    4. RGB Controller mit Iobroker steuern
      A Former User last edited by
      @tourer4778
      Iobroker und Controller im gleichen Netzwerk?
      Udp muss auf dem port in der config gehen.
        tourer4778 @wendy2702 last edited by tourer4778
        @wendy2702
        Er steht auf MiLightRGB, da er hier Einträge im Log macht. Bei den anderen Typen erscheint nichts im Log.
        Das Schätzchen ist sicher auch schon 12 Jahre alt. Ich bin mir nicht sicher, ob es überhaupt kompatibel ist.
        2025-03-17 06:29:26.013 - info: cloud.0 (3220946) User accessed from cloud: vMVR-fTCzHs78BeFA_WY
        2025-03-17 06:29:32.113 - info: cloud.0 (3220946) received all objects
        2025-03-17 06:29:44.205 - info: cloud.0 (3220946) received all objects
        2025-03-17 06:29:45.998 - error: wifilight.0 (3147340) uncaught exception: Cannot read properties of undefined (reading 'length')
        2025-03-17 06:29:46.000 - error: wifilight.0 (3147340) TypeError: Cannot read properties of undefined (reading 'length')
        at compareArrays (/opt/iobroker/node_modules/iobroker.wifilight/lib/dontBeSoSoef.js:613:30)
        at WifiLight.exec (/opt/iobroker/node_modules/iobroker.wifilight/main.js:896:44)
        at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.wifilight/main.js:902:91)
        at listOnTimeout (node:internal/timers:581:17)
        at processTimers (node:internal/timers:519:7)
        2025-03-17 06:29:46.000 - error: wifilight.0 (3147340) Cannot read properties of undefined (reading 'length')
        2025-03-17 06:29:46.014 - info: wifilight.0 (3147340) terminating
        2025-03-17 06:29:46.015 - warn: wifilight.0 (3147340) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-03-17 06:29:46.318 - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'length')
        2025-03-17 06:29:46.318 - error: host.raspberrypi Caught by controller[0]: at compareArrays (/opt/iobroker/node_modules/iobroker.wifilight/lib/dontBeSoSoef.js:613:30)
        2025-03-17 06:29:46.318 - error: host.raspberrypi Caught by controller[0]: at WifiLight.exec (/opt/iobroker/node_modules/iobroker.wifilight/main.js:896:44)
        2025-03-17 06:29:46.318 - error: host.raspberrypi Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.wifilight/main.js:902:91)
        2025-03-17 06:29:46.318 - error: host.raspberrypi Caught by controller[0]: at listOnTimeout (node:internal/timers:581:17)
        2025-03-17 06:29:46.319 - error: host.raspberrypi Caught by controller[0]: at processTimers (node:internal/timers:519:7)
        2025-03-17 06:29:46.319 - error: host.raspberrypi instance system.adapter.wifilight.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-03-17 06:29:46.319 - info: host.raspberrypi Restart adapter system.adapter.wifilight.0 because enabled
        @Neuschwansteini
        Ja, ist im gleichen Netzwerk. Port ist der gleiche.
          Homoran Global Moderator Administrators @tourer4778 last edited by
          @tourer4778 sagte in RGB Controller mit Iobroker steuern:
          kann ich nichts steuern
          wie versuchst du denn das steuern genau?
            tourer4778 @Homoran last edited by
            In dem ich versuche ein DP wie zum Beispiel "brightness" etwas ändere.
            Codierknecht Homoran 2 Replies Last reply Reply Quote 0
            • Codierknecht
              Codierknecht Developer Most Active @tourer4778 last edited by
              Das machst Du natürlich ohne Bestätigung?
              Ändert sich denn z.B. der DP on, wenn Du auf anderem Weg ein- oder ausschaltest?
                tourer4778 @Codierknecht last edited by tourer4778
                @codierknecht
                Nein, bei on ändert sich nichts ...
                Als wenn ich gar keine Verbindung zum Cotoller habe. Gefunden hat er Ihn aber beim suchen.
                  wie genau??
                  @codierknecht sagte in RGB Controller mit Iobroker steuern:
                  oder?
