch regelmäßig von Hand löschen, aber schön wäre es schon wenn es automatisch geht.
                                            283
                                            53910
