    • MassiveAttack
      MassiveAttack @Negalein last edited by
      @negalein
      Ich hoffe dein Regen_Jahr ist nicht nur von Jänner 2025 😵
      • Negalein
        Negalein Global Moderator @MassiveAttack last edited by
        @massiveattack sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        @negalein
        nö, von 2025 müsste ........_kumuliert sein. Sonst hätt ich schon Kiemen. 😂
        • MassiveAttack
          seit dem update von simple api auf v3.0 schreibt das log viele info messages:
          simple-api.0
          	2025-03-10 09:56:56.750	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:56:56.325	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:56:24.372	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:56:23.934	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Monat" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:56:23.889	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:55:52.974	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:55:52.541	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:55:20.192	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:55:19.762	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Jahr" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:55:19.713	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:54:48.999	info	State value to set for "javascript.0.Wetterstation.Sonnenstrahlung" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:54:48.924	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:54:48.485	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:54:16.274	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:54:15.842	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:54:15.798	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Tag" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:53:45.328	info	State value to set for "javascript.0.Wetterstation.Sonnenstrahlung" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:53:45.249	info	State value to set for "javascript.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:53:44.810	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Monat" has to be type "number" but received type "string"
          simple-api.0
          	2025-03-10 09:53:44.761	info	State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
          müsste hier etwas angepasst werden?
          E SBorg 2 Replies Last reply Reply Quote 0
            A Former User last edited by
            @massiveattack
            Das hab ich auch, denke die Prüfung des objects war vorher nicht da..
            muss wohl im Script angepasst werden, wenn es kein Fehler vom Adapter ist..
            • N
              neunteufels last edited by neunteufels
              Hallo.
              ERLEDIGT
              Nochmal alles geprüft und einen Schreibfehler gefunden.
              Manchmal sieht man den Wald vor lauter Bäumen nicht.
              @SBorg ich hoffe du kannst mir helfen.
              Ich habe InfluxDB dieser Tag auf 2.7.x upgegraded und läuft alles soweit, bis auf die Statistik.
              Das Skript schreibt in die Statusmeldung "Fehler beim Lesen der InfluxDB: timeout" und folgender Datenpunkt wird daher nicht richtig aktualisiert:
              • Statistik.VorTag.Regenmenge
              Vermutlich sind es noch mehr Datenpunkte, aber ich verwende nur diesen einen weiter.
              Was kann ich da machen?
              DANKE vorab.
              Ich ergänze noch die .conf:
               #InfluxDB-Konfiguration / ohne InfluxDB alles leer lassen
                #Protokoll (HTTP oder HTTPS) / default: HTTP
                 INFLUX_WEB=HTTP
                #IP und Port der API [xxx.xxx.xxx.xxx:xxxxx]
                 INFLUX_API=10.10.10.51:8086
                #Bucket, Token und Organisation der InfluxDB
                 INFLUX_BUCKET=iobroker
                 INFLUX_TOKEN=DZeHqoyg-DZtgoY61g9wsLXZy5g8YZeurreZhtzz9j5ApckxK-sa_KYX38FzAu4EchBD3fLN9ez4qEQOxd4Ohw==
                 INFLUX_ORG=myorg
              Daten kommen in der InfluxDB richtig an. Das habe ich kontrolliert.
                eve11 @MassiveAttack last edited by
                @massiveattack
                Bei mir das selbe Problem. Konntest du hier eine Lösung finden.
                Heiko
                • Negalein
                  Hallo
                  Gibt es bei der WH4000 SE ein Gateway, dass per LAN angeschlossen wird?
                  Boronsbruder 1 Reply Last reply Reply Quote 0
                  • Boronsbruder
                    Boronsbruder @Negalein last edited by
                    @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                    WH4000 SE
                    Ich glaube, dass die Station eine Wifi Verbindung hat (hab in der ANleitung nix über LAN gefunden)
                    Das GW2000 und das GW3000 hat LAN aber kein Display.Dafürhat man ja auch dann ne VIS 😉
                    • Negalein
                      Negalein Global Moderator @Boronsbruder last edited by
                      @boronsbruder sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                      perfekt.
                      der funktioniert mit der Aussenseinheit der WH4000SE?