                    A Former User @tourer4778 last edited by
                    @tourer4778 alternativ dazu.. wenn das Teil so alt ist.. koennte ein ESP8266 verbaut sein, der freut sich, wenn er Tasmota als Firmware bekommt.. damit bist du dann mit dem Sonoff-Adapter bestens beraten..
                    Meist haben die alten mit so einem grossen Gehaeuse sogar noch die Pins aufgedruckt, an die man zum flashen muss..
                      tourer4778 @Homoran last edited by tourer4778
                      Ich ändere den Wert (Ohne bestätigung).
                      Bestätigung habe bisher immer ignoriert 😰 .
                      Wenn ich daheim bin, teste ich mal mit der Bestätigung.
                      Was genau muss ich bei dem Typen eintragen?
                      @neuschwansteini
                      Was verbaut ist, kann ich nicht sagen.
                      ? Homoran Codierknecht 3 Replies Last reply Reply Quote 0
                        @neuschwansteini
                        ok, dann vergiss das was ich geschrieben habe.
                        Wenn er denn Werte vom Controller lesen kann, sollte doch auch schreiben funktionieren..??
                        Oder hast du die Werte in den Datenpunkten per Hand eingetragen?
                        (von deinem Foto von den States)
                          brauchst du nicht.
                          Das wäre falsch
                          du könntest aber die Instanz mal auf Logstufe debug stellen und dann das debug-log beim Versenden des Wertes posten
                          • Codierknecht
                            Codierknecht Developer Most Active @tourer4778 last edited by Codierknecht
                            Nein - das hilft erst recht nicht.
                            Eine Änderung "ohne Bestätigung" ist für einen Adapter der Hinweis, dass er etwas zu tun hat.
                            Ändert man DP eines Adapters mit Bestätigung, macht der gar nix.
                            Ich vermute, dass etweder das "erkannte" Gerät ein false-positive ist und ein Adapter installiert wurde, der mit dem Gerät entweder nix anfangen kann oder dass die Einstellungen der Instanz nicht korrekt sind.
                              Der Controller wurde eingeschaltet (mit Strom versorgt) und das wurde erkannt, bzw. er hat sofort Connected.
                              Änderungen wurde nicht übernommen, wie zB On True / False
                              2025-03-17 12:44:38.535 - debug: wifilight.0 (3278552) [192.168.178.122] onClose hasError=true client=192.168.178.122:5577
                              2025-03-17 12:44:45.350 - debug: wifilight.0 (3278552) [192.168.178.122] 192.168.178.122 connected
                              2025-03-17 12:44:45.351 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:44:45.352 - debug: wifilight.0 (3278552) self.client.connect: connected
                              2025-03-17 12:44:45.363 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:45:15.352 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:45:15.363 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:45:45.353 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:45:45.364 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:45:51.961 - debug: wifilight.0 (3278552) [192.168.178.122] write: 71 24 0f a4
                              2025-03-17 12:45:51.972 - debug: wifilight.0 (3278552) [192.168.178.122] sending refresh...
