    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    • JB_Sullivan
      JB_Sullivan last edited by
      Weiß irgend jemand, ob man mit den div. json Datenpunkten, welche die Adapterversion liefert, irgend etwas sinnvolles in einer VIS anfangen kann?
      Wenn ja, welches VIS Widget wäre das? Mit "basic-tabelle" funktioniert es schonmal nicht. Vielen Dank für den Denkanstoß
        tippy88 last edited by
        Servus zusammen,
        Mit welchen Einstellungen bekommt man den Cupra Born verbunden?
        Ich habe Typ Seat Cupra und die Alternative probiert, ohne Erfolg.
        Gruß,
        Tobi
        2025-03-15 20:03:46.834 - info: vw-connect.0 (368631) Login in with seatcupra
        2025-03-15 20:03:47.098 - debug: vw-connect.0 (368631) parseEmailForm
        2025-03-15 20:03:47.224 - debug: vw-connect.0 (368631) emailPasswordForm2
        2025-03-15 20:03:47.461 - debug: vw-connect.0 (368631) ""
        2025-03-15 20:03:47.462 - debug: vw-connect.0 (368631) {"date":"Sat, 15 Mar 2025 19:03:47 GMT","content-length":"0","connection":"keep-alive","apigw-requestid":"He1LEg7PliAEJyQ=","x-content-type-options":"nosniff","x-xss-protection":"0","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000; includeSubDomains; preload","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=3c756d46-f1ba-4d78-9f9a-cff0d5292d51@apps_vw-dilab_com&relayState=7d36211df11215fc80ff9dde4995b72eb04dd8aa&userId=640bb7cdee98cbf7ed283","content-language":"en-US"}
        2025-03-15 20:03:47.727 - debug: vw-connect.0 (368631) Error: Invalid protocol: cupra:
        2025-03-15 20:03:47.800 - info: vw-connect.0 (368631) Login successful
        2025-03-15 20:03:47.970 - error: vw-connect.0 (368631) {"timestamp":"2025-03-15T19:03:47.958942578Z","path":"/v1/users/a5ae66df-76d8-43e9-bc7a-1298db4f586d/garage/vehicles","status":404,"error":"Not Found","message":"No static resource v1/users/ae9-bc7a-1298db4f586d/garage/vehicles.","requestId":"53b38186"}
        2025-03-15 20:03:47.971 - error: vw-connect.0 (368631) 404
        2025-03-15 20:03:47.971 - error: vw-connect.0 (368631) Get Vehicles Failed
          tombox @BigTom91 last edited by
          @bigtom91 für wecharge bitte die GitHub version testen ob alle notwendige Daten da sind..
          Format hat sich geändert bitte checken ob was fehlt
          Wszene B M 3 Replies Last reply Reply Quote 0
          • Wszene
            Wszene @tombox last edited by
            @tombox
            Ich habe da mal noch eine Frage
            Bekommst du zufällig diesen Wert in den ioBroker
            Das ist die Restlaufzeit der Standklima
            in der "alten" Version gab es diesen Datenpunkt
            Danke im Voraus
            Marcel
              BigTom91 @tombox last edited by
              @tombox
              Vorher hatte ich ja unter vw-connect.0.wecharge.homecharging.records die einzelnen Ladungen sehen können
              • vw-connect.0.wecharge.homecharging.records.01
              • vw-connect.0.wecharge.homecharging.records.02
              Und unter vw-connect.0.wecharge.homecharging.records.latestItem hatte ich immer die letzte/aktuellste Ladung.
              Nun scheint es so, dass die Ladungen nun unter vw-connect.0.wecharge.history.home zu finden sind.
              • vw-connect.0.wecharge.history.home.items01
              • vw-connect.0.wecharge.history.home.items02
              Wobei item01 die Lademenge des aktuellen Monats ist und die einzelnen Ladungen erst ab items02 beginnt.
              Ich vermute, dass das nun so von VW/Elli kommt, oder?
              Macht natürlich aktuelle Automatisierungen kaputt, vor allem der fehlende latestItem Eintrag.
                tombox @Wszene last edited by
                @wszene ist das skoda? müsste unter mqtt live Daten sein
                Wszene 1 Reply Last reply Reply Quote 0
                • Wszene
                  @tombox sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                  Danke für die schnelle Antwort
                  Ja das ist Skoda du hast auch die Zugangsdaten von mir bekommen
                  Bei mir sind nur folgende DPs unter mqtt zu sehen
                    eb0klud @Wszene last edited by
                    @tombox
                    Login funktioniert wieder einwandfrei. Werte kommen auch. Den Rest werde ich testen. Herzlichen Dank für Deinen Einsatz.