                      • Boronsbruder
                        Boronsbruder @Negalein last edited by Boronsbruder
                        @negalein
                        Ich habe eine WS69 am Gateway in Betrieb, die als Ersatz für eine verstorbene WH4000SE Ausseneinheit dient.
                        Ich betreibe an dem Gateway sowohl Ecowitt- als auch Froggit-Sensoren ohne Probleme.
                        Achja und der Gateway 2000 hängt bei mir draussen unter dem Vordach und hat schon 1 Jahr ohne Probleme überlebt.
                        Er wird bei mir über einen POE-Splitter mit Spannung versorgt.
                        • SBorg
                          SBorg Forum Testing Most Active @Boronsbruder last edited by
                          @SBorg
                          Wann implementierst du eigentlich die Unterstützung fürs🤣 MQTT-Protokoll, die das GW2000 seit der Firmwareversion 3.1.9 kann?
                          Wie üblich "keine Unterstützung seitens der Hersteller", also fehlende Hardware und natürlich keine Zeit meinerseits.
                          Die Frage sei aber gestellt: wofür? Was soll da besser sein? Ich müsste dann einen eigenen MQTT-Broker implementieren. An einen zB. Mosquitto kannst du ja auch so direkt publishen. Also eher nie 😊
                          • SBorg
                            SBorg Forum Testing Most Active @Negalein last edited by
                            @SBorg
                            0_userdata.0.Wetterstation.Regen_Event = der aktuelle Regen; kann der vom Script wieder auf 0 gesetzt werden, wenn Regen vorbei?
                            Nein, der kommt so von der Station. Wenn ich den im Skript auf "0" setze wird er direkt wieder von der Station überschrieben. Würde nur ein Hilfs-DP helfen, der mittels Blockly, NodeRED etc. den "Regen-Event" spiegelt und diesen bei Regenende dann auf "0" setzt.
                            0_userdata.0.Wetterstation.Regen_Jahr vs. 0_userdata.0.Wetterstation.Regen_Jahr_kumuliert?
                            Kann da quasi zB 0_userdata.0.Wetterstation.Regen_Jahr auch von Juni bis Juni sein? Also wann die Station das erste mal in Betrieb genommen wurde?
                            Das hört sich erst mal wieder einfacher an als es dann ist. Ich muss ja auch diejenigen berücksichtigen die dies nicht wollen.
                            Hier wäre es IMO einfacher dies per InfluxDB-Abfrage zu lösen.
                            Und 0_userdata.0.Wetterstation.Regen_Jahr_kumuliert ist der errechnete durch dein Script von Jänner bis Dezember?
                            0_userdata.0.Wetterstation.Regen_Monat ist klar. Aber warum ist hier ein Unterschied von ca. 2 mm zu 0_userdata.0.Wetterstation.Regen_Jahr_kumuliert?
                            Ja. Zu 100% wird das nie identisch sein. Zum einen sind das minimale Rundungsfehler, die sich dann aber bei der Menge an Werten halt aufsummieren. Die meisten Stationen liefern den Wert mittlerweile. Das war eigentlich nur zu der Anfangszeit des Skriptes, um wenigstens einen Wert zu haben. Besser einen nicht ganz genauen, als letzendlich gar keinen zu haben. Außerdem darf man keinen Wert der Station (die immer läuft) direkt mit einem des Skriptes (das beim booten bspw. nicht läuft) vergleichen. Skript läuft nicht = der von der Station gesendete Wert wird nicht berücksichtigt
                            • SBorg
                              SBorg Forum Testing Most Active @MassiveAttack last edited by
                              ...und alle Anderen.