                              2025-03-17 12:45:51.972 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:45:51.972 - debug: wifilight.0 (3278552) [192.168.178.122] write: 71 24 0f a4
                              2025-03-17 12:46:15.354 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:46:15.364 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:46:17.723 - info: cloud.0 (3248787) received all objects
                              2025-03-17 12:46:45.356 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:46:45.366 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:47:15.356 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:47:15.367 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:47:45.358 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:47:45.369 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:48:15.359 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:48:15.370 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:48:45.360 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:48:45.371 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:49:15.168 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 07 07 07 ff 00 0f 54
                              2025-03-17 12:49:15.179 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 0e 0e 0e ff 00 0f 69
                              2025-03-17 12:49:15.189 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 14 14 14 ff 00 0f 7b
                              2025-03-17 12:49:15.200 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 1b 1b 1b ff 00 0f 90
                              2025-03-17 12:49:15.211 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 22 22 22 ff 00 0f a5
                              2025-03-17 12:49:15.221 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 29 29 29 ff 00 0f ba
                              2025-03-17 12:49:15.232 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 30 30 30 ff 00 0f cf
                              2025-03-17 12:49:15.242 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 36 36 36 ff 00 0f e1
                              2025-03-17 12:49:15.252 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 3d 3d 3d ff 00 0f f6
                              2025-03-17 12:49:15.261 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 44 44 44 ff 00 0f 0b
                              2025-03-17 12:49:15.271 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 4b 4b 4b ff 00 0f 20
                              2025-03-17 12:49:15.281 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 52 52 52 ff 00 0f 35
                              2025-03-17 12:49:15.292 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 58 58 58 ff 00 0f 47
                              2025-03-17 12:49:15.303 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 5f 5f 5f ff 00 0f 5c
                              2025-03-17 12:49:15.313 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 66 66 66 ff 00 0f 71
                              2025-03-17 12:49:15.324 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 6d 6d 6d ff 00 0f 86
                              2025-03-17 12:49:15.334 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 74 74 74 ff 00 0f 9b
                              2025-03-17 12:49:15.344 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 7a 7a 7a ff 00 0f ad
                              2025-03-17 12:49:15.355 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 81 81 81 ff 00 0f c2
                              2025-03-17 12:49:15.366 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 88 88 88 ff 00 0f d7
                              2025-03-17 12:49:15.377 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 8f 8f 8f ff 00 0f ec
                              2025-03-17 12:49:15.388 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 96 96 96 ff 00 0f 01
                              2025-03-17 12:49:15.398 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 9c 9c 9c ff 00 0f 13
                              2025-03-17 12:49:15.408 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 a3 a3 a3 ff 00 0f 28
                              2025-03-17 12:49:15.419 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 aa aa aa ff 00 0f 3d
                              2025-03-17 12:49:15.429 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 b1 b1 b1 ff 00 0f 52
                              2025-03-17 12:49:15.440 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 b8 b8 b8 ff 00 0f 67
                              2025-03-17 12:49:15.450 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 be be be ff 00 0f 79
                              2025-03-17 12:49:15.461 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 c5 c5 c5 ff 00 0f 8e
                              2025-03-17 12:49:15.471 - debug: wifilight.0 (3278552) [192.168.178.122] write: 31 cc cc cc ff 00 0f a3
                              2025-03-17 12:49:15.482 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:49:15.493 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:49:45.362 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:49:45.373 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:49:46.955 - debug: wifilight.0 (3278552) [192.168.178.122] write: 71 23 0f a3
                              2025-03-17 12:49:46.967 - debug: wifilight.0 (3278552) [192.168.178.122] sending refresh...
                              2025-03-17 12:49:46.967 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:49:46.968 - debug: wifilight.0 (3278552) [192.168.178.122] write: 71 23 0f a3
                              2025-03-17 12:50:15.363 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                              2025-03-17 12:50:15.373 - debug: wifilight.0 (3278552) [192.168.178.122] write: 81 8a 8b 96
                                sehe ich im log nicht.
                                nur
                                was schreibt denn da die ganzen HEX Befehle?
                                  @homoran sagte in RGB Controller mit Iobroker steuern:
                                  Das meinte ich damit. Der Controller wird bei mir ganz Spannungsfrei geschaltet, wenn ich das Licht aus mache.
                                  Der Adapter? Ich weiß es nicht.
                                    so geht das nicht!
                                    Smart Beleuchtung muss immer "unter Strom" stehen.
                                      Das mag sein und wenn es sein muss, werde ich das noch ändern. Aber dezeit will ich erst einma eine Verbindung herstellen.
                                        @tourer4778
                                        aber mit Licht-an und Licht-aus spielchen setzt du den schnell mal zurueck, dann hat er kein Wifi mehr verbunden...
                                        Also einbinden, online lassen, nicht ausschalten.
                                        Sonst brauchen wir hier nicht weiter machen, da Sinnlos...
                                        T 1 Reply Last reply Reply Quote 2
                                          tourer4778 @Guest last edited by
                                          Das ist der Controller. Ein ESP8266 ist das denke nicht, oder?
                                            @tourer4778
                                            Das ist def. Kein ESP, da geht nix zu flashen..
                                            Die App dazu heißt Cloud Intelligence und dafür gibts keine Anbindung zu ioBroker.
                                            1123