                    Gruß Gerhard
                    • AtrejuAZ
                      AtrejuAZ last edited by
                      @tombox Danke für die tolle Arbeit! Ich sehe meine Box, auch die Ladehistorie und die Verfügbarkeit. Aber ich finde den Datenpunkt nicht, mittels dem ich die Box zum Laden freigeben kann? Vielleicht liegt's an mir, dann freue ich mich über Erhellung 🙂
                      Danke und liebe Grüße,
                      Holger
                        Wolf1997 @tombox last edited by
                        @tombox Auch von mir: Danke für die tolle Arbeit! Ich sehe meine Box, auch die Ladehistorie und die Verfügbarkeit. Die Datenpunkt haben jetzt eine andere Struktur, aber damit kann ich umgehen!🙂
                        Thomas
                          SheepDog @Wolf1997 last edited by SheepDog
                          Hallo @tombox,
                          ich nutze den Adapter schon über ein Jahr und bin sehr zufrieden.
                          Ich würde gerne das "Update-Intervall in Minutes" in den Adaptereinstellungen per JavaScript ändern, d.h. von 15 Minute zeitweise auf 5 Minuten setzen, wenn eine wichtige Aktivität durchgeführt wird. Habe ich da eine Chance dies per JavaScript o.ä. umzusetzen?
                          Viele Grüße
                          Uwe
                            stefu87_CH last edited by stefu87_CH
                            Hallo
                            Ich habe einen Skoda Octavia Combi und seit der Umstellung der Abfrage, sind einige Infos nicht mehr vorhanden, bzw. Datenpunkte sind verschwunden.
                            Weiss jemand, unter welchem Datenpunkt ich den Oel Stand abfragen kann??
                            Vor der Umstellung war der unter:
                            vw-connect.0.TMBJR7NX7XXXXXX.status.data_0x0204040006.field_0x0204040006.value
                            • O
                              oxident @stefu87_CH last edited by
                              @stefu87_ch Ich kann zwar nicht genau helfen, aber bei meinem Seat habe ich diese Werte in einem ganz anderen Ordner wiedergefunden.
                              Such mal nach "service" oder ähnlich.
                                mikelchris @tombox last edited by
                                @tombox Vielen Dank für deine Hilfe die Ladehistorie wieder abrufen zu können. Allerdings hat sich die Struktur komplett verändert. Was kein Problem ist... allerdings fehlen bei den Ladevorgängen einige Werte vw-connect.0.wecharge.history.home.items02: z.B. authentication_method, auhorization_code, rfid_card_serial_number, start_date, end_date
                                  tombox @mikelchris last edited by
                                  @mikelchris sind denn diese werte in der app sichtbar wenn ja wo
                                  • AtrejuAZ
                                    Hallo an alle, ich muss nochmal nachfragen, weil es tatsächlich für mich die wichtigste Funktion ist, und sie mir gerade sehr fehlt 🙂
                                    Ich finde den Datenpunkt nicht, mittels dem ich die Wallbox freischalten kann.
                                    Kann mir jemand helfen?
                                    Viele Grüße,
                                    Holger
                                      stefu87_CH @oxident last edited by
                                      @oxident Habe schon alle Datenpunkte durchgeschaut, aber nichts gefunden, was für den Oil Stand sein könnte.
                                        mikelchris @tombox last edited by Homoran
                                        @tombox
                                        Screenshot_20250319_180359_Volkswagen.jpg Screenshot_20250319_180410_Volkswagen.jpg Screenshot_20250319_180436_Volkswagen.jpg Screenshot_20250319__Volkswagen.jpg
                                        Ich habe mal einige Screenshots der VW app angehängt in denen die Ladevorgange sichtbar sind. Ich hoffe das hilft.
                                          tombox @AtrejuAZ last edited by
                                          @atrejuaz ich habe den Datenpunkt startcharging unter stations hinzugefügt bitte testen ob das geht
                                            @mikelchris di Einformation sollte unter history.home drin sein
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            400
                                            3116
                                            1620673