                              Bisher wurden die Werte nicht geprüft, mit dem Update wird die Info ausgegeben. Leider kann ich nicht nachvollziehen warum er eine Zahl als Text interpretiert. Witzigerweise geht es bei einigen Werten, bei anderen nicht (sind aber identisch angelegt/übertragen). Ich dachte er hätte Probleme bei Integer (also Ganzzahlen wie bspw bei 1[°C]), deswegen habe ich sie mal als Fließkommazahl (1.0[°C] übertragen. Ist ihm aber auch egal. Ich vermute eher, dass er mit der mittlerweile recht hohen Anzahl an Werten die gleichzeitig gesendet werden nicht zu Recht kommt und sich verschluckt.
                              Da es keinen Nachteil darstellt und ich das nicht von meiner Seite ändern kann, einfach bei den bemängelten DPs den Typ auf "gemischt" umstellen. Skripte, Blockly, InfluxDB funktioniert dann trotzdem weiter.
                              • SBorg
                                SBorg Forum Testing Most Active @neunteufels last edited by
                                @neunteufels sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                DANKE vorab.
                                Da das Javaskript die internen Routinen des Adapters nutzt und die Daten in der InfluxDB landen, gibt es nur zwei Dinge die (im JS-Skript) falsch sein können:
                                • die benutzte Instanz
                                • der Name des Buckets (lt. Auszug aus deiner conf "iobroker")
                                Alles andere (Token, Username etc.) wird hierbei nicht benötigt.
                                  DGR last edited by
                                  der User Neuschwansteini hatte mir den Tipp gegeben für die WLAN-Wetterstation.
                                  Ich habe seit ein paar Tagen die "ECOWITT Wetterstation funk mit Außensensor, Drahtlose Wetterstation Array WS69, mit 3 in 1 WiFi/Wired Hub Gateway GW2000, Genaue Wettervorhersagedaten für Haus und Garten 868 MHz" und möchte die Daten zunächst mal in iobroker übernehmen (vielleicht dann auch in influxdb2 und Grafana).
                                  Nach Anleitung hat alles super geklappt mit der Installation. Aus meiner Sicht (Anfänger) fehlen noch Hinweise zur Anpassung der wetterstation.conf (oder ich habe die übersehen). Auch die Objekte im iobroker wurden nach Anleitung schnell angelegt.
                                  Wahrscheinlich muss ich die wetterstation.conf noch weiter anpassen, denn ich bekomme einen Kommunikationsfehler (Code). Kann mir jemand weiterhelfen ?
                                   WLAN-Wetterstation V3.4.0 - (c)2019-2024 by SBorg
                                   Config-Version: V3.4.0
                                   Sub-Version   : V3.4.0
                                   'bc' installiert: [✓]
                                   'jq' installiert: [✓]
                                   'dc' installiert: [✓]
                                  [sudo] Passwort für wetter:
                                   'nc' in der Openbsd-Variante installiert:  [✓]
                                   'netcat' in Openbsd-Variante aktiv, alles korrekt [✓]
                                  Connection to 192.168.196.163 8087 port [tcp/*] succeeded!
                                  Messwerteblock:
                                  Nicht alle Werte werden unterstützt (abhängig vom Modell der Wetterstation und dem verwendeten Protokoll)!
                                   Temperatur Innen               :  °C
                                   Temperatur Aussen              :  °C
                                   Taupunkt                       :  °C
                                   Gefühlte Temperatur            :  °C
                                   Luftfeuchte Innen              :  %
                                   Luftfeuchte Aussen             :  %
                                   Windgeschwindigkeit            :  km/h
                                   Windgeschwindigkeit 10min      :  km/h
                                   Windböengeschwindigkeit        :  km/h
                                   Windböe max.                   :  km/h
                                   Windrichtung                   :  °
                                   Windrichtung                   :
                                   Windrichtung 10min             :  °
                                   Luftdruck absolut              :  hPa
                                   Luftdruck relativ              :  hPa
                                   Regenrate                      :  mm/h
                                   Regenstatus                    :
                                   Regen seit Regenbeginn         :  mm
                                   Regen Stunde                   :  mm
                                   Regen Tag                      :  mm
                                   Regen Woche                    :  mm
                                   Regen Monat                    :  mm
                                   Regen Jahr                     :  mm
                                   Regen Gesamt                   :  mm
                                   Sonnenstrahlung                :  W/m²
                                   UV-Index                       :
                                   Zeitstempel                    :
                                   Firmware                       :
                                   Batteriestand:                 :
                                   Gateway-Modell                 :
                                  Zusatzsensoren:
                                  Datenstring für ioBroker:
                                  DATA von Wetterstation:
                                  Debug VAR:
                                   Installationsverzeichnis: /home/wetter/wetterstation
                                   IPP: 192.168.196.163:8087      WS_PORT: 1080           WS_POLL: 60             PRE_DP: 0_userdata.0.Wetterstation
                                   WEB: HTTP              WS_PROT: Ecowitt
                                  Zusatzsensoren:
                                   DP10/35/40/50/60/70/100/200/250/300: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0
                                   WH31: 0 || WS90: 0
                                   Bresser: 7009999 [0]
                                  Script-Version: V3.4.0  Config-Version: V3.4.0  Sub-Version: V3.4.0
                                  Kommunikationsfehler!
                                  wetter@raspi2:~/wetterstation $
                                  • Boronsbruder
                                    Boronsbruder @DGR last edited by
                                    @dgr
                                    Weil DATA von Wetterstation leer ist, kontrolliere mal die Einstellungen in der Wetterstation.
                                    Ich habe bei mir im GW2000:
                                      DGR @Boronsbruder last edited by
                                      @boronsbruder
                                      Als Server IP habe ich die Adresse meines Raspberry (iobroker) und als Port 8081 (iobroker)
                                      Die Server IP habe ich so belassen, Path und Port so wie bei dir eingestellt (was ist das für ein Port 61999 ?)
                                      Es kommt aber weiterhin der Kommunikationsfehler (in der Code-Anzeige ganz unten).
                                      Messwerteblock:
                                       Taupunkt                       :  °C
                                       Windböe max.                   :  km/h
                                       Windrichtung                   :  °
                                       Windrichtung                   :
                                       Regenrate                      :  mm/h
                                       Regenstatus                    :
                                       Regen Stunde                   :  mm
                                       Regen Tag                      :  mm
                                       Regen Woche                    :  mm
                                       Regen Monat                    :  mm
                                       Regen Jahr                     :  mm
                                       Regen Gesamt                   :  mm
                                       UV-Index                       :
                                       Zeitstempel                    :
                                       Firmware                       :
                                       Batteriestand:                 :
                                       Gateway-Modell                 :
                                      Zusatzsensoren:
                                      Debug VAR:
                                      Zusatzsensoren:
                                       WH31: 0 || WS90: 0
                                        A Former User @DGR last edited by
                                        @dgr
                                        Server IP ist nur die IP ohne Port. Die Station soll ja an den Raspberry senden, aber zu Port 61999 (frei waehlbar, muss halt frei sein)
                                        Beim Script musste ich bei dem Pfad NICHTS eintragen, also leer lassen, da hat es bei meiner Wetterstation funktioniert mit dem Ecowitt Protokoll.
                                          DGR @Guest last edited by DGR
                                          @neuschwansteini
                                          was steht denn bei dir in der wetterstation.conf bei #Port der Wetterstation ?
                                          Bei mir:
                                          WS_PORT=1080
                                          und was bei #Name/ID der Wetterstation ?
                                          Bei mir:
                                          WS_ID=WE-AL-01 (der von mir vergebene Name der Wetterstation)
                                            @dgr
                                            Ws_Port muss bei dir 61999 sein
                                            81.1k
                                            152
                                            5661
                                            3760816
